nrf5340 custom board non-simultaneous updates without external flash with sysbuild on ncs2.7.0+
Hello!
I was wondering if there is any advice from trying to get Non-simultaneous firmware updates using sysbuild with the following constraints:
  • Must update both App Core and Netcore
  • Non-Simultaneous preferably
  • Without External flash
  • Custom board
  • Custom Netcore (DTM/In-house Manufacturing)
  • Using sysbuild (because we were advised to move to 2.8.0 and sysbuild is now a must)
  • Using SMP
During our development we got this working on ncs 2.6.X, and we can do all the above without sysbuild, we wrote our own SMP transport and we can do the updates, and we've seen that there is still ongoing DFU development for sysbuild in ncs2.7.0+ and we are wondering if there are any updates on this?
Most of the samples we've seen cover the simultaneous and with external flash, but not the non-simultaneous without external flash, we could potentially do simultaneous, but the external flash is not something we can add at this point.
To clarify we want this to be able to go from our DTM/Manufacturing image to the Customer/production image (both with different App/Net Core images) using our SMP Transport.
Moreover, we can do sysbuild updates for AppCore, but for our custom DTM/Manufacturing we can't get it to enable NetCore updates, once we enable SB_CONFIG_NETCORE_APP_UPDATE we get:
with this configuration
0020.sysbuild.conf
And this Kconfig.sysbuild (had to add txt so I was able to upload it here):
menu "Network core configuration"
    depends on SUPPORT_NETCORE
config SUPPORT_NETCORE_DIRECT_TEST_MODE
    bool
    default y
choice NETCORE
    prompt "Netcore image"
    depends on SUPPORT_NETCORE && !EXTERNAL_CONFIGURED_NETCORE
config NETCORE_DIRECT_TEST_MODE
    bool "direct test mode"
    help
      Use manufacturing dtm image as the network core image.
endchoice
# if !NETCORE_NONE
config NETCORE_IMAGE_NAME
    default "direct_test_mode" if NETCORE_DIRECT_TEST_MODE
config NETCORE_IMAGE_PATH
    default "../../../" if NETCORE_DIRECT_TEST_MODE
# endif # !NETCORE_NONE
endmenu
source "${ZEPHYR_BASE}/share/sysbuild/Kconfig"
Any advise, ideas would be appreciated!
    Your configuration sounds to be right out of the book and will work, with one caveat and that is the risk of breaking the interface between the app and netcore when migrating from 2.6.0 to 2.8.0.
    As explained in the Non-simultaneous part of https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-bootloaders-and-dfu-fota/topic/dfu-for-the-nrf5340/, the interface may break if it changes between an update making non-simultaneous not recommended for FOTA, which uses the radio. Since you update the network core first, you may end up in a state where the application can't use the network core and thus not being able to receive the new application you want to send over FOTA. If you however are doing DFU not over the air, then you should not have to worry about this.
    Just fyi, for simultaneous DFU you need a quite small application to make this work without an external flash. As illustrated here https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-bootloaders-and-dfu-fota/topic/dfu-for-the-nrf5340/ you need to have a secondary partition for both the application slot and the network slot, meaning that what you have remaining for your primary application slot will be very small.
    Out of curiosity, how large is your application?
    This is true, here's a couple of guides you've probably seen but they're nice to know of in case you're not aware of them:
    Not quite sure how sysbuild relates to DFU in this case, could you expand a bit on this statement so I might understand where you're coming from w.r.t this? DFU using MCUBoot is it's own thing when comparing it to sysbuild, but if you're talkign about sysbuild in general, then yes, sysbuild were a bit immature in NCS 2.7.0, and has matured more and more in 2.8.0 and 2.9.0.
    If you're referring the DFU course on our academy pages and are referring to "DFU development" in terms of adding support for sysbuild within the DFU course it has to do with the fact that the author of the course needed more time to update the course.
    There's quite a few topics in this case, so lets start with these items and go form here.
