https_client connection results in error 22 on nRF7002dk
I took a HTTPS Client Sample application from nRF SDK v2.6.2 and I cannot make it work.
What I figured out already is that SSL certificate for 'example.com' has changed from Digi Cert Global G2 to DigiCert Global G3. However It still doesn't connect properly.
The only changes that I have done is swapping the SSL certifitacte and adding WIFI credfentials. This is my prj.conf:
# Copyright (c) 2023 Nordic Semiconductor ASA
# General
CONFIG_HEAP_MEM_POOL_SIZE=1024
CONFIG_MAIN_STACK_SIZE=4096
# Logging
CONFIG_LOG=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=y
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=1024
CONFIG_WIFI_CREDENTIALS_STATIC=y
CONFIG_WIFI_CREDENTIALS_STATIC_SSID="abc"
CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="xyz"
CONFIG_DNS_RESOLVER=y
The result is as follows:
*** Booting nRF Connect SDK v3.5.99-ncs1-2 ***
HTTPS client sample started
Bringing network interface up
Provisioning certificate
CA certificate already exists, sec tag: 42
Connecting to the network
[00:00:02.095,062] <inf> wifi_mgmt_ext: Connection requested
Network connectivity established and IP address assigned
Looking up example.com
Resolved 23.215.0.136 (AF_INET)
Connecting to example.com:443
connect() failed, err: 22
Network connectivity lost
Disconnected from the network
I also tried it on the latest nRF SDK 2.9.0 and it doesn't connect either.
Please provide a config that works with this sample on nRF7000dk.
I am looking forward for your support!
  • So the issue lies with example.com in a way. example.com uses ECDSA signature while rest.nordicsemi.academy uses RSA-PSS. A coworker of mine as seen the same issue when trying to connect to mqtt.nordicsemi.academy with the nRF7002 DK which also uses ECDSA signature, I'm looking into whether that is a current limitation or not.
    Is the domain you are trying to connect to using ECDSA as well?
    If one would want ECDSA supported, it might be that it can be achieved by configuring mbedTLS. One could look at the Kconfigs here. And in the 5340 board files for the sample here
    Elfving
  • Hi
    I tried to run l5_e2_sol project with ECDSA crypto enabled. Still no success. Resulting logs below:
    *** Booting nRF Connect SDK v3.5.99-ncs1-3 ***
    [00:00:01.592,468] <inf> Lesson5_Exercise2: Waiting to connect to Wi-Fi
    [00:00:09.509,063] <inf> wifi_mgmt_ext: Connection requested
    [00:00:14.650,207] <inf> net_dhcpv4: Received: 172.16.0.204
    [00:00:14.650,390] <inf> Lesson5_Exercise2: Network connected
    [00:00:14.672,882] <inf> Lesson5_Exercise2: IPv4 address of HTTP server found 23.215.0.136
    [00:00:14.807,586] <err> Lesson5_Exercise2: Connecting to server failed, err: 22, Invalid argument
    [00:00:14.807,586] <err> Lesson5_Exercise2: Failed to initialize client
    [00:00:16.090,850] <err> net_ipv6: Could not add router neighbor fe80::f2b6:61ff:fe4a:dff2 [unknown]
    [00:00:16.265,289] <err> net_icmpv6: ICMPv6 handling failure (-5)
    [00:00:16.687,530] <err> net_icmpv6: ICMPv6 handling failure (-5)
    [00:00:17.702,331] <err> net_icmpv6: ICMPv6 handling failure (-5)
    [00:00:28.976,501] <err> net_ipv6: Could not add router neighbor fe80::f2b6:61ff:fe4a:dff2 [unknown]
    [00:00:28.981,903] <err> net_icmpv6: ICMPv6 handling failure (-5)
    [00:01:38.214,599] <err> net_ipv6: Could not add router neighbor fe80::f2b6:61ff:fe4a:dff2 [unknown]
    You can take a look at my project here. I built it with SDK v2.6.2: l5_e2_sol_with_ECDSA.zip
    prj.conf:
    # Wi-Fi
    CONFIG_WIFI=y
    CONFIG_WIFI_NRF700X=y
    CONFIG_WPA_SUPP=y
    CONFIG_WPA_SUPP_CRYPTO_PSA=y
    # Wi-Fi Credentials
    CONFIG_WIFI_CREDENTIALS=y
    # Networking Management API
    CONFIG_NET_MGMT=y
    CONFIG_NET_MGMT_EVENT=y
    CONFIG_NET_MGMT_EVENT_INFO=y
    CONFIG_NET_MGMT_EVENT_STACK_SIZE=4096
    CONFIG_WIFI_MGMT_EXT=y
    # Support for shell commands
    CONFIG_SHELL=y
