BLE Connection Issue with Multiple Simultaneous Peripherals
I have a BLE system where multiple sensors operate as peripherals and send data to a BLE central. These sensors enter sleep mode after transmitting data and later wake up to send new information.
I have observed an issue when increasing the number of sensors connected to the same central. Specifically, when two sensors become available for connection simultaneously, communication starts to fail. This affects the system's stability and impacts the reliability of data transmission.
Currently, I establish connections using the UUID of the NUS service, while other BLE parameters, such as the device name, remain identical among the sensors.
Communication Flow:
  1. The central identifies a peripheral through advertising.
  2. The central establishes a connection with the peripheral.
  3. The central stops the scanning process.
  4. The peripheral and central exchange information.
  5. The central disconnects from the peripheral.
  6. The central restarts scanning while two peripherals are advertising simultaneously.
Observed Behavior:
  • If only one sensor is available for connection, the process works correctly.
  • If two sensors are available simultaneously, communication fails, and the central cannot manage connections properly.
  • When this issue occurs, communication starts timing out, there are unexpected disconnections, and intermittent failures appear, such as the following:
00> [01:58:53.731,842] <inf> BLE: scan_filter_match: Filters matched. Address: DE:62:6A:79:C5:A5 (random) connectable: 1
00> [01:58:54.357,177] <inf> BLE: connected: Connected: DE:62:6A:79:C5:A5 (random)
00> [01:58:54.461,456] <inf> BLE: exchange_func: MTU exchange done
00> [01:58:58.293,762] <inf> MAIN: ble_connected_state: Connection state timeout
00> [01:58:58.293,792] <inf> PROTO: log_protocol_infos: Num: 0 - Extra: 0 - Off: 0
00> [01:58:58.293,792] <inf> PROTO: log_protocol_infos: data: 00 00 00 00
00> [01:58:58.293,823] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
00> [01:58:58.393,920] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
00> [01:58:58.393,951] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
00> [01:58:58.494,049] <inf> MAIN: ble_discovery_state: BLE Discovery State
00> [01:58:58.610,198] <err> nus_c: bt_nus_handles_assign: Missing NUS TX characteristic.
00> [01:58:58.610,198] <err> nus_c: bt_nus_subscribe_receive: Subscribe failed (err -128)
00> [01:58:58.610,351] <inf> BLE: disconnected: Disconnected: DE:62:6A:79:C5:A5 (random) (reason 8)
00> [01:58:58.611,053] <inf> MAIN: ble_discovery_state: BLE Connected
00> [01:58:58.626,312] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
00> [01:58:58.726,379] <inf> MAIN: ble_connected_state: START FLAG sent
00> [01:58:58.726,409] <err> BLE: bluetooth_central_send_data: Cannot send data, no BLE connection
Questions:
  1. Are there any known limitations in managing multiple sequential connections with peripherals that have similar parameters?
  2. Are there any recommendations to handle this scenario better? Any specific configurations in Zephyr or SoftDevice that could help?
  3. Any best practices to differentiate peripherals and avoid connection conflicts?
I appreciate any guidance that can help resolve this issue.
  • Hi Arthur,
    We will need to take a look at how you handle multiple connections in your central code.
    Please show your code and your project configuration.
    Have you looked at this issue:
    Have you made sure you do service discovery correctly when connect to a new peripheral ?
    I would suggest to get familiar with the nRF Sniffer. It's very useful for debugging.
  • Thanks for your response.
    Currently, our central does not support multiple connections. It simply connects to the first peripheral that appears during the scanning process and performs the entire data exchange procedure with that device.
    We’ve only observed the issue when we have too many sensors operating at the same time — specifically when two or more peripherals are advertising simultaneously at the exact moment the central starts scanning. I’ve attached the central_ble file so you can take a look.
    /* main.c - Application main entry point */
    #include <errno.h>
    #include <zephyr/kernel.h>
    #include <zephyr/device.h>
    #include <zephyr/sys/byteorder.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <bluetooth/services/nus.h>
    #include <bluetooth/services/nus_client.h>
    #include <bluetooth/gatt_dm.h>
    #include <bluetooth/scan.h>
    #include <zephyr/settings/settings.h>
    #include <zephyr/random/rand32.h>
    #include "bluetooth_central_app.h"
    #include "data_structures.h"
    #include "protocol.h"
    LOG_MODULE_REGISTER(BLE, CONFIG_LOG_DEFAULT_LEVEL);
    #ifdef CONFIG_USE_CODED_PHY
    #pragma message "Build with LongRange"
    #else
    #pragma message "Build WITHOUT LongRange"
    #endif //CONFIG_USE_CODED_PHY
    /* Connection handle */
    static struct bt_conn *default_conn;
    /* NUS client handle */
    static struct bt_nus_client nus_client;
    /* Buffer to receive data - 492 bytes */
    static uint8_t packet_buffer[BLUETOOTH_PACKET_SIZE] = {0};
    /* Buffer size */
    static uint16_t packet_buffer_len = 0;
    /* Services discovery flag*/
    static bool services_discovery_completed = false;
    K_SEM_DEFINE(ble_connection_discovery_sem, 0, 1);
    static void ble_data_sent(struct bt_nus_client *nus, uint8_t err,
    						  const uint8_t *const data, uint16_t len)
    	ARG_UNUSED(nus);
    	//LOG_INF("NUS sent data callback");
    void bluetooth_start_scan (void)
    	int ret = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
    	if (ret != SUCCESS) {
    		LOG_ERR("Scanning failed to start (ret %d)", ret);
    	LOG_INF("Start bt_scan");
    static uint8_t ble_data_received(struct bt_nus_client *nus, const uint8_t *data, uint16_t len)
    	ARG_UNUSED(nus);
    	// LOG_INF("Received data len: %d", len);
    	memset((void *)&packet_buffer, (int)0x00, (size_t)BLUETOOTH_PACKET_SIZE);
    	memcpy((void *)&packet_buffer, (const void *)data, (size_t)len);
    	packet_buffer_len = len;
    	if (protocol_parse_packet((const uint8_t *)&packet_buffer, packet_buffer_len) == SUCCESS) {
    		return BT_GATT_ITER_CONTINUE;
    	return BT_GATT_ITER_STOP;
    static void discovery_complete(struct bt_gatt_dm *dm,
    							   void *context)
    	struct bt_nus_client *nus = context;
    	//LOG_INF("Service discovery completed");
    	bt_gatt_dm_data_print(dm);
    	bt_nus_handles_assign(dm, nus);
    	bt_nus_subscribe_receive(nus);
    	bt_gatt_dm_data_release(dm);
    	k_sem_give(&ble_connection_discovery_sem);
    	services_discovery_completed = true;
    static void discovery_service_not_found(struct bt_conn *conn, void *context)
    	LOG_INF("Service not found");
    static void discovery_error(struct bt_conn *conn, int err, void *context)
    	LOG_ERR("Error while discovering GATT database: (%d)", err);
    struct bt_gatt_dm_cb discovery_cb = {
    	.completed = discovery_complete,
    	.service_not_found = discovery_service_not_found,
    	.error_found = discovery_error,
    static void gatt_discover(struct bt_conn *conn)
    	int ret = SUCCESS;
    	if (conn != default_conn) {
    		return;
    	ret = bt_gatt_dm_start(conn, BT_UUID_NUS_SERVICE, &discovery_cb, &nus_client);
    		LOG_ERR("could not start the discovery procedure, error code: %d", ret);
    static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
    	if (!err) {
    		LOG_INF("MTU exchange done");
    	} else {
    		LOG_ERR("MTU exchange failed (err %" PRIu8 ")", err);
    static void connected(struct bt_conn *conn, uint8_t conn_err)
    	char addr[BT_ADDR_LE_STR_LEN] = {0};
    	int ret = SUCCESS;
    	if (conn_err) {
    		LOG_ERR("Failed to connect to %s (%d)", addr, conn_err);
    		if (default_conn == conn) {
    			bt_conn_unref(default_conn);
    			default_conn = NULL;
    			bluetooth_start_scan();
    		return;
    	LOG_INF("Connected: %s", addr);
    	// Verificar MTU atual
    	uint16_t mtu = bt_gatt_get_mtu(conn);
    	//LOG_INF("Current MTU size: %u", mtu);
    	// Negociar MTU apenas se necessário
    	if (mtu == 23) { // Tamanho padrão significa que ainda não foi negociado
    		static struct bt_gatt_exchange_params exchange_params;
    		exchange_params.func = exchange_func;
    		ret = bt_gatt_exchange_mtu(conn, &exchange_params);
    		if (ret == 0) {
    			//LOG_INF("MTU exchange initiated");
    		} else if (ret == -EALREADY) {
    			LOG_WRN("MTU already exchanged");
    		} else {
    			LOG_ERR("MTU exchange failed (ret %d)", ret);
    	} else {
    		LOG_INF("MTU already negotiated, no need to exchange");
    	gatt_discover(conn);
    	// ret = bt_conn_set_security(conn, BT_SECURITY_L2);
    	// if (ret)
    	// 	LOG_WRN("Failed to set security: %d", ret);
    	// 	gatt_discover(conn);
    	ret = bt_scan_stop();
    	if ((!ret) && (ret != -EALREADY)) {
    		LOG_INF("Stop LE scan failed (ret %d)", ret);
    	LOG_INF("Disconnected: %s (reason %u)", addr, reason);
    	if (default_conn != conn) {
    		return;
    int bluetooth_is_connected(void)
    	if (default_conn == NULL){
    		return ERROR;
    	return SUCCESS;
    void bluetooth_disconnect_ble_nus(void)
    	if (default_conn) {
    		int ret = bt_conn_disconnect(default_conn, BT_HCI_ERR_LOCALHOST_TERM_CONN);
    		if (ret) {
    			LOG_ERR("Disconnection failed (err %d)", ret);
    		} else {
    			LOG_INF("Disconnection initiated");
    	} else {
    		LOG_INF("No active connection to disconnect");
    static void security_changed(struct bt_conn *conn, bt_security_t level,
    							 enum bt_security_err err)
    	if (!err) {
    		LOG_INF("Security changed: %s level %u", addr, level);
    	else {
    		LOG_ERR("Security failed: %s level %u err %d", addr, level, err);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected = connected,
    	.disconnected = disconnected,
    	.security_changed = security_changed
    static void scan_filter_match(struct bt_scan_device_info *device_info,
    							  struct bt_scan_filter_match *filter_match,
    							  bool connectable)
    	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
    	LOG_INF("Filters matched. Address: %s connectable: %d", addr, connectable);
    	// Se já houver uma conexão ativa, ignora novos anúncios
    	if (default_conn) {
    		LOG_INF("Já existe conexão ativa. Ignorando novo anúncio.");
    		return;
    	int ret;
    	struct bt_conn_le_create_param *conn_params;
    	if (ret) {
    		LOG_ERR("Stop LE scan failed (ret %d)", ret);
    	conn_params = BT_CONN_LE_CREATE_PARAM(
    		BT_CONN_LE_OPT_CODED | BT_CONN_LE_OPT_NO_1M,
    		BT_GAP_SCAN_FAST_INTERVAL,
    		BT_GAP_SCAN_FAST_INTERVAL);
    	ret = bt_conn_le_create(device_info->recv_info->addr, conn_params,
    							BT_LE_CONN_PARAM_DEFAULT,
    							&default_conn);
    	if (ret) {
    		LOG_ERR("Create conn failed (ret %d)", ret);
    	//LOG_INF("Connection pending");
    static void scan_connecting_error(struct bt_scan_device_info *device_info)
    	LOG_ERR("Connecting failed");
    static void scan_connecting(struct bt_scan_device_info *device_info,
    	default_conn = bt_conn_ref(conn);
    static int nus_client_init(void)
    	int ret = SUCCESS;
    	struct bt_nus_client_init_param init = {
    		.cb = {
    			.received = ble_data_received,
    			.sent = ble_data_sent,
    	ret = bt_nus_client_init(&nus_client, &init);
    		LOG_ERR("NUS Client initialization failed (ret %d)", ret);
    		return ret;
    	LOG_INF("NUS Client module initialized");
    	return ret;
    BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
    				scan_connecting_error, scan_connecting);
    static int scan_init(void)
    	int ret = SUCCESS;
    	/* Use active scanning and disable duplicate filtering to handle any
    	 * devices that might update their advertising data at runtime. */
    	struct bt_le_scan_param scan_param = {
    		.type     = BT_LE_SCAN_TYPE_ACTIVE,
    		.interval = BT_GAP_SCAN_FAST_INTERVAL,
    		.window   = BT_GAP_SCAN_FAST_WINDOW,
    		.options  = BT_LE_SCAN_OPT_CODED | BT_LE_SCAN_OPT_NO_1M
    	struct bt_scan_init_param scan_init = {
    		.connect_if_match = 0,
    		.scan_param = &scan_param,
    		.conn_param = NULL
    	#else
    		.connect_if_match = 1,
    	bt_scan_init(&scan_init);
    	bt_scan_cb_register(&scan_cb);
    	ret = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
    		LOG_ERR("Scanning filters cannot be set (ret %d)", ret);
    		return ret;
    	ret = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
    		LOG_ERR("Filters cannot be turned on (ret %d)", ret);
    		return ret;
    	LOG_INF("Scan module initialized");
    	return ret;
    static void auth_cancel(struct bt_conn *conn)
    	LOG_INF("Pairing cancelled: %s", addr);
    static void pairing_complete(struct bt_conn *conn, bool bonded)
    	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
    static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
    	LOG_WRN("Pairing failed conn: %s, reason %d", addr, reason);
    static struct bt_conn_auth_cb conn_auth_callbacks = {
    	.cancel = auth_cancel,
    static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
    	.pairing_complete = pairing_complete,
    	.pairing_failed = pairing_failed
    int bluetooth_central_init(void)
    	int ret = SUCCESS;
    	// Enable pins of SKY66112-11
    	const struct device* gpio0_dev = device_get_binding("gpio@50000000"); // gpio 0
    	//	Table 6. SKY66112-11 Mode Control Logic1
    	//	Mode	Description 		CPS	CHL
    	//	1 	Receive LNA 		0 	X
    	//	2 	Transmit high-power 	0 	1
    	gpio_pin_configure(gpio0_dev, 6, GPIO_OUTPUT); // gpio 0.06 - CPS
    	gpio_pin_set(gpio0_dev, 6, 0);
    	gpio_pin_configure(gpio0_dev, 8, GPIO_OUTPUT); // gpio 0.08 - CHL
    	gpio_pin_set(gpio0_dev, 8, 1);
    	ret = bt_conn_auth_cb_register(&conn_auth_callbacks);
    		LOG_ERR("Failed to register authorization callbacks.");
    		return ERROR;
    	ret = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
    		LOG_ERR("Failed to register authorization info callbacks.");
    		return ERROR;
    	ret = bt_enable(NULL);
    		LOG_ERR("Bluetooth init failed (ret %d)", ret);
    		return ERROR;
    	LOG_INF("Bluetooth initialized");
    	if (IS_ENABLED(CONFIG_SETTINGS)) {
    		settings_load();
    	ret = scan_init();
    		LOG_ERR("scan_init failed (ret %d)", ret);
    		return ERROR;
    	ret = nus_client_init();
    		LOG_ERR("nus_client_init failed (ret %d)", ret);
    		return ERROR;
    		return ERROR;
    	LOG_INF("Scanning successfully started");
    	return SUCCESS;
    int bluetooth_central_send_data(const uint8_t *data, uint16_t len)
    	int ret = SUCCESS;
    	if (!default_conn) {
    		LOG_ERR("Cannot send data, no BLE connection");
    		return -ENOTCONN;
    	ret = bt_nus_client_send(&nus_client, data, len);
    		LOG_ERR("BT NUS send ERROR: %d", ret);
    		return ERROR;
    	return ret;
    bool bluetooth_service_discovery_completed(void)
    	return services_discovery_completed;
    In this case, is implementing multiple simultaneous connections strictly necessary to avoid this failure? If so, would you happen to have an example suited to this use case?
    Our idea is to keep the current approach: connect to the first sensor that appears, perform the data exchange, and disconnect. The other peripherals would only send a command or flag indicating they should wait or disconnect if not selected.
    Let me know your thoughts. Thanks again for the support!
    Arthur
  • Hi Arthur,
    What you describe is a very common use case for a central device that it need to scan for a peripheral and connect to it. I am not aware of any issue related to the central has problem when multiple peripherals advertise. I don't think implementing multi connection handling is the way to go here.
    From what I can see in your log is that right after connection the link is terminated:
    But I don't fully understand this:
    What is this discovery state ? Can you show the code ?
    After the device get disconnected the process of discovery, subscribe to the characteristic or sending data should be stopped. But from the log it was not. The state machine continued after the disconnection. So you need to check your state machine and should not continue to call bluetooth_central_send_data() if the link is disconnected or if bt_nus_subscribe_receive() return failed.
    Do you see the same problem when you test with our central_uart sample ?
  • Hi Hung,
    Thanks again for your previous feedback.
    I’m following up with more information and a detailed timeline of the issue I’m facing. Our setup involves a BLE central that connects to one sensor at a time, performs data exchange (about 100 packets, 98 of them with 492 bytes each), and then disconnects. After disconnecting, the central restarts scanning. Each sensor goes into deep sleep for 60 seconds after completing communication before reattempting advertising.
    Both the central and peripherals are using CODED PHY.
    Here’s a simplified timeline illustrating the expected behavior with 3 sensors, which works reliably:
    | Time (s) | 0 | 5 | 10 | 15 | 20 | 25 | 30 | 35 | 40 | 45 | 50 | 55 | 60 | 65 | 70 | 75 | 80 | 85 | 90 | 95 | 100 | 105 | 110 | 115 | 120 |
    | Sensor 1 | communicating        | sleeping                                                  | communicating      | sleeping              |
    | Sensor 2 | sleeping             | communicating     | sleeping                                                   | communicating         |
    | Sensor 3 | sleeping                                 | communicating     | sleeping                                                       |
    Each communication lasts about 20 seconds, and this sequencing has worked well with up to 3 sensors. However, when a 4th sensor is introduced, failures start to appear. Below is a log extract showing several disconnection reasons and related error codes
    Key Observations:
    • Some connections fail early during data exchange with disconnection reason 8, often at varying packet counts (e.g., packet 70, 43, or even 0).
    • In certain cases, the NUS service cannot be properly discovered:
    • Disconnection reason 19 is also seen, though it usually indicates normal disconnection after successful communication.
    Below is a summarized log highlighting key connection and disconnection events for each sensor, including failure reasons and relevant error messages.
    The full log with all BLE events and debug messages follows right after the summary.
    (((Power on sensor 4)))
    [01:40:46.051,757] connects to sensor 4
    [01:41:03.718,933] disconnects (reason 19) sensor 4 – completed full procedure successfully
    [01:41:03.826,416] enable scan
    [01:41:04.208,435] connects to sensor 3
    [01:41:17.217,803] disconnects (reason 8) sensor 3 – failed at packet 70
    [01:42:05.556,823] enable scan
    [01:42:05.638,122] connects to sensor 3
    [01:42:22.946,166] disconnects (reason 19) sensor 3 – completed full procedure successfully
    [01:42:23.103,820] enable scan
    [01:42:23.122,711] connects to sensor 1
    [01:42:40.217,803] disconnects (reason 8) sensor 1 – failed at packet 43
    [01:43:24.477,111] enable scan
    [01:43:24.627,105] connects to sensor 2
    [01:43:24.839,813] <inf> BLE: exchange_func: MTU exchange done
    [01:43:28.988,525] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    [01:43:28.988,555] <err> nus_c: bt_nus_handles_assign: Missing NUS TX characteristic.
