DFU upgrade of Thing91X/NRF5340 not working
I’m trying to implement DFU upgrade of NRF5340, I can send the image (./build_5340_app/build/signed_by_mcuboot_and_b0_s1_image.bin) to the device when running and it seems to be accepted. I then set test and do a reset (all as SMP requests). Then during mcuboot I can see that nsib_swap_run() is executed without any errors and the call to sys_reboot(SYS_REBOOT_COLD) resets the device again. Now, I would expect the device to start with the new firmware but it is still running the old firmware.
The only error message I see is that when I do a SMP “list” requests after upload of the firmware it gives an error message about Image area ID 2. CONFIG_UPDATEABLE_IMAGE_NUMBER is set to 2 in app but 3 in mcuboot.
[00:00:18.114,593] <err> mcumgr_img_grp: Failed to open flash area ID 2: -2
I also see that the magic is unset and not good. I expect this to be the main reason it not swapping to the new firmware but I can not figure out what is causing it.
Have I understood it correctly that magic=unset for the flash area at start(programmed with jlink swd) is correct and should be unset?
Might it be flash related, how can I be sure that the flash content primary/secondary has been swapped correctly? Is the copy of the image also including the “End-of-image slot structure” or is that updated separately?
*** Delaying boot by 5000ms... ***
*** Booting My Application v2.1.0-dev-b1cbeef4d76d ***
*** Using nRF Connect SDK v2.8.0-rc2-2226307aef40 ***
*** Using Zephyr OS v3.7.99-74bb2cf0a96a ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Image index: 1, Swap type: none
I: Image index: 2, Swap type: test
D: Image 2: swapping image
I: Starting swap using nsib algorithm.
D: erasing trailer; fa_id=16
I: Image index: 0, Swap type: none
I: Image index: 2, Swap type: none
.config file for mcuboot:
# MCUboot-specific configuration options
# CONFIG_BOOT_USE_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_MCUBOOT_SCRATCH=0x1e000
CONFIG_PM_PARTITION_SIZE_MCUBOOT_PAD=0x200
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x13E00
CONFIG_BOOT_USE_NRF_EXTERNAL_CRYPTO=y
CONFIG_MCUBOOT_NRF_CLEANUP_PERIPHERAL=y
# CONFIG_MCUBOOT_NRF_CLEANUP_NONSECURE_RAM is not set
CONFIG_BOOT_SIGNATURE_KEY_FILE="/home/guseve/vinnter/vinnter-embedded/bootloader/mcuboot/root-ec-p256.pem"
CONFIG_BOOT_NRF_EXTERNAL_CRYPTO=y
CONFIG_BOOT_ERASE_PROGRESSIVELY=y
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
CONFIG_BOOT_IMAGE_ACCESS_HOOK_NRF5340=y
CONFIG_NRF53_RECOVERY_NETWORK_CORE=y
CONFIG_NRF53_MCUBOOT_PRIMARY_1_RAM_FLASH=y
CONFIG_NRF53_RAM_FLASH_SIZE=0x40000
CONFIG_MCUBOOT_CLEANUP_UNUSABLE_SECONDARY=y
CONFIG_BOOT_SERIAL_IMG_GRP_HASH=y
CONFIG_MCUBOOT=y
CONFIG_NRFXLIB_CRYPTO=y
# CONFIG_NRF_CC310_BL is not set
# MCUBoot settings
# CONFIG_SINGLE_APPLICATION_SLOT is not set
CONFIG_BOOT_IMG_HASH_ALG_SHA256_ALLOW=y
# CONFIG_BOOT_IMG_HASH_DIRECTLY_ON_STORAGE is not set
CONFIG_BOOT_IMG_HASH_ALG_SHA256=y
# CONFIG_BOOT_SIGNATURE_TYPE_NONE is not set
# CONFIG_BOOT_SIGNATURE_TYPE_RSA is not set
CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y
# CONFIG_BOOT_ECDSA_TINYCRYPT is not set
# CONFIG_BOOT_SIGNATURE_TYPE_ED25519 is not set
CONFIG_MCUBOOT_CLEANUP_ARM_CORE=y
# CONFIG_MBEDTLS is not set
# CONFIG_NRF_SECURITY is not set
# CONFIG_BOOT_HW_KEY is not set
CONFIG_BOOT_VALIDATE_SLOT0=y
CONFIG_BOOT_PREFER_SWAP_MOVE=y
# CONFIG_BOOT_SWAP_USING_SCRATCH is not set
# CONFIG_BOOT_UPGRADE_ONLY is not set
CONFIG_BOOT_SWAP_USING_MOVE=y
# CONFIG_BOOT_DIRECT_XIP is not set
# CONFIG_BOOT_RAM_LOAD is not set
# CONFIG_BOOT_FIRMWARE_LOADER is not set
# CONFIG_BOOT_BOOTSTRAP is not set
CONFIG_BOOT_ENCRYPTION_SUPPORT=y
# CONFIG_BOOT_ENCRYPT_IMAGE is not set
# CONFIG_BOOT_MAX_IMG_SECTORS_AUTO is not set
CONFIG_BOOT_MAX_IMG_SECTORS=110
CONFIG_BOOT_SHARE_BACKEND_DISABLED=y
# CONFIG_BOOT_SHARE_BACKEND_EXTERNAL is not set
CONFIG_BOOT_FIH_PROFILE_OFF=y
# CONFIG_BOOT_FIH_PROFILE_LOW is not set
# CONFIG_BOOT_FIH_PROFILE_MEDIUM is not set
# CONFIG_BOOT_FIH_PROFILE_HIGH is not set
CONFIG_BOOT_USB_DFU_NO=y
# CONFIG_BOOT_USB_DFU_WAIT is not set
# CONFIG_BOOT_USB_DFU_GPIO is not set
# CONFIG_BOOT_USB_DFU_NO_APPLICATION is not set
# CONFIG_BOOT_USE_BENCH is not set
# CONFIG_MCUBOOT_LOG_LEVEL_OFF is not set
# CONFIG_MCUBOOT_LOG_LEVEL_ERR is not set
# CONFIG_MCUBOOT_LOG_LEVEL_WRN is not set
# CONFIG_MCUBOOT_LOG_LEVEL_INF is not set
CONFIG_MCUBOOT_LOG_LEVEL_DBG=y
# CONFIG_MCUBOOT_LOG_LEVEL_DEFAULT is not set
CONFIG_MCUBOOT_LOG_LEVEL=4
CONFIG_MCUBOOT_LOG_THREAD_STACK_SIZE=768
# CONFIG_MCUBOOT_INDICATION_LED is not set
CONFIG_MCUBOOT_SERIAL=y
# CONFIG_BOOT_SERIAL_UART is not set
CONFIG_BOOT_SERIAL_CDC_ACM=y
CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=y
CONFIG_BOOT_SERIAL_UNALIGNED_BUFFER_SIZE=64
CONFIG_BOOT_MAX_LINE_INPUT_LEN=128
CONFIG_BOOT_LINE_BUFS=8
CONFIG_BOOT_SERIAL_MAX_RECEIVE_SIZE=1024
# CONFIG_BOOT_MGMT_ECHO is not set
# CONFIG_ENABLE_MGMT_PERUSER is not set
# Entrance methods
CONFIG_BOOT_SERIAL_ENTRANCE_GPIO=y
CONFIG_BOOT_SERIAL_DETECT_DELAY=0
# CONFIG_BOOT_SERIAL_WAIT_FOR_DFU is not set
CONFIG_BOOT_SERIAL_BOOT_MODE=y
CONFIG_BOOT_SERIAL_NO_APPLICATION=y
# CONFIG_BOOT_SERIAL_PIN_RESET is not set
# end of Entrance methods
CONFIG_BOOT_SERIAL_IMG_GRP_IMAGE_STATE=y
CONFIG_BOOT_SERIAL_IMG_GRP_SLOT_INFO=y
# CONFIG_BOOT_INTR_VEC_RELOC is not set
CONFIG_UPDATEABLE_IMAGE_NUMBER=3
# CONFIG_BOOT_VERSION_CMP_USE_BUILD_NUMBER is not set
CONFIG_BOOT_WATCHDOG_FEED=y
# CONFIG_MCUBOOT_ACTION_HOOKS is not set
# end of MCUBoot settings
CONFIG_MCUBOOT_DEVICE_SETTINGS=y
# Zephyr configuration options
CONFIG_MULTITHREADING=y
CONFIG_USB_DEVICE_PRODUCT="MCUBOOT"
# CONFIG_MCUBOOT_VERIFY_IMG_ADDRESS is not set
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_MIPI_DSI is not set
CONFIG_SERIAL=y
# CONFIG_I2C is not set
# CONFIG_SPI is not set
# CONFIG_MODEM is not set
CONFIG_FLASH_LOAD_SIZE=0x10000
CONFIG_FLASH_LOAD_OFFSET=0x0
CONFIG_HW_STACK_PROTECTION=y
CONFIG_SECURE_BOOT=y
CONFIG_SB_SIGNING_KEY_FILE=""
CONFIG_GPIO_HOGS=y
CONFIG_NFCT_PINS_AS_GPIOS=y
CONFIG_SRAM_SIZE=448
CONFIG_HEAP_MEM_POOL_SIZE=0
# CONFIG_USE_SEGGER_RTT is not set
# CONFIG_REGULATOR is not set
CONFIG_GPIO_HOGS_INIT_PRIORITY=41
CONFIG_NUM_IRQS=69
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_SOC_RESET_HOOK=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_XIP=y
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_IDLE_STACK_SIZE=320
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_COUNTER is not set
# CONFIG_SHARED_INTERRUPTS is not set
# CONFIG_PM_DEVICE is not set
CONFIG_TICKLESS_KERNEL=y
# CONFIG_FPU is not set
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
CONFIG_CLOCK_CONTROL=y
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_USE_DT_CODE_PARTITION=y
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_ISR_TABLES=y
# CONFIG_INIT_STACKS is not set
CONFIG_TIMESLICE_SIZE=0
CONFIG_FLASH_FILL_BUFFER_SIZE=32
# CONFIG_MFD is not set
CONFIG_GPIO=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
# CONFIG_MEMC is not set
CONFIG_KERNEL_ENTRY="__start"
# CONFIG_CACHE is not set
CONFIG_LOG=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_ROMSTART_RELOCATION_ROM is not set
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_SOC="nrf5340"
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_NRF_RTC_TIMER=y
CONFIG_LOG_DOMAIN_NAME=""
# CONFIG_ASSERT is not set
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
# CONFIG_SYSCON is not set
CONFIG_SERIAL_INIT_PRIORITY=50
CONFIG_SOC_SERIES="nrf53"
CONFIG_SOC_FAMILY="nordic_nrf"
# CONFIG_INTC_MTK_ADSP is not set
# CONFIG_MTK_ADSP_TIMER is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=0
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_REBOOT=y
CONFIG_FLASH_INIT_PRIORITY=50
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_SRAM_OFFSET=0
# CONFIG_POWER_DOMAIN is not set
CONFIG_CONSOLE=y
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_ISR_STACK_SIZE=2048
CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y
# CONFIG_SCHED_CPU_MASK is not set
# CONFIG_WATCHDOG is not set
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_PRIVILEGED_STACK_SIZE=1024
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53X_REGULATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
CONFIG_DT_HAS_SEGGER_RTT_UART_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_IPC_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_MEMORY_REGION_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_RETAINED_RAM_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_RETENTION_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_SIM_FLASH_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# gateway_firmware (/home/guseve/vinnter/vinnter-embedded/gateway_firmware)
# Drivers
# end of Drivers
CONFIG_ZEPHYR_GATEWAY_FIRMWARE_MODULE=y
# end of gateway_firmware (/home/guseve/vinnter/vinnter-embedded/gateway_firmware)
# nrf (/home/guseve/vinnter/vinnter-embedded/nrf)
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_MPSL_WORK_STACK_SIZE=1024
# Nordic nRF Connect
CONFIG_HIDE_CHILD_PARENT_CONFIG=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=1024
CONFIG_BT_BUF_CMD_TX_COUNT=10
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_GETOPT is not set
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# CONFIG_NRF70_RADIO_TEST_COMBO is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# Subsystems
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
CONFIG_BOOTLOADER_PROVISION_HEX=y
CONFIG_SB_PRIVATE_KEY_PROVIDED=y
CONFIG_SB_SIGNING_PYTHON=y
# CONFIG_SB_SIGNING_OPENSSL is not set
# CONFIG_SB_SIGNING_CUSTOM is not set
CONFIG_SB_SIGNING_COMMAND=""
CONFIG_SB_SIGNING_PUBLIC_KEY=""
CONFIG_SB_PUBLIC_KEY_FILES=""
# CONFIG_SB_DEBUG_SIGNATURE_PUBLIC_KEY_LAST is not set
CONFIG_SB_MONOTONIC_COUNTER=y
CONFIG_SB_NUM_VER_COUNTER_SLOTS=20
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_IS_SECURE_BOOTLOADER is not set
CONFIG_IS_BOOTLOADER_IMG=y
CONFIG_SECURE_BOOT_CRYPTO=y
CONFIG_SB_ECDSA_SECP256R1=y
CONFIG_SB_SHA256=y
CONFIG_SB_SIGNATURE_LEN=64
CONFIG_SB_PUBLIC_KEY_LEN=64
CONFIG_SB_HASH_LEN=32
# CONFIG_SB_CRYPTO_OBERON_ECDSA_SECP256R1 is not set
CONFIG_SB_CRYPTO_CLIENT_ECDSA_SECP256R1=y
# CONFIG_SB_CRYPTO_NO_ECDSA_SECP256R1 is not set
# CONFIG_SB_CRYPTO_OBERON_SHA256 is not set
CONFIG_SB_CRYPTO_CLIENT_SHA256=y
# CONFIG_SB_CRYPTO_NO_SHA256 is not set
CONFIG_BL_ROT_VERIFY_EXT_API_UNUSED=y
# CONFIG_BL_ROT_VERIFY_EXT_API_OPTIONAL is not set
# CONFIG_BL_ROT_VERIFY_EXT_API_REQUIRED is not set
# CONFIG_BL_ROT_VERIFY_EXT_API_ENABLED is not set
CONFIG_BL_SHA256_EXT_API_REQUIRED=y
CONFIG_BL_SHA256_EXT_API_ATLEAST_REQUIRED=y
# CONFIG_BL_SHA256_EXT_API_ENABLED is not set
CONFIG_BL_SHA256_EXT_API_ID=0x1002
CONFIG_BL_SHA256_EXT_API_FLAGS=0
CONFIG_BL_SHA256_EXT_API_VER=1
CONFIG_BL_SHA256_EXT_API_MAX_VER=255
CONFIG_BL_SECP256R1_EXT_API_REQUIRED=y
CONFIG_BL_SECP256R1_EXT_API_ATLEAST_REQUIRED=y
# CONFIG_BL_SECP256R1_EXT_API_ENABLED is not set
CONFIG_BL_SECP256R1_EXT_API_ID=0x1003
CONFIG_BL_SECP256R1_EXT_API_FLAGS=1
CONFIG_BL_SECP256R1_EXT_API_VER=1
CONFIG_BL_SECP256R1_EXT_API_MAX_VER=255
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# CONFIG_EMDS is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
CONFIG_PCD_APP=y
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# CONFIG_PCD_READ_NETCORE_APP_VERSION is not set
# CONFIG_PCD_USE_CONSTANTS is not set
# CONFIG_PCD_LOG_LEVEL_OFF is not set
# CONFIG_PCD_LOG_LEVEL_ERR is not set
# CONFIG_PCD_LOG_LEVEL_WRN is not set
# CONFIG_PCD_LOG_LEVEL_INF is not set
# CONFIG_PCD_LOG_LEVEL_DBG is not set
CONFIG_PCD_LOG_LEVEL_DEFAULT=y
CONFIG_PCD_LOG_LEVEL=0
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Transport
# CONFIG_NRF_CLOUD_REST is not set
# end of Transport
# Credentials
CONFIG_NRF_CLOUD_SEC_TAG=16842753
CONFIG_NRF_CLOUD_AWS_CA_CERT_SIZE_THRESHOLD=1150
CONFIG_NRF_CLOUD_COAP_CA_CERT_SIZE_THRESHOLD=550
# end of Credentials
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_RUNTIME is not set
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# Firmware Over-the-Air (FOTA) Updates
# CONFIG_NRF_CLOUD_FOTA is not set
CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_FOTA_SMP is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL=0
# end of Firmware Over-the-Air (FOTA) Updates
# Location
# Cellular/Wi-Fi
# CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
# CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_ONLY is not set
CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_RSSI=y
# CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_ALL is not set
# end of Cellular/Wi-Fi
# end of Location
# Alerts
# CONFIG_NRF_CLOUD_ALERT is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=0
# end of Alerts
# Logging
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=0
# end of Logging
# Device Shadow
# Send shadow info sections on initial connect (MQTT/CoAP)
# end of Send shadow info sections on initial connect (MQTT/CoAP)
# end of Device Shadow
CONFIG_NRF_CLOUD_PRINT_DETAILS=y
CONFIG_NRF_CLOUD_VERBOSE_DETAILS=y
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LEVEL=0
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# CONFIG_OPENTHREAD_RPC is not set
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# CONFIG_NFC_RPC is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
CONFIG_FW_INFO=y
# CONFIG_FW_INFO_API is not set
CONFIG_FW_INFO_OFFSET=0x200
CONFIG_FW_INFO_FIRMWARE_VERSION=2
CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
CONFIG_FW_INFO_HARDWARE_ID=53
CONFIG_FW_INFO_VERSION=2
CONFIG_FW_INFO_CRYPTO_ID=0
CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
CONFIG_FW_INFO_MAGIC_LEN=12
CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
# CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_FEM_LOG_LEVEL=0
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
CONFIG_MPSL_LOW_PRIO_IRQN=26
CONFIG_MPSL_HFCLK_LATENCY=1400
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_LOG_LEVEL_INF is not set
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_LOG_LEVEL=0
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_BASE_ADDRESS=0x20000000
CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0x4000
CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0x2000
# Zephyr subsystem configurations
CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY is not set
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x80000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
CONFIG_MGMT_FMFU_LOG_LEVEL=0
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# Nordic-added meta types
# Nordic added alg types
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# Nordic added ECC curve types
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# CONFIG_PSA_WANT_ALG_CHACHA20 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# Nordic addded RNG configuration
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# Nordic added key types
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# end of nRF Security