    Andreas
  • Hi Andreas (  ),
    Thank you for the clarification on the simultaneous, non-simultaneous, to answer your question:
    Our initial manufacturing application is relatively small < 100 KB on both App and Netcore, but our user/production application is much bigger < 400KB on the Appcore ( we will be optimizing this and potentially removing a few KBs ) and 240 KB on the Netcore ( LE Audio, multi role, and multiple connections with soft-device controller in 2.6.X ), so for the transition to the user/production FW, it sounds like it won't work on Simultaneous, thus we were focusing on non-simultaneous.
    About:
    Well because we tried that configuration and got this problem ( in SDK 2.7.0 ):
    [22/275] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/zephyr_img_mgmt.c.obj
    FAILED: zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/zephyr_img_mgmt.c.obj
    C:\ncs\toolchains\ce3b5ff664\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DK_HEAP_MEM_POOL_SIZE=4096 -DNCS_APPLICATION_BOOT_BANNER_GIT_REPO -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_LONG_LONG_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.7.0/zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/include -IC:/ncs/v2.7.0/zephyr/include -IC:/Users/alejandromata/Dev/iotplatform.nordic.manufacturing/application/build_1/application/zephyr/include/generated -IC:/ncs/v2.7.0/zephyr/soc/nordic -IC:/ncs/v2.7.0/zephyr/soc/nordic/nrf53/. -IC:/ncs/v2.7.0/zephyr/soc/nordic/common/. -IC:/ncs/v2.7.0/zephyr/subsys/mgmt/mcumgr/util/include -IC:/ncs/v2.7.0/zephyr/subsys/mgmt/mcumgr/transport/include -IC:/ncs/v2.7.0/bootloader/mcuboot/boot/bootutil/include -IC:/ncs/v2.7.0/bootloader/mcuboot/boot/zephyr/include -IC:/ncs/v2.7.0/zephyr/subsys/rtio -IC:/ncs/v2.7.0/zephyr/subsys/settings/include -IC:/ncs/v2.7.0/nrf/include -IC:/ncs/v2.7.0/nrf/tests/include -IC:/ncs/v2.7.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.7.0/zephyr/modules/cmsis/. -IC:/ncs/v2.7.0/modules/hal/nordic/nrfx -IC:/ncs/v2.7.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.7.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.7.0/zephyr/modules/hal_nordic/nrfx/. -IC:/Users/alejandromata/Dev/iotplatform.nordic.manufacturing/application/build_1/application/modules/libmetal/libmetal/lib/include -IC:/ncs/v2.7.0/modules/lib/open-amp/open-amp/lib/include -IC:/ncs/v2.7.0/modules/debug/segger/SEGGER -IC:/ncs/v2.7.0/modules/debug/segger/Config -IC:/ncs/v2.7.0/modules/lib/zcbor/include -IC:/ncs/v2.7.0/bootloader/mcuboot/boot/bootutil/zephyr/.. -IC:/ncs/v2.7.0/bootloader/mcuboot/boot/bootutil/zephyr/../include -IC:/ncs/v2.7.0/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem C:/ncs/v2.7.0/zephyr/lib/libc/common/include -isystem C:/ncs/v2.7.0/nrfxlib/crypto/nrf_cc312_platform/include -Wshadow -fno-strict-aliasing -Os -imacros C:/Users/alejandromata/Dev/iotplatform.nordic.manufacturing/application/build_1/application/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/Users/alejandromata/Dev/iotplatform.nordic.manufacturing/application=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.7.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.7.0=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/zephyr_img_mgmt.c.obj -MF zephyr\subsys\mgmt\mcumgr\grp\img_mgmt\CMakeFiles\subsys__mgmt__mcumgr__grp__img_mgmt.dir\src\zephyr_img_mgmt.c.obj.d -o zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/zephyr_img_mgmt.c.obj -c C:/ncs/v2.7.0/zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/src/zephyr_img_mgmt.c
    In file included from C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain.h:50,
                     from C:/ncs/v2.7.0/zephyr/include/zephyr/kernel_includes.h:23,
                     from C:/ncs/v2.7.0/zephyr/include/zephyr/kernel.h:17,
                     from C:/ncs/v2.7.0/zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/src/zephyr_img_mgmt.c:7:
    C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "Missing partitions?"