    [01:43:28.988,555] <err> nus_c: bt_nus_subscribe_receive: Subscribe failed (err -128)
    [01:43:28.988,708] disconnects (reason 8) sensor 2 – failed at packet 0
    [01:44:29.139,099] enable scan
    [01:44:29.286,468] connects to sensor 4
    [01:44:29.500,793] <inf> BLE: exchange_func: MTU exchange done
    [01:44:33.649,505] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    [01:44:33.649,505] <err> nus_c: bt_nus_handles_assign: Missing NUS TX characteristic.
    [01:44:33.649,536] <err> nus_c: bt_nus_subscribe_receive: Subscribe failed (err -128)
    [01:44:33.649,688] disconnects (reason 8) sensor 4 – failed at packet 0
    [01:45:33.800,018] enable scan
    [01:45:33.868,194] connects to sensor 1
    [01:45:51.726,470] disconnects (reason 8) sensor 1 – completed full procedure successfully
    [01:45:51.885,345] enable scan
    [01:45:51.893,218] connects to sensor 4
    [01:46:09.251,403] disconnects (reason 19) sensor 4 – completed full procedure successfully
    [01:46:09.409,027] enable scan
    [01:46:43.688,690] connects to sensor 2
    [01:47:00.854,919] disconnects (reason 19) sensor 2 – completed full procedure successfully
    [01:47:01.015,838] enable scan
    [01:47:06.683,990] connects to sensor 1
    [01:47:24.042,785] disconnects (reason 19) sensor 1 – completed full procedure successfully
    [01:47:24.151,397] enable scan
    [01:47:24.166,168] connects to sensor 3
    [01:47:41.629,913] disconnects (reason 19) sensor 3 – completed full procedure successfully
    [01:47:41.787,689] enable scan
    [01:47:41.871,307] connects to sensor 4
    [01:47:55.688,964] disconnects (reason 8) sensor 4 – failed at packet 74
    [01:48:43.227,600] enable scan
    [01:48:43.372,680] connects to sensor 2
    [01:48:50.837,921] disconnects (reason 8) sensor 2 – failed at packet 11
    **(((Power off sensor 4)))**
    [01:49:44.483,398] enable scan
    [01:49:44.502,655] connects to sensor 2
    [01:49:59.251,403] disconnects (reason 19) sensor 2 – completed full procedure successfully
    The following is the complete log output, including all BLE events, debug messages, and data transfer notifications observed during the test.
    For reference, the MAC addresses of the sensors are:
    • Sensor 1 → C8:71:CB:20:81:0A
    • Sensor 2 → D3:D4:C0:F4:AC:94
    • Sensor 3 → E1:35:E1:4C:E8:10
    • Sensor 4 → E7:EA:8B:10:13:35
    00> [01:07:31.735,046] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:07:31.735,076] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:07:31.835,174] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> [01:07:58.687,347] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:07:58.800,506] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:07:58.904,815] <inf> BLE: exchange_func: MTU exchange done
    00> [01:07:59.654,357] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:07:59.654,388] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:07:59.654,418] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:07:59.654,449] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:07:59.654,510] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:07:59.654,632] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:07:59.663,665] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:07:59.763,763] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:08:00.612,335] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:08:00.612,396] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:08:00.612,396] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:08:00.771,331] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:00.917,877] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:01.085,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:01.214,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:01.378,265] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:01.517,883] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:01.664,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:01.814,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:01.964,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:02.157,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:02.264,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:02.414,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:02.564,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:02.714,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:02.864,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:03.014,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:03.164,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:03.314,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:03.464,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:03.628,265] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:03.764,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:03.914,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:04.064,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:04.214,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:04.464,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:04.653,991] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:04.764,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:04.914,428] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:05.064,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:05.214,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:05.381,744] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:08:05.517,883] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:05.674,804] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:05.817,871] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:05.964,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:06.114,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:06.314,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:06.464,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:06.660,949] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:06.771,331] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:06.954,010] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:07.064,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:07.214,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:07.364,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:07.514,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:07.664,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:07.814,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:07.964,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:08.114,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:08.314,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:08.464,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:08.660,949] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:08.764,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:08.914,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:09.064,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:09.214,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:09.364,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:09.514,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:09.681,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:09.814,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:09.987,457] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:10.114,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:10.217,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:10.387,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:10.514,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:10.664,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:10.814,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:11.057,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:11.164,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:11.314,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:11.464,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:11.614,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:11.764,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:11.935,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:12.064,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:12.214,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:12.364,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:12.517,883] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:12.664,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:12.814,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:13.007,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:13.160,949] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:13.264,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:13.414,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:13.594,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:13.714,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:13.864,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:14.014,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:14.164,398] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:14.364,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:14.564,392] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:14.714,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:14.864,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:15.014,404] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:15.207,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:15.357,452] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:15.464,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:15.614,410] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:08:15.780,731] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:08:15.805,877] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:08:15.808,746] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:08:16.052,978] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:08:16.053,100] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:08:16.109,130] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:08:16.209,197] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:08:16.209,838] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:08:16.209,869] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:08:16.242,218] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:08:16.309,936] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:08:16.352,844] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:08:16.457,153] <inf> BLE: exchange_func: MTU exchange done
    00> [01:08:17.206,695] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:08:17.206,726] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:08:17.206,756] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:08:17.206,787] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:08:17.206,848] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:08:17.206,970] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:08:17.216,003] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:08:17.316,101] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:08:18.164,672] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:08:18.164,733] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:08:18.164,733] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:08:18.323,669] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:18.466,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:18.616,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:18.766,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:08:18.966,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:19.116,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:19.266,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:19.416,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:19.566,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:19.716,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:19.866,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:20.016,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:20.166,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:20.316,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:20.466,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:20.616,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:20.766,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:20.923,675] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:21.116,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:21.266,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:21.416,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:21.613,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:21.716,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:08:21.966,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:22.116,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:22.266,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:22.416,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:22.580,627] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:22.716,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:22.866,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:23.016,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:23.170,196] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:23.316,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:23.466,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:23.616,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:23.766,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:23.916,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:24.066,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:24.216,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:24.366,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:24.516,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:24.666,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:24.816,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:24.966,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:25.116,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:25.266,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:25.416,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:25.616,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:25.766,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:25.959,808] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:26.066,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:26.216,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:26.320,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:26.466,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:26.616,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:26.766,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:08:26.916,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:27.066,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:27.234,069] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:27.416,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:27.566,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:27.716,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:27.866,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:28.016,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:28.166,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:28.270,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:28.446,746] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:28.566,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:28.716,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:28.866,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:29.016,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:29.166,778] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:29.323,669] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:29.466,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:29.616,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:29.766,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:29.963,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:30.109,802] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:30.216,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:30.366,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:30.516,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:30.666,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:30.773,681] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:30.916,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:31.066,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:31.216,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:31.366,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:31.516,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:31.666,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:31.816,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:31.966,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:32.116,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:32.266,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:32.416,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:32.566,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:32.716,735] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:32.866,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:33.016,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:33.136,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:08:33.161,651] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:08:33.162,933] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:08:33.405,334] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:08:33.405,426] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:08:33.463,317] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:08:33.563,385] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:08:33.564,025] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:08:33.564,056] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:08:33.664,123] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:08:46.613,861] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:08:46.727,508] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:08:46.831,817] <inf> BLE: exchange_func: MTU exchange done
    00> [01:08:47.581,359] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:08:47.581,390] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:08:47.581,420] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:08:47.581,451] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:08:47.581,512] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:08:47.581,634] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:08:47.590,667] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:08:47.690,765] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:08:48.539,337] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:08:48.539,398] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:08:48.539,398] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:08:48.698,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:48.841,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:48.991,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:49.141,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:49.291,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:49.441,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:49.591,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:49.741,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:49.891,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:50.041,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:50.191,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:08:50.341,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:50.491,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:50.641,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:50.791,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:08:50.962,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:51.091,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:51.241,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:51.391,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:51.541,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:51.691,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:51.841,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:51.991,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:52.141,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:08:52.430,999] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:52.541,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:52.691,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:52.841,430] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:52.991,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:53.141,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:53.291,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:53.441,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:53.601,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:53.741,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:53.891,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:54.041,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:54.191,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:54.341,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:54.491,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:54.641,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:54.791,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:54.941,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:55.091,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:55.241,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:55.391,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:55.541,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:55.691,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:55.841,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:55.991,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:56.141,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:56.291,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:56.441,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:56.591,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:56.741,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:56.891,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:57.041,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:57.191,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:57.341,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:57.512,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:57.641,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:57.791,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:57.941,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:58.098,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:58.241,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:58.441,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:58.591,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:58.741,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:58.891,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:59.041,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:59.194,885] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:59.341,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:59.494,873] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:59.641,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:59.791,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:08:59.941,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:00.091,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:00.244,873] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:00.391,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:00.541,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:00.691,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:00.881,011] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:09:00.991,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:01.141,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:01.291,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:01.441,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:01.591,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:01.741,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:01.891,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:02.041,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:02.191,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:02.341,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:02.491,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:02.691,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:02.887,939] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:02.991,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:03.141,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:03.291,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:03.441,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:03.561,187] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:09:03.586,303] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:09:03.638,061] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:09:03.879,974] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:09:03.880,096] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:09:03.938,446] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:09:04.038,513] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:09:04.039,154] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:09:04.039,184] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:09:04.139,251] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:09:31.294,158] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:09:31.406,158] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:09:31.510,467] <inf> BLE: exchange_func: MTU exchange done
    00> [01:09:32.209,991] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:09:32.210,021] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:09:32.210,052] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:09:32.210,083] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:09:32.210,144] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:09:32.210,296] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:09:32.219,329] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:09:32.319,427] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:09:33.167,968] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:09:33.168,029] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:09:33.168,060] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:09:33.326,995] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:33.470,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:33.620,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:33.770,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:33.920,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:34.070,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:34.220,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:34.370,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:34.520,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:34.670,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:34.820,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:34.970,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:35.120,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:35.276,977] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:35.420,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:35.570,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:35.720,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:35.870,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:36.020,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:36.220,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:36.370,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:36.520,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:36.670,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:36.840,850] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:09:37.070,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:37.220,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:37.370,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:37.520,080] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:37.670,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:37.820,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:37.970,031] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:38.120,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:38.270,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:38.420,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:38.523,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:38.670,074] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:38.820,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:38.970,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:09:39.120,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:39.320,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:39.470,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:39.620,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:39.770,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:39.920,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:40.070,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:40.220,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:40.370,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:40.520,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:40.670,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:40.820,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:40.976,989] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:41.120,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:41.270,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:41.423,522] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:41.570,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:41.720,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:41.870,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:42.020,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:42.170,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:42.320,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:42.513,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:42.620,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:42.800,048] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:42.920,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:43.113,098] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:43.220,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:43.370,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:43.520,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:43.703,613] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:43.820,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:44.020,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:44.170,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:44.366,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:44.520,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:44.683,929] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:44.850,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:44.970,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:45.120,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:45.270,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:45.420,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:45.570,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:45.720,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:45.870,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:46.020,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:46.170,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:46.320,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:46.516,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:46.626,983] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:46.770,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:46.920,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:47.070,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:47.220,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:47.370,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:47.520,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:47.670,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:47.820,037] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:47.970,062] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:48.120,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:48.239,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:09:48.264,984] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:09:48.315,368] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:09:48.658,630] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:09:48.658,721] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:09:48.715,820] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:09:48.815,887] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:09:48.816,528] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:09:48.816,558] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:09:48.916,625] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:09:48.962,127] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:09:49.072,479] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:09:49.176,788] <inf> BLE: exchange_func: MTU exchange done
    00> [01:09:49.876,342] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:09:49.876,373] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:09:49.876,403] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:09:49.876,434] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:09:49.876,495] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:09:49.876,617] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:09:49.885,650] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:09:49.985,748] <inf> MAIN: ble_connected_state: START FLAG sent
    00> Received:
    00> +CSCON: 0
    00> .[01:09:50.834,289] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:09:50.834,381] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:09:50.834,381] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:09:50.993,316] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:51.179,443] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:51.286,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:51.436,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:51.629,455] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:51.736,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:51.886,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:52.036,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:52.186,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:52.336,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:52.486,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:52.636,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:52.786,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:52.936,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:53.086,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:53.286,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:53.436,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:53.586,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:53.736,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:53.886,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:54.036,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:54.186,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:54.336,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:54.486,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:09:54.746,795] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:54.886,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:55.036,407] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:55.186,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:55.336,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:55.486,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:55.636,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:55.829,437] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:55.936,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:56.086,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:56.236,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:56.409,454] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:56.536,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:56.686,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:56.836,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:56.996,795] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:57.136,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:57.286,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:57.436,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:57.636,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:57.832,916] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:57.966,369] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:58.086,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:58.236,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:58.386,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:58.536,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:58.686,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:58.836,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:58.986,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:59.146,789] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:59.286,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:59.436,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:59.586,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:59.736,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:09:59.886,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:00.069,946] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:00.186,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:00.336,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:00.439,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:10:00.586,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:00.736,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:00.886,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:01.036,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:01.186,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:01.336,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:01.486,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:01.686,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:01.836,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:01.986,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:02.136,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:02.286,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:02.393,310] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:02.536,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:02.686,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:02.836,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:02.986,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:03.136,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:03.286,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:03.436,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:03.586,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:03.786,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:03.936,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:04.086,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:04.275,970] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:04.389,862] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:04.536,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:04.689,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:04.836,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:04.986,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:05.136,383] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:05.300,262] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:05.436,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:05.586,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:05.736,389] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:05.856,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:10:05.881,286] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:10:05.881,530] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:10:06.124,969] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:10:06.125,061] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:10:06.181,915] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:10:06.281,982] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:10:06.282,623] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:10:06.282,653] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:10:06.382,720] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:10:19.215,179] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:10:19.327,301] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:10:19.431,610] <inf> BLE: exchange_func: MTU exchange done
    00> [01:10:20.131,134] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:10:20.131,164] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:10:20.131,195] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:10:20.131,225] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:10:20.131,286] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:10:20.131,408] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:10:20.140,441] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:10:20.240,539] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:10:21.089,111] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:10:21.089,172] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:10:21.089,202] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:10:21.248,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:21.391,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:21.541,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:21.691,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:21.841,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:21.991,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:22.141,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:22.291,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:22.441,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:22.591,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:22.741,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:22.891,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:23.087,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:23.241,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:23.391,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:23.541,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:23.691,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:23.841,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:23.991,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:24.141,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:24.291,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:24.441,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:10:24.591,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:24.741,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:10:24.991,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:25.141,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:25.244,659] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:25.391,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:25.541,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:25.691,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:25.841,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:25.991,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:26.241,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:26.411,987] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:26.541,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:26.691,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:26.841,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:27.021,179] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:27.141,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:27.291,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:27.491,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:27.641,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:27.791,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:27.941,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:28.091,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:28.194,641] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:28.341,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:28.491,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:28.641,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:28.791,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:28.951,599] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:29.091,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:29.244,659] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:29.391,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:29.541,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:29.691,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:29.798,126] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:29.941,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:30.124,755] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:30.241,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:30.417,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:30.541,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:30.691,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:30.841,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:30.991,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:31.141,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:31.291,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:31.541,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:31.691,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:31.841,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:31.991,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:32.141,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:32.291,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:32.441,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:32.594,635] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:32.741,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:32.891,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:33.041,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:33.191,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:33.341,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:33.491,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:33.641,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:33.791,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:33.941,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:34.091,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:34.241,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:34.424,743] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:34.541,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:10:34.691,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:34.841,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:34.991,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:35.141,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:35.291,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:35.441,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:35.591,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:35.741,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:35.891,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:36.041,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:10:36.160,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:10:36.186,096] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:10:36.189,758] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:10:36.479,766] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:10:36.479,858] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:10:36.490,142] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:10:36.590,209] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:10:36.590,850] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:10:36.590,881] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:10:36.690,948] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CEREG: 1,"C3C7","0DBD1516",7,
    00> [01:11:03.905,303] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:11:04.012,268] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:11:04.116,577] <inf> BLE: exchange_func: MTU exchange done
    00> [01:11:04.816,101] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:11:04.816,131] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:11:04.816,162] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:11:04.816,192] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:11:04.816,284] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:11:04.816,406] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:11:04.825,439] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:11:04.925,506] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:11:05.774,078] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:11:05.774,139] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:11:05.774,169] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:11:05.933,105] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:06.076,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:06.226,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:06.376,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:06.536,560] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:06.676,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:06.833,099] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:06.976,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:07.126,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:07.276,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:07.476,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:07.626,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:07.776,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:07.926,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:08.076,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:08.226,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:08.376,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:08.526,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:08.676,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:08.826,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:08.979,614] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:09.126,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:09.326,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:09.476,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:11:09.726,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:09.876,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:10.026,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:10.176,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:10.326,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:10.476,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:10.626,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:10.776,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:10.926,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:11.076,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:11.226,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:11.376,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:11.526,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:11.676,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:11.826,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:12.006,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:12.126,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:12.276,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:12.383,087] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:12.526,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:12.690,032] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:12.826,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:11:12.983,093] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:13.126,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:13.326,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:13.476,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:13.719,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:13.826,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:13.976,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:14.126,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:14.276,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:14.426,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:14.579,620] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:14.726,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:14.876,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:15.036,560] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:15.176,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:15.329,620] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:15.476,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:15.626,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:15.776,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:15.926,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:16.115,753] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:16.226,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:16.376,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:16.526,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:16.676,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:16.826,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:16.976,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:17.126,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:17.276,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:17.426,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:17.576,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:17.776,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:17.926,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:18.076,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:18.226,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:18.379,638] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:18.483,093] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:18.652,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:18.776,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:18.926,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:11:19.119,232] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:19.226,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:19.376,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:19.576,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:19.726,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:19.926,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:20.076,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:20.226,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:20.376,159] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:20.526,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:20.676,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:20.829,620] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:20.945,953] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:11:20.971,069] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:11:20.973,876] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:11:21.264,739] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:11:21.264,831] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:11:21.274,261] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:11:21.374,328] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:11:21.374,969] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:11:21.375,000] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:11:21.467,071] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:11:21.475,097] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:11:21.581,939] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:11:21.686,218] <inf> BLE: exchange_func: MTU exchange done
    00> [01:11:22.385,772] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:11:22.385,803] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:11:22.385,833] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:11:22.385,864] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:11:22.385,925] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:11:22.386,047] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:11:22.395,080] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:11:22.495,178] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:11:23.343,750] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:11:23.343,811] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:11:23.343,811] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:11:23.502,746] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:23.645,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:23.795,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:23.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:11:24.095,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:24.245,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:24.395,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:24.545,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:24.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:24.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:25.088,867] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:25.195,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:25.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:25.495,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:25.645,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:25.795,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:25.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:26.095,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:26.245,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:26.395,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:26.545,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:26.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:26.895,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:27.142,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:27.385,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:27.495,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:27.602,752] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:27.745,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:27.895,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:28.045,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:28.195,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:28.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:28.495,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:28.649,291] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:28.795,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:28.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:29.095,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:29.245,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:29.395,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:29.545,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:29.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:29.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:29.995,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:30.145,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:30.295,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:30.506,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:30.645,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:30.795,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:30.995,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:31.145,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:31.342,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:31.445,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:31.595,855] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:31.745,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:31.895,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:32.045,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:32.195,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:32.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:32.495,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:32.645,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:32.795,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:32.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:33.095,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:33.245,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:33.395,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:33.545,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:33.695,800] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:33.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:33.995,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:34.145,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .Received:
    00> +CEREG: 1,"C3C7","0DC27C15",7,
    00> [01:11:34.322,357] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:34.445,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:34.595,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:34.745,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:34.906,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:35.045,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:35.245,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:35.395,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:35.545,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:35.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:35.888,885] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:35.995,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:36.145,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:36.295,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:36.468,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:36.595,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:36.745,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:36.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:37.095,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:37.245,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:37.395,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:37.595,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:37.792,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:37.938,873] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:38.045,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:38.195,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:38.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:38.495,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:38.615,600] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:11:38.640,747] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:11:38.690,460] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:11:38.934,387] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:11:38.934,509] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:11:38.990,844] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:11:39.090,911] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:11:39.091,552] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:11:39.091,583] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:11:39.191,680] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:11:51.719,909] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:11:51.829,986] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:11:51.934,295] <inf> BLE: exchange_func: MTU exchange done
