Hi
I am would like to know how to setup *.overlay file for timer and find code for a simple timer interrupt using the nrf54l15.
Best Regards
David
Hi
Best Regards
David
There are several options here, you can for instance use Zehyr kernel timers, this will then execute any code at given intervals:
https://docs.nordicsemi.com/bundle/ncs-1.9.2-dev1/page/zephyr/reference/kernel/timing/timers.html
(used by: https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-1-zephyr-rtos-advanced/)
(example: https://github.com/NordicDeveloperAcademy/ncs-inter/blob/main/v2.9.0-v2.7.0/l1/l1_e1_sol/src/main.c)
Another option, use the low level nrfx drivers:
https://github.com/NordicSemiconductor/nrfx
(an old example for timer in specific using nrfx: https://github.com/too1/ncs-nrfx-timer-example/tree/master)
Kenneth
Hi Kenneth
Using the K_timer will there not be a problem with interrupts etc, as I want very accurate timings for an ADC sampling.
Best Regards
David
It depends on what you mean by "accurate timing", how much deviation can you tolerate?
Kenneth
Hi
I have just started trying the ncs-nrfx-timer-example example I have problems, I am using a blinky example to start with and have just added the 2 lines of code below.
Maybe you can try:
https://github.com/kemegard/nrfx_timer_nrf54l15/tree/main/src/nrfx_timer/timer
Kenneth
