How to Interface W25Q32 External Flash with nRF21540DK/nRF52840 in nRF Connect SDK 2.9.0?
I am using nRF Connect SDK 2.9.0 with Toolchain 2.9.0 and trying to interface Winbond W25Q32 SPI flash memory with nRF21540DK (nRF52840). I need help with the following:
  1. Device Tree Overlay – Proper setup for enabling W25Q32 in Zephyr.
  2. Driver Support – Recommended drivers, APIs, or sample projects for working with SPI flash.
If anyone has successfully integrated external SPI flash with nRF52840 in nRF Connect SDK 2.9.0, please share your insights or example configurations.
Thanks in advance!
  • I assume you are connecting some external flash chip to the nrf21540DK since it didn't include a flash chip. The v2.9.0\zephyr\samples\drivers\spi_flash example might be a good starting point. Though it specifically targets the nrf52840DK. The only issue for you would be that the nrf52840 will be using a quad spi part.
  • Also, the core .dtsi file that is included into the nrf52840 device tree is stored here \zephyr\dts\arm\nordic\nrf52840.dtsi .
    This shows the base of spi1 which I think you will need to connect to for flash.
    For an example of how to add the flash to the device tree (but to a different spi since it's a different board, sorry I couldn't find one specific to the nrf21540/nrf52840)  zephyr\boards\sparkfun\thing_plus\sparkfun_thing_plus_nrf9160_common.dtsi . This shows a w25q32 attached to a spi3. You need to create an overlay for the nrf21540 and copy this into spi1.
    I haven't had to use an external flash, but this looks like some pieces to start from.
    I am assuming you understand the device tree layout system.
    Also, IF you haven't run through them, I suggest you go through the Nordic courses on how to use their tools.
  • I am using the Adafruit Feather nRF52840 Sense board with an external SPI NOR flash (Winbond W25Q32JV) in nRF Connect SDK 2.9.0. However, the flash is not being recognized, and I get the following error:
    E: Device id 00 00 00 does not match config ef 40 16
    Flash device w25q32jv@0 is not ready
    Here is my overlay file:
     &spi1 {
    	status = "okay";
    	cs-gpios = <&gpio0 8 GPIO_ACTIVE_LOW>;
    	pinctrl-0 = <&spi1_default>;
    	pinctrl-1 = <&spi1_sleep>;
    	w25q32jv: w25q32jv@0 {
    		compatible = "jedec,spi-nor";
    		reg = <0>;
    		spi-max-frequency = <40000000>;
    		size = <0x2000000>;
    		has-dpd;
    		t-enter-dpd = <3000>;
    		t-exit-dpd = <30000>;
    		jedec-id = [ ef 40 16 ];
        chosen {
            nordic,pm-ext-flash = &w25q32jv;
    Here is my prj.conf file:
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_SERIAL=y
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    CONFIG_UART_ASYNC_API=y
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="Nordic_LBS"
    # Enable the LBS service
    CONFIG_BT_LBS=y
    CONFIG_BT_LBS_POLL_BUTTON=y
    CONFIG_DK_LIBRARY=y
    CONFIG_GPIO=y
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_SFDP_DEVICETREE=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_NORDIC_QSPI_NOR=n  # Explicitly disable QSPI if using SPI
    CONFIG_SPI_NOR_SFDP_MINIMAL=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL=y
    CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x8000
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    What could be causing this issue, and how can I fix it? Any suggestions would be appreciated!
    Normally means some electrical problem, try to connect a logic analyzer to the spi pins and check if the chip select, clock and mosi transfers as expected, then check if there is any data on miso. Maybe check that the external flash have same power supply level, and common ground with the DK.
    Kenneth
  • I am checking with the ESP32 module, and it works correctly. I believe the module is working, and there are no hardware issues.
