Simultaneous DFU on nrf5340 and NCS 2.9.0 without external flash
I am using NCS 2.9.0, an nRF5340, custom board files (see attached), and no external flash and I would like to use simultaneous DFU over BLE. I believe this should be possible because my application core image is only ~118kB and my netcore image is ~175kB (it has a custom synch protocol on top of the hci icp logic). I've done my best to read through the intermediate dev zone academy lessons regarding the mcu bootloader and it mentions that simultaneous updates should be possible without external flash:
but then links to this devacedmay blog post that only shows how to do this utilizing external flash. I believe it should be possible because in my mind I see the following:
Where mcu primary is the app core code that is currently running, mcu secondary is where the new app core code goes, and mcu secondary_1 is where the new netcore code goes when an application update happens. So I have tried to add the following pm_static.yml file:
EMPTY_0:
  address: 0xfc000
  end_address: 0x100000
  placement:
    after:
    - mcuboot_secondary
  region: flash_primary
app:
  address: 0x14000
  end_address: 0x84000
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    align:
      end: 0x1000
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xc000
  end_address: 0xc200
  placement:
    align:
      start: 0x4000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - app
  - tfm
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0xc200
  orig_span: &id002
  - app
  - tfm
  span: *id002
mcuboot_secondary:
  address: 0x84000
  end_address: 0xfc000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x4000
    align_next: 0x4000
  share_size:
  - mcuboot_primary
mcuboot_sram:
  address: 0x20000000
  end_address: 0x20008000
  orig_span: &id003
  - tfm_sram
  region: sram_primary
  span: *id003
otp:
  address: 0xff8100
  end_address: 0xff83fc
  region: otp
rpmsg_nrf53_sram:
  address: 0x20070840
  end_address: 0x20080000
  placement:
    before:
    - end
sram_nonsecure:
  address: 0x20008000
  orig_span: &id004
  - sram_primary
  - rpmsg_nrf53_sram
  span: *id004
sram_primary:
  address: 0x20008000
  end_address: 0x20070840
sram_secure:
  address: 0x20000000
  orig_span: &id005
  - tfm_sram
  span: *id005
tfm:
  address: 0xc200
  end_address: 0x14000
  inside:
  placement:
    before:
    - app
tfm_nonsecure:
  address: 0x14000
  orig_span: &id006
  - app
  span: *id006
tfm_secure:
  address: 0xc000
  orig_span: &id007
  - mcuboot_pad
  - tfm
  span: *id007
tfm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
The names are bit different than my diagram but I followed the advice of other similar posts and documentation regarding DFU and copied a build partitions.yml file from one of my successful builds. I have also added the following configs to my sysbuild.conf:
SB_CONFIG_REMOTE_BOARD="candi/nrf5340/cpunet"
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_NETCORE_APP_UPDATE=y
SB_CONFIG_SECURE_BOOT_NETCORE=y
SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES=2
SB_CONFIG_MCUBOOT_NRF53_MULTI_IMAGE_UPDATE=y
SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY=y
Added these two lines to my prj.conf:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
Do I need to set configs for utilizing flash even tho there is no external flash? When I build with the above configs I get the following errors:
I'm not sure how to proceed because I'm having a hard time understanding what these pm_static.yaml file names are supposed to be and I'm not getting the same sort of errors as these previous related posts:
- simultaneous DFU on nRF5340 and NCS 2.6.1 without external flash
- nrf5340 custom board non-simultaneous updates without external flash with sysbuild on ncs2.7.0+
I know from the "Official Simultaneous multi-image DFU with nRF5340 DK" docs that I need to have the following partitions:
1) mcuboot_primary
2) mcuboot_secondary
3) mcuboot_rimary_1
4) mcuboot_secondary_1
5) pcd_sram
and I see the note regarding the placement of mcuboot_primary_1 inside of ram_flash region but I don't understand the second comment about "CONFIG_FLASH_SIMULATOR" within the docs. I'm having a hard time understanding how to get this running because I'm not even hitting the errors I would expect to hit. Instead I'm getting stuff related to the partition_manager.py scripts' arguments...
Do I need to setup a pm_static.yaml file for my custom netcore image too? I don't think so from the docs but I can't find the exact reference that makes me think this but I'm asking just in case.
