iOS support for BLE 5.0 extended advertisement.
I wanted to check if iOS 18 supports extended advertisements on coded PHY. I am not concerned with the advertisement payload limit but the increase in range that is possible due to the coded PHY channel configuration. But on the NRF connect app on iOS I see the coded PHY as PHY 3M, and when I keep both the primary and secondary channel config to be coded PHY, this advertisement is not discovered on the iOS whereas on android it is visible.
