Unexpected Reset Cause: RESET_PIN Instead of RESET_WATCHDOG
Description:
I am encountering an issue while testing the watchdog functionality. When I intentionally hang the system for longer than the configured watchdog timeout period, the system restarts. However, the reset cause is reported as RESET_PIN rather than RESET_WATCHDOG as expected.
Watchdog Initialization Code:
int hal_watchdog_init(void)
    bool found = false;
    if (watchdog_device != NULL) {
        LOG_INF("watchdog HAL already initialized");
        return 0;
    LOG_INF("initialize watchdog HAL");
    watchdog_device = DEVICE_DT_GET(WATCHDOG0_NODE);
    if (watchdog_device) {
        if (device_is_ready(watchdog_device)) {
            LOG_INF("found watchdog device \"%s\"", watchdog_device->name);
            found = true;
            struct wdt_timeout_cfg wdt_config = {
                /* reset SoC when watchdog timer expires. */
                .flags = WDT_FLAG_RESET_SOC,
                /* expire watchdog after max window */
                .window.min = WDT_MIN_WINDOW,
                .window.max = WDT_MAX_WINDOW,
            wdt_channel_id = wdt_install_timeout(watchdog_device, &wdt_config);
            if (wdt_channel_id < 0) {
                LOG_ERR("failed to install watchdog");
                return -1;
        } else {
            LOG_ERR("watchdog device \"%s\" is not ready", watchdog_device->name);
    if (found == false) {
        LOG_ERR("no watchdog device found");
    return (found ? 0 : (-1));
Reset Cause Checking Code:
/* dump reset cause */
hwinfo_get_reset_cause(&reset_cause);
if (reset_cause == RESET_LOW_POWER_WAKE) {
    LOG_INF("reset cause: wakeup");
} else if (reset_cause == RESET_POR) {
    LOG_INF("reset cause: power");
} else if (reset_cause == RESET_WATCHDOG) {
    LOG_INF("reset cause: watchdog");
    #ifdef WATCHDOG_TEST
        isWatchdogTestRun = false; // Disable the Watchdog Test after detecting a Watchdog-induced reset
} else if (reset_cause == RESET_PIN) {
    LOG_INF("reset cause: reset pin");
} else if (reset_cause == RESET_SOFTWARE) {
    LOG_INF("reset cause: software");
    LOG_INF("reset cause: software reset");
} else {
    LOG_INF("reset cause 0x%x", reset_cause);
Expected Behavior:
When the watchdog timeout is exceeded, the system should restart with the reset cause RESET_WATCHDOG.
Observed Behavior:
Instead, the system restart is being reported as due to RESET_PIN.
Ben Ron Udi