    CONFIG_NET_L2_WIFI_SHELL=y
    CONFIG_WIFI_CREDENTIALS_SHELL=y
    CONFIG_SHELL_STACK_SIZE=5200
    # Logging
    CONFIG_LOG=y
    CONFIG_NET_LOG=y
    CONFIG_NET_SOCKETS_LOG_LEVEL_INF=y
    # DK library
    CONFIG_DK_LIBRARY=y
    # System settings
    CONFIG_NEWLIB_LIBC=y
    CONFIG_NEWLIB_LIBC_NANO=n
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=y
    CONFIG_POSIX_MAX_FDS=16
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_NET_IPV4=y
    CONFIG_NET_IPV6=y
    CONFIG_NET_TCP=y
    CONFIG_NET_DHCPV4=y
    # TLS
    # STEP 1.1 - Enable the TLS library and security relevant configurations
    CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
    CONFIG_TLS_CREDENTIALS=y
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_DHM_C=y
    CONFIG_MBEDTLS_ECDSA_C=y
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_WANT_ALG_ECDSA=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
    CONFIG_PSA_WANT_ECC_SECP_R1_256=y
    CONFIG_PSA_WANT_ALG_SHA_256=y
    CONFIG_PSA_WANT_ALG_SHA_384=y
    CONFIG_PSA_WANT_ALG_ECDSA_ANY=y
    CONFIG_PSA_WANT_GENERATE_RANDOM=y
    # STEP 1.2 - Enable support for server name indication (SNI)
    CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
    # Memory
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=153600
    CONFIG_NET_TCP_WORKQ_STACK_SIZE=2048
    CONFIG_NET_TX_STACK_SIZE=4096
    CONFIG_NET_RX_STACK_SIZE=4096
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=16
    CONFIG_NET_BUF_DATA_SIZE=256
    CONFIG_NET_TC_TX_COUNT=0
    # HTTP
    CONFIG_HTTP_CLIENT=y
    CONFIG_WIFI_CREDENTIALS_STATIC_SSID="Ci Global"
    CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="1qazxsw2"
    CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_PSK=y
    My Second attempt was with https example project with enabled ECDSA crypto. Also no success. Logs:
    [00:00:04.683,135] <inf> wifi_mgmt_ext: Connection requested
    [00:00:08.713,745] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x20051628, st=0, user_data=(nil)
    [00:00:08.729,522] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x2005166c, st=0, user_data=(nil)
    [00:00:08.765,533] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x20051628, st=0, user_data=(nil)
    [00:00:08.778,106] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x2005166c, st=0, user_data=(nil)
    [00:00:08.778,320] <inf> net_dhcpv4: Received: 172.16.0.204
    [00:00:08.798,614] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x20051628, st=0, user_data=(nil)
    [00:00:08.798,797] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:08.798,828] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:08.798,858] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:08.798,889] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): getaddrinfo entries overflow
    [00:00:08.798,919] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:08.798,950] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): getaddrinfo entries overflow
    [00:00:08.798,980] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:08.798,980] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): getaddrinfo entries overflow
    [00:00:08.799,011] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:08.799,041] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): getaddrinfo entries overflow
    [00:00:08.799,072] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -103
    Resolved 96.7.128.198
    [00:00:08.800,170] <dbg> net_sock_tls: tls_alloc: (main): Allocated TLS context, 0x2000dce0
    [00:00:08.800,750] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x2000ea70, fd=10
    [00:00:08.806,396] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:08.807,403] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515a0, st=0, user_data=(nil)
    [00:00:08.828,063] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:08.985,473] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515a0, st=0, user_data=(nil)
