https_client connection results in error 22 on nRF7002dk
I took a HTTPS Client Sample application from nRF SDK v2.6.2 and I cannot make it work.
What I figured out already is that SSL certificate for 'example.com' has changed from Digi Cert Global G2 to DigiCert Global G3. However It still doesn't connect properly.
The only changes that I have done is swapping the SSL certifitacte and adding WIFI credfentials. This is my prj.conf:
# Copyright (c) 2023 Nordic Semiconductor ASA
# General
CONFIG_HEAP_MEM_POOL_SIZE=1024
CONFIG_MAIN_STACK_SIZE=4096
# Logging
CONFIG_LOG=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=y
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=1024
CONFIG_WIFI_CREDENTIALS_STATIC=y
CONFIG_WIFI_CREDENTIALS_STATIC_SSID="abc"
CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="xyz"
CONFIG_DNS_RESOLVER=y
The result is as follows:
*** Booting nRF Connect SDK v3.5.99-ncs1-2 ***
HTTPS client sample started
Bringing network interface up
Provisioning certificate
CA certificate already exists, sec tag: 42
Connecting to the network
[00:00:02.095,062] <inf> wifi_mgmt_ext: Connection requested
Network connectivity established and IP address assigned
Looking up example.com
Resolved 23.215.0.136 (AF_INET)
Connecting to example.com:443
connect() failed, err: 22
Network connectivity lost
Disconnected from the network
I also tried it on the latest nRF SDK 2.9.0 and it doesn't connect either.
Please provide a config that works with this sample on nRF7000dk.
I am looking forward for your support!