I utilize the following shared memory overlay within my code base and I don't think I'm correctly partitioning for it within my pm_static.yaml file:
Can you help with this too? It is the only reason I think that adding a partition file for the network core might be needed in addition but I'm really not sure.
Thank you so much for all of your help and time.
Respectfully,
Brady Adcock
  • Hey Menon,
    I'm really looking forward to this example! Thank you so much for helping me.
    Respectfully,
    Brady
    I will continue to help with this ticket.
    I do not know if you have updated to the nRF Connect SDK v3.0.0 yet. But even so, try this on the git tag v3.0.0-rc1 in order to test the following:
    Try the sample l9_e5_nrf5340_both_sol from DevAcademy on DFU in v3.0.0-rc1. I based this academy sample on the Peripheral_lbs sample.
    In v3.0.0-rc1 you should be able to just change SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY to "n" in this sample, and simultaneous DFU should work for internal flash
    Let me know how this goes
    Sigurd Hellesvik
  • Hello Sigurd,
    Thank you for your time. I have tried building the sample you linked using the tag v3.0.0-rc1 and I am having no luck. Can you please share the build command you used? Here is what my build looks like:
    Maybe I need a different toolchain too not just SDK? Here is my build log:
     *  Executing task: nRF Connect: Generate config bl5340_dvk/nrf5340/cpuapp/ns for c:\Impulse\l9_e5_nrf5340_both_sol
    Building l9_e5_nrf5340_both_sol
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/Impulse/l9_e5_nrf5340_both_sol/build c:/Impulse/l9_e5_nrf5340_both_sol --pristine --board bl5340_dvk/nrf5340/cpuapp/ns --sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONFIG_SIZE_OPTIMIZATIONS=y -DCONF_FILE=c:/Impulse/l9_e5_nrf5340_both_sol/prj.conf -DDTC_OVERLAY_FILE=app.overlay"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.0.0-rc1/zephyr/.cache
    -- Board: bl5340_dvk, qualifiers: nrf5340/cpuapp/ns
    Parsing c:/Impulse/l9_e5_nrf5340_both_sol/Kconfig.sysbuild
    Loaded configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/build/_sysbuild/empty.conf'
    Merged configuration 'c:/Impulse/l9_e5_nrf5340_both_sol/sysbuild.conf'
    Configuration saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/zephyr/.config'
    Kconfig header saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: C:/ncs/v3.0.0-rc1/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.0-rc1/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.0.0-rc1/zephyr/boards/ezurio/bl5340_dvk/bl5340_dvk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: C:/Impulse/l9_e5_nrf5340_both_sol/sysbuild/mcuboot.overlay
    -- Found devicetree overlay: C:/ncs/v3.0.0-rc1/nrf/modules/mcuboot/flash_sim.overlay
    -- Generated zephyr.dts: C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/dts.cmake
    warning: I2C (defined at C:/ncs/v3.0.0-rc1/zephyr/boards/ezurio/bl5340_dvk/Kconfig.defconfig:9,
    drivers/i2c/Kconfig:9) was assigned the value 'n' but got the value 'y'. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_I2C and/or look up I2C in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    Parsing C:/ncs/v3.0.0-rc1/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v3.0.0-rc1/zephyr/boards/ezurio/bl5340_dvk/bl5340_dvk_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/ncs/v3.0.0-rc1/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/ncs/v3.0.0-rc1/bootloader/mcuboot/boot/zephyr/boards/bl5340_dvk_nrf5340_cpuapp.conf'
    Merged configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/sysbuild/mcuboot.conf'
    Merged configuration 'C:/ncs/v3.0.0-rc1/nrf/modules/mcuboot/tfm.conf'
    Merged configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    CMake Warning at C:/ncs/v3.0.0-rc1/zephyr/CMakeLists.txt:1002 (message):
      No SOURCES given to Zephyr library: ..__nrf__drivers__mpsl__flash_sync
      Excluding target from build.
    MCUBoot bootloader key file: C:/ncs/v3.0.0-rc1/bootloader/mcuboot/root-rsa-2048.pem
    CMake Warning at CMakeLists.txt:393 (message):
      WARNING: Using default MCUboot signing key file, this file is for debug use
      only and is not secure!