    00> [01:11:52.633,819] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:11:52.633,850] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:11:52.633,880] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:11:52.633,911] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:11:52.634,002] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:11:52.634,124] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:11:52.643,127] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:11:52.743,225] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:11:53.591,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:11:53.591,888] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:11:53.591,918] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:11:53.750,823] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:53.893,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:54.043,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:54.243,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:54.393,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:54.543,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:54.693,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:54.843,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:54.993,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:55.147,338] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:55.293,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:55.443,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:55.593,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:55.747,344] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:55.893,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:56.043,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:56.233,459] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:56.343,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:56.493,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:56.643,859] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:56.836,944] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:56.943,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:57.093,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:11:57.333,465] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:57.443,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:57.593,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:57.764,678] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:57.893,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:11:58.043,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:58.193,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:58.343,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:58.493,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:58.643,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:58.843,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:58.993,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:59.143,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:59.293,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:59.443,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:59.620,391] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:59.786,926] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:11:59.893,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:00.043,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:00.193,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:00.343,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:00.493,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:00.643,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:00.793,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:00.943,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:01.093,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:01.243,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:01.407,745] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:01.543,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:01.693,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:01.843,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:01.993,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:02.143,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:02.293,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:02.443,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:02.593,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:02.743,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:02.893,859] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:03.043,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:03.193,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:03.343,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:03.493,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:03.643,859] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:03.793,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:03.943,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:04.093,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:04.243,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:04.393,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:04.543,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:04.693,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:04.843,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:04.993,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:05.143,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:05.293,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:05.443,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> [01:12:05.593,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:05.743,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:05.893,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:06.043,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:06.193,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:06.343,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:06.493,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:06.643,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:06.793,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:06.943,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:07.143,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:07.293,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:07.443,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:07.643,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:07.793,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:07.943,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:12:08.093,902] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:08.243,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:08.393,890] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:08.543,884] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:08.663,665] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:12:08.688,812] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:12:08.738,525] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:12:08.982,452] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:12:08.982,574] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:12:09.038,909] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:12:09.138,977] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:12:09.139,617] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:12:09.139,648] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:12:09.239,715] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:12:36.708,435] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:12:36.817,840] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:12:36.922,149] <inf> BLE: exchange_func: MTU exchange done
    00> [01:12:37.621,673] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:12:37.621,704] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:12:37.621,734] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:12:37.621,765] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:12:37.621,826] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:12:37.621,948] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:12:37.631,011] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:12:37.731,079] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:12:38.579,650] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:12:38.579,711] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:12:38.579,742] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:12:38.828,247] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:38.971,313] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:39.081,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:39.231,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:39.381,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:39.565,307] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:39.681,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:39.831,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:39.981,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:40.131,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:40.281,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:40.481,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:40.631,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:40.781,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:40.931,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:41.081,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:41.231,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:41.381,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:41.535,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:41.681,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:41.831,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:41.981,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:42.131,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:12:42.381,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:42.485,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:42.631,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:42.781,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:42.978,271] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:43.081,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:43.231,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:43.381,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:43.561,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:43.681,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:43.852,539] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:43.981,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:44.131,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:44.281,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:44.442,138] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:44.631,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:44.835,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:44.981,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:45.131,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:45.281,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:45.431,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:45.611,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:45.731,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:45.881,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:46.031,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:46.181,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:46.331,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:46.488,647] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:12:46.731,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:46.881,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:47.031,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:47.228,240] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:47.331,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:47.481,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:47.631,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:47.781,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:47.931,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:48.081,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:48.231,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:48.381,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:48.531,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:48.681,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:48.831,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:48.981,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:49.131,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:49.281,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:49.474,792] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:49.581,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:49.731,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:49.881,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:50.031,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:50.181,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 0
    00> [01:12:50.331,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:50.481,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:50.631,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:50.781,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:50.931,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:51.108,245] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:51.231,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:51.381,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:51.531,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:51.681,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:51.788,665] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:51.931,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:52.081,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:52.258,270] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:52.381,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:52.531,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:52.681,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:52.831,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:52.995,605] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:53.131,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:53.281,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:53.431,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:53.624,786] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:53.701,507] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:12:53.726,654] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:12:53.776,489] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:12:54.070,312] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:12:54.070,404] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:12:54.076,873] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:12:54.176,940] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:12:54.177,581] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:12:54.177,612] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:12:54.277,679] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:12:54.391,174] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:12:54.497,436] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:12:54.601,745] <inf> BLE: exchange_func: MTU exchange done
    00> [01:12:55.301,269] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:12:55.301,300] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:12:55.301,330] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:12:55.301,361] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:12:55.301,452] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:12:55.301,574] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:12:55.310,607] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:12:55.410,675] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:12:56.259,246] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:12:56.259,307] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:12:56.259,338] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:12:56.418,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:56.561,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:56.711,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:56.861,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:57.054,382] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:57.161,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:57.311,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:57.414,794] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:57.584,381] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:57.711,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:57.861,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:12:58.011,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:58.178,649] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:58.311,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:58.461,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:58.611,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:58.761,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:58.911,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:59.100,921] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:59.211,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:59.361,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:59.511,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:59.661,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:12:59.811,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:13:00.061,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:00.211,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:00.361,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:00.511,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:00.661,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:00.811,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:01.007,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:01.157,867] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:01.261,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:01.411,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:01.521,728] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:01.661,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:01.811,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:01.961,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:02.111,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:02.261,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:02.434,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:02.561,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:02.711,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:02.861,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:03.011,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:03.161,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:03.311,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:03.461,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:03.611,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:03.761,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:03.911,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:04.061,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:04.232,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:04.400,909] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:04.511,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:04.661,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:04.814,788] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:04.961,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:05.161,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:05.350,921] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:05.461,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:05.611,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:05.761,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:05.911,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:06.061,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:06.211,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:06.361,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:06.511,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:06.661,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:06.811,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:06.961,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:07.111,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:07.261,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:07.411,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:07.561,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:07.711,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:07.861,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:08.014,801] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:13:08.161,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:08.334,381] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:08.461,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:08.611,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:08.761,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:08.911,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:09.061,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:09.211,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:09.361,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:09.511,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:09.661,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:09.811,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:09.961,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:10.111,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:10.261,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:10.411,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:10.578,674] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:10.711,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:10.861,328] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:11.011,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:11.131,103] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:13:11.156,250] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:13:11.156,463] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:13:11.449,890] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:13:11.450,012] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:13:11.456,848] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:13:11.556,915] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:13:11.557,556] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:13:11.557,586] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:13:11.657,653] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:13:24.537,994] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:13:24.645,141] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:13:24.749,450] <inf> BLE: exchange_func: MTU exchange done
    00> [01:13:25.448,974] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:13:25.449,005] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:13:25.449,035] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:13:25.449,066] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:13:25.449,127] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:13:25.449,249] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:13:25.458,282] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:13:25.558,380] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:13:26.406,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:13:26.407,012] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:13:26.407,043] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:13:26.565,979] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:26.709,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:26.892,608] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:27.009,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:27.159,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:27.309,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:27.479,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:27.609,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:27.772,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:27.909,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:28.059,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:28.209,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:28.409,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:28.559,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:28.709,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:28.859,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:29.009,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:29.159,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:29.309,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:29.459,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:29.609,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:29.759,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:29.909,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:30.059,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:13:30.359,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:30.509,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:30.659,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:30.809,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:30.959,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:31.109,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:31.259,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:31.409,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:31.559,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:31.709,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:31.876,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:32.009,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:13:32.159,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:32.309,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:32.459,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:32.609,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:32.759,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:32.909,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:33.059,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:33.255,554] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:33.359,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:33.509,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:33.659,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:33.826,385] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:33.959,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:34.109,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:34.259,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:34.409,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:34.559,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:34.759,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:34.909,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:35.062,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:35.209,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:35.315,979] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:35.459,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:35.609,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:35.759,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:35.909,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:36.076,385] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:36.209,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:36.359,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:36.509,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:36.659,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:36.902,099] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:37.009,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:37.159,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:37.309,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:37.459,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:37.609,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:37.798,614] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:37.909,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:38.059,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:38.209,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:38.359,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:38.509,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:38.659,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:38.812,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:39.009,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:39.159,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:39.309,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:39.459,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:39.609,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:39.759,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:39.909,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:40.059,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:40.209,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:40.359,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:40.509,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:40.665,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:40.809,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:40.959,014] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:41.109,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:41.259,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:41.409,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:13:41.528,808] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:13:41.554,046] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:13:41.558,624] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:13:41.797,607] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:13:41.797,698] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:13:41.859,008] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:13:41.959,075] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:13:41.959,716] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:13:41.959,747] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:13:42.059,814] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> [01:14:09.525,177] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:14:09.638,977] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:14:09.743,286] <inf> BLE: exchange_func: MTU exchange done
    00> [01:14:10.442,840] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:14:10.442,871] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:14:10.442,901] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:14:10.442,932] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:14:10.442,993] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:14:10.443,115] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:14:10.452,148] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> .[01:14:10.552,276] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:14:11.400,787] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:14:11.400,878] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:14:11.400,878] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:14:11.559,814] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:11.745,941] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:11.852,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:12.002,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:12.152,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:12.352,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:12.506,347] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:12.652,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:12.802,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:12.995,941] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:13.102,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:13.286,437] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:13.402,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:13.506,347] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:13.652,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:13.802,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:13.952,880] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:14.102,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:14.252,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:14.402,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:14.552,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:14.752,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:14.952,880] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:15.102,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:14:15.352,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:15.502,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:15.652,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:15.802,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:15.982,879] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:16.102,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:16.252,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:16.402,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:16.602,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:16.752,899] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:17.063,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:17.232,879] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:17.352,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:17.545,928] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:17.695,953] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:17.823,699] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:17.975,952] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:18.149,414] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:18.252,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:18.402,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:18.552,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:18.702,880] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:18.852,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 1
    00> [01:14:19.002,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:19.152,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:19.302,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:19.452,880] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:19.559,814] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:19.736,450] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:19.852,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:20.002,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:20.186,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:20.309,814] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:20.452,880] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:20.602,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:20.752,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:14:20.902,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:21.052,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:21.202,880] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:21.402,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:21.552,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:21.702,880] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:21.895,935] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:22.052,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:22.202,911] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:22.352,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:22.549,407] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:22.656,341] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:22.802,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:22.952,880] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:23.102,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:23.252,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:23.502,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:23.673,675] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:23.802,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:23.956,359] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:24.152,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:24.352,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:24.602,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:24.786,437] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:25.002,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:25.152,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:25.302,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:25.499,420] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:25.652,893] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:25.852,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:26.002,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:26.242,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:26.352,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:26.502,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:26.652,923] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:26.852,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:27.102,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:27.295,928] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:27.372,680] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:14:27.397,796] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:14:27.440,002] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:14:27.691,467] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:14:27.691,558] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:14:27.740,478] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:14:27.840,545] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:14:27.841,186] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:14:27.841,217] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:14:27.941,284] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:14:28.167,144] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:14:28.274,688] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:14:28.378,997] <inf> BLE: exchange_func: MTU exchange done
    00> [01:14:29.078,521] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:14:29.078,552] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:14:29.078,582] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:14:29.078,613] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:14:29.078,704] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:14:29.078,826] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:14:29.087,860] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:14:29.187,927] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:14:30.036,499] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:14:30.036,560] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:14:30.036,590] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:14:30.195,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:30.355,926] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:30.488,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:30.638,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:30.788,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:30.938,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:31.172,149] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:31.288,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:31.438,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:31.622,131] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:31.738,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:31.888,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:32.038,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:32.188,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:14:32.338,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:32.488,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:32.642,028] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:32.788,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:32.938,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:33.088,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:33.238,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:33.431,640] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:33.638,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:33.788,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:14:34.040,649] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:34.188,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:34.338,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:34.488,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:34.638,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:34.805,908] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:34.938,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:35.138,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:35.288,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:35.438,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:35.588,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:35.738,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:35.928,161] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:36.038,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:36.218,566] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:36.411,651] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:36.538,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:36.705,902] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:36.838,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:36.988,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:37.138,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:37.288,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:37.438,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:37.588,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:37.738,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:37.888,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:38.109,375] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:38.238,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:38.388,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:38.538,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:38.738,616] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:38.888,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:39.038,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:39.231,628] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:39.381,622] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:39.488,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:39.638,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:39.788,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:39.938,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:40.088,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:40.238,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:40.388,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:40.585,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:40.688,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:40.878,173] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:41.038,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:41.209,381] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:41.338,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:41.492,034] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:41.638,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:41.788,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:41.938,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:42.088,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:42.238,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:42.388,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:14:42.542,053] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:42.738,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:42.895,507] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:43.081,634] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:43.188,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:43.338,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:43.488,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:43.638,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:43.788,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:43.988,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:44.138,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:44.288,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:44.478,179] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:44.588,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:44.738,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:44.888,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:45.038,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:45.205,902] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:45.338,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:45.458,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:14:45.483,489] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:14:45.483,734] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:14:45.777,160] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:14:45.777,252] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:14:45.784,118] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:14:45.884,185] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:14:45.884,826] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:14:45.884,857] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:14:45.984,924] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CEREG: 1,"C3C7","0DC27C15",7,
    00> [01:14:57.135,650] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:14:57.242,584] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:14:57.346,893] <inf> BLE: exchange_func: MTU exchange done
    00> [01:14:58.046,447] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:14:58.046,478] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:14:58.046,508] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:14:58.046,539] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:14:58.046,600] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:14:58.046,722] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:14:58.055,755] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:14:58.155,853] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:14:59.004,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:14:59.004,486] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:14:59.004,486] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:14:59.163,421] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:59.356,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:59.506,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:59.703,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:59.806,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:14:59.956,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:00.106,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:00.249,542] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:00.356,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:00.506,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:00.656,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:00.806,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:00.970,367] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:01.106,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:01.306,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:01.506,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:01.670,349] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:01.806,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:01.956,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:02.109,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:02.256,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:02.406,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:02.596,069] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:15:02.856,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:03.006,469] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:03.156,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:03.313,415] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:03.456,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:03.606,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:03.806,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:03.999,542] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:04.106,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:04.256,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:04.406,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:04.509,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:04.656,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:04.806,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:15:04.956,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:05.129,547] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:05.266,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:05.406,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:05.556,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:05.706,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:05.856,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:06.006,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:06.156,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:06.306,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:06.456,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:06.649,536] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:06.756,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:06.929,565] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:07.056,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:07.206,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:07.356,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:07.506,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:07.656,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:07.806,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:08.006,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:08.156,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:08.306,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:08.456,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:08.606,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:08.756,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:08.906,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:09.077,301] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:09.206,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:09.370,361] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:09.506,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:09.659,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:09.806,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:09.956,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:10.106,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:10.256,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:10.429,534] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:10.556,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:10.756,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:10.906,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:11.056,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:11.206,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:11.356,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:11.506,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:11.656,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:11.806,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:11.956,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:12.156,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:12.306,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:12.499,542] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:12.606,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:12.713,409] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:12.890,045] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:13.006,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:13.156,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:13.309,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:13.456,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:13.629,547] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:13.756,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:13.923,828] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:14.106,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:14.226,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:15:14.251,403] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:15:14.301,422] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:15:14.595,062] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:15:14.595,184] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:15:14.601,806] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:15:14.701,873] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:15:14.702,514] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:15:14.702,545] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:15:14.802,612] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:15:42.935,485] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:15:43.046,295] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:15:43.150,604] <inf> BLE: exchange_func: MTU exchange done
    00> [01:15:43.850,158] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:15:43.850,189] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:15:43.850,219] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:15:43.850,250] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:15:43.850,311] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:15:43.850,433] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:15:43.859,466] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:15:43.959,564] <inf> MAIN: ble_connected_state: START FLAG sent
    00> .[01:15:44.808,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:15:44.808,197] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:15:44.808,197] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:15:44.967,132] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:45.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:45.260,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:45.410,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:45.560,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:45.710,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:45.860,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:46.013,671] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:46.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:46.356,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:46.460,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:46.610,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:46.760,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:46.910,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:47.060,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:47.210,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:47.360,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:47.510,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:47.677,551] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:47.810,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:47.960,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:48.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:48.260,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:48.460,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:48.710,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:15:48.860,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:15:48.999,786] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:49.110,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:49.303,253] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:49.410,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:49.560,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:49.710,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:49.860,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:50.010,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:50.206,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:50.310,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:50.460,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:50.610,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:50.803,253] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:50.910,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:51.060,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:51.210,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:51.386,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:51.510,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:51.677,551] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:51.810,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:51.960,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:52.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:52.260,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:52.510,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:52.660,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:52.810,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:52.960,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:53.170,593] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:15:53.353,271] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:53.460,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:53.610,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:53.760,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:53.910,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:54.060,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:54.210,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:54.360,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:15:54.510,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:54.660,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:54.810,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:54.960,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:55.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:55.260,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:55.410,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:55.560,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:55.710,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:55.860,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:56.010,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:56.174,072] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:56.310,211] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:56.460,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:56.660,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:56.840,209] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:56.963,684] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:57.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:57.349,792] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:57.460,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:57.567,138] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:57.710,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:57.860,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:58.010,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:58.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:58.324,066] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:58.460,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:58.617,126] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:58.860,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:59.010,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:59.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:59.353,271] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:59.460,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:59.610,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:59.760,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:15:59.960,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:00.079,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:16:00.105,102] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:16:00.105,499] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:16:00.749,328] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:16:00.749,450] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 8)
    00> [01:16:00.806,152] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:16:00.906,219] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:16:00.906,860] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:16:00.906,890] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:16:01.006,958] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:16:01.232,116] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:16:01.342,803] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:16:01.447,113] <inf> BLE: exchange_func: MTU exchange done
    00> [01:16:02.146,667] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:16:02.146,697] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:16:02.146,697] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:16:02.146,759] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:16:02.146,820] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:16:02.146,942] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:16:02.155,975] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:16:02.256,072] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:16:03.104,614] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:16:03.104,705] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:16:03.104,705] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:16:03.263,641] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:03.449,768] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:03.596,313] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:03.706,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:03.813,629] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:03.956,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:04.106,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:04.256,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:04.406,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:04.556,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:04.710,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:04.856,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:05.006,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:05.156,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:05.283,233] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:05.406,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:05.556,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:05.796,295] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:16:05.906,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:06.056,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:06.206,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:06.440,277] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:06.556,732] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:06.706,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:16:06.956,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:07.106,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:07.256,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:07.406,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:07.556,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:07.706,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:07.856,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:08.006,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:08.156,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:08.306,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:08.456,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:08.606,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:08.756,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:08.906,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:09.056,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:09.206,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:09.356,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:09.506,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:09.656,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:09.806,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:09.956,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:10.106,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:10.256,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:10.433,227] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:10.556,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:10.720,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:10.856,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:11.006,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:11.156,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:11.306,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:11.456,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:11.656,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:11.849,761] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:11.996,307] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:12.106,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:12.256,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:12.406,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:12.556,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:12.706,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:12.856,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:13.006,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:13.156,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:13.306,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:13.456,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:13.656,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:13.806,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:13.999,755] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:14.106,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:14.256,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:14.406,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:14.556,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:14.706,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:14.856,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:15.006,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:15.156,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:15.306,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:15.460,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:15.606,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:15.756,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:15.906,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:16:16.056,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:16.206,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:16.356,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:16.506,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:16.656,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:16.806,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:16.956,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:17.106,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:17.256,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:17.406,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:17.556,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:17.706,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:17.856,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:18.006,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:18.126,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:16:18.151,611] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:16:18.155,670] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:16:18.395,294] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:16:18.395,385] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:16:18.456,054] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:16:18.556,121] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:16:18.556,762] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:16:18.556,793] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:16:18.656,860] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:16:30.038,543] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:16:30.145,324] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:16:30.249,633] <inf> BLE: exchange_func: MTU exchange done
