dfu is successfully updating but after power cycle its going to previous version even i am calling boot_write_img_confirmed();
hi
i am working with custom board  nrf52833 every thing is working good until i introduced  bonding in my code.
i am using sdk 1.9.1 form my development
i released 1.01 with out bonding to customer but they asked form bonding so i implemented bonding with security level 2 and calling setting_load () function and this sofware versiion is 1.02.
if i try to do DFU with this 1.02 in nrfconnect app  dfu is flashing and telling application update  successfully but if i reset the power its revert back to 1.01 which has no bonding.
but if i update to 1.02 to 1.03 with updated version dfu is working and dfu updating.
my configration: in prj.confi
CONFIG_BT_SMP=y
CONFIG_BT_BONDABLE=y
CONFIG_BT_MAX_PAIRED=3
CONFIG_BT_SETTINGS=y
CONFIG_SETTINGS=y
CONFIG_FLASH=y               # Enable Flash support
CONFIG_NVS=y
please find the attached code and let me know if you can solve.
Linking C executable zephyr\zephyr.elf
Memory region       Used Size          Region Size %     age Used
FLASH:                   214680 B            232960 B 92.           15%
SRAM:                     74311 B              128 KB                  56.69%
IDT_LIST:                    0 GB                  2 KB                    0.00%
#ifdef CONFIG_BOOTLOADER_MCUBOOT
#include "os_mgmt/os_mgmt.h"
#include "img_mgmt/img_mgmt.h"
* Section: Included Files
#define QLENGTH  120
#define MAXDATAFRMSIZE 45
K_TIMER_DEFINE(msec_timer,msectimerCB,NULL);
K_TIMER_DEFINE(onesec,onesecCB,NULL);
tm_u8_t debugstr[DEBUGSTRLEN];
tm_u8_t sver[8] = "1.12";
rx_mcu_buff tm_rx_buff;
bt_addr_le_t mac_address[1];
tm_u8_t macadd[50];
size_t MACcount = 1;
tm_u8_t macid[18];
tm_u8_t rxbuf[2000];
uint8_t mac_id[26] = {0};
uint8_t time_cnt=0;
uint16_t rxbuflen;
char send_data[10] = {"{SHOW IMEI}"};
char rx_Buff_len[10]={"BUFF_LEN: "};
const struct device *uartDev;
struct bt_conn *conn;
static struct bt_conn *default_conn;
tm_instance_t AppInstance;
//struct uart_data uartData;
/* extern Variables */
extern tm_btctrl_t *pBtCtrl;
extern volatile int tm_flag;
extern volatile int FOTA_Flag;
struct sensor_data_type_t
  uint8_t frame_data[45];
  uint8_t frame_len;
static tm_u16_t g_queue_rx, g_queue_tx,RxDatandex,g_time_out;
struct sensor_data_type_t    g_sensor_data[QLENGTH];
enum tm_datarxstate
  LOOKFOR_BEGIN=0
  ,GET_DATA
  ,LOOKFOR_VEHICALID
typedef enum tm_datarxstate tm_datarxstate_t;
tm_datarxstate_t RxDataState;
Function:
    void main(void)
  Summary:
    calling all the events.
  Description:
    This function initilize all the peripirals and ble advertise the ble device.
static void connected(struct bt_conn *conn, uint8_t err)
  int secure_level=0;
  int secure_status=0;
	if (err) {
		printk("Failed to connect to %s (%u)\n\r", addr, err);
    //DPRINTF(debugstr);
		return;
    printk("{Connected: %s}\n\r", addr);
    default_conn = bt_conn_ref(conn);
    secure_status=bt_conn_set_security(conn, BT_SECURITY_L2);
   if(secure_status)
      printk("Failed to set security\n\r");
       printk("Security Enabled\n\r");
    secure_level=bt_conn_get_security(conn);
    if(secure_level != 0)
      printk("security_level:%d\n\r",secure_level);
    }                                                   //bharath
     printk("security :ZERO(0)\n\r");
   request_conn_param_update(conn);
  printk("{Disconnected: %s}\n\r", addr);
  if (default_conn) {
        bt_conn_unref(default_conn);
        default_conn = NULL;}
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected = connected,
	.disconnected = disconnected,
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n\r", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n\r", addr);
static void passkey_cb(struct bt_conn *conn, unsigned int num)
    printk("Passkey callback: %u\n\r", num);
    if (num == 0) {
