ESB PTX and PRX with no ACK - how to wait for TX ready
we have ESB PTX and PRX couple from nRF54H20
nRF54H20DK (rev. 0.9.1), SDK: v2.9.0-nRF54H20-rc2 and the same Toolchain, IDE: VSCode + nRF Connect plugin
build for CPURAD
configured to 4Mbps
noACK and never disable TX radio
I need transmit about 10kBytes of data so speed as possible. When we used (ACK was activated) K_SEM() in PTX for TX ready detecting it was works good, but real data rate (including overhead) was about 2.3Mbps.
After this we deactivated the ACK, but ESB handler is not serviced in this mode.
I tried to check ESB TX ready by functions esb_tx_full() and esb_is_idle() but without success.
How can I check in PTX when is ESB ready for next TX?
Another, similar question - how to check in PRX whether ESB packet is received? (I hope that ESB handler works as usual (with AKC), but I am not sure).
My complementary question: How to set up config.slective_auto_ack for the right work with NoAck?
my prj.conf
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_ESB=y
CONFIG_DK_LIBRARY=y
CONFIG_CLOCK_CONTROL=y
CONFIG_ESB_MAX_PAYLOAD_LENGTH=251
CONFIG_ESB_TX_FIFO_SIZE=256
CONFIG_ESB_RX_FIFO_SIZE=256
CONFIG_CRC=y
CONFIG_ESB_FAST_CHANNEL_SWITCHING=y
CONFIG_ESB_FAST_SWITCHING=y
CONFIG_ESB_NEVER_DISABLE_TX=y
Here is my ESB_init():
int drv_esb_init(ESBcontrol_t * esb_ptr, ESBconfig_t * esb_cfg)  // Attention, a function named "esb_init()" already exists in esb.c.
	int err;
	/* These are arbitrary default addresses. In end user products
	 * different addresses should be used for each set of devices.
    Esb_driver_ptr = esb_ptr;                               // catch pointer to instance
    esb_ptr->tx_sem_ptr = &esb_tx_done_sem;
	esb_ptr->rx_sem_ptr = &esb_rx_done_sem;
	esb_ptr->rx_fifo_ptr = &esb_rx_data_fifo;
    esb_ptr->tx_ready = true;
    esb_ptr->ack_enable = esb_cfg->ack_enable;
	struct esb_config config = ESB_DEFAULT_CONFIG;
	config.protocol = ESB_PROTOCOL_ESB_DPL;
	config.retransmit_delay = 250;
	config.bitrate = ESB_BITRATE_4MBPS;
	config.mode = esb_cfg->mode;
	config.event_handler = drv_esb_event_handler;
	config.payload_length = CONFIG_ESB_MAX_PAYLOAD_LENGTH;
//    config.selective_auto_ack = esb_cfg->ack_enable ? true : false;   // identity - old try
//    config.selective_auto_ack = esb_cfg->ack_enable ? false : true;   // inversion of user config: Selective auto acknowledgement.
				   // When this feature is disabled, all packets will be acknowledged ignoring the noack field.
	config.selective_auto_ack = true;				// respects the ACK configuraion (MS note)
	if (IS_ENABLED(CONFIG_ESB_FAST_SWITCHING)) {
		config.use_fast_ramp_up = true;
#if TEST_DRV_ESB_INIT_PARAM_PRINT
    LOG_DBG("base_addr_0_ptr=%p, base_addr_1_ptr=%p, addr_prefix_ptr=%p ",
        esb_cfg->base_addr_0_ptr, esb_cfg->base_addr_1_ptr, esb_cfg->addr_prefix_ptr);
	LOG_DBG("tx_sem_ptr=%p, rx_fifo_ptr=%p, ack_enable=%d, selective_auto_ack=%d, use_fast_ramp_up=%d",
		esb_ptr->tx_sem_ptr, esb_ptr->rx_fifo_ptr, esb_ptr->ack_enable, config.selective_auto_ack, config.use_fast_ramp_up);
	err = esb_init(&config);
	if (err) {
        LOG_ERR("esb_init() failed, err %d", err);
		return err;
	err = esb_set_base_address_0(esb_cfg->base_addr_0_ptr);
	if (err) {
        LOG_ERR("esb_set_base_address_0() failed, err %d", err);
		return err;
	err = esb_set_base_address_1(esb_cfg->base_addr_1_ptr);
	if (err) {
        LOG_ERR("esb_set_base_address_1() failed, err %d", err);
		return err;
	err = esb_set_prefixes(esb_cfg->addr_prefix_ptr, ESB_PREFIX_SIZE);
	if (err) {
        LOG_ERR("esb_set_prefixes() failed, err %d", err);
		return err;
	return 0;
Which is called from main() using:
    /* Initialize ESB driver. */
	ESBconfig_t drv_esb_cfg = {
		.base_addr_0_ptr = Base_addr_0,
		.base_addr_1_ptr = Base_addr_1,
		.addr_prefix_ptr = Addr_prefix,
		.mode = TRANSMIT_ESB_MODE,
		.ack_enable = TRANSMIT_ACK_CTRL,
	err = drv_esb_init(&Esb_ctrl, &drv_esb_cfg);
Here is my project: 3386.ESB_noACK tetsing.ZIP
There is the  directory "ConfigInfo" with build info.
BR
  • Thanks for your answer,
    Activating ESB_NEVER_DISABLE_TX is excluded from the activated ESB_FAST_SWITCHING.
    When I activated ESB_NEVER_DISABLE_TX  to YES ESB handler was not handled. Only FAST_SWITCHING is good solution, but he have data rate only 3.34Mbps (50 x 256B / 29ms).
    I want to know why data rate is not 4Mbps and why activating ESB_NEVER_DISABLE_TX stops the handler service.
    Here is oscillogpraph for one ESB packet and 50x ESB packets
    I want to ask if when setting CONFIG_ESB_TX_FIFO_SIZE=50 and sending 50 ESB packets in quick succession, do I have to wait for TX READY from the ESB handler.
  • Hi Peter,
    I think you are hitting the limit. You can't expect the actual payload data to be equal to theoretical bit rate. This is due to:
    - Overhead: address byte, preamble, CRC
    - Radio switching time. The radio has to switch between TX and RX. Even with FAST_SWITCHING the switching time is 40us.
    The longer the packet the less number of radio switching. However , longer packet may have higher chance of interference and get corrupted. If you enable re-transmission the whole bigger packet will have to be retransmitted. So you need to balance between high through put and waste on packet loss and retransmission.
