Hi
I am using hci_pwr_ctrl and want to get the RSS (read_conn_rssi(default_conn_handle, &rssi) in a very high frequency. However, I notice when I use 100Hz frequency, a series of RSSI are the same. I suspect that the RSSI is not updated correctly and needs to be updated at a certain frequency. Is this correct?
void modulate_tx_power(void *p1, void *p2, void *p3) { int8_t txp_get = 0; uint8_t idx = 0; while (1) { if (!default_conn) { printk("Set Tx power level to %d\n", txpower[idx]); set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_ADV, 0, txpower[1]); //一直0 k_sleep(K_SECONDS(5)); printk("Get Tx power level -> "); get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_ADV, 0, &txp_get); printk("TXP = %d\n", txp_get); idx = (idx+1) % DEVICE_BEACON_TXPOWER_NUM; } else { int8_t rssi = 0xFF; int8_t txp_adaptive; idx = 0; read_conn_rssi(default_conn_handle, &rssi); printk("Connected (%d) - RSSI = %d\n", default_conn_handle, rssi); if (rssi > -70) { txp_adaptive = 0;//一直0 } else if (rssi > -90) { txp_adaptive = -12; } else { txp_adaptive = -4; } printk("Adaptive Tx power selected = %d\n", txp_adaptive); set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, default_conn_handle, txp_adaptive); get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, default_conn_handle, &txp_get); printk("Connection (%d) TXP = %d\n", default_conn_handle, txp_get); k_sleep(K_MSEC(10)); } } }
