I have a problem with connecting to my device after i disconnect from it.
I have tried ubond function, it does not work.
This is my disconnect function:
@brief callback function when BT connection is disconnected
LOG_INF("Disconnected: %s, reason 0x%02x %s", addr, reason, bt_hci_err_to_str(reason));
if (auth_conn) {
bt_conn_unref(auth_conn);
auth_conn = NULL;
if (current_conn) {
bt_conn_unref(current_conn);
current_conn = NULL;
advertising_stop();
advertising_start();
I have a service with 2 characteristics and one configuration
I use nrf connect application on my mobile phone, and i connect to it, but after disconnecting i cannot again connect to the device.
Also adding advertising data:
// Declaring the advertising data
struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA(BT_DATA_NAME_COMPLETE, ble_dev_name, 16),
// Declaring the scanning data
struct bt_data sd[] = {
BT_DATA(BT_DATA_UUID128_ALL, uuid_128, sizeof(uuid_128)),
BT_DATA(BT_DATA_MANUFACTURER_DATA, manufacturer_data, sizeof(manufacturer_data))
// Declaring advertising parameters
static struct bt_le_adv_param adv_param =
.options = BT_LE_ADV_OPT_CONNECTABLE | BT_LE_ADV_OPT_USE_IDENTITY, /* Connectable advertising and use identity address */
.interval_max = BT_GAP_ADV_FAST_INT_MAX_1, /* 0x30 units, 48 units, 30ms */
.interval_min = BT_GAP_ADV_FAST_INT_MIN_1, /* 0x60 units, 96 units, 60ms */
.peer = NULL /* Set to NULL for undirected advertising */
I am using 2.9 version of nrf connect for vscode.