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot
       * Running CMake for ipc_radio *
    -- Application: C:/ncs/v3.0.0-rc1/nrf/applications/ipc_radio
    -- Board: bl5340_dvk, qualifiers: nrf5340/cpunet
    -- Found BOARD.dts: C:/ncs/v3.0.0-rc1/zephyr/boards/ezurio/bl5340_dvk/bl5340_dvk_nrf5340_cpunet.dts
    -- Generated zephyr.dts: C:/Impulse/l9_e5_nrf5340_both_sol/build/ipc_radio/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Impulse/l9_e5_nrf5340_both_sol/build/ipc_radio/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Impulse/l9_e5_nrf5340_both_sol/build/ipc_radio/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Impulse/l9_e5_nrf5340_both_sol/build/ipc_radio/zephyr/dts.cmake
    Parsing C:/ncs/v3.0.0-rc1/nrf/applications/ipc_radio/Kconfig
    Loaded configuration 'C:/ncs/v3.0.0-rc1/zephyr/boards/ezurio/bl5340_dvk/bl5340_dvk_nrf5340_cpunet_defconfig'
    Merged configuration 'C:/ncs/v3.0.0-rc1/nrf/applications/ipc_radio/prj.conf'
    Merged configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/sysbuild/ipc_radio.conf'
    Merged configuration 'C:/ncs/v3.0.0-rc1/nrf/applications/ipc_radio/overlay-bt_hci_ipc.conf'
    Merged configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/build/ipc_radio/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/ipc_radio/zephyr/.config'
    Kconfig header saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/ipc_radio/zephyr/include/generated/zephyr/autoconf.h'
    -- libmetal version: 1.7.0 (C:/ncs/v3.0.0-rc1/nrf/applications/ipc_radio)
    -- Build type:
    -- Host:    Windows/AMD64
    -- Target:  Generic/arm
    -- Machine: arm
    -- Vendor: none
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.7.0 (C:/ncs/v3.0.0-rc1/modules/lib/open-amp/open-amp)
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    CMake Warning at C:/ncs/v3.0.0-rc1/zephyr/CMakeLists.txt:2185 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Impulse/l9_e5_nrf5340_both_sol/build/ipc_radio
       * Running CMake for b0n *
    -- Application: C:/ncs/v3.0.0-rc1/nrf/samples/nrf5340/netboot
    -- Generated zephyr.dts: C:/Impulse/l9_e5_nrf5340_both_sol/build/b0n/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Impulse/l9_e5_nrf5340_both_sol/build/b0n/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Impulse/l9_e5_nrf5340_both_sol/build/b0n/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Impulse/l9_e5_nrf5340_both_sol/build/b0n/zephyr/dts.cmake
    Parsing C:/ncs/v3.0.0-rc1/nrf/samples/nrf5340/netboot/Kconfig
    Merged configuration 'C:/ncs/v3.0.0-rc1/nrf/samples/nrf5340/netboot/prj.conf'
    Merged configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/build/b0n/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/b0n/zephyr/.config'
    Kconfig header saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/b0n/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Impulse/l9_e5_nrf5340_both_sol/build/b0n
       * Running CMake for l9_e5_nrf5340_both_sol *
    -- Application: C:/Impulse/l9_e5_nrf5340_both_sol
    -- Found BOARD.dts: C:/ncs/v3.0.0-rc1/zephyr/boards/ezurio/bl5340_dvk/bl5340_dvk_nrf5340_cpuapp_ns.dts
    -- Found devicetree overlay: app.overlay
    -- Generated zephyr.dts: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/dts.cmake
    Parsing C:/Impulse/l9_e5_nrf5340_both_sol/Kconfig
    Loaded configuration 'C:/ncs/v3.0.0-rc1/zephyr/boards/ezurio/bl5340_dvk/bl5340_dvk_nrf5340_cpuapp_ns_defconfig'
    Merged configuration 'c:/Impulse/l9_e5_nrf5340_both_sol/prj.conf'
    Merged configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/misc/generated/extra_kconfig_options.conf'
    Merged configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/.config'
    Kconfig header saved to 'C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/include/generated/zephyr/autoconf.h'
    CMake Warning at C:/ncs/v3.0.0-rc1/nrf/cmake/version_app.cmake:19 (message):
      APP_VERSION: git rev-parse failed: fatal: not a git repository (or any of
      the parent directories): .git
      C:/ncs/v3.0.0-rc1/nrf/CMakeLists.txt:26 (include)
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: False
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- libmetal version: 1.7.0 (C:/Impulse/l9_e5_nrf5340_both_sol)
    -- Build type:
    -- Machine: arm
    -- Vendor: none
    -- Machine: arm
    -- Including signing script: C:/ncs/v3.0.0-rc1/nrf/cmake/sysbuild/image_signing.cmake
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol
    CMake Warning at C:/ncs/v3.0.0-rc1/nrf/cmake/sysbuild/debug_keys.cmake:27 (message):
          --- WARNING: Using generated NSIB public/private key-pair. ---
          --- It should not be used for production.                  ---
          --- See SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE             ---
      C:/ncs/v3.0.0-rc1/nrf/cmake/sysbuild/provision_hex.cmake:11 (include)
      C:/ncs/v3.0.0-rc1/nrf/sysbuild/CMakeLists.txt:55 (include)
      C:/ncs/v3.0.0-rc1/nrf/sysbuild/CMakeLists.txt:728 (include_provision_hex)
      cmake/modules/sysbuild_extensions.cmake:583 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/ncs/v3.0.0-rc1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v3.0.0-rc1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      C:/ncs/v3.0.0-rc1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    CMake Warning at C:/ncs/v3.0.0-rc1/nrf/cmake/sysbuild/partition_manager.cmake:121 (message):
            --- WARNING: Using a bootloader without pm_static.yml.            ---
            --- There are cases where a deployed product can consist of       ---
            --- multiple images, and only a subset of these images can be     ---
            --- upgraded through a firmware update mechanism. In such cases,  ---
            --- the upgradable images must have partitions that are static    ---
            --- and are matching the partition map used by the bootloader     ---
            --- programmed onto the device.                                   ---
      C:/ncs/v3.0.0-rc1/nrf/cmake/sysbuild/partition_manager.cmake:620 (partition_manager)
      C:/ncs/v3.0.0-rc1/nrf/sysbuild/CMakeLists.txt:768 (include)
    -- Configuring done
    -- Generating done
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    Loaded configuration 'C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/.config'