    00> [01:16:30.999,176] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:16:30.999,206] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:16:30.999,237] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:16:30.999,267] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:16:30.999,328] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:16:30.999,450] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:16:31.008,483] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:16:31.108,581] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:16:31.957,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:16:31.957,214] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:16:31.957,214] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:16:32.116,149] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:32.259,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:32.409,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:32.559,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:32.759,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:32.909,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:33.062,683] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:33.209,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:33.359,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:33.509,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:33.659,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:33.852,294] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:33.959,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:34.109,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:34.259,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:34.409,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:34.562,683] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:34.709,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:34.859,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:35.009,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:35.159,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:35.309,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:35.459,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:16:35.709,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:35.859,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:36.032,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:36.159,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:36.309,265] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:36.459,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:36.609,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:36.759,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:36.909,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:37.059,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:37.209,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:37.359,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:37.509,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:37.659,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:37.809,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:38.039,215] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:38.159,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:38.309,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:38.459,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:16:38.609,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:38.762,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:38.909,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:39.059,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:39.209,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:39.359,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:39.509,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:39.702,301] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:39.809,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:39.962,677] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:40.135,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:40.259,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:40.412,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:40.516,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:40.659,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:40.809,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:40.959,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:41.109,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:41.259,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:41.409,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:41.559,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:41.709,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:41.859,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:42.009,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:42.159,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:42.309,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:42.462,677] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:42.652,282] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:42.759,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:42.909,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:43.059,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:43.209,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:43.409,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:43.605,743] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:43.752,288] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:43.898,834] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:44.009,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:44.159,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:44.335,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:44.459,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:44.630,035] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:44.759,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:44.919,616] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:45.059,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:45.209,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:45.602,294] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:45.755,767] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:45.909,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:46.059,265] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:46.219,635] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:46.359,222] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:46.509,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:46.616,149] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:46.759,216] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:46.909,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:47.112,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:16:47.229,003] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:16:47.254,150] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:16:47.304,168] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:16:47.948,364] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:16:47.948,455] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 8)
    00> [01:16:48.004,821] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:16:48.104,888] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:16:48.105,529] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:16:48.105,560] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:16:48.205,627] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CEREG: 1,"C3C7","0DBD1516",7,
    00> [01:17:15.844,421] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:17:15.953,216] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:17:16.057,525] <inf> BLE: exchange_func: MTU exchange done
    00> [01:17:16.757,049] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:17:16.757,080] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:17:16.757,110] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:17:16.757,141] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:17:16.757,202] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:17:16.757,354] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:17:16.766,387] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:17:16.866,455] <inf> MAIN: ble_connected_state: START FLAG sent
    00> .[01:17:17.715,026] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:17:17.715,087] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:17:17.715,118] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:17:17.874,053] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:18.017,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:18.124,053] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:18.267,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:18.417,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:18.567,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:18.717,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:18.867,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:19.017,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:17:19.167,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:19.317,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:19.467,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:19.617,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:19.767,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:19.917,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:20.113,647] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:20.267,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:20.417,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:20.567,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:20.717,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:20.890,167] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:21.017,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:21.167,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:21.317,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:17:21.567,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:21.717,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:21.867,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:22.017,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:22.213,623] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:22.317,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:22.467,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:22.617,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:22.767,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:22.927,520] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:23.067,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:23.217,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:23.370,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:23.517,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:23.667,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:23.824,035] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:23.967,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:24.117,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:24.267,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:24.417,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:24.567,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:24.717,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:24.867,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:25.017,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:25.167,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:25.317,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:25.484,436] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:25.617,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:25.767,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:25.917,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:26.067,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:26.217,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:26.324,035] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:26.467,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:26.617,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:26.806,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:26.917,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:27.067,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:27.217,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:27.397,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:27.517,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:17:27.667,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:27.817,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:27.967,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:28.187,927] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:28.343,627] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:28.467,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:28.617,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:28.767,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:28.917,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:29.027,496] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:29.167,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:29.367,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:29.517,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:29.710,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:29.817,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:29.967,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:30.117,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:30.267,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:30.467,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:30.660,156] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:30.810,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:30.917,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:31.067,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:31.217,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:31.367,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:31.560,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:31.667,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:31.860,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:31.967,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:32.117,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:32.317,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:32.467,102] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:32.617,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:32.736,877] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:17:32.762,023] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:17:32.812,561] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:17:33.105,682] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:17:33.105,773] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:17:33.112,945] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:17:33.213,012] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:17:33.213,653] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:17:33.213,684] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:17:33.313,751] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:17:33.849,517] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:17:33.960,784] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:17:34.065,093] <inf> BLE: exchange_func: MTU exchange done
    00> [01:17:34.764,648] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:17:34.764,678] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:17:34.764,709] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:17:34.764,739] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:17:34.764,801] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:17:34.764,923] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:17:34.773,956] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:17:34.874,053] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:17:35.722,595] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:17:35.722,686] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:17:35.722,686] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:17:35.881,622] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:36.024,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:36.174,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:36.324,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:36.474,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:36.624,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:36.774,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:36.924,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:37.074,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:37.224,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:37.374,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:37.564,270] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:37.681,640] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:37.824,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:37.974,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:38.124,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:38.274,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:38.424,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:38.574,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:38.724,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:38.874,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:39.024,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:39.204,681] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:17:39.371,215] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:17:39.574,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:39.724,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:39.874,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:40.024,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:40.174,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:40.324,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:40.474,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:40.624,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:40.774,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:40.924,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:41.074,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:41.224,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:41.374,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:41.524,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:41.674,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:41.874,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:42.024,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:42.174,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:42.324,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:42.495,513] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:42.624,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:42.774,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:42.958,251] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:43.114,288] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:43.224,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:43.374,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:43.524,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:43.674,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:43.824,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:43.974,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:44.124,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:44.274,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:44.424,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:44.574,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:44.774,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:44.924,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:45.074,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:45.224,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:45.424,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:45.574,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:45.724,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:45.874,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:46.024,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:46.174,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:46.328,155] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:46.474,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:46.624,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:46.774,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:46.924,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:47.074,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:47.224,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:47.374,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:47.524,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:47.724,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:47.874,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:48.071,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:48.174,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:48.324,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:48.474,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:48.624,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:48.774,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:48.967,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:49.128,143] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:49.274,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:17:49.424,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:49.574,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:49.724,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:49.874,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:50.024,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:50.174,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:50.324,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:50.474,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:50.624,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:50.774,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:17:50.894,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:17:50.919,616] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:17:50.924,499] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:17:51.213,256] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:17:51.213,378] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:17:51.224,884] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:17:51.324,951] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:17:51.325,592] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:17:51.325,622] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:17:51.425,689] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CEREG: 1,"C3C7","0DC27C15",7,
    00> [01:18:02.937,530] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:18:03.047,790] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:18:03.152,099] <inf> BLE: exchange_func: MTU exchange done
    00> [01:18:03.851,654] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:18:03.851,684] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:18:03.851,684] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:18:03.851,745] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:18:03.851,806] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:18:03.851,928] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:18:03.860,961] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:18:03.961,059] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:18:04.809,600] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:18:04.809,692] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:18:04.809,692] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:18:04.968,627] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:05.111,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:05.261,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:05.411,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:05.561,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:05.711,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:05.861,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:06.011,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:06.161,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:06.311,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:06.461,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:06.661,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:06.861,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:07.011,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:07.161,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:07.311,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:07.461,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:07.611,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:07.761,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:07.911,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:08.111,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:08.311,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:08.461,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:18:08.711,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:08.861,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:09.011,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:09.161,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:09.311,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:09.461,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:09.611,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:09.761,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:09.911,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:10.061,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:10.265,167] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:10.461,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:10.611,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:10.761,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:10.951,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:11.104,766] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:11.211,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:11.361,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:11.511,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:11.661,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:11.858,215] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:18:11.961,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:12.111,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:12.311,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:12.461,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:12.611,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:12.808,227] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:12.911,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:13.061,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:13.168,640] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:13.358,215] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:13.504,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:13.611,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:13.761,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:13.925,567] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:14.061,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:14.211,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:14.361,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:14.532,501] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:14.661,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:14.811,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:14.961,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:15.111,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:15.301,300] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:15.411,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:15.591,705] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:15.711,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:15.861,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:15.965,148] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:16.111,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:16.275,573] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:16.411,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:16.561,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:16.711,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:16.861,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:17.011,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:17.208,221] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:17.311,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:17.461,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:17.611,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:17.761,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:17.911,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:18.015,167] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:18.161,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:18.311,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:18.461,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:18.611,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:18.761,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:18.911,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:18:19.061,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:19.211,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:19.361,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:19.561,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:19.711,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:19.861,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:19.981,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:18:20.006,622] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:18:20.060,821] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:18:20.300,262] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:18:20.300,384] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:18:20.361,206] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:18:20.461,273] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:18:20.461,914] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:18:20.461,944] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:18:20.562,011] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:18:48.458,862] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:18:48.566,467] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:18:48.670,776] <inf> BLE: exchange_func: MTU exchange done
    00> [01:18:49.472,747] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:18:49.472,778] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:18:49.472,808] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:18:49.472,839] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:18:49.472,900] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:18:49.473,022] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:18:49.482,086] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:18:49.582,153] <inf> MAIN: ble_connected_state: START FLAG sent
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> [01:18:50.428,283] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:18:50.428,344] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:18:50.428,375] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:18:50.606,872] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:50.730,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:50.880,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:18:51.030,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:51.180,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:51.330,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:51.480,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:51.630,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:51.783,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:51.930,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:52.080,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:52.230,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:52.380,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:52.530,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:52.680,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:52.851,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:52.980,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:53.130,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:53.280,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:53.480,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:53.630,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:53.780,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:53.930,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:18:54.180,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:54.330,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:54.480,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:54.687,286] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:54.830,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:54.980,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:55.130,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:55.290,740] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:55.476,867] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:55.580,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:55.730,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:55.880,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:56.076,873] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:56.180,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:56.330,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:56.480,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:56.673,400] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:56.780,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:56.930,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:57.080,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:57.230,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:57.401,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:57.530,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:57.730,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:57.837,280] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:57.980,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:58.130,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:58.280,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:58.430,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:58.630,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:58.780,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:58.930,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:59.101,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:59.280,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:59.480,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:59.647,705] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:18:59.780,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:00.030,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:00.180,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:00.330,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:00.480,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:00.630,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:00.780,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:00.960,357] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:01.080,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:01.247,680] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:19:01.380,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:01.530,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:01.680,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:01.830,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:01.980,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:02.180,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:02.333,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:02.519,958] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:02.630,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:02.780,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:02.969,940] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:03.080,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:03.230,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:03.426,879] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:03.530,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:03.680,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:03.830,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:03.980,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:04.130,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:04.280,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:04.430,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:04.580,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:04.769,958] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:04.880,340] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:05.030,334] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:05.180,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:05.353,424] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:05.540,740] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:05.680,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:05.800,140] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:19:05.825,286] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:19:05.826,477] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:19:06.118,927] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:19:06.119,018] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:19:06.126,861] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:19:06.226,928] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:19:06.227,569] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:19:06.227,600] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:19:06.327,667] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:19:06.560,791] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:19:06.670,196] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:19:06.774,505] <inf> BLE: exchange_func: MTU exchange done
    00> [01:19:07.474,060] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:19:07.474,090] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:19:07.474,121] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:19:07.474,151] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:19:07.474,212] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:19:07.474,334] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:19:07.483,367] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:19:07.583,465] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:19:08.432,006] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:19:08.432,098] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:19:08.432,098] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:19:08.591,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:08.734,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:08.884,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:09.034,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:09.184,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:09.334,075] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:09.484,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:09.634,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:09.784,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:09.934,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:10.084,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:10.234,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:10.384,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:10.534,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:10.684,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:10.834,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:10.984,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:11.134,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:11.284,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:11.434,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:11.584,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:11.734,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:11.884,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:12.034,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:19:12.284,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:12.434,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:12.584,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:19:12.734,130] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:12.884,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:13.077,148] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:13.184,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:13.334,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:13.484,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:13.634,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:13.784,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:13.957,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:14.084,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:14.234,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:14.384,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:14.534,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:14.684,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:14.834,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:14.984,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:15.134,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:15.284,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:15.434,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:15.584,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:15.734,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:15.884,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:16.034,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:16.184,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:16.334,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:16.484,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:16.634,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:16.784,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:16.934,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:17.084,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:17.234,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:17.384,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:17.534,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:17.684,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:17.834,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:17.984,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:18.134,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:18.284,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:18.434,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:18.584,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:18.734,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:18.884,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:19.034,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 1
    00> [01:19:19.184,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:19.334,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:19.484,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:19.634,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:19.784,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:19.934,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:20.084,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:20.234,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:20.404,907] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:20.534,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:20.697,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:20.834,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:20.984,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:21.134,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:21.284,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:21.480,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:21.623,687] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:21.734,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:21.884,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:22.034,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:22.184,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:22.334,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:22.484,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:22.634,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:19:22.784,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:22.934,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:23.084,106] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:23.234,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:23.353,881] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:19:23.379,028] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:19:23.379,486] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:19:23.622,680] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:19:23.622,772] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:19:23.679,870] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:19:23.779,937] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:19:23.780,578] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:19:23.780,609] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:19:23.880,676] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:19:35.749,908] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:19:35.860,565] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:19:35.964,874] <inf> BLE: exchange_func: MTU exchange done
    00> [01:19:36.664,428] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:19:36.664,459] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:19:36.664,489] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:19:36.664,520] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:19:36.664,581] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:19:36.664,703] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:19:36.673,736] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:19:36.773,834] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:19:37.622,406] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:19:37.622,467] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:19:37.622,467] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:19:37.781,402] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> [01:19:37.924,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:38.121,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:38.224,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:38.417,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:38.524,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:38.677,947] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:38.824,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:38.974,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:39.124,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:39.274,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:39.424,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:39.574,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:39.774,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:39.924,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:40.074,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:40.224,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:40.374,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:40.564,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:40.708,038] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:40.827,941] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:40.974,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:41.124,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:41.274,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:19:41.524,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:41.674,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:41.824,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:41.974,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:42.124,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:42.314,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:42.424,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:42.574,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:42.724,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:42.874,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:43.024,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:43.174,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:43.324,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:43.474,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:43.624,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:43.774,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:43.924,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:44.074,493] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:44.224,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:44.374,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:44.570,983] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:44.717,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:44.824,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:45.008,026] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:45.167,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:45.324,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:45.495,269] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:45.624,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:45.774,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:19:45.924,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:46.074,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:46.274,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:46.424,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:46.574,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:46.724,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:46.874,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:47.024,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:47.174,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:47.324,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:47.474,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:47.645,294] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:47.774,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:47.924,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:48.074,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:48.224,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:48.424,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:48.624,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:48.774,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:48.967,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:49.124,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:49.274,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:49.424,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:49.574,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:49.724,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:49.874,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:50.024,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:50.174,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:50.324,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:50.508,026] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:50.624,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:50.774,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:50.924,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:51.077,941] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:51.224,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:51.374,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:51.524,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:51.674,468] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:51.824,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:51.974,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:52.124,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:52.300,994] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:52.431,396] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:52.574,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:52.724,456] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:19:52.844,268] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:19:52.869,384] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:19:52.918,762] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:19:53.213,043] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:19:53.213,165] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:19:53.219,146] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:19:53.319,213] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:19:53.319,854] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:19:53.319,885] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:19:53.419,952] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CSCON: 1
    00> [01:20:21.365,875] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:20:21.473,297] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:20:21.577,606] <inf> BLE: exchange_func: MTU exchange done
    00> [01:20:22.277,160] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:20:22.277,191] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:20:22.277,191] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:20:22.277,252] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:20:22.277,313] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:20:22.277,435] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:20:22.286,468] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:20:22.386,566] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:20:23.235,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:20:23.235,198] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:20:23.235,198] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:20:23.394,134] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:23.537,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:23.687,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:23.837,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:23.987,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:24.137,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:24.287,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:24.437,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:24.597,595] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:24.737,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:24.887,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:20:25.037,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:25.187,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:25.380,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:25.487,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:25.687,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:25.837,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:25.987,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:26.137,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:26.287,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:26.483,734] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:26.587,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:26.760,253] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:20:27.010,253] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:27.137,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:27.287,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:27.437,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:27.587,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:27.740,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:27.920,776] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:28.037,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:28.187,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:28.376,800] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:28.487,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:28.637,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:28.797,607] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:28.954,528] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:29.090,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:29.237,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:29.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:29.583,740] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:29.687,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:29.837,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:29.987,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:30.180,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:30.287,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:30.437,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:30.587,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:30.737,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:30.887,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:31.037,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:31.187,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:31.337,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:31.487,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:31.683,715] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:31.787,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:31.976,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:32.090,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:32.237,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:32.417,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:32.537,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:32.687,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:32.863,739] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:32.987,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:33.140,655] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:33.287,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:33.437,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:33.587,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:33.737,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:33.970,764] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:34.126,800] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:34.276,794] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:34.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:34.563,720] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:34.687,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:34.837,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:34.990,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:35.137,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:35.287,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:20:35.437,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:35.587,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:35.737,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:35.887,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:36.037,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:36.237,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:36.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:36.537,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:36.733,734] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:36.837,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:36.987,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:37.137,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:37.287,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:37.504,547] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:37.687,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:37.937,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:38.133,728] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:38.237,182] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:38.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:38.506,988] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:20:38.532,104] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:20:38.582,824] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:20:38.825,775] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:20:38.825,866] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:20:38.883,209] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:20:38.983,276] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:20:38.983,917] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:20:38.983,947] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:20:39.071,350] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:20:39.084,045] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:20:39.184,417] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:20:39.288,726] <inf> BLE: exchange_func: MTU exchange done
    00> [01:20:39.988,281] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:20:39.988,311] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:20:39.988,311] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:20:39.988,372] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:20:39.988,433] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:20:39.988,555] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:20:39.997,589] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:20:40.097,686] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:20:40.946,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:20:40.946,319] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:20:40.946,319] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:20:41.105,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:41.248,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:41.398,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:41.548,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:41.698,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:41.848,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:41.998,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:42.148,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:42.298,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:42.448,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:42.598,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:42.748,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:42.898,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:43.048,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:43.198,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:43.348,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:43.498,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:43.648,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:43.798,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:43.948,303] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:44.098,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:44.248,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:44.398,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:44.548,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:20:44.798,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:44.948,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:45.098,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:45.248,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:45.428,314] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:45.548,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:45.698,303] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:45.848,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:45.998,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:46.148,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:46.298,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:46.448,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:20:46.598,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:46.748,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:46.898,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:47.048,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:47.198,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:47.348,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:47.498,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:47.648,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:47.798,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:47.948,303] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:48.098,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:48.248,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:48.398,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:48.551,788] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:48.698,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:48.848,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:48.998,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:49.148,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:49.298,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:49.448,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:49.598,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:49.748,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:49.898,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:50.048,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:50.198,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:50.348,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 0
    00> [01:20:50.498,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:50.648,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:50.798,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:50.948,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:51.098,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:51.248,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:51.398,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:51.548,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:51.698,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:51.848,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:51.998,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:52.148,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:52.298,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:52.448,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:52.598,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:52.748,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:52.898,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:53.048,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:53.198,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:53.348,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:53.498,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:53.648,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:53.798,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:53.948,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:54.098,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:54.248,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:54.398,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:54.548,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:54.698,303] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:54.848,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:54.998,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:55.148,315] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:55.298,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:55.448,333] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:55.598,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:55.748,321] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:20:55.868,103] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:20:55.893,249] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:20:55.945,648] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:20:56.236,907] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:20:56.236,999] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:20:56.246,032] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:20:56.346,099] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:20:56.346,740] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:20:56.346,771] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:20:56.446,838] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:21:08.558,258] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:21:08.665,954] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:21:08.770,263] <inf> BLE: exchange_func: MTU exchange done
