BLE Mesh Deep Sleep and RTC Setup
I am using Mesh of 30 nodes with avg Current Consumption 6mA and 2mA in sleep mode(by calling k_sleeps) , timer is 1s timer is running to keep Real Time incremented.
Want to achieve Deep Sleep current in micro amps, while in deep sleep time needs to be incremented.
I thought RTC would consume less power than timer(if i am correct?) but not able to get RTC working , also no sample code available.
I also tried to reduce the Tx power assuming it will save power(need 6 to 7 mtr range only) but that also doesn't seem to working
Please help to get RTC working and reduce TX power to save energy and other available configs for low power in deep sleep.
Thanks in advance!
Edit:
Using SDK and Toolchain v2.9.0
  • Hello AP,
    You might be confused. The RTC is on by default when using the nRF Connect SDK and the nRF5340.
    There are two states of sleeps:
    System ON Idle - This is automatically entered when all threads go idle.
    System OFF - This has to be entered manually. The consumption is even lower in this state.
    For more information about the state, please refer to the Power and clock management section of the Product Specification.
    Since you are asking about RTC, you might want to know that in System OFF, the deepest sleep state, RTC is stopped, and the system can only be woken up by GPIO. The system will also have to reinitialize from the beginning like after a reset.
    Hieu
  • Hi Hieu,
    Thank you, This information is helpful!
    However , I am not able to use RTC using "const struct device *rtc = DEVICE_DT_GET(DT_NODELABEL(rtc1));"
    Please suggest some samples code or tutorial for this.
    Also I am successfully able to enter in LPN Mode but seems not able to come out of LPN mode is that possible or not to dynamically changing states?
    Additionally when tried to use Power management configurations and API. its gives error. below config not supported.
    CONFIG_PM=y
    CONFIG_PM_DEVICE=y
    When I tried to use Sample code device_pm , I am not getting option for nrf5340 board target in build config.
    Waiting for your response!
    Edit:
    I tried Using RTC with
    nrfx_rtc_t sti_period_rtc_1 = NRFX_RTC_INSTANCE(0);
    and
    nrfx_rtc_t sti_period_rtc_1 = NRFX_RTC_INSTANCE(1);
    but getting error-
    error: NRFX_RTC (defined at C:/ncs/v2.9.0/zephyr/modules/hal_nordic\nrfx/Kconfig:443,
    modules\hal_nordic\nrfx/Kconfig:443) is assigned in a configuration file, but is not directly user-
    configurable (has no prompt). It gets its value indirectly from other symbols. See
    docs.zephyrproject.org/.../kconfig.html and/or look up NRFX_RTC in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    Edit2:
    1.Regarding PM (CONFIG_PM=y) I tried with nrf52832dk and Its working.
    2.in some discussion I found that in latest versions(after v2.5.0) PM is deprecated and not supported anymore for nrf5340
    3.Then I tried with v2.3.0 and its working.
    So how to achieve it with v2.9.0?
    4.Regarding RTC I tried rtc0 and rtc1 both but seems like its not available for user. I need something that can increment clock time every second. while MCU is in sleep mode.
    In Summary I have 3 points.
    1.how Come Out of LPN Mode.
    2.PM(power management) for nrf5340, v2.9.0
    3.RTC or similar timer active in sleep mode.
    Your investigation is correct. CONFIG_PM is no longer supported for the nRF5340.
    The rationale is that the PM subsystem is intended to be used to switch the system over different power states.
    However, the nRF5340 only have two power state, System ON and System OFF, so PM doesn't fit.
    As for sleep states, as mentioned, there are two: System ON Idle and System OFF.
    System ON Idle is automatically entered when all threads go idle, and is automatically exited when any thread resume activity.
    To enter System OFF, you will want to use the Power Off API instead. On the nRF5340, System OFF can only be exited with specific GPIO, NFC, or LPCOMP events or reset. |
    Further information about System OFF: Power and clock management.
    SDK API Documentation: Zephyr API: System power off
    SDK Sample: System Off
    The RTC is available with the correct configuration. One RTC is always reserved for System timekeeping.
    For something like tracking passing seconds, I recommend taking advantage of System time services instead. You can calculate current time from system uptime and a reference point. Refer this documentation: Time Utilities.
    Please experiment with them a little.
  • Hi Hieu,
    Thanks now I am able to used PM.
    But still waiting response on "Also I am successfully able to enter in LPN Mode but seems not able to come out of LPN mode is that possible or not to dynamically changing states?"
    When low power mode active it by default(as well as using function in below code) goes in to LPN after 16 sec and Current reduces from 5mA to 1.6mA.
    but not able to bring back to normal mode.
    void SCHNEE_lpn_enable(void)
        int err;
        // //Disable sending of the Secure Network Beacon.
        bt_mesh_beacon_set(0);
        // //Disable the GATT Proxy feature.
        bt_mesh_gatt_proxy_set(0);
        //Set LPN
        // Enable Low Power Node mode
        err = bt_mesh_lpn_set(true);  // Passing true enables LPN mode
        if (err) {
            printk("Failed to enable Low Power Node (err %d)\n", err);
        } else {
            printk("Low Power Node mode enabled.\n");
        k_sleep(K_SECONDS(1));
        // bt_mesh_lpn_set_cb(lpn_cb);
        // printk("LPN mode set. Waiting for Friend Node...\n");
        // while (1) {
        //  k_sleep(K_SECONDS(10)); // Device sleeps while waiting for messages
        // Start periodic polling loop
        //SCHNEE_lpn_poll_periodically();
    void SCHNEE_lpn_disable(void)
        int err;
        // //Enable the GATT Proxy feature.
        bt_mesh_gatt_proxy_set(1);
        // //Enable sending of the Secure Network Beacon.
        bt_mesh_beacon_set(1);
        //Reset LPN
        // Disable Low Power Node mode
        err = bt_mesh_lpn_set(false);  // Passing true enables LPN mode
        if (err) {
            printk("Failed to disable Low Power Node (err %d)\n", err);
        } else {
            printk("Low Power Node mode disabled.\n");
        //bt_mesh_lpn_disable(1);
        //bt_mesh_lpn_friendship_end();
        // err = bt_le_adv_start(BT_LE_ADV_CONN, NULL, 0, NULL, 0);
        // if (err) {
        //     printk("Failed to bt_le_adv_start(err %d)\n", err);
        // } else {
        //     printk("bt_le_adv_start.\n");
  • Hello AP,
    To be sure, are you using Power Management, pm, or Device Power Management, pm_device? Or are you using the Power Off API?
    As I said, PM is not supported in NCS v2.9.0, so if you are somehow using it, we need to be sure you are getting what you expect.
    The naming of those Zephyr APIs are a little confusing, but it's important to know what you are running.
    What is the problem when you run bt_mesh_lpn_set()?
1 2