# CONFIG_NET_CORE_MONITOR is not set
# Audio Modules
# CONFIG_AUDIO_MODULE_TEST is not set
CONFIG_AUDIO_MODULE_NAME_SIZE=20
# Log levels
# CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
CONFIG_AUDIO_MODULE_LOG_LEVEL=0
# end of Log levels
# end of Audio Modules
# Audio Modules
# CONFIG_AUDIO_MODULE_TEMPLATE is not set
# CONFIG_UART_ASYNC_ADAPTER is not set
# CONFIG_TRUSTED_STORAGE is not set
# Logging over RPC
# CONFIG_LOG_FORWARDER_RPC is not set
# end of Logging over RPC
# SUIT provisioning
# CONFIG_SUIT_MPI_GENERATE is not set
# end of SUIT provisioning
# CONFIG_SUIT is not set
# CONFIG_NRF_COMPRESS is not set
# MCUboot IDs (informative only, do not change)
CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=1
CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=2
CONFIG_MCUBOOT_MCUBOOT_S0_S1_VERSION_MAJOR=0
CONFIG_MCUBOOT_MCUBOOT_S0_S1_VERSION_MINOR=0
CONFIG_MCUBOOT_MCUBOOT_S0_S1_VERSION_REVISION=0
CONFIG_MCUBOOT_MCUBOOT_S0_S1_VERSION_BUILD_NUMBER=0
# end of MCUboot IDs (informative only, do not change)
# end of Subsystems
# CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
# CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
# CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
# CONFIG_WFA_QT_LOG_LEVEL_INF is not set
# CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
CONFIG_WFA_QT_LOG_LEVEL=0
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
CONFIG_FPROTECT_BLOCK_SIZE=0x4000
CONFIG_FPROTECT=y
# CONFIG_FPROTECT_APP is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_PARSER is not set
# CONFIG_MODEM_INFO is not set
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
# CONFIG_MODEM_JWT is not set
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="My Application"
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_FLASH_RPC is not set
# CONFIG_GPIO_NRFE_EGPIO_BACKEND_MBOX is not set
CONFIG_GPIO_NRFE_EGPIO_BACKEND_ICMSG=y
# CONFIG_GPIO_NRFE_EGPIO_BACKEND_ICBMSG is not set
CONFIG_HW_CC3XX=y
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# CONFIG_MOCK_NRF_RPC is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (/home/guseve/vinnter/vinnter-embedded/nrf)
# mcuboot (/home/guseve/vinnter/vinnter-embedded/bootloader/mcuboot)
# MCUboot
CONFIG_SIGN_IMAGES=y
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
# CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (/home/guseve/vinnter/vinnter-embedded/bootloader/mcuboot)
# mbedtls (/home/guseve/vinnter/vinnter-embedded/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# end of mbedtls (/home/guseve/vinnter/vinnter-embedded/modules/crypto/mbedtls)
# oberon-psa-crypto (/home/guseve/vinnter/vinnter-embedded/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (/home/guseve/vinnter/vinnter-embedded/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (/home/guseve/vinnter/vinnter-embedded/modules/tee/tf-m/trusted-firmware-m)
CONFIG_TFM_BOARD="/home/guseve/vinnter/vinnter-embedded/zephyr/modules/trusted-firmware-m/nordic/nrf5340_cpuapp"
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (/home/guseve/vinnter/vinnter-embedded/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
# cjson (/home/guseve/vinnter/vinnter-embedded/modules/lib/cjson)
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (/home/guseve/vinnter/vinnter-embedded/modules/lib/cjson)
# azure-sdk-for-c (/home/guseve/vinnter/vinnter-embedded/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (/home/guseve/vinnter/vinnter-embedded/modules/lib/azure-sdk-for-c)
# cirrus-logic (/home/guseve/vinnter/vinnter-embedded/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (/home/guseve/vinnter/vinnter-embedded/modules/hal/cirrus-logic)
# openthread (/home/guseve/vinnter/vinnter-embedded/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (/home/guseve/vinnter/vinnter-embedded/modules/lib/openthread)
# suit-generator (/home/guseve/vinnter/vinnter-embedded/modules/lib/suit-generator)
CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
CONFIG_SUIT_ENVELOPE_TARGET=""
CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
# CONFIG_SUIT_RECOVERY is not set
CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
# CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
# CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
# end of suit-generator (/home/guseve/vinnter/vinnter-embedded/modules/lib/suit-generator)
# suit-processor (/home/guseve/vinnter/vinnter-embedded/modules/lib/suit-processor)
# CONFIG_SUIT_PROCESSOR is not set
CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
# end of suit-processor (/home/guseve/vinnter/vinnter-embedded/modules/lib/suit-processor)
# memfault-firmware-sdk (/home/guseve/vinnter/vinnter-embedded/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (/home/guseve/vinnter/vinnter-embedded/modules/lib/memfault-firmware-sdk)
# coremark (/home/guseve/vinnter/vinnter-embedded/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (/home/guseve/vinnter/vinnter-embedded/modules/benchmark/coremark)
# canopennode (/home/guseve/vinnter/vinnter-embedded/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (/home/guseve/vinnter/vinnter-embedded/modules/lib/canopennode)
# chre (/home/guseve/vinnter/vinnter-embedded/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (/home/guseve/vinnter/vinnter-embedded/modules/lib/chre)
# lz4 (/home/guseve/vinnter/vinnter-embedded/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (/home/guseve/vinnter/vinnter-embedded/modules/lib/lz4)
# nanopb (/home/guseve/vinnter/vinnter-embedded/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (/home/guseve/vinnter/vinnter-embedded/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (/home/guseve/vinnter/vinnter-embedded/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (/home/guseve/vinnter/vinnter-embedded/modules/lib/zscilib)
# cmsis (/home/guseve/vinnter/vinnter-embedded/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis (/home/guseve/vinnter/vinnter-embedded/modules/hal/cmsis)
# cmsis-dsp (/home/guseve/vinnter/vinnter-embedded/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (/home/guseve/vinnter/vinnter-embedded/modules/lib/cmsis-dsp)
# cmsis-nn (/home/guseve/vinnter/vinnter-embedded/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (/home/guseve/vinnter/vinnter-embedded/modules/lib/cmsis-nn)
# fatfs (/home/guseve/vinnter/vinnter-embedded/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (/home/guseve/vinnter/vinnter-embedded/modules/fs/fatfs)
# hal_nordic (/home/guseve/vinnter/vinnter-embedded/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_HOST is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# nrfx drivers logging
# CONFIG_NRFX_CLOCK_LOG is not set
# CONFIG_NRFX_DPPI_LOG is not set
# CONFIG_NRFX_GPIOTE_LOG is not set
# CONFIG_NRFX_NVMC_LOG is not set
# CONFIG_NRFX_POWER_LOG is not set
# CONFIG_NRFX_USBREG_LOG is not set
# CONFIG_NRFX_WDT_LOG is not set
# end of nrfx drivers logging
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_COMP is not set
CONFIG_NRFX_DPPI=y
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE0=y
# CONFIG_NRFX_GPIOTE1 is not set
# CONFIG_NRFX_I2S0 is not set
# CONFIG_NRFX_IPC is not set
# CONFIG_NRFX_NFCT is not set
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM0 is not set
CONFIG_NRFX_POWER=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC0 is not set
# CONFIG_NRFX_QDEC1 is not set
# CONFIG_NRFX_QSPI is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SPIM4 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_TWIM2 is not set
# CONFIG_NRFX_TWIM3 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_UARTE2 is not set
# CONFIG_NRFX_UARTE3 is not set
CONFIG_NRFX_USBREG=y
CONFIG_NRFX_WDT=y
CONFIG_NRFX_WDT0=y
CONFIG_NRFX_WDT1=y
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of hal_nordic (/home/guseve/vinnter/vinnter-embedded/modules/hal/nordic)
# hal_st (/home/guseve/vinnter/vinnter-embedded/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (/home/guseve/vinnter/vinnter-embedded/modules/hal/st)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
# hostap (/home/guseve/vinnter/vinnter-embedded/modules/lib/hostap)
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (/home/guseve/vinnter/vinnter-embedded/modules/lib/hostap)
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# liblc3 (/home/guseve/vinnter/vinnter-embedded/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (/home/guseve/vinnter/vinnter-embedded/modules/lib/liblc3)
# littlefs (/home/guseve/vinnter/vinnter-embedded/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (/home/guseve/vinnter/vinnter-embedded/modules/fs/littlefs)
# loramac-node (/home/guseve/vinnter/vinnter-embedded/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (/home/guseve/vinnter/vinnter-embedded/modules/lib/loramac-node)
# lvgl (/home/guseve/vinnter/vinnter-embedded/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (/home/guseve/vinnter/vinnter-embedded/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# picolibc (/home/guseve/vinnter/vinnter-embedded/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (/home/guseve/vinnter/vinnter-embedded/modules/lib/picolibc)
# segger (/home/guseve/vinnter/vinnter-embedded/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
# end of segger (/home/guseve/vinnter/vinnter-embedded/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (/home/guseve/vinnter/vinnter-embedded/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (/home/guseve/vinnter/vinnter-embedded/modules/lib/uoscore-uedhoc)
# zcbor (/home/guseve/vinnter/vinnter-embedded/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
CONFIG_ZCBOR=y
# CONFIG_ZCBOR_CANONICAL is not set
# CONFIG_ZCBOR_STOP_ON_ERROR is not set
# CONFIG_ZCBOR_VERBOSE is not set
CONFIG_ZCBOR_MAX_STR_LEN=256
# end of zcbor (/home/guseve/vinnter/vinnter-embedded/modules/lib/zcbor)
# nrfxlib (/home/guseve/vinnter/vinnter-embedded/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# end of nrf_modem (Modem library)
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_HAS_HW_NRF_CC3XX=y
CONFIG_NRF_OBERON=y
CONFIG_NRF_CC3XX_PLATFORM=y
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# CONFIG_CC3XX_HW_MUTEX_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (/home/guseve/vinnter/vinnter-embedded/nrfxlib)
# connectedhomeip (/home/guseve/vinnter/vinnter-embedded/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (/home/guseve/vinnter/vinnter-embedded/modules/lib/matter)
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
CONFIG_MCUBOOT_BOOTUTIL_LIB=y
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="thingy91x"
CONFIG_BOARD_REVISION=""
CONFIG_BOARD_TARGET="thingy91x/nrf5340/cpuapp"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_THINGY91X=y
CONFIG_BOARD_THINGY91X_NRF5340_CPUAPP=y
CONFIG_BOARD_QUALIFIERS="nrf5340/cpuapp"
# Board Options
# CONFIG_BOARD_LOG_LEVEL_OFF is not set
# CONFIG_BOARD_LOG_LEVEL_ERR is not set
# CONFIG_BOARD_LOG_LEVEL_WRN is not set
# CONFIG_BOARD_LOG_LEVEL_INF is not set
# CONFIG_BOARD_LOG_LEVEL_DBG is not set
CONFIG_BOARD_LOG_LEVEL_DEFAULT=y
CONFIG_BOARD_LOG_LEVEL=0
CONFIG_BOARD_ENABLE_DCDC_APP=y
CONFIG_BOARD_ENABLE_DCDC_NET=y
# end of Board Options
# Hardware Configuration
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF53X=y
CONFIG_SOC_NRF5340_CPUAPP=y
CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_HAS_HW_NRF_CC312=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_CTRLAP=y
CONFIG_HAS_HW_NRF_DCNF=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_KMU=y
CONFIG_HAS_HW_NRF_MUTEX=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_OSCILLATORS=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_RESET=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPU=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_USBREG=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_HW_NRF_WDT0=y
# CONFIG_NRF_SYS_EVENT is not set
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
# CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
CONFIG_SOC_NRF53_RTC_PRETICK=y
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
CONFIG_SOC_DCDC_NRF53X_APP=y
CONFIG_SOC_DCDC_NRF53X_NET=y
CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
CONFIG_SOC_NRF_GPIO_FORWARDER_FOR_NRF5340=y
CONFIG_SOC_NRF53_CPUNET_MGMT=y
# CONFIG_SOC_NRF53_CPUNET_ENABLE is not set
# CONFIG_BOARD_ENABLE_CPUNET is not set
CONFIG_SOC_ENABLE_LFXO=y
# CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
# CONFIG_SOC_LFXO_CAP_INT_6PF is not set
CONFIG_SOC_LFXO_CAP_INT_7PF=y
# CONFIG_SOC_LFXO_CAP_INT_9PF is not set
CONFIG_SOC_HFXO_CAP_DEFAULT=y
# CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
# CONFIG_SOC_HFXO_CAP_INTERNAL is not set
CONFIG_NRF_ENABLE_CACHE=y
# CONFIG_NRF53_SYNC_RTC is not set
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
# CONFIG_SOC_NRF54H20_GPD is not set
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_APPROTECT_USER_HANDLING is not set
CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
# CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
# CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
# CONFIG_NRF_TRACE_PORT is not set
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
# CONFIG_SOC_LOG_LEVEL_INF is not set
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL_DEFAULT=y
CONFIG_SOC_LOG_LEVEL=0
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF53X=y
CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
CONFIG_ARCH="arm"
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_CPU_CORTEX=y
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# ARM Options
CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
CONFIG_ARM_ON_EXIT_CPU_IDLE=y
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
# CONFIG_PLATFORM_SPECIFIC_INIT is not set
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_ARMV8_M_DSP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_ARM_TRUSTZONE_M=y
# CONFIG_MPU_STACK_GUARD is not set
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_CPU_HAS_NRF_IDAU=y
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
# CONFIG_ARCH_LOG_LEVEL_INF is not set
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
CONFIG_ARCH_LOG_LEVEL=0
CONFIG_LITTLE_ENDIAN=y
# CONFIG_TRUSTED_EXECUTION_SECURE is not set
# CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# CONFIG_FRAME_POINTER is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_TEE=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
# CONFIG_MPU_LOG_LEVEL_INF is not set
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL_DEFAULT=y
CONFIG_MPU_LOG_LEVEL=0
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
# CONFIG_KERNEL_LOG_LEVEL_INF is not set
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
CONFIG_KERNEL_LOG_LEVEL=0
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Misc Kernel related options
CONFIG_ERRNO=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=4000
# CONFIG_BOOT_CLEAR_SCREEN is not set
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_POLL is not set