    00> [01:21:09.519,805] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:21:09.519,836] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:21:09.519,836] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:21:09.519,897] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:21:09.519,958] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:21:09.520,080] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:21:09.529,113] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> .[01:21:09.629,241] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:21:10.477,752] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:21:10.477,844] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:21:10.477,844] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:21:10.640,258] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:10.779,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:10.929,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:11.079,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:11.279,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:11.429,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:11.579,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:11.729,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:11.879,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:12.029,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:12.179,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:12.329,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:12.479,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:12.629,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:12.779,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:12.929,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:13.079,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:13.229,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:13.379,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:13.529,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:13.679,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:13.829,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:13.979,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:21:14.229,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:14.409,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:14.529,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:14.702,911] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:14.829,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:14.979,858] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:15.129,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:15.290,252] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:15.433,319] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:15.579,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:15.779,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:15.929,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:16.119,445] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:16.229,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:16.379,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:16.529,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:16.679,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:16.829,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:16.979,858] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:17.143,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:17.279,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:17.436,767] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:17.579,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:17.729,858] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:17.879,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:18.029,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:18.179,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:18.329,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:18.479,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:18.629,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:18.779,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:18.886,779] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:19.029,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:21:19.179,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:19.329,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:19.479,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:19.629,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:21:19.779,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:19.929,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:20.126,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:20.229,858] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:20.379,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:20.576,385] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:20.693,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:20.829,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:20.979,858] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:21.129,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:21.326,385] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:21.429,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:21.640,258] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:21.779,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:21.929,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:22.079,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:22.263,397] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:22.379,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:22.529,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:22.679,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:22.829,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:22.979,858] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:23.129,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:23.279,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:23.472,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:23.579,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:23.756,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:23.879,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:24.029,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:24.179,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:24.376,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:24.479,858] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:24.629,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:24.779,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:24.929,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:25.079,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:25.229,858] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:25.379,852] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:25.499,633] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:21:25.524,749] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:21:25.526,641] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:21:25.818,420] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:21:25.818,542] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:21:25.827,026] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:21:25.927,093] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:21:25.927,734] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:21:25.927,764] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:21:26.027,832] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> [01:21:54.281,066] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:21:54.392,150] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:21:54.496,429] <inf> BLE: exchange_func: MTU exchange done
    00> [01:21:55.295,989] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:21:55.296,020] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:21:55.296,051] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:21:55.296,081] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:21:55.296,142] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:21:55.296,264] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:21:55.305,297] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:21:55.405,395] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:21:56.253,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:21:56.254,028] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:21:56.254,058] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:21:56.412,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:56.556,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:56.706,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:56.856,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:57.006,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:57.206,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:57.356,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:57.506,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:57.656,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:57.806,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:57.956,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:58.229,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:58.356,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:58.506,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:58.656,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:58.806,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:58.956,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:59.106,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:21:59.256,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:59.449,096] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:59.556,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:59.745,635] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:21:59.956,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:00.106,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:00.279,083] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:00.406,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:00.556,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:00.706,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:00.856,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:01.006,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:01.156,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:01.306,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:01.456,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:01.606,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:01.756,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:01.962,982] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:02.106,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:02.256,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:02.406,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:02.556,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:02.706,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:02.856,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:03.006,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:03.156,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:03.306,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:03.456,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:03.606,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:03.756,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:03.945,617] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:04.056,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:04.209,503] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:04.359,497] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:04.506,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:04.656,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:04.856,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:05.006,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:05.162,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:05.406,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:05.556,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:05.706,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:05.856,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:06.006,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:06.156,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:06.306,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:06.456,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:06.632,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:06.756,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:06.923,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:07.059,509] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:07.206,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:07.356,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:07.506,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:07.609,497] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:07.756,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:07.949,096] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:08.123,382] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:08.256,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:08.412,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:08.586,029] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:08.706,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:08.856,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:09.006,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:09.156,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:09.306,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:22:09.456,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:09.606,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:09.756,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:09.906,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:10.056,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:10.206,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:10.379,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:10.506,042] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:10.656,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:10.806,030] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:10.956,024] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:11.106,018] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:11.302,551] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:11.406,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:11.525,817] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:22:11.550,964] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:22:11.552,246] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:22:11.844,604] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:22:11.844,726] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:22:11.852,630] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:22:11.952,697] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:22:11.953,338] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:22:11.953,369] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:22:12.053,436] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:22:12.094,299] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:22:12.201,782] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:22:12.306,091] <inf> BLE: exchange_func: MTU exchange done
    00> [01:22:13.005,645] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:22:13.005,676] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:22:13.005,676] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:22:13.005,737] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:22:13.005,798] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:22:13.005,920] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:22:13.014,953] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:22:13.115,051] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:22:13.963,592] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:22:13.963,684] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:22:13.963,684] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:22:14.122,619] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:14.315,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:14.465,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:14.615,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:14.765,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:14.915,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:15.065,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:15.215,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:15.365,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:15.515,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:15.665,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:15.815,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:15.965,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:16.115,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:16.265,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:16.415,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:16.565,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:16.715,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:16.865,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:17.015,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:17.165,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:17.315,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:17.465,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:17.615,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:22:17.865,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:18.015,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:18.169,158] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:18.315,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:18.465,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:18.615,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:18.765,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:18.915,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:19.065,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 1
    00> [01:22:19.215,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:19.365,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:19.545,684] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:19.665,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:19.815,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:19.965,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:20.115,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:20.265,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:20.415,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:22:20.565,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:20.715,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:20.865,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:21.015,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:21.165,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:21.315,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:21.465,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:21.615,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:21.765,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:21.915,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:22.065,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:22.215,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:22.365,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:22.515,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:22.665,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:22.862,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:22.965,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:23.115,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:23.265,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:23.415,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:23.565,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:23.715,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:23.865,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:24.015,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:24.165,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:24.315,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:24.465,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:24.622,619] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:24.765,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:24.915,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:25.065,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:25.215,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:25.365,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:25.515,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:25.665,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:25.815,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:25.992,218] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:26.115,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:26.265,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:26.415,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:26.565,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:26.715,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:26.865,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:27.015,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:27.165,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:27.315,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:27.465,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:27.615,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:27.769,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:27.872,619] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:28.042,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:28.165,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:28.315,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:28.465,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:28.615,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:28.765,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:28.885,467] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:22:28.910,614] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:22:28.910,827] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:22:29.154,266] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:22:29.154,357] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:22:29.211,212] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:22:29.311,279] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:22:29.311,920] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:22:29.311,950] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:22:29.412,017] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:22:41.163,787] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:22:41.276,092] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:22:41.380,401] <inf> BLE: exchange_func: MTU exchange done
    00> [01:22:42.079,956] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:22:42.079,986] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:22:42.080,017] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:22:42.080,047] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:22:42.080,108] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:22:42.080,230] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:22:42.089,263] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:22:42.189,361] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:22:43.037,933] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:22:43.037,994] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:22:43.037,994] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:22:43.283,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:22:43.389,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:43.579,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:43.690,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:43.839,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:43.989,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:44.139,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:44.290,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:44.440,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:44.589,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:44.739,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:44.893,463] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:45.040,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:45.216,522] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:45.339,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:45.489,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:45.639,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:45.790,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:45.940,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:46.089,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:46.307,342] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:46.440,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:46.589,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:22:46.843,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:46.989,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:47.139,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:47.290,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:47.440,032] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:47.633,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:47.783,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:47.889,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:48.040,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:48.143,463] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:48.290,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:48.440,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:48.589,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:48.739,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:48.889,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:49.040,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:49.190,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:49.440,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:49.589,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:49.740,020] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:49.889,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:49.996,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:50.139,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:50.329,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:22:50.440,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:50.639,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:50.863,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:50.989,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:51.139,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:51.290,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:51.440,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:51.589,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:51.739,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:51.889,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:52.040,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:52.190,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:52.339,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:52.489,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:52.639,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:52.790,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:52.940,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:53.089,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:53.239,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:53.416,534] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:53.540,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:22:53.783,050] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:53.889,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:54.040,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:54.190,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:54.339,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:54.489,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:54.639,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:54.790,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:54.940,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:55.089,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:55.250,396] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:55.389,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:55.540,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:55.690,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:55.839,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:55.989,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:56.139,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:56.336,517] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:56.443,450] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:56.619,995] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:56.739,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:56.889,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:57.040,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:57.190,002] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:57.339,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:57.489,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:57.639,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:57.839,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:58.036,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:58.139,984] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:22:58.259,796] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:22:58.284,912] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:22:58.285,308] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:22:58.528,564] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:22:58.528,686] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:22:58.585,693] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:22:58.685,760] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:22:58.686,401] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:22:58.686,431] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:22:58.786,499] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:23:27.085,876] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:23:27.199,310] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:23:27.303,619] <inf> BLE: exchange_func: MTU exchange done
    00> [01:23:28.003,143] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:23:28.003,173] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:23:28.003,204] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:23:28.003,234] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:23:28.003,295] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:23:28.003,448] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:23:28.012,481] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:23:28.112,548] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:23:28.961,120] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:23:28.961,181] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:23:28.961,212] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:23:29.159,729] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:29.263,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:29.413,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:29.563,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:29.713,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:29.863,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:30.013,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:30.196,777] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:30.313,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:30.463,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:30.627,075] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:30.763,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:30.913,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:31.063,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:31.213,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:31.363,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:31.513,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:31.663,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:31.813,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:31.963,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:32.113,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:32.263,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:32.413,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:32.563,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:23:32.813,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:32.963,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:23:33.113,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:33.263,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:33.413,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:33.563,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:33.713,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:33.863,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:34.013,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:34.163,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:34.313,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:34.463,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:34.713,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:34.863,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:35.013,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:35.163,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:35.313,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:35.463,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:35.613,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:35.763,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:35.913,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:36.066,650] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:36.213,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:36.413,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:36.563,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:36.713,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:36.863,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:37.013,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:37.163,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:37.313,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:37.463,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:37.613,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:37.783,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:37.913,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:38.063,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:38.213,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:38.363,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:38.513,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:38.663,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:38.813,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:38.963,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:39.113,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:39.302,795] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:39.413,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:39.563,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:39.713,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:39.863,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:40.013,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:40.163,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:40.313,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:40.463,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:40.627,075] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:40.763,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:40.913,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:41.063,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:41.213,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:41.363,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:41.513,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:41.706,268] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:41.856,262] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:41.963,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:42.156,250] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:42.280,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:42.413,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:42.580,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:42.713,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:42.877,075] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:43.013,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:23:43.163,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:43.313,201] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:43.463,195] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:43.613,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:43.763,183] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:43.913,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:44.032,989] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:23:44.058,105] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:23:44.058,593] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:23:44.351,776] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:23:44.351,867] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:23:44.358,978] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:23:44.459,045] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:23:44.459,686] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:23:44.459,716] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:23:44.559,783] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:23:44.606,689] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:23:44.718,475] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:23:44.822,784] <inf> BLE: exchange_func: MTU exchange done
    00> [01:23:45.522,308] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:23:45.522,338] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:23:45.522,369] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:23:45.522,399] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:23:45.522,491] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:23:45.522,613] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:23:45.531,646] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:23:45.631,744] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:23:46.480,285] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:23:46.480,346] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:23:46.480,377] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:23:46.682,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:46.832,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:46.982,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:47.132,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:47.282,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:47.432,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:47.582,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:47.732,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:47.882,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:48.032,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:48.232,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:48.382,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:48.532,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:48.728,881] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:48.832,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:48.982,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:49.165,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:49.282,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:49.432,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:49.582,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:49.732,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:49.882,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:50.032,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:23:50.282,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 0
    00> [01:23:50.482,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:50.632,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:50.782,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:50.932,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:51.121,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:51.232,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:51.382,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:51.532,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:51.682,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:51.832,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:51.982,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:52.132,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:52.292,785] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:52.432,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:52.635,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:52.782,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:52.932,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:53.082,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:53.232,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:53.428,894] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:53.532,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:53.682,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:53.832,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:53.982,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:54.132,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:23:54.282,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:54.432,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:54.582,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:54.732,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:54.882,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:55.032,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:55.182,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:55.332,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:55.439,300] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:55.582,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:55.732,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:55.882,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:56.032,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:56.199,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:56.332,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:56.482,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:56.635,833] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:56.785,827] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:56.932,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:57.082,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:57.275,421] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:57.389,312] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:57.532,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:57.682,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:57.832,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:57.982,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:58.153,167] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:58.282,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:58.432,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:58.582,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:58.732,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:58.882,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:59.032,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:59.182,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:59.332,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:59.482,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:59.632,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:59.815,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:23:59.932,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:00.082,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:00.232,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:00.382,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:00.532,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:00.682,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:00.832,366] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:00.982,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:01.232,360] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:01.382,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:01.532,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:01.652,160] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:24:01.677,276] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:24:01.677,764] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:24:01.970,947] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:24:01.971,038] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:24:01.978,149] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:24:02.078,216] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:24:02.078,857] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:24:02.078,887] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:24:02.178,955] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:24:13.872,802] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:24:13.977,966] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:24:14.082,275] <inf> BLE: exchange_func: MTU exchange done
    00> [01:24:14.784,271] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:24:14.784,301] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:24:14.784,301] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:24:14.784,362] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:24:14.784,423] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:24:14.784,545] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:24:14.793,579] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:24:14.893,646] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:24:15.739,776] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:24:15.739,868] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:24:15.739,868] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:24:15.898,803] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:16.045,318] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:16.191,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:16.341,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:16.584,930] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:16.691,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:16.841,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:16.991,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:17.141,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:24:17.291,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:17.441,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:17.591,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:17.741,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:17.902,252] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:18.041,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:18.191,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:18.341,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:18.491,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:18.641,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:18.791,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:18.941,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:19.091,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 1
    00> [01:24:19.241,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:19.391,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:24:19.641,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:19.791,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:19.941,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:20.091,888] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:20.241,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:20.391,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:20.591,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:20.791,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:20.941,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:21.091,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:21.241,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:21.391,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:21.541,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:21.691,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:21.841,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:22.034,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:22.141,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:22.298,797] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:22.441,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:22.591,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:22.741,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:22.891,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:23.084,930] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:23.191,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:23.341,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:23.491,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:23.641,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:23.791,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:23.941,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:24.091,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:24.241,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:24.391,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:24.548,797] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:24.691,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:24.841,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:24.991,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:25.141,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:25.291,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:25.441,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:25.591,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:25.741,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:25.891,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:26.041,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:26.191,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:26.341,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:26.491,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:26.641,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:26.838,409] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:26.975,433] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:27.145,324] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:27.291,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:24:27.441,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:27.591,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:27.775,421] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:27.905,731] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:28.041,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:28.191,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:28.341,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:28.491,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:28.662,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:28.791,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:28.941,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:29.091,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:29.241,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:29.391,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:29.541,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:29.691,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:29.841,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:29.991,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:30.141,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:30.291,870] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:30.441,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:30.591,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:30.741,851] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:24:30.861,663] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:24:30.886,779] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:24:30.937,622] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:24:31.230,438] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:24:31.230,560] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:24:31.238,006] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:24:31.338,073] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:24:31.338,714] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:24:31.338,745] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:24:31.438,812] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CEREG: 1,"C3C7","0DBD1516",7,
    00> [01:24:59.692,779] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:24:59.806,671] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:24:59.910,980] <inf> BLE: exchange_func: MTU exchange done
    00> [01:25:00.610,534] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:25:00.610,565] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:25:00.610,595] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:25:00.610,626] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:25:00.610,687] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:25:00.610,809] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:25:00.619,842] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:25:00.719,940] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:25:01.568,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:25:01.568,572] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:25:01.568,572] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:25:01.727,508] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:01.870,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:02.024,047] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:02.170,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:02.320,556] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:02.513,641] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:02.620,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:02.804,138] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:02.920,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:03.100,585] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:03.220,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:03.370,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:03.524,047] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:03.670,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:03.820,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:03.970,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:04.120,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:04.270,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:04.420,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:04.617,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:04.720,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:04.870,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:05.060,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:05.170,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:05.420,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:05.570,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:05.720,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:05.870,605] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:06.020,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:06.170,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:06.370,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:06.567,108] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:06.670,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:25:06.820,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:06.970,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:07.191,375] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:07.320,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:07.497,100] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:07.624,053] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:07.787,902] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:07.943,634] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:08.080,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:08.220,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:08.417,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:08.520,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:08.670,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:08.850,585] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:08.970,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:09.120,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:09.270,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:09.420,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:09.570,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:09.741,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:09.870,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:10.020,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:10.170,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:10.320,556] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:10.470,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:10.620,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:10.770,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:10.920,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:11.070,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:11.280,975] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:11.424,041] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:11.570,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:11.674,041] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:11.820,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:11.970,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:12.147,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:12.274,047] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:12.420,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:12.574,035] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:12.770,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:12.920,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:13.110,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:13.220,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:13.370,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:13.550,567] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:13.670,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:13.820,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:13.970,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:14.120,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:14.270,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:14.430,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:14.667,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:14.770,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:14.920,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:15.120,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:15.270,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:15.420,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:15.570,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:15.720,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:15.870,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:16.020,568] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:16.213,623] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:16.320,587] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:16.470,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:16.620,574] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:16.740,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:25:16.765,594] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:25:16.765,808] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:25:17.059,143] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:25:17.059,265] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:25:17.066,192] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:25:17.166,259] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:25:17.166,900] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:25:17.166,931] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> .[01:25:17.266,998] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:25:17.321,228] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:25:17.427,673] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:25:17.531,982] <inf> BLE: exchange_func: MTU exchange done
    00> [01:25:18.281,524] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:25:18.281,555] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:25:18.281,585] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:25:18.281,616] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:25:18.281,677] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:25:18.281,799] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:25:18.290,832] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:25:18.390,930] <inf> MAIN: ble_connected_state: START FLAG sent
    00> Received:
    00> +CSCON: 1
    00> [01:25:19.239,501] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:25:19.239,562] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:25:19.239,593] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:25:19.398,498] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:19.541,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:19.691,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:19.841,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:20.091,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:20.198,516] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:20.341,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:20.491,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:20.641,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:20.791,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:20.941,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:21.091,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:21.241,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:21.391,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:21.541,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:21.701,965] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:21.841,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:22.041,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:22.191,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:22.388,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:22.491,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:22.641,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:22.791,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:25:22.995,056] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:23.168,121] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:23.291,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:23.441,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:23.591,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:23.741,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:23.891,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:24.041,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:24.191,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:24.341,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:24.491,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:24.684,631] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:24.791,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:24.941,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:25.045,043] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:25.191,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:25.341,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:25.491,607] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:25.641,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:25.791,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:25.941,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:26.091,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:26.241,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:26.391,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:26.541,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:26.691,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:26.841,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:26.991,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:27.141,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:27.291,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:27.441,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:27.591,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:27.741,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:27.891,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:28.041,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:28.191,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:28.391,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:25:28.541,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:28.741,607] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:28.891,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:29.041,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:29.191,558] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:29.341,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:29.491,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:29.641,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:29.791,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:29.941,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:30.091,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:30.241,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:30.391,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:30.541,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:30.691,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:30.841,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:30.991,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:31.141,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:31.291,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:31.441,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:31.591,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:31.741,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:31.891,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:32.041,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:32.191,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:32.341,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:32.541,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:32.691,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:32.841,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:32.991,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:33.184,631] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:33.291,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:33.441,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:33.591,583] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:33.741,577] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:33.891,571] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:34.041,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:34.191,589] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:34.311,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:25:34.336,486] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:25:34.336,761] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:25:34.580,169] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:25:34.580,261] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:25:34.637,145] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:25:34.737,213] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:25:34.737,854] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:25:34.737,884] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:25:34.837,951] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CEREG: 1,"C3C7","0DC27C15",7,
