I have a private version of the VL53L1X driver ecause the driver in ncs2.9.0 hasnt been properly updated per my previous case. They suggested changing the CONFIG_VL53L1X=y to something like CONFIG_VL53L1X_PRIV which I have done. All of my code is compiled fine, however so is the driver from ncs2.9.0 So i get duplicate definitions. What would be causing this driver to still be included?
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/sensor/st/vl53l1x/libdrivers__sensor__st__vl53l1x.a(vl53l1_platform.c.obj): in function `VL53L1_WriteMulti': C:/ncs/v2.9.0/zephyr/drivers/sensor/st/vl53l1x/vl53l1_platform.c:25: multiple definition of `VL53L1_WriteMulti'; app/libapp.a(vl53l1_platform.c.obj):C:/Users/-----/source/repos/hhhhhh-plus/cpuapp/src/vl53l1x/vl53l1_platform.c:25: first defined here etc...
I have defined a new config:
CONFIG_VL53L1X_ABC=y
my kconfig file now contains:
menuconfig VL53L1X_ABC bool "VL53L1X time of flight sensor" #depends on I2C <--took out because of a circular reference select HAS_STLIB help Enable driver for VL53L1X_ABC I2C-based time of flight sensor. if VL53L1X_ABC config VL53L1X_PROXIMITY_THRESHOLD int "Proximity threshold in millimeters" default 100 depends on VL53L1X_ABC help Threshold used for proximity detection when sensor is used with SENSOR_CHAN_PROX. config VL53L1X_INTERRUPT_MODE bool "Use interrupt mode for VL53L1X time of flight sensor" default n depends on GPIO help Enable interrupt mode for VL53L1X time of flight sensor. Otherwise, the driver will use the polling method. config VL53L1X_XSHUT bool "Use xshut pin on VL53L1X time of flight sensor" default n depends on GPIO help Enable to use the xshut pin on the VL53L1X. If not, the pin should be connected to VDD. module = VL53L1X_ABC module-str = VL53L1X_ABC source "${ZEPHYR_BASE}/subsys/logging/Kconfig.template.log_config" module = RANGER module-str = RANGER source "${ZEPHYR_BASE}/subsys/logging/Kconfig.template.log_config" endif # VL53L1X_ABC
Im not sure what else i have to do. im working my way through devacademy but that obviously takes some time. ive been tasked to get this code from 2.3.0 to 2.9.0 and have made great progress and i think this is the last problem since it happens during link.
Brian