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
CONFIG_MP_NUM_CPUS=1
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
# CONFIG_THREAD_LOCAL_STORAGE is not set
CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
# CONFIG_STATIC_INIT_GNU is not set
# CONFIG_BOOTARGS is not set
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_DEPS is not set
# CONFIG_DEVICE_MUTABLE is not set
# CONFIG_DEVICE_DT_METADATA is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# end of Virtual Memory Support
# SoC and Board Hooks
# CONFIG_SOC_PREP_HOOK is not set
# CONFIG_SOC_EARLY_INIT_HOOK is not set
# CONFIG_SOC_LATE_INIT_HOOK is not set
# CONFIG_BOARD_EARLY_INIT_HOOK is not set
# CONFIG_BOARD_LATE_INIT_HOOK is not set
# end of SoC and Board Hooks
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
CONFIG_FLASH=y
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_CLOCK_CONTROL_LOG_LEVEL=0
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
# CONFIG_COMPARATOR is not set
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
# CONFIG_RAM_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_DBG=y
# CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT is not set
CONFIG_UART_CONSOLE_LOG_LEVEL=4
# CONFIG_EFI_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_DP_DRIVER is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
# CONFIG_ENTROPY_GENERATOR is not set
# CONFIG_ESPI is not set
# Firmware drivers
# CONFIG_ARM_SCMI is not set
# end of Firmware drivers
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
# CONFIG_SOC_FLASH_NRF_UICR is not set
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
# MSPI flash device driver
# end of MSPI flash device driver
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_UNALIGNED_READ=y
CONFIG_FLASH_SIMULATOR_EXPLICIT_ERASE=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
# CONFIG_FLASH_SIMULATOR_SIMULATE_TIMING is not set
# CONFIG_FLASH_SIMULATOR_STATS is not set
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_FLASH_LOG_LEVEL_INF is not set
CONFIG_FLASH_LOG_LEVEL_DBG=y
# CONFIG_FLASH_LOG_LEVEL_DEFAULT is not set
CONFIG_FLASH_LOG_LEVEL=4
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
# CONFIG_GPIO_LOG_LEVEL_INF is not set
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
CONFIG_GPIO_LOG_LEVEL=0
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_HAPTICS is not set
CONFIG_HWINFO=y
# CONFIG_HWINFO_LOG_LEVEL_OFF is not set
# CONFIG_HWINFO_LOG_LEVEL_ERR is not set
# CONFIG_HWINFO_LOG_LEVEL_WRN is not set
# CONFIG_HWINFO_LOG_LEVEL_INF is not set
# CONFIG_HWINFO_LOG_LEVEL_DBG is not set
CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
CONFIG_HWINFO_LOG_LEVEL=0
CONFIG_HWINFO_HAS_DRIVER=y
CONFIG_HWINFO_NRF=y
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
# CONFIG_INTC_LOG_LEVEL_INF is not set
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL_DEFAULT=y
CONFIG_INTC_LOG_LEVEL=0
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_KSCAN is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
# CONFIG_MBOX is not set
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_MSPI is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
# CONFIG_PINCTRL_LOG_LEVEL_INF is not set
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
CONFIG_PINCTRL_LOG_LEVEL=0
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
CONFIG_RETAINED_MEM=y
CONFIG_RETAINED_MEM_INIT_PRIORITY=40
CONFIG_RETAINED_MEM_MUTEXES=y
# CONFIG_RETAINED_MEM_MUTEX_FORCE_DISABLE is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_OFF is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_ERR is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_WRN is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_INF is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_DBG is not set
CONFIG_RETAINED_MEM_LOG_LEVEL_DEFAULT=y
CONFIG_RETAINED_MEM_LOG_LEVEL=0
CONFIG_RETAINED_MEM_NRF_GPREGRET=y
CONFIG_RETAINED_MEM_ZEPHYR_RAM=y
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
# CONFIG_UART_LOG_LEVEL_INF is not set
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL_DEFAULT=y
CONFIG_UART_LOG_LEVEL=0
CONFIG_UART_LINE_CTRL=y
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_ASYNC_RX_HELPER is not set
# Serial Drivers
# CONFIG_SMBUS is not set
# CONFIG_STEPPER is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
CONFIG_USB_DEVICE_DRIVER=y
# CONFIG_USB_DC_HAS_HS_SUPPORT is not set
CONFIG_USB_DEVICE_REMOTE_WAKEUP=y
CONFIG_USB_NRFX=y
CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=1024
CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=0
# CONFIG_USB_DRIVER_LOG_LEVEL_OFF is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_ERR is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_WRN is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_INF is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_DBG is not set
CONFIG_USB_DRIVER_LOG_LEVEL_DEFAULT=y
CONFIG_USB_DRIVER_LOG_LEVEL=0
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_USBD_COMMON_LOG_LEVEL=0
CONFIG_NRF_USBD_COMMON=y
CONFIG_NRF_USBD_ISO_IN_ZLP=y
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
# CONFIG_USBC_LOG_LEVEL_INF is not set
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL_DEFAULT=y
CONFIG_USBC_LOG_LEVEL=0
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_TEE is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
CONFIG_MINIMAL_LIBC=y
# CONFIG_PICOLIBC is not set
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
CONFIG_COMMON_LIBC_ASCTIME=y
# CONFIG_COMMON_LIBC_ASCTIME_R is not set
CONFIG_COMMON_LIBC_CTIME=y
# CONFIG_COMMON_LIBC_CTIME_R is not set
CONFIG_COMMON_LIBC_GMTIME_R=y
CONFIG_COMMON_LIBC_LOCALTIME_R_UTC=y
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
CONFIG_COMMON_LIBC_STRNLEN=y
# CONFIG_COMMON_LIBC_REMOVE is not set
CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y
# CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
# CONFIG_MINIMAL_LIBC_RAND is not set
CONFIG_MINIMAL_LIBC_TIME=y
# CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# end of C++ Language Support
CONFIG_CRC=y
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
# CONFIG_NET_BUF is not set
# OS Support Library
# CONFIG_FDTABLE is not set
CONFIG_ZVFS_OPEN_MAX=4
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
# CONFIG_SPSC_PBUF is not set
CONFIG_HAS_POWEROFF=y
# CONFIG_POWEROFF is not set
# CONFIG_CBPRINTF_COMPLETE is not set
CONFIG_CBPRINTF_NANO=y
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_LIBC_SUBSTS=y
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=0
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# CONFIG_ZVFS is not set
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
CONFIG_POSIX_AEP_CHOICE_NONE=y
# CONFIG_POSIX_AEP_CHOICE_BASE is not set
# CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_BARRIERS is not set
# CONFIG_POSIX_C_LANG_SUPPORT_R is not set
# CONFIG_POSIX_C_LIB_EXT is not set
# POSIX device I/O
# CONFIG_POSIX_DEVICE_IO is not set
CONFIG_POSIX_OPEN_MAX=4
# end of POSIX device I/O
# CONFIG_POSIX_FD_MGMT is not set
# CONFIG_POSIX_FILE_SYSTEM is not set
# POSIX memory
CONFIG_POSIX_PAGE_SIZE=0x40
# CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
# CONFIG_POSIX_MAPPED_FILES is not set
# CONFIG_POSIX_MEMORY_PROTECTION is not set
# end of POSIX memory
# CONFIG_POSIX_MESSAGE_PASSING is not set
# CONFIG_POSIX_SINGLE_PROCESS is not set
# CONFIG_POSIX_MULTI_PROCESS is not set
# CONFIG_POSIX_THREADS is not set
# CONFIG_POSIX_READER_WRITER_LOCKS is not set
# POSIX scheduler options
# CONFIG_POSIX_PRIORITY_SCHEDULING is not set
# end of POSIX scheduler options
# CONFIG_POSIX_SEMAPHORES is not set
# POSIX signals
# CONFIG_POSIX_REALTIME_SIGNALS is not set
# CONFIG_POSIX_SIGNALS is not set
# end of POSIX signals
# CONFIG_POSIX_SPIN_LOCKS is not set
# POSIX synchronized I/O
# CONFIG_POSIX_FSYNC is not set
# CONFIG_POSIX_SYNCHRONIZED_IO is not set
# end of POSIX synchronized I/O
# CONFIG_POSIX_TIMERS is not set
# X/Open system interfaces
# CONFIG_XOPEN_STREAMS is not set
# CONFIG_XSI_SYSTEM_LOGGING is not set
# CONFIG_XSI_THREADS_EXT is not set
# end of X/Open system interfaces
# Miscellaneous POSIX-related options
# CONFIG_EVENTFD is not set
# end of Miscellaneous POSIX-related options
# Deprecated POSIX options
CONFIG_EVENTFD_MAX=0
# CONFIG_FNMATCH is not set
CONFIG_MAX_PTHREAD_COUNT=0
CONFIG_MAX_PTHREAD_KEY_COUNT=0
CONFIG_MAX_TIMER_COUNT=0
CONFIG_MSG_COUNT_MAX=0
# CONFIG_POSIX_CLOCK is not set
# CONFIG_POSIX_FS is not set
CONFIG_POSIX_LIMITS_RTSIG_MAX=0
CONFIG_POSIX_MAX_FDS=4
CONFIG_POSIX_MAX_OPEN_FILES=4
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_POSIX_PUTMSG is not set
# CONFIG_POSIX_SIGNAL is not set
# CONFIG_POSIX_SYSCONF is not set
# CONFIG_POSIX_UNAME is not set
# CONFIG_PTHREAD is not set
# CONFIG_PTHREAD_BARRIER is not set
# CONFIG_PTHREAD_COND is not set
# CONFIG_PTHREAD_IPC is not set
# CONFIG_PTHREAD_KEY is not set
# CONFIG_PTHREAD_MUTEX is not set
# CONFIG_PTHREAD_RWLOCK is not set
# CONFIG_PTHREAD_SPINLOCK is not set
# CONFIG_TIMER is not set
CONFIG_TIMER_DELAYTIMER_MAX=0
CONFIG_SEM_NAMELEN_MAX=0
CONFIG_SEM_VALUE_MAX=0
# end of Deprecated POSIX options
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
CONFIG_RING_BUFFER=y
CONFIG_NOTIFY=y
CONFIG_BASE64=y
CONFIG_ONOFF=y
# CONFIG_WINSTREAM is not set
# CONFIG_UTF8 is not set
# end of Utility Library
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_DAP is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# CONFIG_SYMTAB is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_CS_TRACE_DEFMT is not set
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_FCB is not set
# CONFIG_NVS is not set
# CONFIG_ZMS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# Linkable loadable Extension Development Kit (EDK)
CONFIG_LLEXT_EDK_NAME="llext-edk"
# CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
# end of Linkable loadable Extension Development Kit (EDK)
# Logging
CONFIG_LOG_CORE_INIT_PRIORITY=0
# CONFIG_LOG_MODE_DEFERRED is not set
# CONFIG_LOG_MODE_IMMEDIATE is not set
CONFIG_LOG_MODE_MINIMAL=y
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_FRONTEND_OPT_API is not set
# CONFIG_LOG_CUSTOM_HEADER is not set
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
CONFIG_LOG_DEFAULT_LEVEL=0
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
# end of Processing
# Misc
CONFIG_LOG_USE_VLA=y
CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_FMT_STRING_VALIDATE is not set
# CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
# end of Misc
# CONFIG_LOG_OUTPUT is not set
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
# end of Power Management
# Portability
# end of Portability
# CONFIG_PROFILING is not set
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
# end of Random Number Generators
CONFIG_RETENTION=y
CONFIG_RETENTION_INIT_PRIORITY=86
CONFIG_RETENTION_MUTEXES=y
# CONFIG_RETENTION_MUTEX_FORCE_DISABLE is not set
CONFIG_RETENTION_BUFFER_SIZE=16
# Retention modules
CONFIG_RETENTION_BOOT_MODE=y
# CONFIG_RETENTION_BOOTLOADER_INFO is not set
# end of Retention modules
# CONFIG_RETENTION_LOG_LEVEL_OFF is not set
# CONFIG_RETENTION_LOG_LEVEL_ERR is not set
# CONFIG_RETENTION_LOG_LEVEL_WRN is not set
# CONFIG_RETENTION_LOG_LEVEL_INF is not set
# CONFIG_RETENTION_LOG_LEVEL_DBG is not set
CONFIG_RETENTION_LOG_LEVEL_DEFAULT=y
CONFIG_RETENTION_LOG_LEVEL=0
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
# CONFIG_SETTINGS is not set
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
# CONFIG_FLASH_MAP_LABELS is not set
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
CONFIG_USB_DEVICE_STACK=y
# CONFIG_USB_DEVICE_LOG_LEVEL_OFF is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_ERR is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_WRN is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_INF is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_DBG is not set
CONFIG_USB_DEVICE_LOG_LEVEL_DEFAULT=y
CONFIG_USB_DEVICE_LOG_LEVEL=0
CONFIG_USB_DEVICE_VID=0x1915
CONFIG_USB_DEVICE_PID=0x910A
CONFIG_USB_DEVICE_MANUFACTURER="Nordic Semiconductor"
CONFIG_USB_DEVICE_SN="0123456789ABCDEF"
# CONFIG_USB_CONFIGURATION_STRING_DESC_ENABLE is not set
CONFIG_USB_COMPOSITE_DEVICE=y
CONFIG_USB_MAX_NUM_TRANSFERS=4
CONFIG_USB_REQUEST_BUFFER_SIZE=128
CONFIG_USB_MAX_ALT_SETTING=8
CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
# CONFIG_USB_DEVICE_SOF is not set
# CONFIG_USB_DEVICE_BOS is not set
# CONFIG_USB_DEVICE_OS_DESC is not set
CONFIG_USB_SELF_POWERED=y
CONFIG_USB_MAX_POWER=50
CONFIG_USB_WORKQUEUE=y
CONFIG_USB_WORKQUEUE_STACK_SIZE=1024
CONFIG_USB_WORKQUEUE_PRIORITY=-1
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=y
# USB CDC ACM Class support
CONFIG_USB_CDC_ACM=y
CONFIG_USB_CDC_ACM_RINGBUF_SIZE=1024
CONFIG_CDC_ACM_INTERRUPT_EP_MPS=16
CONFIG_CDC_ACM_BULK_EP_MPS=64
CONFIG_CDC_ACM_TX_DELAY_MS=100
CONFIG_CDC_ACM_IAD=y
# CONFIG_CDC_ACM_DTE_RATE_CALLBACK_SUPPORT is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_OFF is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_ERR is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_WRN is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_INF is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_DBG is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL_DEFAULT=y
CONFIG_USB_CDC_ACM_LOG_LEVEL=0
# end of USB CDC ACM Class support
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_DEVICE_BLUETOOTH is not set
# CONFIG_USB_DEVICE_BT_H4 is not set
# CONFIG_USB_DEVICE_LOOPBACK is not set
# USB Device Networking support
# CONFIG_USB_DEVICE_NETWORK_ECM is not set
# CONFIG_USB_DEVICE_NETWORK_EEM is not set
# CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
# end of USB Device Networking support
# CONFIG_USB_DEVICE_HID is not set
# CONFIG_USB_DEVICE_AUDIO is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# CONFIG_MODULES is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_ROM_END_OFFSET=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_ITERABLE_SUBALIGN=4
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# CONFIG_STD_C17 is not set
# CONFIG_STD_C23 is not set
CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
# CONFIG_GNU_C_EXTENSIONS is not set
# CONFIG_CODING_GUIDELINE_CHECK is not set
CONFIG_COMPILER_FREESTANDING=y
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
CONFIG_FORTIFY_SOURCE_NONE=y
# CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
CONFIG_BUILD_OUTPUT_META=y
# CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_DEPRECATED=y
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
# end of Compatibility
.config file for app
# Connectivity Bridge
CONFIG_APP_PAYLOAD_CHANNEL_BUFFER_MAX_SIZE=128
CONFIG_APP_SHELL=y
CONFIG_APP_SHELL_THREAD_STACK_SIZE=1024
CONFIG_APP_SHELL_WATCHDOG_TIMEOUT_SECONDS=120
CONFIG_APP_SHELL_EXEC_TIME_SECONDS_MAX=3
CONFIG_APP_SHELL_UART_PM_ENABLE=y
# CONFIG_APP_SHELL_LOG_LEVEL_OFF is not set
# CONFIG_APP_SHELL_LOG_LEVEL_ERR is not set
# CONFIG_APP_SHELL_LOG_LEVEL_WRN is not set
# CONFIG_APP_SHELL_LOG_LEVEL_INF is not set
CONFIG_APP_SHELL_LOG_LEVEL_DBG=y