    00> [01:25:46.471,282] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:25:46.584,350] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:25:46.688,659] <inf> BLE: exchange_func: MTU exchange done
    00> [01:25:47.388,214] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:25:47.388,244] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:25:47.388,244] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:25:47.388,305] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:25:47.388,366] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:25:47.388,488] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:25:47.397,521] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:25:47.497,619] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:25:48.346,160] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:25:48.346,252] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:25:48.346,252] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:25:48.505,187] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:48.648,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:48.798,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:48.998,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:49.148,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:49.298,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:49.448,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:49.598,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:49.798,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:49.948,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:50.148,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:50.298,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:50.448,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:50.598,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:50.774,780] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:50.901,702] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:51.048,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:25:51.198,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:51.348,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:51.498,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:51.648,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:51.798,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:51.948,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:25:52.198,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:52.378,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:52.498,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:52.651,702] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:52.798,278] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:52.948,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:53.098,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:53.269,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:53.398,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:53.562,133] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:53.698,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:53.848,266] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:53.998,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:54.198,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:54.348,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:54.498,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:54.648,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:54.798,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:54.948,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:55.051,727] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:55.198,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:55.348,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:55.498,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:55.648,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:55.808,654] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:55.948,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:56.148,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:56.298,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:56.498,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:56.648,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:56.837,829] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:56.948,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:57.098,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:57.251,708] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:57.398,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:57.574,768] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:57.701,721] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:57.848,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:57.998,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:58.205,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:58.398,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:58.548,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:58.744,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:58.848,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:58.998,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:59.148,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:59.255,187] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:59.401,702] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:59.548,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:59.698,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:59.848,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:25:59.998,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:00.148,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:00.298,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:00.448,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:00.598,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:00.748,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:00.898,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:01.048,248] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:01.198,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:26:01.348,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:01.498,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:01.648,254] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:01.801,727] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:01.948,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:02.055,175] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:02.198,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:02.355,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:02.551,727] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:02.698,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:02.848,236] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:02.998,260] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:03.187,835] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:03.331,817] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:03.448,242] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:03.568,023] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:26:03.593,170] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:26:03.593,383] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:26:03.836,822] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:26:03.836,944] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:26:03.893,768] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:26:03.993,835] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:26:03.994,476] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:26:03.994,506] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:26:04.094,573] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> Received:
    00> +CSCON: 1
    00> [01:26:32.405,456] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:26:32.518,585] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:26:32.622,894] <inf> BLE: exchange_func: MTU exchange done
    00> [01:26:33.322,418] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:26:33.322,448] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:26:33.322,479] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:26:33.322,509] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:26:33.322,570] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:26:33.322,692] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:26:33.331,726] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:26:33.431,823] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:26:34.280,395] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:26:34.280,456] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:26:34.280,487] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:26:34.439,422] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:34.582,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:34.732,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:34.882,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:35.032,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:35.182,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:35.332,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:35.482,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:35.632,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:35.782,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:35.932,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:36.082,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:36.232,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:36.382,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:36.532,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:36.682,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:36.835,937] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:36.982,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:37.132,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:37.282,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:37.432,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:37.642,883] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:37.782,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:37.932,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:26:38.235,931] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:38.382,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:38.532,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:38.682,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:38.832,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:38.982,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:39.132,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:39.282,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:39.432,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:39.625,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:39.735,931] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:39.885,925] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> [01:26:40.032,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:40.182,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:40.382,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:40.532,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:40.722,076] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:26:40.832,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:40.982,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:41.132,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:41.282,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:41.432,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:41.582,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:41.732,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:41.882,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:42.032,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:42.185,943] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:42.332,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:42.482,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:42.666,046] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:42.782,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:42.932,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:43.082,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:43.232,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:43.382,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:43.532,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:43.682,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:43.846,343] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:43.982,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:44.132,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:44.332,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:44.482,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:44.632,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:44.782,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:44.932,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:45.128,997] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:45.232,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:45.382,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:45.532,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:45.699,829] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:45.832,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:45.992,889] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:46.132,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:46.285,949] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:46.432,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:46.582,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:46.778,991] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:46.882,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:47.082,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:47.232,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:47.382,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:47.532,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:47.682,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:47.832,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:48.016,052] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:48.132,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:48.282,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:48.432,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:48.632,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:48.782,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:48.932,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:49.082,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:49.282,501] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:49.432,464] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:49.552,246] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:26:49.577,484] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:26:49.579,376] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:26:49.871,063] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:26:49.871,154] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:26:49.879,760] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:26:49.979,827] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:26:49.980,468] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:26:49.980,499] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:26:50.080,566] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:26:50.241,577] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:26:50.355,651] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:26:50.459,960] <inf> BLE: exchange_func: MTU exchange done
    00> [01:26:51.159,515] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:26:51.159,545] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:26:51.159,576] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:26:51.159,606] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:26:51.159,667] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:26:51.159,790] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:26:51.168,823] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:26:51.268,920] <inf> MAIN: ble_connected_state: START FLAG sent
    00> .[01:26:52.117,462] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:26:52.117,553] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:26:52.117,553] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:26:52.276,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:52.419,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:52.569,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:52.719,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:52.869,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:53.019,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:53.169,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:53.319,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:53.469,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:53.619,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:53.769,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:53.873,016] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:54.019,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:54.169,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:54.319,580] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:54.469,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:54.619,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:54.812,622] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:54.940,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:55.069,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:55.266,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:55.369,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:55.519,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:55.669,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:26:55.919,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:56.069,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:56.223,022] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:56.469,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:56.619,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:56.769,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:56.919,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:57.069,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:57.219,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:57.369,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:57.519,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:57.669,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:57.819,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:57.969,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:58.119,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:58.269,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:58.419,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:58.569,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:58.769,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:58.942,626] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:59.069,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:59.219,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:59.369,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:59.473,022] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:59.646,087] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:59.769,592] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:26:59.919,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:00.069,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:00.219,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:00.369,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:00.519,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:00.669,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:00.819,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:01.019,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:01.203,125] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:01.359,161] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:01.469,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:01.619,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:01.769,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:01.919,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:02.069,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:27:02.219,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:02.383,422] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:02.519,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:02.669,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:02.819,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:02.969,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:03.119,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:03.269,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:03.419,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:03.569,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:03.719,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:03.869,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:04.019,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:04.169,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:04.319,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:04.469,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:04.619,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:04.786,895] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:04.969,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:05.119,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:05.269,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:05.419,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:05.569,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:05.719,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:05.869,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:06.019,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:06.169,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:06.319,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:06.486,907] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:06.619,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:06.769,561] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:06.969,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:07.119,537] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:07.239,349] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:27:07.264,465] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:27:07.268,005] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:27:07.508,117] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:27:07.508,239] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:27:07.568,389] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:27:07.668,457] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:27:07.669,097] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:27:07.669,128] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:27:07.769,195] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CSCON: 1
    00> [01:27:19.280,578] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:27:19.393,249] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:27:19.497,558] <inf> BLE: exchange_func: MTU exchange done
    00> [01:27:20.197,082] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:27:20.197,113] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:27:20.197,143] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:27:20.197,174] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:27:20.197,235] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:27:20.197,387] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:27:20.206,420] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:27:20.306,488] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:27:21.155,059] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:27:21.155,120] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:27:21.155,151] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:27:21.317,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:21.457,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:21.653,656] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:21.757,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:21.907,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:22.060,607] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:22.207,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:22.310,607] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:22.483,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:22.610,595] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:22.757,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:22.907,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:23.057,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:23.227,935] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:23.357,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:23.507,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:23.657,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:23.807,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:23.957,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:24.107,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:24.257,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:24.407,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:24.557,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:27:24.707,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:27:24.957,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:25.107,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:25.257,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:25.407,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:25.557,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:25.707,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:25.857,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:26.007,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:26.157,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:26.307,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:26.410,614] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:26.514,068] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:26.657,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:26.807,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:26.957,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:27.107,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:27.257,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:27.407,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:27.607,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:27.760,620] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:28.007,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:28.157,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:28.350,189] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:28.500,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:28.607,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:28.777,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:28.933,654] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:29.057,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:29.207,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:29.357,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:29.517,547] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:29.657,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:29.807,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:30.007,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:30.157,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:30.307,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:30.457,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:30.607,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:30.757,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:30.907,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:31.010,620] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:31.157,165] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:31.307,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:31.457,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:31.607,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:31.757,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:31.907,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:32.057,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:32.207,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:32.360,595] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:32.507,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:32.657,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:32.780,212] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:32.907,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:33.057,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:33.246,734] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:33.357,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:33.507,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:33.657,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:33.807,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:33.960,601] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:34.107,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:34.257,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:34.407,135] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:34.557,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:34.707,122] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:34.857,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:27:35.007,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:35.110,595] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:35.257,141] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:35.410,614] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:35.557,128] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:35.707,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:35.857,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:27:35.976,928] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:27:36.002,075] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:27:36.006,469] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:27:36.245,727] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:27:36.245,819] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:27:36.306,854] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:27:36.406,921] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:27:36.407,562] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:27:36.407,592] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:27:36.507,659] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CEREG: 1,"C3C7","0DBD1516",7,
    00> [01:28:05.117,095] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:28:05.230,072] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:28:05.384,368] <inf> BLE: exchange_func: MTU exchange done
    00> [01:28:06.133,911] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:28:06.133,941] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:28:06.133,972] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:28:06.134,002] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:28:06.134,063] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:28:06.134,185] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:28:06.143,218] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:28:06.243,316] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:28:07.091,888] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:28:07.091,949] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:28:07.091,979] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:28:07.250,885] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:07.393,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:07.587,005] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:07.693,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:07.843,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:07.993,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:08.183,563] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:08.293,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:08.443,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:08.593,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:08.743,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:08.920,501] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:09.043,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:09.193,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:09.343,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:09.493,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:09.643,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:09.793,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:09.943,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:10.137,023] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:10.243,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:10.397,430] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:10.543,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:10.793,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:10.920,471] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:11.043,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:11.193,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:11.343,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:11.504,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:11.643,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:11.843,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:11.993,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:12.143,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:12.293,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:12.490,478] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:12.593,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:12.743,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:12.893,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:13.043,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:13.193,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:13.343,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:13.493,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:13.650,878] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:13.793,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:13.943,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:14.093,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:14.243,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:14.393,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:14.633,544] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:14.743,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:28:14.893,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:15.043,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:15.193,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:15.343,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:15.493,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:15.643,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:15.800,903] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:15.943,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:16.143,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:16.293,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:16.443,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:16.593,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:16.743,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:16.893,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:17.070,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:17.193,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:17.343,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:17.493,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:17.643,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:17.793,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:17.943,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:18.193,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:18.347,412] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:18.493,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:18.643,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:18.837,005] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:18.943,939] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:19.047,424] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:28:19.243,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:19.417,022] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:19.583,557] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:19.704,376] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:19.843,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:19.993,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:20.143,951] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:20.293,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:20.443,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:20.593,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:20.743,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:20.943,939] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:21.093,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:21.197,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:21.343,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:21.493,957] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:21.687,011] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:21.793,945] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:21.943,969] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:22.093,963] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:22.213,745] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:28:22.238,952] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:28:22.239,196] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:28:22.482,543] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:28:22.482,635] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:28:22.539,581] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:28:22.639,648] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:28:22.640,289] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:28:22.640,319] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:28:22.740,386] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:28:22.968,017] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:28:23.082,794] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:28:23.187,103] <inf> BLE: exchange_func: MTU exchange done
    00> [01:28:23.886,627] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:28:23.886,657] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:28:23.886,688] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:28:23.886,718] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:28:23.886,779] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:28:23.886,901] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:28:23.895,935] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:28:23.996,032] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:28:24.844,604] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:28:24.844,665] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:28:24.844,696] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:28:25.003,601] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:25.146,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:25.296,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:25.446,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:25.596,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:25.773,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:25.896,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:26.046,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:26.196,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:28:26.346,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:26.496,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:26.646,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:26.796,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:26.946,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:27.096,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:27.246,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:27.396,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:27.546,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:27.726,684] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:27.846,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:27.996,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:28.146,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:28.307,098] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:28.446,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:28:28.696,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:28.896,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:29.046,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:29.196,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:29.389,739] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:29.496,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:29.646,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:29.796,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:29.946,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:30.096,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:30.246,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:30.396,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:30.546,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:30.696,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:30.846,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:31.046,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:31.243,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:31.346,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:31.496,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:31.646,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:31.796,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:31.946,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:32.096,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:32.203,613] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:32.346,710] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:32.510,559] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:32.646,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:32.796,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:32.946,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:33.096,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:33.246,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:33.396,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:33.546,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:33.736,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:33.846,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:33.996,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:34.146,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:34.296,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:34.446,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:34.596,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:34.746,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:34.896,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:35.046,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:35.196,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:35.346,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:35.496,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:35.646,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:35.796,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:35.946,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:36.096,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:36.246,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:28:36.396,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:36.546,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:36.696,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:36.846,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:37.007,080] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:37.146,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:37.300,140] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:37.496,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:37.693,206] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:37.796,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:37.986,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:38.096,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:38.276,672] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:38.396,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:38.546,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:38.696,685] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:38.846,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:38.996,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:39.146,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:39.350,158] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:39.496,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:39.646,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:39.796,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:39.916,473] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:28:39.941,589] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:28:39.942,504] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:28:40.235,260] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:28:40.235,351] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:28:40.242,889] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:28:40.342,956] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:28:40.343,597] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:28:40.343,627] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:28:40.443,695] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CEREG: 1,"C3C7","0DC27C15",7,
    00> [01:28:51.587,585] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:28:51.697,082] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:28:51.801,391] <inf> BLE: exchange_func: MTU exchange done
    00> [01:28:52.500,946] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:28:52.500,976] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:28:52.501,007] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:28:52.501,037] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:28:52.501,098] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:28:52.501,220] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:28:52.510,253] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:28:52.610,351] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:28:53.458,923] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:28:53.458,984] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:28:53.459,014] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:28:53.650,573] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:53.760,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:53.934,051] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:54.060,974] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:54.210,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:54.360,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:54.510,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:54.660,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:54.810,974] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:54.960,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:55.110,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:55.304,046] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:55.410,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:55.561,004] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:55.710,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:55.890,991] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:56.010,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:56.160,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:56.310,974] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:56.460,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:56.610,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:56.760,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:56.964,447] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:57.110,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:28:57.360,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:57.510,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:57.660,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:57.811,004] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:57.960,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:58.110,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:58.260,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:58.410,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:28:58.561,004] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:58.710,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:58.860,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:59.010,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:59.160,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:59.357,513] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:59.460,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:59.610,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:59.760,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:28:59.910,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:00.017,913] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:00.160,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:00.310,974] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:00.460,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:00.610,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:00.774,871] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:00.910,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:01.067,932] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:01.210,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:01.410,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:01.560,974] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:01.710,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:01.860,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:02.010,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:02.160,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:02.337,524] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:02.460,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:02.610,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:02.760,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:02.910,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:03.061,004] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:03.210,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:03.410,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:03.561,004] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:03.710,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:03.860,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:04.010,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:04.164,459] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:04.310,974] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:04.484,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:04.610,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:04.778,320] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:04.910,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:05.071,380] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:05.210,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:05.360,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:05.510,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:05.660,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:05.811,004] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:05.960,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:06.110,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:06.260,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:06.440,979] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:06.560,974] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:06.710,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:06.860,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:07.010,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:07.260,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:07.410,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:07.561,004] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:07.710,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:07.860,992] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:08.010,986] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:08.160,980] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:08.337,524] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:08.460,998] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:08.580,780] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:29:08.605,895] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:29:08.606,750] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> .[01:29:08.849,578] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:29:08.849,670] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:29:08.907,165] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:29:09.007,232] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:29:09.007,873] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:29:09.007,904] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:29:09.108,001] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:29:37.721,588] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:29:37.835,784] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:29:37.940,093] <inf> BLE: exchange_func: MTU exchange done
    00> [01:29:38.639,617] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:29:38.639,648] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:29:38.639,678] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:29:38.639,709] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:29:38.639,770] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:29:38.639,892] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:29:38.648,925] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:29:38.749,023] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:29:39.597,595] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:29:39.597,656] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:29:39.597,686] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:29:39.756,591] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:39.899,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:40.049,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:40.220,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:40.349,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:40.499,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:40.649,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:40.849,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:40.999,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:41.149,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:41.299,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:41.449,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:41.599,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:41.749,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:41.899,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:42.053,131] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:42.199,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:42.349,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:42.499,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:42.649,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:42.799,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:42.949,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:43.099,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:43.299,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:29:43.599,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:43.789,276] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:43.899,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:44.049,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:44.203,125] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:44.349,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:44.499,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:44.649,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:44.799,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:44.949,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:45.099,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:45.249,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:45.449,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:45.599,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:45.749,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:45.899,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:46.089,263] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:46.199,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:46.349,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:46.499,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:46.649,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:46.799,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:46.949,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:47.099,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:47.249,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:47.399,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:47.549,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:47.699,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:47.849,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:47.999,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:48.149,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:48.333,251] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:48.449,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:29:48.599,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:48.749,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:48.899,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:49.049,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:49.199,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:49.349,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:49.529,663] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:49.649,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:49.799,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:49.949,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:50.099,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:50.296,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:50.399,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:50.549,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:29:50.699,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:50.849,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:51.003,143] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:51.163,543] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:51.299,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:51.449,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:51.599,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:51.749,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:51.899,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:52.092,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:52.199,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:52.349,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:52.533,233] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:52.649,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:52.799,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:52.999,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:53.149,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:53.299,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:53.449,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:53.599,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:53.749,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:53.899,658] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:54.049,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:54.199,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:54.349,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:54.549,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:54.699,676] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:54.819,458] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:29:54.844,604] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:29:54.895,507] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:29:55.588,806] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:29:55.588,928] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 8)
    00> [01:29:55.596,160] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:29:55.696,228] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:29:55.696,868] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:29:55.696,899] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:29:55.791,290] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:29:55.796,997] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:29:55.904,266] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:29:56.008,575] <inf> BLE: exchange_func: MTU exchange done