       87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
    C:/ncs/v2.7.0/zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/src/zephyr_img_mgmt.c:43:1: note: in expansion of macro 'BUILD_ASSERT'
       43 | BUILD_ASSERT(FIXED_PARTITION_EXISTS(SLOT2_PARTITION) &&
    Main error:
    "C:/ncs/v2.7.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "Missing partitions?"
    Note that I probably should have stressed that we are using MCUMgr and MCUBoot (our own SMP Transport), and we are not considering FOTA updates, as the ble module is part of another system (not standalone), and we want the firmware to be handled from outside the module, and all works well for the User/produciton FW updates in 2.6.X to upgrade to further versions of production firmware, but the first upgrade ( manufacturing to production - manufacturing constraint) is what we are migrating first to sysbuild, and having problems with. (Perhaps we should move to 2.8.0 and skip 2.7.0 ? , please advise)
    For this problem I think I forgot to add the mcuboot.conf, here it is:
    1050.mcuboot.conf
    As for:
    Yes, we were seeing that in the courses:
    And things like this in the code:
    To summarize:
    We want to have those non-simultaneous FW updates with MCUmgr/MCUBoot in SDK 2.7.0 with sysbuild, and we are trying to transition first the manufacturing to production firmware update first update to this setup.
    Hope that makes more sense. Slight smile
    It does, thank you very much, with the exception of this sentence "and we are trying to transition first the manufacturing to production firmware update first update to this setup.", but I guess it relates to "To clarify we want this to be able to go from our DTM/Manufacturing image to the Customer/production image".  Correct me if I've misunderstood this:
    You have your firmware in 2.6 that you currently call DTM/Manufacturing (state), that you want to perform DFU to get to the customer/production (state) in 2.7.0?
    I agree, then the available flash on the app core will be too small to fit simultaneous. Thank you for elaborating
    Ah, I see.
    I would say that you should get it working in 2.7.0 before going to 2.8.0 and the migration to sysbuild guide should be the same for both versions, but there might be other changes in 2.8.0 that you need to account for in your firmware that you might miss if you skip one release. But of course, if you're confident enough, you can go directly from 2.6 to 2.9 as well by following the migration guides, release notes and changes in the relevant modules in the SDK.
    How have you done your partitioning in the previous firmware? I assume it is through a pm_static.yml? Have you done any partitioning in dts? It not, then that might be the reason as both are required for sysbuild (although it only uses one of them). The error you post seems to indicate that it is a partitioning issue.
    Andreas
  • Hi Andreas (  )
    Here are some more tidbits
    Yes, that is correct, we want this to work with "sysbuild".
    ahh not quite ( sorry for the confusion ), we have a 2.6 user/production firmware with this non-simultaneous Fw updates and we now have a manufacturing FW on 2.7.0 with sysbuild, but no FW updates. So we want the FW updates on that manufacturing FW, and later we will move the user/prod FW to 2.8.0.
    Yes, so we better get it on 2.7.0 before going to 2.8.0.
    In the user/prod Fw in 2.6.0 we did not created a static partitioning, and it was working fine, I gather that we now need to create one ( pm_static.yml ), I'll do that and come back, thanks.
    Cheers,
  • Aha, thank you for verifying.
    Aha, yes please do that. The short reason for why you would want static partitioning is so you can migrate to newer versions further up with the same partitioning map. Dynamic partitioning may change between versions, meaning that you may get issues with addresses due to for instance changes in how large a partition is between the two different versions.
    You must also make sure that you sign your new application with keys which that your old bootloader recognizes so that the new image will be approved.
    In short, migrating through an update is quite more complex than simply migrating, but it is possible as long as you have enough headspace on the previous memory map (given that you will add features), and/or have static partitioning as well as you're using the same keys.
    Andreas