# CONFIG_APP_SHELL_LOG_LEVEL_DEFAULT is not set
CONFIG_APP_SHELL_LOG_LEVEL=4
# SMP Server
CONFIG_APP_SMP_SERVER_THREAD_STACK_SIZE=1024
CONFIG_APP_SMP_SERVER_WATCHDOG_TIMEOUT_SECONDS=120
CONFIG_APP_SMP_SERVER_EXEC_TIME_SECONDS_MAX=3
# CONFIG_APP_SMP_SERVER_LOG_LEVEL_OFF is not set
# CONFIG_APP_SMP_SERVER_LOG_LEVEL_ERR is not set
# CONFIG_APP_SMP_SERVER_LOG_LEVEL_WRN is not set
# CONFIG_APP_SMP_SERVER_LOG_LEVEL_INF is not set
CONFIG_APP_SMP_SERVER_LOG_LEVEL_DBG=y
# CONFIG_APP_SMP_SERVER_LOG_LEVEL_DEFAULT is not set
CONFIG_APP_SMP_SERVER_LOG_LEVEL=4
# end of SMP Server
# Trigger
CONFIG_APP_TRIGGER_TIMEOUT_SECONDS=3600
CONFIG_FREQUENT_POLL_DURATION_INTERVAL_SEC=600
# CONFIG_APP_TRIGGER_LOG_LEVEL_OFF is not set
# CONFIG_APP_TRIGGER_LOG_LEVEL_ERR is not set
# CONFIG_APP_TRIGGER_LOG_LEVEL_WRN is not set
# CONFIG_APP_TRIGGER_LOG_LEVEL_INF is not set
CONFIG_APP_TRIGGER_LOG_LEVEL_DBG=y
# CONFIG_APP_TRIGGER_LOG_LEVEL_DEFAULT is not set
CONFIG_APP_TRIGGER_LOG_LEVEL=4
# end of Trigger
# Uart Bridge
CONFIG_APP_UART_BRIDGE_THREAD_STACK_SIZE=1024
CONFIG_APP_UART_BRIDGE_WATCHDOG_TIMEOUT_SECONDS=120
CONFIG_APP_UART_BRIDGE_EXEC_TIME_SECONDS_MAX=3
# CONFIG_APP_UART_BRIDGE_LOG_LEVEL_OFF is not set
# CONFIG_APP_UART_BRIDGE_LOG_LEVEL_ERR is not set
# CONFIG_APP_UART_BRIDGE_LOG_LEVEL_WRN is not set
# CONFIG_APP_UART_BRIDGE_LOG_LEVEL_INF is not set
CONFIG_APP_UART_BRIDGE_LOG_LEVEL_DBG=y
# CONFIG_APP_UART_BRIDGE_LOG_LEVEL_DEFAULT is not set
CONFIG_APP_UART_BRIDGE_LOG_LEVEL=4
# end of Uart Bridge
# end of Connectivity Bridge
# Zephyr Kernel
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_MIPI_DSI is not set
CONFIG_SERIAL=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_I2C is not set
# CONFIG_SPI is not set
# CONFIG_MODEM is not set
# CONFIG_BT_SPI is not set
CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
CONFIG_BT_HCI_VS=y
CONFIG_FLASH_LOAD_SIZE=0x40000
CONFIG_FLASH_LOAD_OFFSET=0x10000
CONFIG_HW_STACK_PROTECTION=y
CONFIG_SECURE_BOOT=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_SB_SIGNING_KEY_FILE="/home/guseve/vinnter/vinnter-embedded/nrf/boards/nordic/thingy91x/nsib_signing_key_nrf5340.pem"
CONFIG_GPIO_HOGS=y
CONFIG_NFCT_PINS_AS_GPIOS=y
CONFIG_SRAM_SIZE=448
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MBOX_NRFX_IPC=y
# CONFIG_BT_CTLR is not set
CONFIG_USE_SEGGER_RTT=y
CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
CONFIG_REGULATOR=y
CONFIG_MFD_NPM6001_INIT_PRIORITY=87
CONFIG_REGULATOR_NPM6001_INIT_PRIORITY=88
CONFIG_WIFI_INIT_PRIORITY=89
CONFIG_GPIO_HOGS_INIT_PRIORITY=86
CONFIG_NUM_IRQS=69
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_SOC_RESET_HOOK=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
CONFIG_PINCTRL=y
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_XIP=y
CONFIG_MAIN_STACK_SIZE=16384
CONFIG_IDLE_STACK_SIZE=320
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_TASK_WDT_HW_FALLBACK_DELAY=20
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_COUNTER is not set
# CONFIG_SHARED_INTERRUPTS is not set
CONFIG_PM_DEVICE=y
CONFIG_TICKLESS_KERNEL=y
# CONFIG_FPU is not set
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
# CONFIG_BT_USER_PHY_UPDATE is not set
CONFIG_CLOCK_CONTROL=y
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_USE_DT_CODE_PARTITION=y
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_ISR_TABLES=y
CONFIG_INIT_STACKS=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_PM_DEVICE_SYSTEM_MANAGED=y
CONFIG_FLASH_FILL_BUFFER_SIZE=32
# CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
# CONFIG_HCI_NXP_SET_CAL_DATA is not set
# CONFIG_MFD is not set
CONFIG_GPIO=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
CONFIG_TINYCRYPT=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
# CONFIG_MBEDTLS is not set
# CONFIG_MEMC is not set
CONFIG_KERNEL_ENTRY="__start"
# CONFIG_CACHE is not set
CONFIG_LOG=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_ROMSTART_RELOCATION_ROM is not set
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_SOC="nrf5340"
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_NRF_RTC_TIMER=y
CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y
CONFIG_LOG_DOMAIN_NAME=""
CONFIG_ASSERT=y
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_PM_DEVICE_POWER_DOMAIN=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
# CONFIG_SYSCON is not set
CONFIG_SERIAL_INIT_PRIORITY=50
CONFIG_SOC_SERIES="nrf53"
CONFIG_SOC_FAMILY="nordic_nrf"
# CONFIG_INTC_MTK_ADSP is not set
# CONFIG_MTK_ADSP_TIMER is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_REBOOT=y
CONFIG_FLASH_INIT_PRIORITY=50
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_SRAM_OFFSET=0
# CONFIG_POWER_DOMAIN is not set
CONFIG_CONSOLE=y
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_ISR_STACK_SIZE=2048
# CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
# CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
# CONFIG_SCHED_CPU_MASK is not set
# CONFIG_WATCHDOG is not set
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_BT_BUF_ACL_TX_COUNT=10
CONFIG_BT_BUF_CMD_TX_SIZE=65
CONFIG_BT_BUF_EVT_RX_SIZE=68
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_L2CAP_TX_MTU=247
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53X_REGULATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
CONFIG_DT_HAS_SEGGER_RTT_UART_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_IPC_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_MEMORY_REGION_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_RAM_DISK_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_RETAINED_RAM_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_RETENTION_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_SWDP_GPIO_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# gateway_firmware (/home/guseve/vinnter/vinnter-embedded/gateway_firmware)
# Drivers
# end of Drivers
CONFIG_ZEPHYR_GATEWAY_FIRMWARE_MODULE=y
# end of gateway_firmware (/home/guseve/vinnter/vinnter-embedded/gateway_firmware)
# nrf (/home/guseve/vinnter/vinnter-embedded/nrf)
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_MPSL_WORK_STACK_SIZE=1024
# Nordic nRF Connect
CONFIG_HIDE_CHILD_PARENT_CONFIG=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=1024
CONFIG_BT_BUF_CMD_TX_COUNT=10
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_GETOPT is not set
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# CONFIG_NRF70_RADIO_TEST_COMBO is not set
CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE=y
CONFIG_NCS_SAMPLE_HCI_IPC_CHILD_IMAGE=y
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set
# CONFIG_IMG_ERASE_PROGRESSIVELY is not set
# CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS is not set
# CONFIG_MCUMGR_GRP_ZBASIC is not set
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
# Subsystems
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
CONFIG_BOOTLOADER_PROVISION_HEX=y
CONFIG_SB_PRIVATE_KEY_PROVIDED=y
CONFIG_SB_SIGNING_PYTHON=y
# CONFIG_SB_SIGNING_OPENSSL is not set
# CONFIG_SB_SIGNING_CUSTOM is not set
CONFIG_SB_SIGNING_COMMAND=""
CONFIG_SB_SIGNING_PUBLIC_KEY=""
CONFIG_SB_PUBLIC_KEY_FILES=""
# CONFIG_SB_DEBUG_SIGNATURE_PUBLIC_KEY_LAST is not set
CONFIG_SB_MONOTONIC_COUNTER=y
CONFIG_SB_NUM_VER_COUNTER_SLOTS=20
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_IS_SECURE_BOOTLOADER is not set
# CONFIG_NRF53_ENFORCE_IMAGE_VERSION_EQUALITY is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
CONFIG_SECURE_BOOT_STORAGE=y
# CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_BT_COMPANY_ID_NORDIC=0x0059
CONFIG_BT_COMPANY_ID=0x0059
CONFIG_BT_MAX_CONN=1
CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
CONFIG_BT_HCI_TX_STACK_SIZE=1024
CONFIG_BT_RX_STACK_SIZE=1200
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
# CONFIG_BT_GATT_DM is not set
# CONFIG_BT_ADV_PROV is not set
# CONFIG_BT_CONN_CTX is not set
# Bluetooth Services
CONFIG_BT_NRF_SERVICES=y
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
# CONFIG_BT_BMS is not set
# CONFIG_BT_CTS_CLIENT is not set
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
# CONFIG_BT_LBS is not set
# CONFIG_BT_NSMS is not set
CONFIG_BT_NUS=y
# CONFIG_BT_NUS_AUTHEN is not set
# CONFIG_BT_NUS_LOG_LEVEL_OFF is not set
# CONFIG_BT_NUS_LOG_LEVEL_ERR is not set
# CONFIG_BT_NUS_LOG_LEVEL_WRN is not set
# CONFIG_BT_NUS_LOG_LEVEL_INF is not set
# CONFIG_BT_NUS_LOG_LEVEL_DBG is not set
CONFIG_BT_NUS_LOG_LEVEL_DEFAULT=y
CONFIG_BT_NUS_LOG_LEVEL=3
# CONFIG_BT_NUS_CLIENT is not set
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
CONFIG_BT_GATT_AUTO_SEC_REQ=y
# end of Bluetooth Services
# BLE over nRF RPC
# CONFIG_BT_RPC is not set
CONFIG_BT_DRIVERS=y
# CONFIG_BT_RPC_STACK is not set
# CONFIG_BT_CENTRAL is not set
CONFIG_BT_PERIPHERAL=y
# CONFIG_BT_OBSERVER is not set
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CONN=y
# CONFIG_BT_REMOTE_VERSION is not set
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_DATA_LEN_UPDATE=y
# CONFIG_BT_EXT_ADV is not set
CONFIG_BT_LOG=y
# CONFIG_BT_LOG_LEVEL_OFF is not set
# CONFIG_BT_LOG_LEVEL_ERR is not set
# CONFIG_BT_LOG_LEVEL_WRN is not set
# CONFIG_BT_LOG_LEVEL_INF is not set
# CONFIG_BT_LOG_LEVEL_DBG is not set
CONFIG_BT_LOG_LEVEL_DEFAULT=y
CONFIG_BT_LOG_LEVEL=3
CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
# CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
CONFIG_BT_RPA_LOG_LEVEL=3
# CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
# CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
# CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
# CONFIG_BT_RPA_LOG_LEVEL_INF is not set
# CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
# CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
CONFIG_BT_CRYPTO_LOG_LEVEL=3
# CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
# CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
CONFIG_BT_ATT_LOG_LEVEL=3
# CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
# CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
# CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
# CONFIG_BT_ATT_LOG_LEVEL_INF is not set
# CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
# CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
CONFIG_BT_GATT_LOG_LEVEL=3
# CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
# CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
# CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
# CONFIG_BT_GATT_LOG_LEVEL_INF is not set
# CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
# CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
CONFIG_BT_L2CAP_LOG_LEVEL=3
# CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
# CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
CONFIG_BT_HCI_CORE_LOG_LEVEL=3
# CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
# CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
CONFIG_BT_CONN_LOG_LEVEL=3
# CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
# CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
# CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
# CONFIG_BT_CONN_LOG_LEVEL_INF is not set
# CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
# CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
CONFIG_BT_KEYS_LOG_LEVEL=3
# CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
# CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
# CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
# CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
# CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
# CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
CONFIG_BT_SMP_LOG_LEVEL=3
# CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
# CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
# CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
# CONFIG_BT_SMP_LOG_LEVEL_INF is not set
# CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
# CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set
CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
CONFIG_BT_SERVICE_LOG_LEVEL=3
# CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
# CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
# CONFIG_BT_DIS is not set
# CONFIG_BT_CTS is not set
# CONFIG_BT_HRS is not set
# CONFIG_BT_TPS is not set
# CONFIG_BT_ZEPHYR_NUS is not set
# CONFIG_BT_IAS is not set
# CONFIG_BT_IAS_CLIENT is not set
# CONFIG_BT_OTS is not set
# CONFIG_BT_OTS_CLIENT is not set
# CONFIG_BT_BAS is not set
# CONFIG_BT_BAS_BLS is not set
CONFIG_BT_BUF_ACL_RX_COUNT=6
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
CONFIG_BT_HAS_HCI_VS=y
# CONFIG_BT_HCI_VS_FATAL_ERROR is not set
# CONFIG_BT_HCI_VS_EXT_DETECT is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_RPA=y
CONFIG_BT_ASSERT=y
CONFIG_BT_ASSERT_VERBOSE=y
# CONFIG_BT_ASSERT_PANIC is not set
# CONFIG_BT_HCI_ERR_TO_STR is not set
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_DEBUG_MONITOR_RTT is not set
CONFIG_BT_LONG_WQ=y
CONFIG_BT_LONG_WQ_STACK_SIZE=1300
CONFIG_BT_LONG_WQ_PRIO=10
CONFIG_BT_LONG_WQ_INIT_PRIO=50
CONFIG_BT_HCI_HOST=y
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
# CONFIG_BT_AUDIO is not set
CONFIG_BT_HOST_CRYPTO=y
CONFIG_BT_HOST_CRYPTO_PRNG=y
# CONFIG_BT_SETTINGS is not set
# CONFIG_BT_FILTER_ACCEPT_LIST is not set
CONFIG_BT_LIM_ADV_TIMEOUT=30
CONFIG_BT_CONN_TX_USER_DATA_SIZE=16
CONFIG_BT_CONN_FRAG_COUNT=1
CONFIG_BT_CONN_TX_MAX=10
# CONFIG_BT_CONN_PARAM_ANY is not set
CONFIG_BT_AUTO_PHY_UPDATE=y
# CONFIG_BT_USER_DATA_LEN_UPDATE is not set
CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
# CONFIG_BT_REMOTE_INFO is not set
CONFIG_BT_SMP=y
# CONFIG_BT_SECURITY_ERR_TO_STR is not set
# CONFIG_BT_SMP_ERR_TO_STR is not set
# CONFIG_BT_PASSKEY_KEYPRESS is not set
# CONFIG_BT_PRIVACY is not set
# CONFIG_BT_SIGNING is not set
# CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
# CONFIG_BT_SMP_SC_PAIR_ONLY is not set
# CONFIG_BT_SMP_SC_ONLY is not set
# CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
# CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
# CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set
# CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_FIXED_PASSKEY is not set
# CONFIG_BT_USE_DEBUG_KEYS is not set
# CONFIG_BT_BONDABLE is not set
# CONFIG_BT_BONDABLE_PER_CONNECTION is not set
# CONFIG_BT_STORE_DEBUG_KEYS is not set
CONFIG_BT_SMP_ENFORCE_MITM=y
# CONFIG_BT_KEYS_OVERWRITE_OLDEST is not set
CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7
CONFIG_BT_L2CAP_TX_BUF_COUNT=10
CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
# CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set
# CONFIG_BT_L2CAP_SEG_RECV is not set
# CONFIG_BT_ATT_ERR_TO_STR is not set
CONFIG_BT_ATT_TX_COUNT=10
CONFIG_BT_ATT_PREPARE_COUNT=0
CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
# CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set
CONFIG_BT_GATT_AUTO_RESUBSCRIBE=y
CONFIG_BT_GATT_SERVICE_CHANGED=y
# CONFIG_BT_GATT_DYNAMIC_DB is not set
CONFIG_BT_GATT_CACHING=y
# CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
# CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_READ_MULTIPLE=y
CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
# CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
# CONFIG_BT_GATT_AUTO_UPDATE_MTU is not set
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=6
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=16
CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=y
CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT=y
# CONFIG_DEVICE_NAME_GATT_WRITABLE_AUTHEN is not set
# CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_CREATE_CONN_TIMEOUT=3
CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_DEVICE_NAME_MAX=28
CONFIG_BT_DEVICE_NAME="Thingy:91 X UART"
# CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_ID_MAX=1
# CONFIG_BT_DF is not set
CONFIG_BT_ECC=y
# CONFIG_BT_TINYCRYPT_ECC is not set
# CONFIG_BT_HOST_CCM is not set
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_CLASSIC is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
CONFIG_BT_CRYPTO=y
# CONFIG_BT_SHELL is not set
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# CONFIG_EMDS is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Transport
# CONFIG_NRF_CLOUD_REST is not set
# end of Transport
# Credentials
CONFIG_NRF_CLOUD_SEC_TAG=16842753
CONFIG_NRF_CLOUD_AWS_CA_CERT_SIZE_THRESHOLD=1150
CONFIG_NRF_CLOUD_COAP_CA_CERT_SIZE_THRESHOLD=550
# end of Credentials
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_HW_ID is not set
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_RUNTIME is not set
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# Firmware Over-the-Air (FOTA) Updates
# CONFIG_NRF_CLOUD_FOTA is not set
CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_FOTA_SMP is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_FOTA_LOG_LEVEL=3
# end of Firmware Over-the-Air (FOTA) Updates
# Location
# Cellular/Wi-Fi
# CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
# CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_ONLY is not set
CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_MAC_RSSI=y
# CONFIG_NRF_CLOUD_WIFI_LOCATION_ENCODE_OPT_ALL is not set
# end of Cellular/Wi-Fi
# end of Location
# Alerts
# CONFIG_NRF_CLOUD_ALERT is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
# end of Alerts
# Logging
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
# end of Logging
# Device Shadow
# Send shadow info sections on initial connect (MQTT/CoAP)
# end of Send shadow info sections on initial connect (MQTT/CoAP)
# end of Device Shadow
CONFIG_NRF_CLOUD_PRINT_DETAILS=y
CONFIG_NRF_CLOUD_VERBOSE_DETAILS=y
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_PROVISIONING is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# CONFIG_OPENTHREAD_RPC is not set
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# CONFIG_NFC_RPC is not set
# end of NFC
CONFIG_APP_EVENT_MANAGER=y
CONFIG_APP_EVENT_MANAGER_REBOOT_ON_EVENT_ALLOC_FAIL=y
CONFIG_APP_EVENT_MANAGER_SHOW_EVENTS=y
# CONFIG_APP_EVENT_MANAGER_SHOW_EVENT_HANDLERS is not set
# CONFIG_APP_EVENT_MANAGER_TRACE_EVENT_DATA is not set
CONFIG_APP_EVENT_MANAGER_SHELL=y
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_WRN is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_INF is not set
# CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL_DEFAULT=y
CONFIG_APP_EVENT_MANAGER_LOG_LEVEL=3
# CONFIG_APP_EVENT_MANAGER_USE_DEPRECATED_LOG_FUN is not set
CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=y
CONFIG_APP_EVENT_MANAGER_MAX_EVENT_CNT=32
# CONFIG_APP_EVENT_MANAGER_PROVIDE_EVENT_SIZE is not set
# CONFIG_APP_EVENT_MANAGER_POSTINIT_HOOK is not set
# CONFIG_APP_EVENT_MANAGER_SUBMIT_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PREPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_POSTPROCESS_HOOKS is not set
# CONFIG_APP_EVENT_MANAGER_PROFILER_TRACER is not set
# CONFIG_EVENT_MANAGER_PROXY is not set
# CONFIG_NRF_PROFILER is not set
CONFIG_FW_INFO=y
# CONFIG_FW_INFO_API is not set
CONFIG_FW_INFO_OFFSET=0x200
CONFIG_FW_INFO_FIRMWARE_VERSION=1
CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
CONFIG_FW_INFO_HARDWARE_ID=53
CONFIG_FW_INFO_VERSION=2
CONFIG_FW_INFO_CRYPTO_ID=0
CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
CONFIG_FW_INFO_MAGIC_LEN=12
CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
# CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
# CONFIG_SHELL_IPC is not set
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
CONFIG_MPSL_LOW_PRIO_IRQN=26
CONFIG_MPSL_HFCLK_LATENCY=1400
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_LOG_LEVEL_INF is not set
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_LOG_LEVEL=3
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_BASE_ADDRESS=0x20000000
CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0x4000
CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0x2000
# Zephyr subsystem configurations
CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x4000
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x80000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# Nordic-added meta types
# Nordic added alg types
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# Nordic added ECC curve types
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# CONFIG_PSA_WANT_ALG_CHACHA20 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# Nordic addded RNG configuration
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# Nordic added key types
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# end of nRF Security
# CONFIG_NET_CORE_MONITOR is not set
# Audio Modules
# CONFIG_AUDIO_MODULE_TEST is not set
CONFIG_AUDIO_MODULE_NAME_SIZE=20
# Log levels
# CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
CONFIG_AUDIO_MODULE_LOG_LEVEL=3
# end of Log levels
# end of Audio Modules
# Audio Modules
# CONFIG_AUDIO_MODULE_TEMPLATE is not set
# CONFIG_UART_ASYNC_ADAPTER is not set
# CONFIG_TRUSTED_STORAGE is not set
# Logging over RPC
# CONFIG_LOG_FORWARDER_RPC is not set
# CONFIG_LOG_BACKEND_RPC is not set
# end of Logging over RPC
# SUIT provisioning
# CONFIG_SUIT_MPI_GENERATE is not set
# end of SUIT provisioning
# CONFIG_SUIT is not set
# CONFIG_DULT is not set
# CONFIG_NRF_COMPRESS is not set
# MCUboot IDs (informative only, do not change)
CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=1
CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
# end of MCUboot IDs (informative only, do not change)
# end of Subsystems
# CONFIG_HW_ID_LIBRARY_SOURCE_IMEI is not set
# CONFIG_HW_ID_LIBRARY_SOURCE_NET_MAC is not set
# CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
# CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
# CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
# CONFIG_WFA_QT_LOG_LEVEL_INF is not set
# CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
CONFIG_WFA_QT_LOG_LEVEL=3
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
CONFIG_FPROTECT_BLOCK_SIZE=0x4000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10
CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y
# CONFIG_DK_LIBRARY_BUTTON_NO_ISR is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_OFF is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_ERR is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_WRN is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_INF is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_DBG is not set
CONFIG_DK_LIBRARY_LOG_LEVEL_DEFAULT=y
CONFIG_DK_LIBRARY_LOG_LEVEL=3
# CONFIG_DK_LIBRARY_SHELL is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_AT_PARSER is not set
# CONFIG_MODEM_INFO is not set
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y
CONFIG_FATAL_ERROR_LOG_LEVEL=3
# CONFIG_SMS is not set
CONFIG_DATE_TIME=y
# CONFIG_DATE_TIME_AUTO_UPDATE is not set
CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=14400
CONFIG_DATE_TIME_TOO_OLD_SECONDS=3600
CONFIG_DATE_TIME_RETRY_COUNT=0
CONFIG_DATE_TIME_RETRY_INTERVAL_SECONDS=60
# CONFIG_DATE_TIME_NTP is not set
CONFIG_DATE_TIME_THREAD_STACK_SIZE=1280
CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5
# CONFIG_DATE_TIME_LOG_LEVEL_OFF is not set
# CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set
# CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set
# CONFIG_DATE_TIME_LOG_LEVEL_INF is not set
# CONFIG_DATE_TIME_LOG_LEVEL_DBG is not set
CONFIG_DATE_TIME_LOG_LEVEL_DEFAULT=y
CONFIG_DATE_TIME_LOG_LEVEL=3
CONFIG_HW_ID_LIBRARY=y
# CONFIG_HW_ID_LIBRARY_SOURCE_BLE_MAC is not set
CONFIG_HW_ID_LIBRARY_SOURCE_DEVICE_ID=y
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
# CONFIG_MODEM_JWT is not set
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_FLASH_RPC is not set
# CONFIG_GPIO_NRFE_EGPIO_BACKEND_MBOX is not set
CONFIG_GPIO_NRFE_EGPIO_BACKEND_ICMSG=y
# CONFIG_GPIO_NRFE_EGPIO_BACKEND_ICBMSG is not set
CONFIG_HW_CC3XX=y
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# CONFIG_IPC_UART is not set
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# CONFIG_MOCK_NRF_RPC is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (/home/guseve/vinnter/vinnter-embedded/nrf)
# mcuboot (/home/guseve/vinnter/vinnter-embedded/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
# CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
# CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set
CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
# CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
# CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
# end of MCUboot
# CONFIG_XIP_SPLIT_IMAGE is not set
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (/home/guseve/vinnter/vinnter-embedded/bootloader/mcuboot)
# mbedtls (/home/guseve/vinnter/vinnter-embedded/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# end of mbedtls (/home/guseve/vinnter/vinnter-embedded/modules/crypto/mbedtls)
# oberon-psa-crypto (/home/guseve/vinnter/vinnter-embedded/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (/home/guseve/vinnter/vinnter-embedded/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (/home/guseve/vinnter/vinnter-embedded/modules/tee/tf-m/trusted-firmware-m)
CONFIG_TFM_BOARD="/home/guseve/vinnter/vinnter-embedded/zephyr/modules/trusted-firmware-m/nordic/nrf5340_cpuapp"
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (/home/guseve/vinnter/vinnter-embedded/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
# cjson (/home/guseve/vinnter/vinnter-embedded/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (/home/guseve/vinnter/vinnter-embedded/modules/lib/cjson)
# azure-sdk-for-c (/home/guseve/vinnter/vinnter-embedded/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (/home/guseve/vinnter/vinnter-embedded/modules/lib/azure-sdk-for-c)
# cirrus-logic (/home/guseve/vinnter/vinnter-embedded/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (/home/guseve/vinnter/vinnter-embedded/modules/hal/cirrus-logic)
# openthread (/home/guseve/vinnter/vinnter-embedded/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (/home/guseve/vinnter/vinnter-embedded/modules/lib/openthread)
# suit-generator (/home/guseve/vinnter/vinnter-embedded/modules/lib/suit-generator)
CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
CONFIG_SUIT_ENVELOPE_TARGET=""
CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
# CONFIG_SUIT_RECOVERY is not set
CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
# CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
# CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
# end of suit-generator (/home/guseve/vinnter/vinnter-embedded/modules/lib/suit-generator)
# suit-processor (/home/guseve/vinnter/vinnter-embedded/modules/lib/suit-processor)
# CONFIG_SUIT_PROCESSOR is not set
CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
# end of suit-processor (/home/guseve/vinnter/vinnter-embedded/modules/lib/suit-processor)
# memfault-firmware-sdk (/home/guseve/vinnter/vinnter-embedded/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (/home/guseve/vinnter/vinnter-embedded/modules/lib/memfault-firmware-sdk)
# coremark (/home/guseve/vinnter/vinnter-embedded/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (/home/guseve/vinnter/vinnter-embedded/modules/benchmark/coremark)
# canopennode (/home/guseve/vinnter/vinnter-embedded/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (/home/guseve/vinnter/vinnter-embedded/modules/lib/canopennode)
# chre (/home/guseve/vinnter/vinnter-embedded/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (/home/guseve/vinnter/vinnter-embedded/modules/lib/chre)
# lz4 (/home/guseve/vinnter/vinnter-embedded/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (/home/guseve/vinnter/vinnter-embedded/modules/lib/lz4)
# nanopb (/home/guseve/vinnter/vinnter-embedded/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (/home/guseve/vinnter/vinnter-embedded/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (/home/guseve/vinnter/vinnter-embedded/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (/home/guseve/vinnter/vinnter-embedded/modules/lib/zscilib)
# cmsis (/home/guseve/vinnter/vinnter-embedded/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis (/home/guseve/vinnter/vinnter-embedded/modules/hal/cmsis)
# cmsis-dsp (/home/guseve/vinnter/vinnter-embedded/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (/home/guseve/vinnter/vinnter-embedded/modules/lib/cmsis-dsp)
# cmsis-nn (/home/guseve/vinnter/vinnter-embedded/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (/home/guseve/vinnter/vinnter-embedded/modules/lib/cmsis-nn)
# fatfs (/home/guseve/vinnter/vinnter-embedded/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (/home/guseve/vinnter/vinnter-embedded/modules/fs/fatfs)
# hal_nordic (/home/guseve/vinnter/vinnter-embedded/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_HOST is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# nrfx drivers logging
# CONFIG_NRFX_CLOCK_LOG is not set
# CONFIG_NRFX_DPPI_LOG is not set
# CONFIG_NRFX_GPIOTE_LOG is not set
# CONFIG_NRFX_IPC_LOG is not set
# CONFIG_NRFX_NVMC_LOG is not set
# CONFIG_NRFX_POWER_LOG is not set
# CONFIG_NRFX_USBREG_LOG is not set
# end of nrfx drivers logging
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_COMP is not set
CONFIG_NRFX_DPPI=y
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE0=y
# CONFIG_NRFX_GPIOTE1 is not set
# CONFIG_NRFX_I2S0 is not set
CONFIG_NRFX_IPC=y
# CONFIG_NRFX_NFCT is not set
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM0 is not set
CONFIG_NRFX_POWER=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC0 is not set
# CONFIG_NRFX_QDEC1 is not set
# CONFIG_NRFX_QSPI is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SPIM4 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_TWIM2 is not set
# CONFIG_NRFX_TWIM3 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_UARTE2 is not set
# CONFIG_NRFX_UARTE3 is not set
CONFIG_NRFX_USBREG=y
