I need a replacement battery for the thingy91, however not sure how to search for it.
Searching just the TE connector battery not helping
Hello, thanks for the link.
But what is written there I think is incorrect, the battery is a normal LIthium battery with positive and negative and the thermistor terminal. The battery outputs 3.7-4.2V. I used this battery on a custom board with an npm1300. However from bad use the cable of the battery destroyed and now can't find an alternative for my thingy91.
The battery that is used in the Thingy:91 can be found in the BOM which can be found in the hardware files.. The one that is used currently is:
You can look based on this one.. Do make sure that the connector type is the one that you would need before buying since it might come with different connectors.
Best Regards,
Swathy
Hello, thanks very much for your response.
I wasnt expecting to find the battery in BOM.
Thats what I was looking for, much appreciate it!
Regards
Kostas