    00> [01:29:56.708,099] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:29:56.708,129] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:29:56.708,160] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:29:56.708,190] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:29:56.708,251] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:29:56.708,404] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:29:56.717,437] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:29:56.817,504] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:29:57.666,076] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:29:57.666,137] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:29:57.666,168] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:29:57.825,103] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:57.968,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:58.118,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:58.268,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:58.418,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:58.568,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:58.718,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:58.875,091] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:59.068,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:59.218,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:59.407,745] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:59.518,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:29:59.668,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:59.818,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:29:59.968,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:00.118,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:00.268,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:00.418,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:00.578,552] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:00.718,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:00.868,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:01.018,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:01.211,212] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:01.318,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:30:01.568,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:01.718,139] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:01.868,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:02.018,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:02.168,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:02.318,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:02.468,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:02.618,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:02.768,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:02.921,630] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:03.068,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:03.218,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:03.368,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:03.518,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:03.668,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:03.818,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:03.994,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:04.118,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:04.268,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:04.418,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:04.568,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:04.718,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:04.868,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:05.018,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:05.168,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:05.318,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:05.468,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:05.618,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:05.768,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:05.918,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:06.068,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:06.218,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:06.368,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:06.538,970] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:06.668,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:06.818,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:06.968,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:07.118,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:07.268,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:07.418,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:07.568,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:07.761,230] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:07.901,733] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:08.018,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:08.168,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:08.318,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:08.491,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:08.618,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:08.768,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:08.918,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:09.068,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:09.218,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:09.368,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:09.518,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:30:09.668,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:09.818,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:09.968,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:10.118,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:10.271,636] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:10.418,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:10.568,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:10.738,952] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:10.868,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:11.018,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:11.168,151] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:11.318,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:11.468,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:11.618,164] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:11.768,157] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:11.961,212] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:12.068,145] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:12.218,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:12.361,206] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:12.468,170] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:12.613,677] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:30:12.638,671] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:30:12.638,916] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:30:12.856,750] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:30:12.856,842] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:30:12.939,300] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:30:13.039,367] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:30:13.040,008] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:30:13.040,039] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:30:13.140,106] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:30:24.294,677] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:30:24.401,519] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:30:24.505,828] <inf> BLE: exchange_func: MTU exchange done
    00> [01:30:25.205,352] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:30:25.205,383] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:30:25.205,413] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:30:25.205,444] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:30:25.205,505] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:30:25.205,627] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:30:25.214,691] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:30:25.314,758] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:30:26.163,330] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:30:26.163,391] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:30:26.163,421] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:30:26.322,326] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:26.465,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:26.615,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:26.808,471] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:26.915,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:27.065,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:27.215,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:27.375,823] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:27.515,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:27.691,925] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:27.815,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:27.965,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:28.115,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:28.365,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:28.565,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:28.715,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:28.865,386] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:29.015,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:29.165,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:29.315,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:29.465,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:29.615,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:29.765,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:30:30.015,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:30.165,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:30.315,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:30.515,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:30.665,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:30.815,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:30.965,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:31.115,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:31.265,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:31.368,865] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:31.541,931] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:31.665,435] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:31.815,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:30:31.965,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:32.115,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:32.268,859] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:32.422,332] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:32.565,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:32.715,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:32.865,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:33.015,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:33.165,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:33.315,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:33.465,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:33.615,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:33.765,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:33.915,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:34.082,733] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:34.215,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:34.365,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:34.515,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:34.665,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:34.911,926] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:35.015,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:35.165,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:35.315,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:35.465,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:35.615,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:35.815,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:35.965,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:36.115,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:36.265,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:36.415,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:36.529,266] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:36.665,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:36.865,386] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:37.015,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:37.165,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:37.315,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:37.465,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:37.615,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:37.765,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:37.915,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:38.065,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:38.215,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:38.365,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:38.515,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:38.665,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:38.815,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:38.965,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:39.165,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:39.361,938] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:39.508,453] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:39.615,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:39.765,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:39.915,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:40.065,399] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:40.215,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:40.365,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:40.515,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:40.665,405] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:40.825,805] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:40.965,393] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:41.115,417] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:41.265,411] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:30:41.385,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:30:41.410,339] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:30:41.410,552] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:30:41.653,991] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:30:41.654,083] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:30:41.710,937] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:30:41.811,004] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:30:41.811,645] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:30:41.811,676] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:30:41.911,743] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> [01:31:10.757,873] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:31:10.867,492] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:31:10.971,801] <inf> BLE: exchange_func: MTU exchange done
    00> [01:31:11.721,343] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:31:11.721,374] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:31:11.721,374] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:31:11.721,435] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:31:11.721,496] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:31:11.721,618] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:31:11.730,651] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:31:11.830,749] <inf> MAIN: ble_connected_state: START FLAG sent
    00> .[01:31:12.679,290] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:31:12.679,382] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:31:12.679,382] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:31:12.838,317] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:12.981,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:13.134,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:13.288,330] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:13.431,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:13.581,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:13.781,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:13.977,905] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:14.081,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:14.231,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:14.381,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:14.531,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:14.681,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:14.854,431] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:14.981,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:15.131,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:15.281,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:15.431,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:15.581,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:15.781,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:15.981,414] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:16.131,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:16.281,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:31:16.531,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:16.707,916] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:16.834,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:17.002,197] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:17.134,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:17.281,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:17.431,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:17.581,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:17.781,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:17.931,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:18.081,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:18.277,923] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:18.420,989] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:18.531,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:18.681,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:18.831,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:18.981,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:19.134,857] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:31:19.281,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:19.431,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:19.581,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:19.781,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:19.931,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:20.081,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:20.231,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:20.427,917] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:20.531,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:20.681,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:20.831,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:20.981,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:21.131,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:21.281,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:21.431,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:21.581,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:21.731,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:21.881,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:22.081,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:31:22.231,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:22.381,408] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:22.531,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:22.681,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:22.834,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:22.981,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:23.131,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:23.314,941] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:23.431,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:23.581,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:23.734,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:23.881,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:24.124,450] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:24.281,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:24.431,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:24.581,420] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:24.774,444] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:24.881,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:25.074,432] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:25.181,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:25.331,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:25.481,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:25.631,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:25.781,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:25.931,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:26.081,390] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:26.231,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:26.431,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:26.624,450] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:26.731,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:26.881,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:27.031,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:27.181,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:27.357,910] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:27.481,384] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:27.631,378] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:27.781,372] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:27.931,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:28.051,177] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:31:28.076,385] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:31:28.126,220] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:31:28.419,952] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:31:28.420,074] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:31:28.426,605] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:31:28.526,672] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:31:28.527,313] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:31:28.527,343] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:31:28.621,337] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:31:28.627,410] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:31:28.731,933] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:31:28.836,242] <inf> BLE: exchange_func: MTU exchange done
    00> [01:31:29.585,784] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:31:29.585,815] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:31:29.585,845] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:31:29.585,876] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:31:29.585,937] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:31:29.586,059] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:31:29.595,123] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:31:29.695,190] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:31:30.543,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:31:30.543,823] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:31:30.543,853] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:31:30.702,789] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:30.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:30.995,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:31.195,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:31.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:31.542,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:31.645,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:31.795,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:31.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:32.095,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:32.245,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:32.435,424] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:32.545,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:32.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:32.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:32.995,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:33.195,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:33.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:31:33.542,358] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:33.645,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:33.795,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:33.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:34.095,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:31:34.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:34.516,662] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:34.645,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:34.795,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:34.945,861] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:35.102,783] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:35.245,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:35.395,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:35.545,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:35.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:35.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:35.995,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:36.145,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:36.295,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:36.472,381] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:36.595,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:36.745,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:36.895,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:37.045,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:37.195,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:37.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:37.495,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:37.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:37.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:37.995,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:38.145,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:38.295,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:38.445,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:38.595,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:38.745,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:38.895,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:39.045,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:39.195,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:39.345,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:39.549,316] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:39.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:39.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:39.995,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:40.188,903] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:40.295,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:40.399,291] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:40.545,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:40.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:40.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:40.995,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:41.145,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:41.295,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:41.445,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:41.595,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:41.799,316] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:41.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:42.142,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:42.288,909] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:42.395,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:42.549,316] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:42.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:42.845,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:42.995,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:43.145,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:43.295,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:43.466,644] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:43.595,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:31:43.795,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:43.945,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:44.095,855] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:44.245,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:44.399,322] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:44.545,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:44.695,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:44.849,304] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:44.995,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:45.145,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:45.295,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:45.459,716] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:45.595,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:45.715,637] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:31:45.740,753] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:31:45.744,445] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:31:45.984,405] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:31:45.984,527] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:31:46.044,830] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:31:46.144,897] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:31:46.145,538] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:31:46.145,568] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:31:46.245,635] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> [01:31:57.093,444] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:31:57.206,939] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:31:57.311,248] <inf> BLE: exchange_func: MTU exchange done
    00> [01:31:58.060,791] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:31:58.060,821] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:31:58.060,821] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:31:58.060,882] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:31:58.060,943] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:31:58.061,065] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:31:58.070,098] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:31:58.170,196] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:31:59.018,737] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:31:59.018,829] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:31:59.018,829] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:31:59.177,764] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:59.320,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:59.470,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:59.620,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:59.770,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:31:59.920,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:00.070,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:00.220,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:00.370,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:00.477,752] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:00.650,817] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:00.770,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:00.947,357] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:01.084,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:01.220,855] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:01.374,298] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:01.520,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:01.688,171] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:01.824,279] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:01.970,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:02.120,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:02.270,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:02.420,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:02.570,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:32:02.820,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:02.963,897] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:03.070,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:03.220,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:03.370,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:03.520,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:03.670,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:03.820,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:04.004,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:04.120,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:04.317,352] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:04.420,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:04.570,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:04.720,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:04.870,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:05.050,811] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:05.170,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:05.320,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:05.474,304] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:05.634,704] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:32:05.788,177] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:05.920,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:06.070,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:06.304,382] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:06.467,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:06.570,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:06.720,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:06.870,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:07.020,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:07.234,710] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:07.370,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:07.520,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:07.677,764] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:07.820,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:07.970,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:08.120,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:08.270,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:08.420,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:08.617,370] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:08.720,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:08.870,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:09.050,811] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:09.170,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:09.347,351] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:09.470,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:09.620,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:09.770,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:09.920,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:10.070,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:10.270,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:10.420,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:10.570,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:10.720,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:10.870,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:11.020,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:11.170,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:11.363,891] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:11.497,344] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:11.620,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:11.770,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:11.920,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:12.070,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:12.220,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:12.370,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:12.520,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:12.670,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:12.870,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:13.020,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:13.220,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:13.370,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:13.520,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:13.670,837] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:13.820,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:13.970,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:14.090,606] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:32:14.115,753] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:32:14.166,809] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:32:14.809,967] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:32:14.810,089] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 8)
    00> [01:32:14.867,462] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:32:14.967,529] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:32:14.968,170] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:32:14.968,200] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:32:15.068,267] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:32:43.665,161] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:32:43.776,763] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:32:43.881,103] <inf> BLE: exchange_func: MTU exchange done
    00> [01:32:44.580,627] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:32:44.580,657] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:32:44.580,688] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:32:44.580,718] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:32:44.580,780] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:32:44.580,902] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:32:44.589,935] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:32:44.690,032] <inf> MAIN: ble_connected_state: START FLAG sent
    00> .[01:32:45.585,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:32:45.585,205] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:32:45.585,205] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:32:45.697,601] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:45.840,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:46.020,660] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:46.144,134] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:46.290,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:46.440,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:46.590,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:46.740,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:46.890,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:47.040,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:47.190,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:47.340,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:47.490,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:47.640,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:47.790,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:47.940,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:48.090,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:48.270,690] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:48.390,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:48.540,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:48.690,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:48.854,553] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:48.990,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:49.140,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:32:49.390,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:49.540,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:49.690,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:49.840,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:49.990,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:50.140,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:50.290,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:50.440,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:32:50.590,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CEREG: 1,"C3C7","0DBD1516",7,
    00> [01:32:50.740,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:50.890,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:51.040,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:51.190,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:51.340,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:51.540,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:51.690,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:51.840,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:51.997,619] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:52.140,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:52.290,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:52.490,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:52.737,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:52.840,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:52.990,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:53.194,152] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:53.340,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:53.490,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:53.663,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:53.790,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:53.940,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:54.090,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:54.294,158] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:54.451,080] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:54.590,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:54.694,152] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:54.917,205] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:55.083,740] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:55.240,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:55.390,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:55.540,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:32:55.690,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:55.933,746] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:56.040,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:56.190,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:56.440,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:56.601,074] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:56.740,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:56.890,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:57.040,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:57.190,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:57.390,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:57.540,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:57.740,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:57.940,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:58.090,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:58.337,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:58.440,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:58.590,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:58.770,690] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:58.890,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:59.040,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:59.190,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:59.340,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:59.490,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:59.640,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:59.790,679] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:32:59.940,673] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:00.090,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:00.240,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:00.437,194] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:00.590,667] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:00.780,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:00.890,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:01.042,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:01.183,929] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:33:01.208,923] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:33:01.236,511] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:33:01.529,266] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:33:01.529,357] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:33:01.536,895] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:33:01.636,962] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:33:01.637,603] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:33:01.637,634] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:33:01.655,517] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:33:01.737,701] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:33:01.767,608] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:33:01.871,917] <inf> BLE: exchange_func: MTU exchange done
    00> [01:33:02.571,472] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:33:02.571,502] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:33:02.571,502] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:33:02.571,563] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:33:02.571,624] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:33:02.571,746] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:33:02.580,780] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:33:02.680,877] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:33:03.529,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:33:03.529,510] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:33:03.529,510] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:33:03.691,925] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:03.831,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:03.981,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:04.131,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:04.281,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:04.471,099] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:04.581,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:04.761,505] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:04.881,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:05.054,565] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:05.181,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:05.331,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:05.481,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:05.631,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:05.781,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:05.931,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:06.081,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:06.231,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:06.381,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:06.531,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:33:06.681,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:06.831,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:06.981,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:07.131,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:33:07.398,834] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:07.531,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:07.681,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:07.831,542] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:07.981,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:08.131,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:08.328,033] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:08.431,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:08.581,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:08.731,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:08.881,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:09.031,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:09.181,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:09.352,325] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:09.481,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:09.648,834] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:09.781,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:09.931,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:10.081,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:10.231,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:10.381,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:10.531,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:10.681,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:10.831,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:10.981,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:11.131,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:11.281,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:11.431,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:11.602,325] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:11.731,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:11.881,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:12.031,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:12.195,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:12.381,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:12.581,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:12.731,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:12.921,112] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:13.031,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:13.181,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:13.361,511] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:13.481,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:13.631,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:13.781,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:13.931,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:14.081,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:14.231,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:14.381,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:14.531,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:14.681,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:14.831,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:14.981,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:15.131,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:15.311,492] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:15.431,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:15.608,032] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:15.731,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:15.881,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:16.031,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:16.181,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:16.331,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:16.481,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:16.631,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:16.781,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:33:16.931,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:17.081,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:17.234,985] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:17.381,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:17.531,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:17.681,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:17.831,512] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:17.981,506] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:18.131,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:18.281,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:18.431,518] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:18.551,300] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:33:18.576,416] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:33:18.580,291] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:33:18.920,074] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:33:18.920,196] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:33:18.980,743] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:33:19.080,810] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:33:19.081,451] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:33:19.081,481] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:33:19.181,549] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:33:29.916,137] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:33:30.024,169] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:33:30.128,509] <inf> BLE: exchange_func: MTU exchange done
    00> [01:33:30.828,033] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:33:30.828,063] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:33:30.828,094] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:33:30.828,125] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:33:30.828,186] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:33:30.828,308] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:33:30.837,341] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:33:30.937,438] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:33:31.786,010] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:33:31.786,071] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:33:31.786,071] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:33:31.945,007] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:32.131,134] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:32.281,127] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:32.388,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:32.538,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:32.641,540] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:32.788,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:32.938,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:33.105,407] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:33.238,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:33.388,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:33.538,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:33.688,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:33.838,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:33.988,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:34.184,600] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:34.288,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:34.438,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:34.588,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:34.768,096] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:34.888,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:35.038,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:35.191,558] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:35.351,959] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:33:35.588,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:35.738,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:35.888,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:36.038,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:36.238,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:36.431,152] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:36.538,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:36.688,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:36.888,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:37.041,564] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:37.188,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:37.338,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:37.488,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:37.638,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:37.788,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:37.938,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:38.088,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:38.238,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:38.388,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:38.538,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:33:38.688,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:38.871,643] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:39.058,898] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:39.191,558] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:39.358,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:39.491,546] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:39.638,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:39.788,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:39.938,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:40.088,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:40.238,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:40.388,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:40.538,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:40.731,140] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:40.838,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:40.988,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:41.138,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:41.288,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:41.438,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:41.588,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:41.738,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:41.888,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:42.038,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:42.188,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:42.338,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:42.488,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:42.638,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:42.788,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:42.938,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:43.088,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:43.238,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:43.388,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:43.538,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:43.688,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:43.838,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:43.988,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:44.138,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:44.288,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:44.438,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:44.588,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:44.784,606] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:44.888,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:45.038,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:45.188,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:45.338,073] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:45.505,432] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:45.638,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:45.788,085] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:45.938,079] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:46.134,613] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:46.238,067] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:46.388,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:46.638,092] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:46.788,116] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:33:46.907,867] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:33:46.933,074] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:33:46.983,123] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:33:47.276,672] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:33:47.276,763] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:33:47.283,508] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:33:47.383,575] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:33:47.384,216] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:33:47.384,246] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:33:47.484,313] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> [01:34:16.871,246] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:34:16.984,832] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:34:17.089,141] <inf> BLE: exchange_func: MTU exchange done
    00> [01:34:17.788,665] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:34:17.788,696] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:34:17.788,726] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:34:17.788,757] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:34:17.788,818] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:34:17.788,940] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:34:17.797,973] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:34:17.898,071] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:34:18.746,643] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:34:18.746,704] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:34:18.746,734] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:34:18.905,639] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:19.098,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:34:19.248,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:34:19.438,323] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:19.548,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:19.652,191] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:19.838,317] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:19.948,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:20.098,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:20.248,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:20.398,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:20.548,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:20.698,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:20.848,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:20.998,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:21.148,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:21.341,766] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:21.448,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:21.598,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:21.752,197] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:21.925,262] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:22.048,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:22.212,585] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:22.348,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:34:22.598,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:22.755,645] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:22.898,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:23.098,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:23.248,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:23.445,251] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:23.548,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:23.741,790] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:23.852,172] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:23.955,657] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:24.098,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:24.248,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:24.398,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:24.548,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:24.712,585] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:24.848,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:24.998,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:25.148,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:25.298,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:25.448,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:25.598,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:25.838,317] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:25.948,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:26.098,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:26.248,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:26.398,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:26.548,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:26.698,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:26.848,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:26.998,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:27.148,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:27.298,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:27.475,250] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:27.688,323] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:27.798,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:27.948,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:28.055,664] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:28.198,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:28.348,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:28.498,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:28.648,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:28.798,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:28.948,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:29.105,651] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:29.348,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:29.548,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:34:29.698,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:29.848,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:29.998,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:30.148,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:30.298,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:30.475,250] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:30.648,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:30.802,185] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:30.962,585] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:31.116,058] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:31.298,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:31.448,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:31.748,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:31.882,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:31.998,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:32.148,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:32.366,058] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:32.498,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:32.648,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:32.798,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:32.971,771] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:33.098,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:33.248,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:33.419,525] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:33.648,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:33.848,724] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:33.998,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:34.148,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:34.318,511] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:34:34.343,627] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:34:34.393,493] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:34:34.637,298] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:34:34.637,390] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:34:34.693,878] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:34:34.793,945] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:34:34.794,586] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:34:34.794,616] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:34:34.894,683] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:34:35.002,166] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:34:35.111,877] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:34:35.216,186] <inf> BLE: exchange_func: MTU exchange done