# CONFIG_NRFX_WDT0 is not set
# CONFIG_NRFX_WDT1 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of hal_nordic (/home/guseve/vinnter/vinnter-embedded/modules/hal/nordic)
# hal_st (/home/guseve/vinnter/vinnter-embedded/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (/home/guseve/vinnter/vinnter-embedded/modules/hal/st)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
# hostap (/home/guseve/vinnter/vinnter-embedded/modules/lib/hostap)
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (/home/guseve/vinnter/vinnter-embedded/modules/lib/hostap)
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# liblc3 (/home/guseve/vinnter/vinnter-embedded/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (/home/guseve/vinnter/vinnter-embedded/modules/lib/liblc3)
# littlefs (/home/guseve/vinnter/vinnter-embedded/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (/home/guseve/vinnter/vinnter-embedded/modules/fs/littlefs)
# loramac-node (/home/guseve/vinnter/vinnter-embedded/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (/home/guseve/vinnter/vinnter-embedded/modules/lib/loramac-node)
# lvgl (/home/guseve/vinnter/vinnter-embedded/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (/home/guseve/vinnter/vinnter-embedded/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# picolibc (/home/guseve/vinnter/vinnter-embedded/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (/home/guseve/vinnter/vinnter-embedded/modules/lib/picolibc)
# segger (/home/guseve/vinnter/vinnter-embedded/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=8192
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
# CONFIG_SEGGER_RTT_SECTION_NONE is not set
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# CONFIG_SEGGER_RTT_SECTION_CCM is not set
CONFIG_SEGGER_RTT_SECTION_CUSTOM=y
# CONFIG_SEGGER_RTT_SECTION_CUSTOM_DTS_REGION is not set
CONFIG_SEGGER_RTT_SECTION_CUSTOM_NAME=".rtt_buff_data"
# CONFIG_SEGGER_RTT_INIT_MODE_ALWAYS is not set
CONFIG_SEGGER_RTT_INIT_MODE_STRONG_CHECK=y
# CONFIG_SEGGER_RTT_INIT_MODE_WEAK_CHECK is not set
# end of segger (/home/guseve/vinnter/vinnter-embedded/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (/home/guseve/vinnter/vinnter-embedded/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (/home/guseve/vinnter/vinnter-embedded/modules/lib/uoscore-uedhoc)
# zcbor (/home/guseve/vinnter/vinnter-embedded/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
CONFIG_ZCBOR=y
# CONFIG_ZCBOR_CANONICAL is not set
# CONFIG_ZCBOR_STOP_ON_ERROR is not set
# CONFIG_ZCBOR_VERBOSE is not set
CONFIG_ZCBOR_ASSERT=y
CONFIG_ZCBOR_MAX_STR_LEN=256
# end of zcbor (/home/guseve/vinnter/vinnter-embedded/modules/lib/zcbor)
# nrfxlib (/home/guseve/vinnter/vinnter-embedded/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# end of nrf_modem (Modem library)
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_HAS_HW_NRF_CC3XX=y
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
CONFIG_NRF_CC3XX_PLATFORM=y
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# CONFIG_CC3XX_HW_MUTEX_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (/home/guseve/vinnter/vinnter-embedded/nrfxlib)
# connectedhomeip (/home/guseve/vinnter/vinnter-embedded/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (/home/guseve/vinnter/vinnter-embedded/modules/lib/matter)
CONFIG_LIBMETAL=y
CONFIG_LIBMETAL_SRC_PATH="libmetal"
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
CONFIG_OPENAMP=y
CONFIG_OPENAMP_SRC_PATH="open-amp"
CONFIG_OPENAMP_MASTER=y
CONFIG_OPENAMP_SLAVE=y
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCRYPT_CTR_PRNG is not set
CONFIG_TINYCRYPT_SHA256=y
CONFIG_TINYCRYPT_SHA256_HMAC=y
CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
# CONFIG_TINYCRYPT_ECC_DH is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
CONFIG_TINYCRYPT_AES=y
# CONFIG_TINYCRYPT_AES_CBC is not set
# CONFIG_TINYCRYPT_AES_CTR is not set
# CONFIG_TINYCRYPT_AES_CCM is not set
CONFIG_TINYCRYPT_AES_CMAC=y
CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS="--quiet"
CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="/home/guseve/vinnter/vinnter-embedded/bootloader/mcuboot/root-ec-p256.pem"
CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE=""
CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="0.0.0+0"
# CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY is not set
CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
# On board MCUboot operation mode
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set
CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
# CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
# end of On board MCUboot operation mode
CONFIG_MCUBOOT_BOOTUTIL_LIB=y
CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
# CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y
CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="thingy91x"
CONFIG_BOARD_REVISION=""
CONFIG_BOARD_TARGET="thingy91x/nrf5340/cpuapp"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_THINGY91X=y
CONFIG_BOARD_THINGY91X_NRF5340_CPUAPP=y
CONFIG_BOARD_QUALIFIERS="nrf5340/cpuapp"
# Board Options
# CONFIG_BOARD_LOG_LEVEL_OFF is not set
# CONFIG_BOARD_LOG_LEVEL_ERR is not set
# CONFIG_BOARD_LOG_LEVEL_WRN is not set
# CONFIG_BOARD_LOG_LEVEL_INF is not set
# CONFIG_BOARD_LOG_LEVEL_DBG is not set
CONFIG_BOARD_LOG_LEVEL_DEFAULT=y
CONFIG_BOARD_LOG_LEVEL=3
CONFIG_BOARD_ENABLE_DCDC_APP=y
CONFIG_BOARD_ENABLE_DCDC_NET=y
# end of Board Options
# Hardware Configuration
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF53X=y
CONFIG_SOC_NRF5340_CPUAPP=y
CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_HAS_HW_NRF_CC312=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_CTRLAP=y
CONFIG_HAS_HW_NRF_DCNF=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_KMU=y
CONFIG_HAS_HW_NRF_MUTEX=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_OSCILLATORS=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_RESET=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPU=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_UARTE1=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_USBREG=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_HW_NRF_WDT0=y
# CONFIG_NRF_SYS_EVENT is not set
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
# CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
CONFIG_SOC_NRF53_RTC_PRETICK=y
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
CONFIG_SOC_DCDC_NRF53X_APP=y
CONFIG_SOC_DCDC_NRF53X_NET=y
CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
CONFIG_SOC_NRF_GPIO_FORWARDER_FOR_NRF5340=y
CONFIG_SOC_NRF53_CPUNET_MGMT=y
# CONFIG_SOC_NRF53_CPUNET_ENABLE is not set
# CONFIG_BOARD_ENABLE_CPUNET is not set
CONFIG_SOC_ENABLE_LFXO=y
# CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
# CONFIG_SOC_LFXO_CAP_INT_6PF is not set
CONFIG_SOC_LFXO_CAP_INT_7PF=y
# CONFIG_SOC_LFXO_CAP_INT_9PF is not set
CONFIG_SOC_HFXO_CAP_DEFAULT=y
# CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
# CONFIG_SOC_HFXO_CAP_INTERNAL is not set
CONFIG_NRF_ENABLE_CACHE=y
CONFIG_NRF53_SYNC_RTC=y
# CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_INF is not set
# CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set
CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT=y
CONFIG_SYNC_RTC_LOG_LEVEL=3
CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1
CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y
CONFIG_NRF53_SYNC_RTC_IPM_OUT=7
CONFIG_NRF53_SYNC_RTC_IPM_IN=8
CONFIG_IPM_MSG_CH_8_ENABLE=y
CONFIG_IPM_MSG_CH_8_RX=y
# CONFIG_SOC_NRF54H20_GPD is not set
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_APPROTECT_USER_HANDLING is not set
CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
# CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
# CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
# CONFIG_NRF_TRACE_PORT is not set
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
# CONFIG_SOC_LOG_LEVEL_INF is not set
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL_DEFAULT=y
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF53X=y
CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
CONFIG_ARCH="arm"
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_CPU_CORTEX=y
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# ARM Options
CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
CONFIG_ARM_ON_EXIT_CPU_IDLE=y
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
# CONFIG_PLATFORM_SPECIFIC_INIT is not set
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_ARMV8_M_DSP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_ARM_TRUSTZONE_M=y
# CONFIG_MPU_STACK_GUARD is not set
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_CPU_HAS_NRF_IDAU=y
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
# CONFIG_ISR_TABLE_SHELL is not set
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
# CONFIG_ARCH_LOG_LEVEL_INF is not set
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
# CONFIG_TRUSTED_EXECUTION_SECURE is not set
# CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# CONFIG_FRAME_POINTER is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_TEE=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
# CONFIG_MPU_LOG_LEVEL_INF is not set
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL_DEFAULT=y
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
# CONFIG_KERNEL_LOG_LEVEL_INF is not set
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Misc Kernel related options
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_CURRENT_THREAD_USE_TLS=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
# CONFIG_BOOT_CLEAR_SCREEN is not set
CONFIG_THREAD_MONITOR=y
CONFIG_THREAD_NAME=y
CONFIG_THREAD_MAX_NAME_LEN=32
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
CONFIG_POLL=y
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
CONFIG_MP_NUM_CPUS=1
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
# CONFIG_STATIC_INIT_GNU is not set
# CONFIG_BOOTARGS is not set
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_DEPS is not set
# CONFIG_DEVICE_MUTABLE is not set
# CONFIG_DEVICE_DT_METADATA is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# end of Virtual Memory Support
# SoC and Board Hooks
# CONFIG_SOC_PREP_HOOK is not set
# CONFIG_SOC_EARLY_INIT_HOOK is not set
# CONFIG_SOC_LATE_INIT_HOOK is not set
# CONFIG_BOARD_EARLY_INIT_HOOK is not set
# CONFIG_BOARD_LATE_INIT_HOOK is not set
# end of SoC and Board Hooks
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# Bluetooth HCI Driver Options
CONFIG_BT_HCI_IPC=y
CONFIG_BT_HCI_INIT_PRIORITY=50
# CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
CONFIG_FLASH=y
CONFIG_BT_DRV_TX_STACK_SIZE=256
CONFIG_BT_DRV_RX_STACK_SIZE=256
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_SHELL is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
# CONFIG_COMPARATOR is not set
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
# CONFIG_RAM_CONSOLE is not set
# CONFIG_RTT_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
CONFIG_UART_MCUMGR=y
CONFIG_UART_MCUMGR_RX_BUF_SIZE=128
CONFIG_UART_MCUMGR_RX_BUF_COUNT=2
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_EFI_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
CONFIG_DISK_DRIVERS=y
CONFIG_DISK_DRIVER_RAM=y
# CONFIG_RAMDISK_LOG_LEVEL_OFF is not set
# CONFIG_RAMDISK_LOG_LEVEL_ERR is not set
# CONFIG_RAMDISK_LOG_LEVEL_WRN is not set
# CONFIG_RAMDISK_LOG_LEVEL_INF is not set
# CONFIG_RAMDISK_LOG_LEVEL_DBG is not set
CONFIG_RAMDISK_LOG_LEVEL_DEFAULT=y
CONFIG_RAMDISK_LOG_LEVEL=3
# CONFIG_DISK_DRIVER_LOOPBACK is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
CONFIG_DP_DRIVER=y
# CONFIG_DP_DRIVER_LOG_LEVEL_OFF is not set
# CONFIG_DP_DRIVER_LOG_LEVEL_ERR is not set
# CONFIG_DP_DRIVER_LOG_LEVEL_WRN is not set
# CONFIG_DP_DRIVER_LOG_LEVEL_INF is not set
# CONFIG_DP_DRIVER_LOG_LEVEL_DBG is not set
CONFIG_DP_DRIVER_LOG_LEVEL_DEFAULT=y
CONFIG_DP_DRIVER_LOG_LEVEL=3
CONFIG_DP_DRIVER_INIT_PRIO=80
CONFIG_SWDP_BITBANG_DRIVER=y
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
# CONFIG_ENTROPY_GENERATOR is not set
# CONFIG_ESPI is not set
# Firmware drivers
# CONFIG_ARM_SCMI is not set
# end of Firmware drivers
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
# CONFIG_FLASH_SHELL is not set
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
# CONFIG_SOC_FLASH_NRF_UICR is not set
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
# MSPI flash device driver
# end of MSPI flash device driver
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_FLASH_LOG_LEVEL_INF is not set
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
CONFIG_FLASH_LOG_LEVEL=3
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
# CONFIG_GPIO_LOG_LEVEL_INF is not set
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_SHELL is not set
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_HAPTICS is not set
CONFIG_HWINFO=y
# CONFIG_HWINFO_LOG_LEVEL_OFF is not set
# CONFIG_HWINFO_LOG_LEVEL_ERR is not set
# CONFIG_HWINFO_LOG_LEVEL_WRN is not set
# CONFIG_HWINFO_LOG_LEVEL_INF is not set
# CONFIG_HWINFO_LOG_LEVEL_DBG is not set
CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
CONFIG_HWINFO_LOG_LEVEL=3
CONFIG_HWINFO_HAS_DRIVER=y
# CONFIG_HWINFO_SHELL is not set
CONFIG_HWINFO_NRF=y
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
# CONFIG_INTC_LOG_LEVEL_INF is not set
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL_DEFAULT=y
CONFIG_INTC_LOG_LEVEL=3
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_KSCAN is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
CONFIG_MBOX=y
CONFIG_MBOX_INIT_PRIORITY=40
# CONFIG_MBOX_LOG_LEVEL_OFF is not set
# CONFIG_MBOX_LOG_LEVEL_ERR is not set
# CONFIG_MBOX_LOG_LEVEL_WRN is not set
# CONFIG_MBOX_LOG_LEVEL_INF is not set
# CONFIG_MBOX_LOG_LEVEL_DBG is not set
CONFIG_MBOX_LOG_LEVEL_DEFAULT=y
CONFIG_MBOX_LOG_LEVEL=3
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_MSPI is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
# CONFIG_PINCTRL_LOG_LEVEL_INF is not set
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
CONFIG_REGULATOR_THREAD_SAFE_REFCNT=y
# CONFIG_REGULATOR_SHELL is not set
# CONFIG_REGULATOR_LOG_LEVEL_OFF is not set
# CONFIG_REGULATOR_LOG_LEVEL_ERR is not set
# CONFIG_REGULATOR_LOG_LEVEL_WRN is not set
# CONFIG_REGULATOR_LOG_LEVEL_INF is not set
# CONFIG_REGULATOR_LOG_LEVEL_DBG is not set
CONFIG_REGULATOR_LOG_LEVEL_DEFAULT=y
CONFIG_REGULATOR_LOG_LEVEL=3
CONFIG_RETAINED_MEM=y
CONFIG_RETAINED_MEM_INIT_PRIORITY=40
CONFIG_RETAINED_MEM_MUTEXES=y
# CONFIG_RETAINED_MEM_MUTEX_FORCE_DISABLE is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_OFF is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_ERR is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_WRN is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_INF is not set
# CONFIG_RETAINED_MEM_LOG_LEVEL_DBG is not set
CONFIG_RETAINED_MEM_LOG_LEVEL_DEFAULT=y
CONFIG_RETAINED_MEM_LOG_LEVEL=3
CONFIG_RETAINED_MEM_NRF_GPREGRET=y
CONFIG_RETAINED_MEM_ZEPHYR_RAM=y
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