        bt_conn_auth_passkey_entry(conn, FIXED_PASSKEY);  // Enter the fixed passkey
static void pairing_complete(struct bt_conn *conn, bool bonded)
  int err;
	printk("Pairing Complete\n\r");
  err=settings_save();
  if(err)
    printk("failed to save settings\n\r");
    printk("settings saved\n\r");
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing Failed (%d). Disconnecting.\n\r", reason);
	bt_conn_disconnect(conn, BT_HCI_ERR_AUTH_FAIL);
static void pairing_confirm(struct bt_conn *conn)
  bt_conn_auth_pairing_confirm(conn);
	printk("Pairing Confirm\n\r");
static void passkey_confirm (struct bt_conn *conn, unsigned int passkey)
  bt_conn_auth_passkey_confirm(conn);
static void pair_delete(uint8_t id, const bt_addr_le_t *peer)
  clear_bonds();
static struct bt_conn_auth_cb auth_cb_display = {
	.passkey_display = auth_passkey_display,
	//.passkey_entry = passkey_cb,
  .passkey_confirm = passkey_confirm,
  .pairing_confirm=pairing_confirm,
	.cancel = auth_cancel,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed,
  .bond_deleted = pair_delete,
void main(void)
  bool adv_status;
  bool boot_status;
  int index=0;
  int err;
  int settig_init_err;
  int setting_load_err;
  int settings_saved;
  int bood_image_conform;
  pBtCtrl = &AppInstance.BtCtrl;
  memset(&AppInstance, 0, sizeof(AppInstance));
  AppInstance.BtCtrl.bConfigUpdate = false;
  /* upgrade FOTA */
  os_mgmt_register_group();
  img_mgmt_register_group();
  #ifdef CONFIG_MCUMGR_SMP_BT
  smp_bt_register();
  bood_image_conform=boot_write_img_confirmed();
  if(bood_image_conform)
    printk("new image failed to boot error%d\n\r",bood_image_conform);
    printk("-----new image confirm------\n\r");
  boot_status=boot_is_img_confirmed();
  if(!boot_status)
    printk("boot image failed\n\r");
  /*else
    printk("boot image confirm\n\r");
  k_timer_start(&onesec,K_SECONDS(1),K_SECONDS(1));
  k_timer_start(&msec_timer,K_MSEC(20),K_MSEC(20));
  uartDev = device_get_binding("UART_0");  /* uart changed to 1 to test bootloader sequence */
  AppInstance.UartQTx.pUartData = &AppInstance.UartData;
  InitUart(&AppInstance.UartQTx,uartDev,uart_cb);
  //clear_bonds();
 settig_init_err = settings_subsys_init();
 if (settig_init_err)
      printk("Failed to initialize settings subsystem (err %d)\n", settig_init_err);
  RxDataState=LOOKFOR_BEGIN;
  err=bt_enable(NULL);
  if(err)
    printk("{Bluetooth init failed (err %d)}\n\r", err);
    return;
    printk("{Bluetooth initialized}\n\r");
  setting_load_err=settings_load();
  if(setting_load_err)
    printk("settinges loded failed:%d\n\r",setting_load_err);
  {                                                            //bharath
    printk("settinges loded\n\r");
  bt_set_bondable(true);
  bt_conn_auth_cb_register(&auth_cb_display);
  settings_saved=settings_save();
  if(settings_saved)
    printk("failed to save settings(error%d)\n\r",settings_saved);
    printk("settings saved\n\r");   //bharath
  bt_id_get(&mac_address,&MACcount);
  if(MACcount>0)
    bt_addr_le_to_str(mac_address, macid, sizeof(macid));
    for (int i = 3; i >= 0; i--)
        index += sprintf(&mac_id[index],"%02x", mac_address[0].a.val[i]);
     strcat(macadd,"{MAC:");
     strcat(macadd,macid);
     strcat(macadd,"}");
     printk(macadd);
  strcpy(AppInstance.BtCtrl.btName, "TM_");
  strcat(AppInstance.BtCtrl.btName,mac_id);
  strcat(AppInstance.BtCtrl.btName,"_v");
  strcat(AppInstance.BtCtrl.btName,sver);
  AppInstance.BtCtrl.btNameLen = strlen(AppInstance.BtCtrl.btName);
  adv_status = bt_start_adv(&AppInstance.BtCtrl);
  if (adv_status)
     printk("BLE STARTED ADVERTISING\n\r");
     printk("BLE STOPPED ADVERTISING\n\r");
  printk("NAME:%s",AppInstance.BtCtrl.btName);
   while (1)
     for(uint8_t i =NUMBEROFEVENTS-1; i>=0; i--)
      if(AppInstance.Events[i]==TM_TRUE)
        HandleEvents(i);
        AppInstance.Events[i] = TM_FALSE;
        k_sleep(K_MSEC(100));
