Issue with QSPI Flash MX25R64 on Custom Pin Configuration (nRF52840)
I am experiencing an issue while trying to connect an external flash memory (MX25R64) via the QSPI interface on an nRF52840-based custom board. My pin configuration differs from the one used in the official development kit.
Here is my pin setup:
qspi_default: qspi_default {
    group1 {
        psels = <NRF_PSEL(QSPI_SCK, 1, 12)>,
                <NRF_PSEL(QSPI_IO0, 1, 11)>,
                <NRF_PSEL(QSPI_IO1, 1, 10)>,
                <NRF_PSEL(QSPI_IO2, 0, 10)>,
                <NRF_PSEL(QSPI_IO3, 0, 9)>,
                <NRF_PSEL(QSPI_CSN, 0, 31)>;
        nordic,drive-mode = <NRF_DRIVE_H0H1>;
qspi_sleep: qspi_sleep {
    group1 {
                <NRF_PSEL(QSPI_IO3, 0, 9)>;
        low-power-enable;
    group2 {
        psels = <NRF_PSEL(QSPI_CSN, 0, 31)>;
        low-power-enable;
        bias-pull-up;
Flash configuration:
&qspi {
    status = "okay";
    pinctrl-0 = <&qspi_default>;
    pinctrl-1 = <&qspi_sleep>;
    mx25r64: mx25r6435f@0 {
        compatible = "nordic,qspi-nor";
        reg = <0>;
        writeoc = "pp4io";
        readoc = "read4io";
        sck-frequency = <2000000>;
        jedec-id = [ c2 28 17 ];
        sfdp-bfp = [ e5 20 f1 ff ff ff ff 03 44 eb 08 6b 08 3b 04 bb ee ff ff ff ff ff 00 ff ff ff 00 ff 0c 20 0f 52 10 d8 00 ff 23 72 f5 00 82 ed 04 cc 44 83 68 44 30 b0 30 b0 f7 c4 d5 5c 00 be 29 ff f0 d0 ff ff ];
        size = <67108864>;
        has-dpd;
        t-enter-dpd = <10000>;
        t-exit-dpd = <35000>;
Upon initialization, I get the following error:
<err> qspi_nor: JEDEC id [00 00 00] expect [c2 28 17]
I suspect that the issue may be related to the fact that some of the assigned pins were originally used for NFC functionality. I attempted to reconfigure them as GPIO using:
nrfx_nvmc_word_write((uint32_t) & (NRF_UICR->NFCPINS),
                     (uint32_t)UICR_NFCPINS_PROTECT_Disabled);
However, this did not resolve the issue.
Could you please provide guidance on resolving this problem?
Thank you for your assistance!
  • We came back to this problem. We managed to connect an external flash in SPI mode.
    My current hypothesis is that the issue may be related to how the QSPI peripheral maps its IO lines across Port 0 and Port 1. In our current hardware design, the flash lines are distributed across both ports.
    Could this be the cause of the problem?
    Apologies for the delayed response. I was on vacation and have just returned to work.
    Glad to hear you got it working in SPI mode!
    As long as the pin configuration is valid and matches the hardware setup, assigning the I/O lines across both ports shouldn’t be an issue. I recommend probing the QSPI lines with a logic analyzer or oscilloscope to check the signals.
    Abhijith
