UART communication with external device on nRF9160dk
I've been trying to set up UART communication with external device using uart3 instance and have so far failed.
The scenario requires sending 5 bytes to the device, receiving 1 byte confirmation, then another 5 byte request and receiving indeterminate amount of data (though about 75 bytes).
So I set up my overlay to enable uart3:
&pinctrl {
	uart3_default: uart3_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 13)>, <NRF_PSEL(UART_RX, 0, 10)>;
&uart3 {
	status = "okay";
	current-speed = <2400>;
    parity = "even";
    stop-bits = "1";
    data-bits = <8>;
	pinctrl-0 = <&uart3_default>;
	pinctrl-names = "default";
then, in prj.conf:
#UART
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_UART_LINE_CTRL=n
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
When I run the code (using asynchronous API), after 1st req-ack I get proper UART operation as per observed events:
events generated on tmo = 100
total_rcved_len = 1
uart_rx_rdy_evt = 1
uart_rx_buf_req_evt = 2
uart_tx_done_evt = 1
uart_tx_aborted_evt = 0
uart_rx_stopped_evt = 0
--uart_rx_stopped_overrun = 0
--uart_rx_stopped_parity = 0
--uart_rx_stopped_framing = 0
--uart_rx_stopped_break_condition = 0
--uart_rx_stopped_collision = 0
--uart_rx_stopped_noise = 0
--uart_rx_stopped_other = 0
uart_rx_disabled_evt = 0
Then moving to next cycle of req-data i get following events (counted as increment of previous values):
total_rcved_len = 38
uart_rx_rdy_evt = 13
uart_rx_buf_req_evt = 15
uart_tx_done_evt = 2
uart_rx_stopped_evt = 59
--uart_rx_stopped_other = 59
uart_rx_disabled_evt = 9
Given that UART settings are correct (8e1@2400, no line control), and I was able to verify with oscilloscope that data is sent correctly from outside device, I think that something is missing either in my conf or overlay though I fail to see what could that be. Additionally, when setting CONFIG_UART_USE_RUNTIME_CONFIGURE=n and removing uart_configure() call from code no transmission occurs as far as I can tell, which as I understand should not be the case as overlay provides necessary configuration making uart_configure() redundant.
UART0 is used as logger backend. Tuning timeouts doesn't help, buffers are sized 256 so no overflow is possible.
Any help is appreciated.
  • I do not see anything wrong with your prj.conf and code. Maybe try enabling the hardware flow control as mentioned in this thread.
    My colleague in this thread, suggested to enable hw_async mode which seemed to have helped. I do not see anything else apart from these two to help us at this point. If this have not helped, then maybe I need to get more context and code from your end to understand the issue.
  • Hi Susheel,
    Thanks for getting back to me.
    Your suggested solution from this thread has solved my issue. Many thanks!
    For future reference, adding:
    CONFIG_UART_0_NRF_HW_ASYNC=y
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=1
    to prj.conf is the exact solution to my problem. With this addition, observability printout is:
    total_rcved_len = 73
    uart_rx_rdy_evt = 73
    uart_rx_disabled_evt = 1
    In the spirit of full disclosure, I've swapped logger backend to uart3 and used uart0 for communication, like this:
        chosen {
            zephyr,console = &uart3;
            zephyr,shell-uart = &uart3;
    &uart0 {
        parity = "even";
        stop-bits = "1";
        data-bits = <8>;
    &uart0_sleep {
        group1 {
                    <NRF_PSEL(UART_RX, 0, 10)>,
                    <NRF_PSEL(UART_RTS, 0, 20)>,
                    <NRF_PSEL(UART_CTS, 0, 21)>;
    &uart0_default {
        group1 {
    &uart3 {
    	status = "okay";
    	current-speed = <115200>;
        parity = "even";
        stop-bits = "1";
        data-bits = <8>;
    &pinctrl {
            group2 {
                psels = <NRF_PSEL(UART_TX, 0, 18)>, <NRF_PSEL(UART_RX, 0, 19)>;
    I don't know if that had anything to do with solving the issue, but there you have it.
    Cheers,
    V