    [00:00:08.998,199] <dbg> net_sock: z_impl_zsock_close: (main): close: ctx=0x2000dce0, fd=9
    [00:00:08.998,382] <dbg> net_sock: z_impl_zsock_close: (main): close: ctx=0x2000ea70, fd=10
    [00:00:09.012,878] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.015,777] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515a0, st=0, user_data=(nil)
    [00:00:09.216,491] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.217,468] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x2005166c, st=0, user_data=(nil)
    [00:00:09.421,661] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.423,736] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x2005166c, st=0, user_data=(nil)
    [00:00:09.628,906] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.630,126] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x2005166c, st=0, user_data=(nil)
    [00:00:09.631,408] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.632,629] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x2005166c, st=0, user_data=(nil)
    [00:00:09.636,199] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.637,420] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x2005166c, st=0, user_data=(nil)
    [00:00:09.638,641] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.831,451] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x2005166c, st=0, user_data=(nil)
    [00:00:09.834,716] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.836,730] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515a0, st=0, user_data=(nil)
    [00:00:09.847,259] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515e4, st=0, user_data=(nil)
    [00:00:09.848,480] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000e900, pkt=0x200515a0, st=0, user_data=(nil)
    [00:00:10.041,198] <dbg> net_sock: z_impl_zsock_close: (): close: ctx=0x2000e900, fd=4
    [00:00:10.051,330] <dbg> net_sock: z_impl_zsock_close: (net_mgmt): close: ctx=0x20045180, fd=6
    [00:00:10.052,001] <dbg> net_sock: z_impl_zsock_close: (net_mgmt): close: ctx=0x20047270, fd=8
    [00:00:10.052,642] <dbg> net_sock: z_impl_zsock_close: (net_mgmt): close: ctx=0x200461f8, fd=7
    [00:00:10.054,473] <dbg> net_sock: z_impl_zsock_close: (): close: ctx=0x20044108, fd=5
    You can take a look at this entire project here (also built with SDK v2.6.2):  https_client_2_6_2_with_ECDSA.zip
    If it comes to address ci-global-uat-emhuapeeakcrbpb2.z01.azurefd.net/
    It's secured using SHA-384 RSA Encryption.
  • Hi  any update?
    I have the issue like yours where i got: connect() failed, err: 22 if i build https_client sample with
    overlay-tfm-nrf91.conf
    If i build without that option, the connection is ok for me.
  • Hi  , not for now
    But I've tried building https_client sample without overlay-tfm-nrf91.conf and it didn't work for me. Did you by any chance changed anything else
  • Hi  i change my
    DigiCertGlobalG2.pem
    cert to this:
    -----BEGIN CERTIFICATE-----
    MIICPzCCAcWgAwIBAgIQBVVWvPJepDU1w6QP1atFcjAKBggqhkjOPQQDAzBhMQsw
    CQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3d3cu
    ZGlnaWNlcnQuY29tMSAwHgYDVQQDExdEaWdpQ2VydCBHbG9iYWwgUm9vdCBHMzAe
    Fw0xMzA4MDExMjAwMDBaFw0zODAxMTUxMjAwMDBaMGExCzAJBgNVBAYTAlVTMRUw
    EwYDVQQKEwxEaWdpQ2VydCBJbmMxGTAXBgNVBAsTEHd3dy5kaWdpY2VydC5jb20x
    IDAeBgNVBAMTF0RpZ2lDZXJ0IEdsb2JhbCBSb290IEczMHYwEAYHKoZIzj0CAQYF
    K4EEACIDYgAE3afZu4q4C/sLfyHS8L6+c/MzXRq8NOrexpu80JX28MzQC7phW1FG
    fp4tn+6OYwwX7Adw9c+ELkCDnOg/QW07rdOkFFk2eJ0DQ+4QE2xy3q6Ip6FrtUPO
    Z9wj/wMco+I+o0IwQDAPBgNVHRMBAf8EBTADAQH/MA4GA1UdDwEB/wQEAwIBhjAd
    BgNVHQ4EFgQUs9tIpPmhxdiuNkHMEWNpYim8S8YwCgYIKoZIzj0EAwMDaAAwZQIx
    AK288mw/EkrRLTnDCgmXc/SINoyIJ7vmiI1Qhadj+Z4y3maTD/HMsQmP3Wyr+mt/
    oAIwOWZbwmSNuJ5Q3KjVSaLtx9zRSX8XAbjIho9OjIgrqJqpisXRAL34VOKa5Vt8
    sycX
    -----END CERTIFICATE-----
    and run the build cmd. You should try to rm -rf build folder first for a clean build.
