What is the update frequency for RSSI acquisition
Hi
I am using hci_pwr_ctrl and want to get the RSS (read_conn_rssi(default_conn_handle, &rssi) in a very high frequency. However, I notice when I use 100Hz frequency, a series of RSSI are the same. I suspect that the RSSI is not updated correctly and needs to be updated at a certain frequency. Is this correct?
void modulate_tx_power(void *p1, void *p2, void *p3)
	int8_t txp_get = 0;
	uint8_t idx = 0;
	while (1) {
		if (!default_conn) {
			printk("Set Tx power level to %d\n", txpower[idx]);
			set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_ADV,
				     0, txpower[1]);  //一直0
			k_sleep(K_SECONDS(5));
			printk("Get Tx power level -> ");
			get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_ADV,
				     0, &txp_get);
			printk("TXP = %d\n", txp_get);
			idx = (idx+1) % DEVICE_BEACON_TXPOWER_NUM;
		} else {
			int8_t rssi = 0xFF;
			int8_t txp_adaptive;
			idx = 0;
			read_conn_rssi(default_conn_handle, &rssi);
			printk("Connected (%d) - RSSI = %d\n",
			       default_conn_handle, rssi);
			if (rssi > -70) {
				txp_adaptive = 0;//一直0
			} else if (rssi > -90) {
				txp_adaptive = -12;
			} else {
				txp_adaptive = -4;
			printk("Adaptive Tx power selected = %d\n",
			       txp_adaptive);
			set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN,
				     default_conn_handle, txp_adaptive);
			get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN,
				     default_conn_handle, &txp_get);
			printk("Connection (%d) TXP = %d\n",
			       default_conn_handle, txp_get);
k_sleep(K_MSEC(10));
