SDK2.9.0 - QSPI and TWI driver power management (CONFIG_PM_DEVICE_RUNTIME)
Hi.
After migration from SDK2.7.0 to SDK2.9.0 I have issues with power mangement. CONFIG_PM_DEVICE_RUNTIME=y, which I used, causes that twi driver doesn't start. I try to manage with this issue and call pm_device_runtime_enable(i2c_dev) when I init only device which I have on TWI bus.
1. Is it right way? Is it enough to make that twi_driver power management works automatically?
2. How to manage qspi driver? (I have external flash on board). The same way will be OK? In this case, I have no idea where to call pm_device_runtime_enable.
Best regards
PW
    I bet that the change you see between v2.7.0 and v2.9.0 is related to This Commit.
    From this, it looks to me that nrfx_twim_enable() is not longer called automatically by the TWI init code. So in this case, I agree that it looks like you will have to use Power Management to enable TWI now.
    No, external flash over QSPI is a bit different. I believe that this should be enabled at first. Then you can put the external flash into Deep Power Down (DPD) mode + uninit the QSPI using the Power Management API. See here for driver code (And wake it up the also).
    Sigurd Hellesvik