    No change to configuration in 'C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/.config'
    No change to Kconfig header in 'C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/include/generated/zephyr/autoconf.h'
    -- Build type:
    -- Machine: arm
    -- Vendor: none
    -- Machine: arm
    -- Configuring done
    -- Generating done
    [1/376] Generating include/generated/zephyr/app_version.h
    -- git describe failed: fatal: not a git repository (or any of the parent directories): .git
    [5/376] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.0-rc1/zephyr), build: v3.7.99-ncs2-rc1-8048-ge48bca44dd59
    [6/376] Generating ../../tfm/CMakeCache.txt
    CMake Warning at cmake/version.cmake:31 (message):
      TFM_VERSION_MANUAL mismatches to actual TF-M version.  Please update
      TFM_VERSION_MANUAL in cmake/version.cmake
      CMakeLists.txt:13 (include)
    -- Found Git: C:/ncs/toolchains/b620d30767/mingw64/bin/git.exe (found version "2.37.3.windows.1")
    -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found version "3.12.4") found components: Interpreter
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm
    [141/145] Linking C executable bin\tfm_s.axf
               FLASH:       31588 B      32256 B     97.93%
                 RAM:       10916 B        32 KB     33.31%
    [13/376] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/tfm_ioctl_core_api.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/src/tfm_ioctl_core_ns_api.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/config_nordic_nrf_spe.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/driver/Driver_Common.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/driver/Driver_Flash.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/driver/Driver_USART.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/startup.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/startup_nrf5340.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/nrfx_glue.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/pal_plat_test.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/pal_plat_test.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/startup.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/target_cfg.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/nrfx_config.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/CMakeLists.txt
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/config.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/native_drivers
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/native_drivers/mpu_armv8m_drv.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/native_drivers/mpu_armv8m_drv.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/native_drivers/spu.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/native_drivers/spu.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/cmsis_drivers
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/cmsis_drivers/Driver_Flash.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/cmsis_drivers/Driver_USART.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/common
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/common/cmsis.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/common/nrf-pinctrl.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/common/nrfx_glue.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/common/nrfx_log.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/common/tfm_hal_platform_common.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/nrfx/nrfx.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/services
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/services/include
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/services/include/tfm_ioctl_core_api.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/services/include/tfm_platform_hal_ioctl.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/services/src
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/services/src/tfm_ioctl_core_ns_api.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/services/src/tfm_ioctl_core_s_api.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/services/src/tfm_platform_hal_ioctl.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/tests
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/core/tests/tfm_tests_config.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/linker_scripts/tfm_common_ns.ld
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/nrfx_config_nrf5340_application.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/CMakeLists.txt
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/config.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/cpuarch.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/tests
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/tests/psa_arch_tests_config.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/partition
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/partition/flash_layout.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/common/nrf5340/partition/region_defs.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/CMakeLists.txt
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/cpuarch.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/config.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/../common/config.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/tests
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/tests/psa_arch_tests_config.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/tests/tfm_tests_config.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/bin
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/bin/tfm_s.axf
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/bin/tfm_s.bin
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/bin/tfm_s.elf
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/bin/tfm_s.hex
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/bin/tfm_s.map
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/lib/s_veneers.o
