Please make the BLACK MAGIC PROBE debugger a fully supported probe in the nRF Connect Extension in vscode
I successfully am using BLACK MAGIC PROBE (BMP)  with nRF Connect Extension in VScode already, based on answers in this support forum. I can Run, Pause, Examine breakpoints, ReStart, Examine a Memory View, etc. The extension currently supports Seggar J-link, but the BMP would be a great alternative because it is much less expensive.
HOWEVER several of the nice Extension features are missing. These include showing 'CONNECTED DEVICES', the 'THREAD VIEWER', connection to RTT, etc.
I am currently developing on a custom board with a nrf52840, and the following versions
*** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
nRF connect VS Code Extension version 2025.1.127
Below is my current launch.json file. It works, but there are a some problems that I work around:
  1. I have to use "type:": "cppdbg" instead of  "type:":"nrf-connect"
  2. I have to adjust the "program" path and/or the build name if the Build Configuration in not exactly named "build". Providing better variables would be helpful.
  3. Likewise I have to manually adjust the line with   "name": "Launch build" to match the Build Configuration
Here is my launch.json:
	"version": "0.2.0",
	"configurations": [
			"name": "Launch build",
            /*"name": "Black Magic Probe", // Ref: https://www.martinhubacek.cz/blog/black-magic-probe-vs-code/ */
            "type": "cppdbg",
            //"type": "nrf-connect",
            "request": "launch",
            /* "preLaunchTask": "build", // causes a can't find buid dialog to appear */
            "cwd": "${workspaceRoot}",
            "MIMode": "gdb",
            "svdPath": "",
            "targetArchitecture": "arm",
            "logging": { "engineLogging": true },
            "program": "${workspaceRoot}\\build\\${workspaceFolderBasename}\\zephyr\\zephyr.elf",
            "miDebuggerPath": "C:\\gcc-arm-none-eabi\\bin\\arm-none-eabi-gdb.exe",
			"stopAtEntry": true,
            "customLaunchSetupCommands": [
                {"text": "cd ${workspaceRoot}\\build\\${workspaceFolderBasename}\\zephyr"}, // C:\projects\ncsfund\vscode\l1_e2\build_2\l1_e2\zephyr
                {"text": "target extended-remote \\\\.\\COM14"},        // replace with your COM or /dev/ttyX
                {"text": "monitor swdp_scan"},
                {"text": "attach 1"},
                {"text": "file zephyr.elf"},             // was:   "text": "file firmware.elf"
                {"text": "load"},
                {"text": "cd ${workspaceRoot}"}, // set bath back so VScode can find source files
                {"text": "set mem inaccessible-by-default off"},
                {"text": "break main"},
            "serverLaunchTimeout": 10000,
            /* "windows": { "miDebuggerPath": "arm-none-eabi-gdb.exe" } */
    I am glad to hear that the basic debugging functionality is working.
    Thread viewer requires a debug plugin specifically for the debug host, which is currently available for segger based hosts.
    https://github.com/zephyrproject-rtos/jlink-zephyr
    Thank you so much for taking the time to share this on our forum. This is highly appreciated!
    I will report the requeset for BMP-support back to our team as a feature request.
    Håkon