# CONFIG_UART_LOG_LEVEL_INF is not set
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL_DEFAULT=y
CONFIG_UART_LOG_LEVEL=3
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_ASYNC_RX_HELPER is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_NRFX_UARTE=y
CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
CONFIG_UART_0_INTERRUPT_DRIVEN=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_1_INTERRUPT_DRIVEN=y
CONFIG_UART_1_ENHANCED_POLL_OUT=y
# CONFIG_UART_1_NRF_PARITY_BIT is not set
CONFIG_UART_1_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_RTT=y
CONFIG_UART_RTT_0=y
CONFIG_UART_RTT_DRIVER=y
# CONFIG_SMBUS is not set
# CONFIG_STEPPER is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
CONFIG_USB_DEVICE_DRIVER=y
# CONFIG_USB_DC_HAS_HS_SUPPORT is not set
CONFIG_USB_DEVICE_REMOTE_WAKEUP=y
CONFIG_USB_NRFX=y
CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=1024
CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=0
# CONFIG_USB_DRIVER_LOG_LEVEL_OFF is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_ERR is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_WRN is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_INF is not set
# CONFIG_USB_DRIVER_LOG_LEVEL_DBG is not set
CONFIG_USB_DRIVER_LOG_LEVEL_DEFAULT=y
CONFIG_USB_DRIVER_LOG_LEVEL=3
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
CONFIG_NRF_USBD_COMMON=y
CONFIG_NRF_USBD_ISO_IN_ZLP=y
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
# CONFIG_USBC_LOG_LEVEL_INF is not set
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL_DEFAULT=y
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
CONFIG_SHELL_STACK_SIZE=2048
# CONFIG_TEE is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
# CONFIG_COMMON_LIBC_ASCTIME_R is not set
# CONFIG_COMMON_LIBC_CTIME_R is not set
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
CONFIG_COMMON_LIBC_REMOVE=y
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
# CONFIG_PICOLIBC_IO_FLOAT is not set
CONFIG_PICOLIBC_IO_LONG_LONG=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# end of C++ Language Support
CONFIG_CRC=y
# CONFIG_CRC_SHELL is not set
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
# CONFIG_NET_BUF_LOG_LEVEL_INF is not set
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NET_BUF_ALIGNMENT=0
# OS Support Library
# CONFIG_FDTABLE is not set
CONFIG_ZVFS_OPEN_MAX=4
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_HAS_POWEROFF=y
# CONFIG_POWEROFF is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# CONFIG_ZVFS is not set
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
CONFIG_POSIX_AEP_CHOICE_NONE=y
# CONFIG_POSIX_AEP_CHOICE_BASE is not set
# CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_BARRIERS is not set
# CONFIG_POSIX_C_LANG_SUPPORT_R is not set
CONFIG_POSIX_C_LIB_EXT=y
# CONFIG_GETOPT_LONG is not set
# POSIX device I/O
# CONFIG_POSIX_DEVICE_IO is not set
CONFIG_POSIX_OPEN_MAX=4
# end of POSIX device I/O
# CONFIG_POSIX_FD_MGMT is not set
# CONFIG_POSIX_FILE_SYSTEM is not set
# POSIX memory
CONFIG_POSIX_PAGE_SIZE=0x40
# CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
# CONFIG_POSIX_MAPPED_FILES is not set
# CONFIG_POSIX_MEMORY_PROTECTION is not set
# end of POSIX memory
# CONFIG_POSIX_MESSAGE_PASSING is not set
# CONFIG_POSIX_SINGLE_PROCESS is not set
# CONFIG_POSIX_MULTI_PROCESS is not set
# CONFIG_POSIX_THREADS is not set
# CONFIG_POSIX_READER_WRITER_LOCKS is not set
# POSIX scheduler options
# CONFIG_POSIX_PRIORITY_SCHEDULING is not set
# end of POSIX scheduler options
# CONFIG_POSIX_SEMAPHORES is not set
# POSIX signals
# CONFIG_POSIX_REALTIME_SIGNALS is not set
# CONFIG_POSIX_SIGNALS is not set
# end of POSIX signals
# CONFIG_POSIX_SPIN_LOCKS is not set
# POSIX synchronized I/O
# CONFIG_POSIX_FSYNC is not set
# CONFIG_POSIX_SYNCHRONIZED_IO is not set
# end of POSIX synchronized I/O
CONFIG_POSIX_TIMERS=y
# CONFIG_POSIX_THREAD_CPUTIME is not set
CONFIG_POSIX_MONOTONIC_CLOCK=y
CONFIG_POSIX_CPUTIME=y
CONFIG_POSIX_CLOCK_SELECTION=y
CONFIG_POSIX_DELAYTIMER_MAX=32
CONFIG_POSIX_TIMER_MAX=32
CONFIG_POSIX_TIMEOUTS=y
CONFIG_TIMER_CREATE_WAIT=100
# CONFIG_TIMER_LOG_LEVEL_OFF is not set
# CONFIG_TIMER_LOG_LEVEL_ERR is not set
# CONFIG_TIMER_LOG_LEVEL_WRN is not set
# CONFIG_TIMER_LOG_LEVEL_INF is not set
# CONFIG_TIMER_LOG_LEVEL_DBG is not set
CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
CONFIG_TIMER_LOG_LEVEL=3
# X/Open system interfaces
# CONFIG_XOPEN_STREAMS is not set
# CONFIG_XSI_SYSTEM_LOGGING is not set
# CONFIG_XSI_THREADS_EXT is not set
# end of X/Open system interfaces
# Miscellaneous POSIX-related options
# CONFIG_EVENTFD is not set
# end of Miscellaneous POSIX-related options
# Deprecated POSIX options
CONFIG_EVENTFD_MAX=0
# CONFIG_FNMATCH is not set
CONFIG_MAX_PTHREAD_COUNT=0
CONFIG_MAX_PTHREAD_KEY_COUNT=0
CONFIG_MAX_TIMER_COUNT=32
CONFIG_MSG_COUNT_MAX=0
CONFIG_POSIX_CLOCK=y
# CONFIG_POSIX_FS is not set
CONFIG_POSIX_LIMITS_RTSIG_MAX=0
CONFIG_POSIX_MAX_FDS=4
CONFIG_POSIX_MAX_OPEN_FILES=4
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_POSIX_PUTMSG is not set
# CONFIG_POSIX_SIGNAL is not set
# CONFIG_POSIX_SYSCONF is not set
# CONFIG_POSIX_UNAME is not set
# CONFIG_PTHREAD is not set
# CONFIG_PTHREAD_BARRIER is not set
# CONFIG_PTHREAD_COND is not set
# CONFIG_PTHREAD_IPC is not set
# CONFIG_PTHREAD_KEY is not set
# CONFIG_PTHREAD_MUTEX is not set
# CONFIG_PTHREAD_RWLOCK is not set
# CONFIG_PTHREAD_SPINLOCK is not set
# CONFIG_TIMER is not set
CONFIG_TIMER_DELAYTIMER_MAX=32
CONFIG_SEM_NAMELEN_MAX=0
CONFIG_SEM_VALUE_MAX=0
# end of Deprecated POSIX options
CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
# end of POSIX Options
# POSIX Shell Utilities
# CONFIG_POSIX_ENV_SHELL is not set
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
CONFIG_SMF=y
CONFIG_SMF_ANCESTOR_SUPPORT=y
CONFIG_SMF_INITIAL_TRANSITION=y
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
CONFIG_RING_BUFFER=y
CONFIG_NOTIFY=y
CONFIG_BASE64=y
CONFIG_ONOFF=y
# CONFIG_WINSTREAM is not set
# CONFIG_UTF8 is not set
# end of Utility Library
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
CONFIG_BT=y
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
# CONFIG_BT_HCI_RAW is not set
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
CONFIG_BT_CONN_TX=y
# CONFIG_BT_SCA_UPDATE is not set
# CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
# CONFIG_BT_PATH_LOSS_MONITORING is not set
# CONFIG_BT_SUBRATING is not set
# CONFIG_BT_CHANNEL_SOUNDING is not set
# CONFIG_BT_ISO_PERIPHERAL is not set
# CONFIG_BT_ISO_CENTRAL is not set
# CONFIG_BT_ISO_BROADCASTER is not set
# CONFIG_BT_ISO_SYNC_RECEIVER is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# L2CAP Options
# end of L2CAP Options
# ATT and GATT Options
# end of ATT and GATT Options
# GATT Services
# end of GATT Services
# Bluetooth Classic Options
# end of Bluetooth Classic Options
# end of Bluetooth Host
# CONFIG_BT_EAD is not set
# Bluetooth logging
# Common
# end of Common
# Libraries
# end of Libraries
# Host
# end of Host
# Services
# end of Services
# end of Bluetooth logging
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
CONFIG_DAP=y
CONFIG_CMSIS_DAP_PACKET_COUNT=4
CONFIG_CMSIS_DAP_PACKET_SIZE=64
CONFIG_CMSIS_DAP_PROBE_VENDOR="Zephyr"
CONFIG_CMSIS_DAP_PROBE_NAME="CMSIS-DAP"
CONFIG_CMSIS_DAP_BOARD_VENDOR=""
CONFIG_CMSIS_DAP_BOARD_NAME=""
CONFIG_CMSIS_DAP_DEVICE_VENDOR="Nordic Semiconductor ASA"
CONFIG_CMSIS_DAP_DEVICE_NAME="nrf91"
# CONFIG_DAP_LOG_LEVEL_OFF is not set
# CONFIG_DAP_LOG_LEVEL_ERR is not set
# CONFIG_DAP_LOG_LEVEL_WRN is not set
# CONFIG_DAP_LOG_LEVEL_INF is not set
# CONFIG_DAP_LOG_LEVEL_DBG is not set
CONFIG_DAP_LOG_LEVEL_DEFAULT=y
CONFIG_DAP_LOG_LEVEL=3
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
CONFIG_ASSERT_LEVEL=2
CONFIG_SPIN_VALIDATE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# CONFIG_SYMTAB is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_CS_TRACE_DEFMT is not set
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
# CONFIG_MCUBOOT_SHELL is not set
CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x2000
CONFIG_IMG_BLOCK_BUF_SIZE=512
# CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
# CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
CONFIG_IMG_MANAGER_LOG_LEVEL=3
CONFIG_DISK_ACCESS=y
# CONFIG_DISK_LOG_LEVEL_OFF is not set
# CONFIG_DISK_LOG_LEVEL_ERR is not set
# CONFIG_DISK_LOG_LEVEL_WRN is not set
# CONFIG_DISK_LOG_LEVEL_INF is not set
# CONFIG_DISK_LOG_LEVEL_DBG is not set
CONFIG_DISK_LOG_LEVEL_DEFAULT=y
CONFIG_DISK_LOG_LEVEL=3
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
CONFIG_FILE_SYSTEM=y
# CONFIG_FS_LOG_LEVEL_OFF is not set
# CONFIG_FS_LOG_LEVEL_ERR is not set
# CONFIG_FS_LOG_LEVEL_WRN is not set
# CONFIG_FS_LOG_LEVEL_INF is not set
# CONFIG_FS_LOG_LEVEL_DBG is not set
CONFIG_FS_LOG_LEVEL_DEFAULT=y
CONFIG_FS_LOG_LEVEL=3
CONFIG_APP_LINK_WITH_FS=y
CONFIG_FILE_SYSTEM_MAX_TYPES=2
CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1
CONFIG_FILE_SYSTEM_INIT_PRIORITY=99
# CONFIG_FILE_SYSTEM_SHELL is not set
# CONFIG_FILE_SYSTEM_MKFS is not set
CONFIG_FAT_FILESYSTEM_ELM=y
# ELM FAT file system settings
# CONFIG_FS_FATFS_READ_ONLY is not set
CONFIG_FS_FATFS_MKFS=y
CONFIG_FS_FATFS_MOUNT_MKFS=y
CONFIG_FS_FATFS_MAX_ROOT_ENTRIES=512
# CONFIG_FS_FATFS_EXFAT is not set
CONFIG_FS_FATFS_NUM_FILES=4
CONFIG_FS_FATFS_NUM_DIRS=4
CONFIG_FS_FATFS_LFN=y
CONFIG_FS_FATFS_LFN_MODE_BSS=y
# CONFIG_FS_FATFS_LFN_MODE_STACK is not set
# CONFIG_FS_FATFS_LFN_MODE_HEAP is not set
CONFIG_FS_FATFS_FF_USE_LFN=1
CONFIG_FS_FATFS_MAX_LFN=255
CONFIG_FS_FATFS_CODEPAGE=437
CONFIG_FS_FATFS_MAX_SS=512
CONFIG_FS_FATFS_MIN_SS=512
CONFIG_FS_FATFS_WINDOW_ALIGNMENT=1
# CONFIG_FS_FATFS_MULTI_PARTITION is not set
# end of ELM FAT file system settings
# CONFIG_FILE_SYSTEM_LITTLEFS is not set
# CONFIG_FILE_SYSTEM_EXT2 is not set
# CONFIG_EXT2_LOG_LEVEL_OFF is not set
# CONFIG_EXT2_LOG_LEVEL_ERR is not set
# CONFIG_EXT2_LOG_LEVEL_WRN is not set
# CONFIG_EXT2_LOG_LEVEL_INF is not set
# CONFIG_EXT2_LOG_LEVEL_DBG is not set
CONFIG_EXT2_LOG_LEVEL_DEFAULT=y
CONFIG_EXT2_LOG_LEVEL=3
CONFIG_FCB=y
# CONFIG_FCB_ALLOW_FIXED_ENDMARKER is not set
# CONFIG_NVS is not set
# CONFIG_ZMS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
CONFIG_IPC_SERVICE=y
CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
CONFIG_IPC_SERVICE_RPMSG=y
CONFIG_IPC_SERVICE_STATIC_VRINGS=y
CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
# CONFIG_IPC_SERVICE_ICMSG is not set
# CONFIG_IPC_SERVICE_ICMSG_ME is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_INF is not set
# CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set
CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT=y
CONFIG_IPC_SERVICE_LOG_LEVEL=3
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# Linkable loadable Extension Development Kit (EDK)
CONFIG_LLEXT_EDK_NAME="llext-edk"
# CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
# end of Linkable loadable Extension Development Kit (EDK)
# Logging
CONFIG_LOG_CORE_INIT_PRIORITY=0
CONFIG_LOG_MODE_DEFERRED=y
# CONFIG_LOG_MODE_IMMEDIATE is not set
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_FRONTEND_OPT_API is not set
# CONFIG_LOG_CUSTOM_HEADER is not set
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
CONFIG_LOG_RUNTIME_FILTERING=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_BLOCK_IN_THREAD is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
# CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# CONFIG_LOG_TIMESTAMP_USE_REALTIME is not set
# CONFIG_LOG_SPEED is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_THREAD_ID_PREFIX is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
# CONFIG_LOG_DBG_COLOR_BLUE is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
# end of Output Formatting
# Backends
# CONFIG_LOG_BACKEND_BLE is not set
# CONFIG_LOG_BACKEND_FS is not set
CONFIG_LOG_BACKEND_RTT=y
# CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
# CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
CONFIG_LOG_BACKEND_RTT_BUFFER=0
# CONFIG_LOG_BACKEND_SWO is not set
# CONFIG_LOG_BACKEND_UART is not set
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
# CONFIG_LOG_CMDS is not set
CONFIG_LOG_USE_VLA=y
CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_FMT_STRING_VALIDATE is not set
# CONFIG_LOG_MEM_UTILIZATION is not set
CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
# end of Misc
CONFIG_LOG_OUTPUT=y
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
CONFIG_MCUMGR=y
# CONFIG_MCUMGR_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_LOG_LEVEL_WRN is not set
# CONFIG_MCUMGR_LOG_LEVEL_INF is not set
CONFIG_MCUMGR_LOG_LEVEL_DBG=y
# CONFIG_MCUMGR_LOG_LEVEL_DEFAULT is not set
CONFIG_MCUMGR_LOG_LEVEL=4
# CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set
# CONFIG_MCUMGR_MGMT_HANDLER_USER_DATA is not set
# CONFIG_MCUMGR_MGMT_CUSTOM_PAYLOAD is not set
CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15
CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=2
CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y
CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=4
CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=0
CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=4
CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y
# CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set
# CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set
# SMP Client
# CONFIG_SMP_CLIENT is not set
# end of SMP Client
# Command Handlers
# CONFIG_MCUMGR_GRP_FS is not set
CONFIG_MCUMGR_GRP_IMG=y
# CONFIG_MCUMGR_GRP_IMG_USE_HEAP_FOR_FLASH_IMG_CONTEXT is not set
CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER=2
# CONFIG_MCUMGR_GRP_IMG_VERBOSE_ERR is not set
CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY=y
# CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_ANY is not set
# CONFIG_MCUMGR_GRP_IMG_ALLOW_ERASE_PENDING is not set
# CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD is not set
# CONFIG_MCUMGR_GRP_IMG_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
# CONFIG_MCUMGR_GRP_IMG_FRUGAL_LIST is not set
# CONFIG_MCUMGR_GRP_IMG_VERSION_CMP_USE_BUILD_NUMBER is not set
# CONFIG_MCUMGR_GRP_IMG_MUTEX is not set
CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_DISABLED=y
# CONFIG_MCUMGR_GRP_IMG_TOO_LARGE_SYSBUILD is not set
CONFIG_MCUMGR_GRP_IMG_IMAGE_SLOT_STATE_STATES=15
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_WRN is not set
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_INF is not set
# CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT=y
CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL=3
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_OS_RESET_MS=250
# CONFIG_MCUMGR_GRP_OS_TASKSTAT is not set
CONFIG_MCUMGR_GRP_OS_ECHO=y
# CONFIG_MCUMGR_GRP_OS_INFO is not set
# CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_WRN is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_INF is not set
# CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DBG is not set
CONFIG_MCUMGR_GRP_OS_LOG_LEVEL_DEFAULT=y