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/client.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/error.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa_manifest/sid.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/config_impl.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/tfm_veneers.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/tfm_ns_interface.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/tfm_ns_client_ext.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/config_tfm.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/config_base.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/tfm_psa_call_pack.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/framework_feature.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/build_info.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_adjust_auto_enabled.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_adjust_config_key_pair_types.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_adjust_config_synonyms.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_compat.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_driver_common.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_driver_contexts_composites.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_driver_contexts_key_derivation.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_driver_contexts_primitives.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_extra.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_legacy.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_platform.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_se_driver.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_sizes.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_struct.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_types.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto_values.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/psa/crypto.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/mbedtls/build_info.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/mbedtls/config_psa.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/nrf-config.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/nrf-psa-crypto-config.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/tfm_platform_api.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/src/tfm_tz_psa_ns_api.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/os_wrapper
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/os_wrapper/common.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/include/os_wrapper/mutex.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/src/os_wrapper
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/src/os_wrapper/tfm_ns_interface_bare_metal.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/src/os_wrapper/tfm_ns_interface_rtos.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/src/tfm_crypto_api.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/interface/src/tfm_platform_api.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/config/cp_check.cmake
    ----- Installing platform NS -----
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/a-profile
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_armclang_a.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_clang_a.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_cp15.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_gcc_a.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_iccarm_a.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/a-profile/irq_ctrl.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/cmsis_compiler.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/cmsis_version.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_ca.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm0.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm0plus.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm1.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm23.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm3.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm33.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm35p.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm4.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm52.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm55.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm7.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_cm85.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_sc000.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_sc300.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/core_starmc1.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv7m_cachel1.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv7m_mpu.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv81m_pac.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv8m_mpu.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv8m_pmu.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_armclang_m.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_clang_m.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_gcc_m.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_iccarm_m.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_tiarmclang_m.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/cmsis/Include/tz_context.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/common/uart_stdout.c
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/ext/common/uart_stdout.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/boot_hal.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/cmsis_override.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/exception_info.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/fatal_error.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/mbedtls_entropy_nv_seed_config.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/region.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_attest_hal.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_defs.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_device_header.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_interrupt.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_isolation.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_its.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_its_encryption.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_mailbox.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_multi_core.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_platform.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_hal_ps.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_platform_system.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_boot_seed.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_config.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_crypto_keys.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_crypto_nv_seed.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_defs.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_device_id.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_ns.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_nv_counters.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_otp.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_provisioning.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_rotpk.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/tfm_plat_test.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/CMakeLists.txt