CONFIG_MCUMGR_GRP_OS_LOG_LEVEL=3
# CONFIG_MCUMGR_GRP_ENUM is not set
# end of Command Handlers
# Transports and Transport Related Configuration Options
CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=2048
CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3
CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=4
CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE=4
CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=128
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_OFF is not set
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_ERR is not set
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_WRN is not set
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_INF is not set
CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DBG=y
# CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT is not set
CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL=4
# CONFIG_MCUMGR_TRANSPORT_DUMMY is not set
# CONFIG_MCUMGR_TRANSPORT_BT is not set
# CONFIG_MCUMGR_TRANSPORT_SHELL is not set
CONFIG_MCUMGR_TRANSPORT_UART=y
CONFIG_MCUMGR_TRANSPORT_UART_MTU=256
# end of Transports and Transport Related Configuration Options
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set
# CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set
CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y
CONFIG_PM_DEVICE_LOG_LEVEL=3
# CONFIG_PM_DEVICE_RUNTIME is not set
# CONFIG_PM_DEVICE_SHELL is not set
# end of Power Management
# Portability
# end of Portability
# CONFIG_PROFILING is not set
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
# end of Random Number Generators
CONFIG_RETENTION=y
CONFIG_RETENTION_INIT_PRIORITY=86
CONFIG_RETENTION_MUTEXES=y
# CONFIG_RETENTION_MUTEX_FORCE_DISABLE is not set
CONFIG_RETENTION_BUFFER_SIZE=16
# Retention modules
CONFIG_RETENTION_BOOT_MODE=y
# CONFIG_RETENTION_BOOTLOADER_INFO is not set
# end of Retention modules
# CONFIG_RETENTION_LOG_LEVEL_OFF is not set
# CONFIG_RETENTION_LOG_LEVEL_ERR is not set
# CONFIG_RETENTION_LOG_LEVEL_WRN is not set
# CONFIG_RETENTION_LOG_LEVEL_INF is not set
# CONFIG_RETENTION_LOG_LEVEL_DBG is not set
CONFIG_RETENTION_LOG_LEVEL_DEFAULT=y
CONFIG_RETENTION_LOG_LEVEL=3
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
CONFIG_SETTINGS=y
# CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
# CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
# CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
# CONFIG_SETTINGS_LOG_LEVEL_INF is not set
# CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
CONFIG_SETTINGS_LOG_LEVEL_DEFAULT=y
CONFIG_SETTINGS_LOG_LEVEL=3
# CONFIG_SETTINGS_RUNTIME is not set
CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
CONFIG_SETTINGS_FCB=y
# CONFIG_SETTINGS_FILE is not set
# CONFIG_SETTINGS_CUSTOM is not set
# CONFIG_SETTINGS_NONE is not set
CONFIG_SETTINGS_FCB_NUM_AREAS=8
CONFIG_SETTINGS_FCB_MAGIC=0xc0ffeeee
# CONFIG_SETTINGS_SHELL is not set
CONFIG_SHELL=y
# CONFIG_SHELL_LOG_LEVEL_OFF is not set
# CONFIG_SHELL_LOG_LEVEL_ERR is not set
# CONFIG_SHELL_LOG_LEVEL_WRN is not set
# CONFIG_SHELL_LOG_LEVEL_INF is not set
# CONFIG_SHELL_LOG_LEVEL_DBG is not set
CONFIG_SHELL_LOG_LEVEL_DEFAULT=y
CONFIG_SHELL_LOG_LEVEL=3
CONFIG_SHELL_BACKENDS=y
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_SHELL_BACKEND_SERIAL_INIT_PRIORITY=90
CONFIG_SHELL_PROMPT_UART="uart:~$ "
CONFIG_SHELL_BACKEND_SERIAL_INTERRUPT_DRIVEN=y
# CONFIG_SHELL_BACKEND_SERIAL_API_POLLING is not set
CONFIG_SHELL_BACKEND_SERIAL_API_INTERRUPT_DRIVEN=y
# CONFIG_SHELL_BACKEND_SERIAL_API_ASYNC is not set
# CONFIG_SHELL_BACKEND_SERIAL_FORCE_TX_BLOCKING_MODE is not set
CONFIG_SHELL_BACKEND_SERIAL_TX_RING_BUFFER_SIZE=8
CONFIG_SHELL_BACKEND_SERIAL_RX_RING_BUFFER_SIZE=64
CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_TIMEOUT=100
CONFIG_SHELL_BACKEND_SERIAL_LOG_MESSAGE_QUEUE_SIZE=512
CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DEFAULT=y
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_DBG is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_INF is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_WRN is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_ERR is not set
# CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL_NONE is not set
CONFIG_SHELL_BACKEND_SERIAL_LOG_LEVEL=5
# CONFIG_SHELL_BACKEND_RTT is not set
# CONFIG_SHELL_BACKEND_RPMSG is not set
# CONFIG_SHELL_BACKEND_DUMMY is not set
# CONFIG_SHELL_MINIMAL is not set
# CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set
CONFIG_SHELL_BACKSPACE_MODE_DELETE=y
CONFIG_SHELL_PROMPT_CHANGE=y
CONFIG_SHELL_PROMPT_BUFF_SIZE=20
CONFIG_SHELL_CMD_BUFF_SIZE=256
CONFIG_SHELL_PRINTF_BUFF_SIZE=30
CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80
CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24
CONFIG_SHELL_ARGC_MAX=20
CONFIG_SHELL_TAB=y
CONFIG_SHELL_TAB_AUTOCOMPLETION=y
CONFIG_SHELL_ASCII_FILTER=y
CONFIG_SHELL_WILDCARD=y
CONFIG_SHELL_MSG_CMD_NOT_FOUND=y
CONFIG_SHELL_MSG_SPECIFY_SUBCOMMAND=y
CONFIG_SHELL_ECHO_STATUS=y
# CONFIG_SHELL_START_OBSCURED is not set
CONFIG_SHELL_VT100_COMMANDS=y
CONFIG_SHELL_VT100_COLORS=y
# CONFIG_SHELL_GETOPT is not set
CONFIG_SHELL_METAKEYS=y
CONFIG_SHELL_HELP=y
CONFIG_SHELL_HELP_OPT_PARSE=y
CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=y
CONFIG_SHELL_HISTORY=y
CONFIG_SHELL_HISTORY_BUFFER=512
CONFIG_SHELL_STATS=y
CONFIG_SHELL_CMDS=y
CONFIG_SHELL_CMDS_RESIZE=y
# CONFIG_SHELL_CMDS_SELECT is not set
CONFIG_SHELL_CMD_ROOT=""
CONFIG_SHELL_LOG_BACKEND=y
CONFIG_SHELL_LOG_FORMAT_TIMESTAMP=y
CONFIG_SHELL_AUTOSTART=y
CONFIG_SHELL_CMDS_RETURN_VALUE=y
# CONFIG_SHELL_CUSTOM_HEADER is not set
CONFIG_DEVICE_SHELL=y
CONFIG_DATE_SHELL=y
CONFIG_DEVMEM_SHELL=y
CONFIG_KERNEL_SHELL=y
CONFIG_KERNEL_SHELL_REBOOT_DELAY=0
CONFIG_KERNEL_THREAD_SHELL=y
CONFIG_KERNEL_THREAD_SHELL_LIST=y
CONFIG_KERNEL_THREAD_SHELL_STACKS=y
# CONFIG_STATS is not set
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_MAP_SHELL is not set
# CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
# CONFIG_FLASH_MAP_LABELS is not set
CONFIG_STREAM_FLASH=y
# CONFIG_STREAM_FLASH_ERASE is not set
# CONFIG_STREAM_FLASH_PROGRESS is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
# CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
CONFIG_STREAM_FLASH_LOG_LEVEL=3
# end of Storage
CONFIG_TASK_WDT=y
CONFIG_TASK_WDT_CHANNELS=9
CONFIG_TASK_WDT_HW_FALLBACK=y
CONFIG_TASK_WDT_MIN_TIMEOUT=10000
# CONFIG_TASK_WDT_SHELL is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
CONFIG_USB_DEVICE_STACK=y
# CONFIG_USB_DEVICE_LOG_LEVEL_OFF is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_ERR is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_WRN is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_INF is not set
# CONFIG_USB_DEVICE_LOG_LEVEL_DBG is not set
CONFIG_USB_DEVICE_LOG_LEVEL_DEFAULT=y
CONFIG_USB_DEVICE_LOG_LEVEL=3
CONFIG_USB_DEVICE_VID=0x1915
CONFIG_USB_DEVICE_PID=0x910A
CONFIG_USB_DEVICE_MANUFACTURER="ZEPHYR"
CONFIG_USB_DEVICE_PRODUCT="Thingy:91 X UART"
CONFIG_USB_DEVICE_SN="0123456789ABCDEF"
# CONFIG_USB_CONFIGURATION_STRING_DESC_ENABLE is not set
CONFIG_USB_COMPOSITE_DEVICE=y
CONFIG_USB_MAX_NUM_TRANSFERS=8
CONFIG_USB_DEVICE_BLUETOOTH_BIG_BUF=y
CONFIG_USB_REQUEST_BUFFER_SIZE=128
CONFIG_USB_MAX_ALT_SETTING=8
CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
# CONFIG_USB_DEVICE_SOF is not set
# CONFIG_USB_DEVICE_BOS is not set
# CONFIG_USB_DEVICE_OS_DESC is not set
CONFIG_USB_SELF_POWERED=y
CONFIG_USB_MAX_POWER=250
CONFIG_USB_WORKQUEUE=y
CONFIG_USB_WORKQUEUE_STACK_SIZE=1024
CONFIG_USB_WORKQUEUE_PRIORITY=-1
# CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT is not set
# USB CDC ACM Class support
CONFIG_USB_CDC_ACM=y
CONFIG_USB_CDC_ACM_RINGBUF_SIZE=1024
CONFIG_CDC_ACM_INTERRUPT_EP_MPS=16
CONFIG_CDC_ACM_BULK_EP_MPS=64
CONFIG_CDC_ACM_TX_DELAY_MS=100
CONFIG_CDC_ACM_IAD=y
# CONFIG_CDC_ACM_DTE_RATE_CALLBACK_SUPPORT is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_OFF is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_ERR is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_WRN is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_INF is not set
# CONFIG_USB_CDC_ACM_LOG_LEVEL_DBG is not set
CONFIG_USB_CDC_ACM_LOG_LEVEL_DEFAULT=y
CONFIG_USB_CDC_ACM_LOG_LEVEL=3
# end of USB CDC ACM Class support
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_DEVICE_BLUETOOTH is not set
# CONFIG_USB_DEVICE_BT_H4 is not set
# CONFIG_USB_DEVICE_LOOPBACK is not set
# USB Device Networking support
# CONFIG_USB_DEVICE_NETWORK_ECM is not set
# CONFIG_USB_DEVICE_NETWORK_EEM is not set
# CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
# end of USB Device Networking support
# CONFIG_USB_DEVICE_HID is not set
# CONFIG_USB_DEVICE_AUDIO is not set
# CONFIG_USB_DFU_CLASS is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
CONFIG_ZBUS=y
CONFIG_ZBUS_CHANNELS_SYS_INIT_PRIORITY=5
CONFIG_ZBUS_CHANNEL_NAME=y
# CONFIG_ZBUS_OBSERVER_NAME is not set
CONFIG_ZBUS_MSG_SUBSCRIBER=y
CONFIG_ZBUS_MSG_SUBSCRIBER_BUF_ALLOC_DYNAMIC=y
# CONFIG_ZBUS_MSG_SUBSCRIBER_BUF_ALLOC_STATIC is not set
# CONFIG_ZBUS_MSG_SUBSCRIBER_NET_BUF_POOL_ISOLATION is not set
CONFIG_ZBUS_MSG_SUBSCRIBER_NET_BUF_POOL_SIZE=64
# CONFIG_ZBUS_RUNTIME_OBSERVERS is not set
CONFIG_ZBUS_PRIORITY_BOOST=y
# CONFIG_ZBUS_ASSERT_MOCK is not set
# CONFIG_ZBUS_LOG_LEVEL_OFF is not set
# CONFIG_ZBUS_LOG_LEVEL_ERR is not set
# CONFIG_ZBUS_LOG_LEVEL_WRN is not set
# CONFIG_ZBUS_LOG_LEVEL_INF is not set
# CONFIG_ZBUS_LOG_LEVEL_DBG is not set
CONFIG_ZBUS_LOG_LEVEL_DEFAULT=y
CONFIG_ZBUS_LOG_LEVEL=3
# CONFIG_MODULES is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_ROM_END_OFFSET=0x2000
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_ITERABLE_SUBALIGN=4
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# CONFIG_STD_C17 is not set
# CONFIG_STD_C23 is not set
CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
# CONFIG_GNU_C_EXTENSIONS is not set
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_COMPILER_FREESTANDING is not set
# CONFIG_SIZE_OPTIMIZATIONS is not set
# CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
CONFIG_SPEED_OPTIMIZATIONS=y
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_DEPRECATED=y
CONFIG_WARN_DEPRECATED=y
CONFIG_EXPERIMENTAL=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
# end of Compatibility
# end of Zephyr Kernel
    signed_by_mcuboot_and_b0_s1_image.bin is the mcuboot update image for devices that use MCUBoot as the second stage bootloader.  Which tool/app are you using to upload the image, and are you selecting the image number when uploading? It should be '4' for MCUBoot updates if you are using SDK v2.9.0: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/bootloaders_dfu/sysbuild_image_ids.html
    The only error message I see is that when I do a SMP “list” requests after upload of the firmware it gives an error message about Image area ID 2. CONFIG_UPDATEABLE_IMAGE_NUMBER is set to 2 in app but 3 in mcuboot.
    [00:00:18.114,593] <err> mcumgr_img_grp: Failed to open flash area ID 2: -2
    This can be ignored. The error is returned when the app tries to read the emulated flash partition in RAM (mcuboot_primary_1) which is used for FW updates of the network core by MCUBoot.
    Vidar
  • Thank you, I think I got the partitions mixed up. I thought that mcuboot_primary/ mcuboot_secondary was for the mcuboot and S0/S1 for the app but I understand now that it is the reverse. I also found that SB_CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0. So all this combined I now tested to run
    mcumgr-client --device /dev/ttyACM1 upload ./build_5340_app/build/app_nrf5340/zephyr/zephyr.signed.bin --slot 0
    This seems to also just fine upload the image and I can set it to test and then reset. mcuboot now have a different error, now it says
    I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
    I: Starting swap using move algorithm.
    W: Not enough free space to run swap upgrade
    W: required 278528 bytes but only 274432 are available
    D: writing copy_done; fa_id=11 off=0x43fe0 (0x73fe0)
    Am I still uploading the wrong image file? Or do I have to change the image size somewhere. I found the partitions.yml in the build folder, how is the size of flash partitions configured? Here is the content of the file:
    app:
      address: 0x30200
      end_address: 0x74000
      region: flash_primary
    app_image:
      address: 0x30200
      span:
      - app
    b0:
      address: 0x0
      end_address: 0x8000
    b0_container:
      address: 0x0
      end_address: 0x8000
      span:
      - b0
    mcuboot:
      address: 0x8200
      end_address: 0x1c000
    mcuboot_pad:
      address: 0x30000
      end_address: 0x30200
    mcuboot_primary:
      address: 0x30000
      span:
      - mcuboot_pad
      - app
    mcuboot_primary_1:
      address: 0x0
      device: nordic_ram_flash_controller
      end_address: 0x40000
      region: ram_flash
    mcuboot_primary_app:
      address: 0x30200
      span:
      - app
    mcuboot_secondary:
      address: 0x74000
      end_address: 0xb8000
    mcuboot_secondary_1:
      address: 0xb8000
      end_address: 0xf8000
    otp:
      address: 0xff8380
      end_address: 0xff83fc
      region: otp
    pcd_sram:
      address: 0x20000000
      end_address: 0x20002000
      region: sram_primary
    provision:
      address: 0xff8100
      end_address: 0xff8380
      region: otp
    ram_flash:
      address: 0x40000
      region: ram_flash
    rpmsg_nrf53_sram:
      address: 0x2006fc00
      end_address: 0x2007fc00
      placement:
        before:
        - end
    s0:
      address: 0x8000
      span:
      - mcuboot
      - s0_pad
    s0_image:
      address: 0x8200
      span:
      - mcuboot
    s0_pad:
      address: 0x8000
      end_address: 0x8200
      share_size:
      - mcuboot_pad
    s1:
      address: 0x1c000
      end_address: 0x30000
      span:
      - s1_pad
      - s1_image
    s1_image:
      address: 0x1c200
      share_size:
      - mcuboot
    s1_pad:
      address: 0x1c000
      end_address: 0x1c200
      share_size:
      - mcuboot_pad
    settings_storage:
      address: 0xf8000
      end_address: 0x100000
    sram_primary:
      address: 0x20002000
      end_address: 0x2006fc00
    sram_retained_mem:
      address: 0x2007fc00
      end_address: 0x20080000
    Or is it as simple now that the flash image is just to big and I need to optimize it somehow even if it works fine to load it via jlink? I saw this during build, so it seems that I'm close to the limit.
    [7/7] Linking C executable zephyr/zephyr.elf
               FLASH:      271764 B     278016 B     97.75%
                 RAM:      184604 B       439 KB     41.07%
         RetainedMem:          0 GB         1 KB      0.00%
            IDT_LIST:          0 GB        32 KB      0.00%
  • After removing some features I got the flash size down and now I can do a full DFO upgrade and start the new firmware. Thanks for the support.