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/cmake/toolchain_ns_GNUARM.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/cmake/toolchain_ns_ARMCLANG.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/cmake/toolchain_ns_IARARM.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/platform/include/fih.h
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/cmake/spe_export.cmake
    -- Installing: C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/tfm/api_ns/cmake/set_extensions.cmake
    [96/376] Building C object CMakeFiles/app.dir/src/main.c.obj
    In file included from C:/Impulse/l9_e5_nrf5340_both_sol/src/main.c:17:
    C:/Impulse/l9_e5_nrf5340_both_sol/src/main.c: In function 'main':
    C:/ncs/v3.0.0-rc1/zephyr/include/zephyr/bluetooth/bluetooth.h:1093:24: warning: 'BT_LE_ADV_OPT_CONNECTABLE' is deprecated [-Wdeprecated-declarations]
     1093 |         ((const struct bt_le_adv_param[]) { \
    C:/ncs/v3.0.0-rc1/zephyr/include/zephyr/bluetooth/bluetooth.h:1106:9: note: in expansion of macro 'BT_LE_ADV_PARAM'
     1106 |         BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE, BT_GAP_ADV_FAST_INT_MIN_2,                      \
    C:/Impulse/l9_e5_nrf5340_both_sol/src/main.c:236:31: note: in expansion of macro 'BT_LE_ADV_CONN'
      236 |         err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
    C:/ncs/v3.0.0-rc1/zephyr/include/zephyr/bluetooth/bluetooth.h:638:9: note: declared here
      638 |         BT_LE_ADV_OPT_CONNECTABLE __deprecated = BIT(0),
    C:/Impulse/l9_e5_nrf5340_both_sol/src/main.c:236:20: warning: Macro is deprecated
    [376/376] Linking C executable zephyr\zephyr.elf
               FLASH:      149184 B       320 KB     45.53%
                 RAM:       42388 B       408 KB     10.15%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from C:/Impulse/l9_e5_nrf5340_both_sol/build/l9_e5_nrf5340_both_sol/zephyr/zephyr.elf for board: bl5340_dvk
    image.py: sign the payload
    [6/310] Generating include/generated/zephyr/version.h
    [305/310] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=C:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf5340/libsoc__nordic.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/i2c/libdrivers__i2c.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/subsys/pcd/lib..__nrf__subsys__pcd.a  modules/nrf/modules/mcuboot/hooks/lib..__nrf__modules__mcuboot__hooks.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  modules/mbedtls/libmodules__mbedtls.a  modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -LC:/Impulse/l9_e5_nrf5340_both_sol/build/mcuboot/zephyr  zephyr/arch/common/libisr_tables.a  modules/mbedtls/libmbedTLSBase.a  modules/mbedtls/libmbedTLSCrypto.a  modules/mbedtls/libmbedTLSX509.a  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  C:/ncs/v3.0.0-rc1/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.19.a -L"c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp"  -lgcc && cmd.exe /C "cd /D C:\Impulse\l9_e5_nrf5340_both_sol\build\mcuboot\zephyr && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe -E true""
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `datas' will not fit in region `FLASH'
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `bss' will not fit in region `RAM'
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 392 bytes
    c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `RAM' overflowed by 254176 bytes
    collect2.exe: error: ld returned 1 exit status
    FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build C:/Impulse/l9_e5_nrf5340_both_sol/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
    cmd.exe /C "cd /D C:\Impulse\l9_e5_nrf5340_both_sol\build\mcuboot && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe --build ."
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' --build C:/Impulse/l9_e5_nrf5340_both_sol/build
     *  The terminal process terminated with exit code: 1.
  • Just what you did, but for the nRF5340dk/nrf5340/cpuapp.
    Can you  try to build for the DK instead, just to see if there is a difference?
  • Hey Sigurd,
    Thank you so much for the help!!! The example builds for the secure version of the nrf5340dk but it doesn't actually allow for updates of the network core regardless of external flash use. I have tried every bin file I can find within my build folder and I'm having no luck. I am pretty sure the correct bin file is the "zephyr.signed.bin" file but maybe I'm mistaken. The example updates the app core as expected but not the network core :(
    Here is what my build config looks like now:
    This is a list of all the bin files created by the build:
    Here is the error I get after updating over the air:
    No matter if I use external flash or not I get the "Failed to open flash area ID 1: -1" message which I believe is the network core flash. I really appreciate your time and effort. Thank you so much Sigurd.
    Brady
    For some more context, I'm modifying the ipc_radio application within the directory: "C:\ncs\v3.0.0-rc1\nrf\applications\ipc_radio". I know this is correct because when I manually flash the changes the network core logs update as expected but when I try to use the DFU feature from my mobile application I don't see the changes I expect to my logs on the network core and instead see the error posted above. Here is an example of the logs updated on the net core after manually flashing:
    Except it doesn't work :(