    00> [01:34:35.915,710] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:34:35.915,771] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:34:35.915,771] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:34:35.915,832] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:34:35.915,893] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:34:35.916,015] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:34:35.925,048] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:34:36.025,115] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:34:36.873,687] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:34:36.873,748] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:34:36.873,779] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:34:37.132,720] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:37.275,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:37.425,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:37.575,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:37.725,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:37.875,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:38.025,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:38.175,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:38.325,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:38.475,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:38.625,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:38.775,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:38.925,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:39.075,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:39.225,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:39.375,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:39.525,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:39.679,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:39.825,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:39.929,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:40.075,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:40.225,799] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:40.472,290] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:40.625,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:34:40.875,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:34:41.025,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:41.202,301] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:41.375,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:41.525,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:41.675,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:41.825,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:41.975,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:42.155,761] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:42.275,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:42.475,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:42.675,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:42.825,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:42.975,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:43.159,332] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:43.275,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:43.565,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:43.722,290] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:43.865,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:43.975,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:44.125,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:44.325,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:44.475,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:44.675,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:44.825,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:44.975,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:45.175,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:45.422,302] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:45.525,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:45.675,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:45.868,835] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:45.975,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:46.125,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:46.275,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:46.425,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:46.575,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:46.765,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:46.875,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:47.025,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:47.175,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:47.325,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:47.475,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:47.625,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:47.775,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:47.925,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:48.075,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:48.225,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:48.405,761] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:48.525,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:48.705,780] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:48.825,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:48.975,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:49.125,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:49.275,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:49.475,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:49.625,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:49.822,296] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:49.925,750] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:50.075,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:50.225,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:50.422,302] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:50.558,105] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:50.675,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:50.825,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:50.975,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:51.125,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:34:51.275,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:51.425,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:51.618,835] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:51.725,769] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:51.875,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:52.025,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:52.175,781] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:52.325,775] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:34:52.445,556] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:34:52.470,672] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:34:52.470,916] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> Received:
    00> +CSCON: 0
    00> [01:34:52.764,343] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:34:52.764,434] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:34:52.771,301] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:34:52.871,368] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:34:52.872,009] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:34:52.872,039] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:34:52.972,137] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:35:02.618,865] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:35:02.724,395] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:35:02.828,704] <inf> BLE: exchange_func: MTU exchange done
    00> [01:35:03.528,259] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:35:03.528,259] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:35:03.528,289] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:35:03.528,320] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:35:03.528,411] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:35:03.528,533] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:35:03.537,567] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:35:03.637,634] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:35:04.486,206] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:35:04.486,267] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:35:04.486,297] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:35:04.681,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:04.788,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:04.988,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:05.095,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:05.284,820] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:05.388,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:05.584,808] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:05.771,850] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:05.888,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:06.038,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:06.188,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:06.338,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:06.488,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:06.638,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:06.788,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:06.938,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:07.134,826] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:07.238,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:07.388,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:07.581,359] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:07.695,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:07.871,856] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:07.988,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:08.138,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:35:08.388,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:08.538,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:08.734,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:08.848,693] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:08.988,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:09.138,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:09.288,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:09.438,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:09.588,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:09.738,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:09.888,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:10.038,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:10.188,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:10.338,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:10.488,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:10.638,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:10.788,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:10.938,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:11.088,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:11.238,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:11.409,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:11.538,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:11.688,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:11.881,347] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:11.988,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:35:12.184,814] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:12.288,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:12.468,292] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:12.588,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:12.781,341] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:12.888,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:13.038,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:13.188,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:13.338,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:13.441,772] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:13.588,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:13.738,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:13.931,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:14.048,706] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:14.188,323] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:14.341,766] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:14.514,831] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:14.638,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:14.788,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:14.977,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:15.131,347] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:15.238,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:15.345,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:15.521,850] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:15.688,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:15.838,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:15.988,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:16.138,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:16.288,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:16.438,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:16.588,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:16.738,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:16.888,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:17.038,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:17.188,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:17.338,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:17.488,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:17.638,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:17.821,868] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:17.984,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:18.134,826] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:18.238,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:18.388,305] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:18.538,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:18.641,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:18.788,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:19.009,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:19.138,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:19.288,299] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:35:19.408,081] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:35:19.433,197] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:35:19.486,602] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:35:19.776,855] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:35:19.776,977] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:35:19.786,987] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:35:19.887,054] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:35:19.887,695] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:35:19.887,725] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:35:19.987,792] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:35:49.982,818] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:35:50.096,282] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:35:50.250,610] <inf> BLE: exchange_func: MTU exchange done
    00> [01:35:51.000,152] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:35:51.000,183] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:35:51.000,183] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:35:51.000,244] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:35:51.000,305] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:35:51.000,427] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:35:51.009,460] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:35:51.109,527] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:35:51.958,099] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:35:51.958,190] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:35:51.958,190] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:35:52.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:52.310,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:52.513,641] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:52.690,185] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:52.833,251] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:52.960,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:53.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:53.303,253] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:53.417,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:53.560,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:35:53.710,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:53.860,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:54.056,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:54.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:54.340,179] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:54.460,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:54.613,647] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:54.767,120] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:54.970,581] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:55.136,718] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:55.303,253] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:55.413,665] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:35:55.663,665] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:55.810,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:55.999,786] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:56.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:56.310,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:56.510,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:56.710,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:56.910,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:57.060,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:57.256,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:57.360,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:57.510,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:57.660,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 0
    00> Received:
    00> +CEREG: 1,"C3C7","0DC27C15",7,
    00> [01:35:57.810,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:57.960,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:58.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:58.260,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:58.456,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:58.640,197] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:58.760,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:58.910,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:59.060,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:59.210,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:59.360,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:59.510,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:59.617,126] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:59.760,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:35:59.943,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:00.060,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:00.163,665] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:00.356,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:00.460,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:00.610,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:00.806,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:00.960,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:01.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:01.260,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:01.410,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:01.603,240] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:01.710,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:01.863,647] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:02.010,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:02.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:02.360,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:02.527,526] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:02.706,726] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:02.860,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:03.017,120] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:03.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:03.310,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:03.460,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:03.653,259] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:03.760,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:36:03.910,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:04.060,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:04.210,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:04.360,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:04.463,653] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:04.610,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:04.760,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:04.913,665] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:05.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:05.286,712] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:05.460,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:05.613,647] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:05.836,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:05.960,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:06.110,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:06.260,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:06.410,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:06.560,180] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:06.727,539] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:06.860,198] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:07.010,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:07.160,186] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:07.313,659] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:07.453,430] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:36:07.478,393] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:36:07.505,493] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:36:07.748,779] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:36:07.748,870] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:36:07.805,877] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:36:07.905,944] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:36:07.906,585] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:36:07.906,616] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:36:08.006,713] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:36:08.110,900] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:36:08.218,322] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:36:08.322,631] <inf> BLE: exchange_func: MTU exchange done
    00> [01:36:09.122,161] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:36:09.122,192] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:36:09.122,222] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:36:09.122,253] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:36:09.122,344] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:36:09.122,467] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:36:09.131,500] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:36:09.231,567] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:36:10.080,139] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:36:10.080,200] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:36:10.080,230] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:36:10.239,166] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:10.382,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:10.565,795] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:10.732,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:10.882,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:11.071,807] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:11.182,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:11.399,566] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:11.532,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:11.682,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:11.832,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:11.982,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:12.132,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:12.282,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:12.439,147] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:12.632,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:12.782,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:12.932,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:13.082,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:13.232,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:13.412,200] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:13.532,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:36:13.803,039] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:13.932,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:14.082,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:14.232,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:14.382,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:14.532,257] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:14.682,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:14.832,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:14.982,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:15.175,262] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:15.282,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:36:15.432,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:15.582,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:15.732,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:15.882,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:16.032,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:16.182,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:16.396,087] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:16.532,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:16.682,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:16.832,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:16.982,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:17.132,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:17.282,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:17.432,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:17.582,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:17.732,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:17.882,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:18.032,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:18.182,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:18.332,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:18.482,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:18.632,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:18.782,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:18.932,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:19.082,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:19.232,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 1
    00> [01:36:19.382,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:19.532,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:19.682,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:19.832,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:19.982,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:20.158,752] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:20.282,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:20.432,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:20.582,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:20.732,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:20.882,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:21.032,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:21.182,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:21.332,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:21.525,268] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:21.632,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:21.782,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:21.932,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:22.082,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:22.232,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:22.382,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:22.532,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:22.682,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:22.832,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:22.982,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:23.132,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:23.282,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:23.482,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:23.678,741] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:23.782,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:23.932,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:24.082,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:24.258,758] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:24.382,202] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:24.532,226] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:24.682,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:24.832,214] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:24.982,208] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:25.221,801] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:25.302,001] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:36:25.327,117] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:36:25.365,844] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> .[01:36:25.570,800] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:36:25.570,892] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:36:25.666,259] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:36:25.766,326] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:36:25.766,967] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:36:25.766,998] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:36:25.867,065] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:36:35.333,953] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:36:35.438,934] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:36:35.543,243] <inf> BLE: exchange_func: MTU exchange done
    00> [01:36:36.242,767] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:36:36.242,797] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:36:36.242,828] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:36:36.242,858] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:36:36.242,919] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:36:36.243,072] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:36:36.252,075] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:36:36.352,172] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:36:37.200,744] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:36:37.200,805] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:36:37.200,836] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:36:37.359,771] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:37.502,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:37.652,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:37.802,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:37.952,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:38.102,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:38.270,172] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:38.402,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:38.552,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:38.706,298] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:38.852,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:39.052,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:39.202,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:39.392,425] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:39.502,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:39.652,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:39.806,304] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:39.952,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:40.102,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:40.252,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:40.402,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:40.575,897] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:40.749,359] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:40.852,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:36:41.223,632] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:41.442,413] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:41.552,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:41.702,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:41.852,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:42.002,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:42.152,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:42.302,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:42.502,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:42.652,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:42.802,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:43.023,651] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:43.152,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:43.302,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:43.499,359] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:43.602,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:43.752,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:43.859,771] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:44.006,286] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:44.152,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:44.349,365] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:44.452,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:44.620,178] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:44.752,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:44.902,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:45.095,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:45.202,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:45.395,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:45.502,807] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:45.695,892] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:45.802,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:45.952,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:46.102,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:36:46.292,419] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:46.402,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:46.552,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:46.702,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:46.882,812] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:47.002,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:47.152,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:47.302,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:47.559,753] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:47.702,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:47.852,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:48.006,286] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:48.152,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:48.302,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:48.452,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:48.623,626] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:48.752,807] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:48.902,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:49.052,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:49.206,298] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:49.352,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:49.502,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:49.702,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:49.852,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:50.002,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:50.220,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:50.352,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:50.532,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:36:50.652,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:50.802,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:50.952,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:51.102,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:51.252,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:51.429,351] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:51.552,825] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:51.752,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:51.902,832] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:52.095,886] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:52.202,819] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:52.352,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:52.502,838] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:36:52.622,619] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:36:52.647,735] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:36:52.647,979] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:36:52.891,418] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:36:52.891,510] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:36:52.948,364] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:36:53.048,431] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:36:53.049,072] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:36:53.049,102] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:36:53.149,169] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:37:22.996,459] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:37:23.101,470] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:37:23.205,780] <inf> BLE: exchange_func: MTU exchange done
    00> [01:37:23.905,303] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:37:23.905,334] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:37:23.905,364] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:37:23.905,395] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:37:23.905,487] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:37:23.905,609] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:37:23.914,611] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:37:24.014,709] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:37:24.863,281] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:37:24.863,342] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:37:24.863,372] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:37:25.022,308] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:25.165,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:25.315,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:25.465,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:25.615,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:25.765,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:25.915,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:26.065,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:26.215,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:26.365,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:26.515,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:26.665,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:26.815,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:26.965,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:37:27.115,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:27.265,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:27.415,344] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:27.565,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:27.748,931] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:27.865,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:28.065,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:28.215,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:28.365,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:28.515,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:37:28.804,962] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:28.915,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:29.018,829] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:29.165,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:29.315,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:29.465,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:29.615,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:29.765,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:29.915,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:30.065,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:30.215,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:30.365,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:30.515,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:30.665,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:30.815,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:30.965,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:31.115,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:31.265,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:31.415,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:31.565,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:31.715,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:31.865,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:32.015,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:32.165,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:32.315,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:32.515,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:32.665,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:32.815,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:32.965,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:33.115,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:33.295,349] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:33.415,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:33.565,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:33.715,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:33.865,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:34.015,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:34.165,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:34.315,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:34.465,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:34.615,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:34.765,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:34.915,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:35.065,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:35.248,931] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:35.365,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:35.515,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:35.665,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:35.832,702] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:35.965,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:36.145,355] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:36.358,428] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:36.465,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:36.615,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:36.815,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:36.965,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:37.115,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:37.265,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:37:37.415,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:37.565,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:37.715,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:37.865,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:38.015,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:38.165,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:38.315,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:38.465,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:38.615,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:38.765,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:38.915,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:39.065,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:39.215,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:39.365,356] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:39.548,919] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:39.665,374] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:39.815,368] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:39.958,618] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:37:39.983,612] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:37:40.012,725] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:37:40.253,936] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:37:40.254,058] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:37:40.313,110] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:37:40.413,177] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:37:40.413,818] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:37:40.413,848] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:37:40.513,916] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:37:40.915,283] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:37:41.029,724] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:37:41.134,033] <inf> BLE: exchange_func: MTU exchange done
    00> [01:37:41.833,557] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:37:41.833,587] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:37:41.833,618] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:37:41.833,648] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:37:41.833,709] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:37:41.833,831] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:37:41.842,864] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:37:41.942,962] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:37:42.841,522] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:37:42.841,613] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:37:42.841,613] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:37:43.033,203] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:43.143,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:43.293,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:43.443,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:43.593,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:43.743,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:43.893,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:44.043,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:44.197,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:44.354,003] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:44.493,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:44.690,155] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:44.793,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:44.943,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:45.093,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:45.243,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:45.393,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:45.583,221] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:45.693,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:45.843,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:45.993,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:46.143,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:46.293,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:46.443,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:37:46.693,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:46.843,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:46.993,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:47.143,646] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:47.293,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:47.443,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:47.593,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:47.747,070] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:47.893,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:48.090,148] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:48.193,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:48.343,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:48.493,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:48.643,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:37:48.793,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:48.943,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:49.093,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:49.243,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:49.393,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:49.543,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:49.693,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:49.847,076] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:49.993,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:50.143,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:50.293,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:50.493,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 0
    00> [01:37:50.690,155] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:50.793,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:50.990,142] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:51.097,076] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:51.243,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:51.393,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:51.543,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:51.720,153] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:51.843,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:51.993,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:52.143,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:52.293,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:52.443,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:52.593,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:52.743,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:52.893,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:53.043,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:53.193,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:53.343,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:53.493,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:53.643,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:53.793,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:53.964,416] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:54.093,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:54.257,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:54.393,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:54.543,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:54.693,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:54.893,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:55.090,148] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:55.193,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:55.343,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:55.493,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:55.643,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:55.793,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:55.943,603] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:56.093,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:56.243,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:56.393,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:56.543,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:56.697,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:56.843,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:57.043,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:57.240,142] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:57.343,597] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:57.493,621] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:57.643,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:57.793,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:37:57.913,391] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:37:57.938,629] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:37:57.988,372] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:37:58.282,196] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:37:58.282,287] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:37:58.288,757] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:37:58.388,824] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:37:58.389,465] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:37:58.389,495] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:37:58.489,562] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:38:08.132,934] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:38:08.246,063] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:38:08.350,372] <inf> BLE: exchange_func: MTU exchange done
    00> [01:38:09.049,896] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:38:09.049,926] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:38:09.049,957] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:38:09.049,987] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:38:09.050,048] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:38:09.050,170] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:38:09.059,204] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:38:09.159,301] <inf> MAIN: ble_connected_state: START FLAG sent
    00> .[01:38:10.007,873] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:38:10.007,934] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:38:10.007,965] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:38:10.166,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:10.352,996] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:10.559,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:10.709,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:10.859,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:11.009,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:11.159,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:11.309,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:11.459,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:11.609,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:11.759,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:11.909,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:12.059,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:12.209,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:12.359,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:12.509,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:12.659,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:12.809,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:12.959,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:13.109,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:13.306,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:13.409,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:13.559,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:38:13.809,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:13.959,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:14.109,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:14.259,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:14.409,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:14.559,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:14.709,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:14.859,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:15.009,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:15.159,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:15.309,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:15.489,959] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:15.609,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:15.759,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:15.909,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:16.077,301] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:16.209,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:16.359,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:16.509,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:16.659,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:16.809,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:17.006,469] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:17.149,536] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:17.299,530] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:17.443,511] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:17.559,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:17.709,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:17.909,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:18.059,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:18.216,888] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:18.359,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:18.520,355] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:18.659,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:18.809,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:18.959,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:19.149,536] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:19.306,488] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:38:19.409,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:19.559,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:38:19.709,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:19.859,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:20.059,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:20.239,959] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:20.373,809] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:20.509,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:20.659,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:20.809,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:21.009,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:21.159,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:21.309,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:21.477,294] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:21.609,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:21.759,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:21.966,888] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:22.133,026] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:22.259,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:22.409,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:22.573,822] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:22.709,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:22.859,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:23.009,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:23.209,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:23.406,494] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:23.509,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:23.683,013] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:23.809,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:23.986,480] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:24.109,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:24.259,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:24.409,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:24.559,936] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:24.709,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:24.859,954] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:25.009,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:25.113,403] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:25.229,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:38:25.254,852] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:38:25.257,568] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:38:25.498,535] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:38:25.498,626] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:38:25.557,952] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:38:25.658,020] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:38:25.658,660] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:38:25.658,691] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:38:25.758,758] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 0
    00> [01:38:55.497,253] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:38:55.609,008] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:38:55.713,317] <inf> BLE: exchange_func: MTU exchange done
    00> [01:38:56.412,872] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:38:56.412,902] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:38:56.412,933] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:38:56.412,963] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:38:56.413,024] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:38:56.413,146] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:38:56.422,180] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:38:56.522,277] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:38:57.370,849] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:38:57.370,910] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:38:57.370,910] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:38:57.529,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:57.672,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:57.822,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:58.015,991] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:58.122,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:58.272,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:58.422,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:58.572,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:58.722,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:58.893,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:59.022,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:59.172,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:59.322,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:59.472,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:59.622,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:59.772,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:38:59.922,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:00.115,966] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:00.222,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:00.386,779] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:39:00.543,731] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:00.672,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:00.822,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:00.972,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:01.222,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:01.372,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:01.529,846] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:01.672,943] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:01.822,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:01.926,391] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:02.122,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:02.272,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:02.422,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:02.572,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:02.722,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:02.893,737] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:03.022,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:03.193,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:03.322,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:03.483,306] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:03.626,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:03.772,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:03.922,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:04.072,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:04.222,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:04.372,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:04.572,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:04.756,469] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:04.872,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:05.086,791] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:05.222,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:05.376,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:05.522,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:05.672,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:05.872,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:06.062,500] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:06.172,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:06.372,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:06.568,023] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:06.712,493] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:06.822,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:06.972,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:07.143,737] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:07.329,864] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:07.502,899] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:07.622,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:07.776,367] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:07.922,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:08.072,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:08.222,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:08.372,924] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:08.522,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:08.672,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:08.822,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:08.972,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:09.126,373] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:09.272,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:09.443,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:09.576,385] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:09.722,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:09.883,331] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:10.022,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:10.179,840] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:10.322,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:10.522,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:10.672,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:10.822,906] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:39:10.972,900] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:11.149,444] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:11.299,438] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:11.422,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:11.615,966] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:11.765,960] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:11.886,779] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:12.022,918] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:12.172,912] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:12.326,385] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:12.476,379] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:12.642,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:39:12.667,846] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:39:12.670,684] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:39:12.961,486] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:39:12.961,608] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:39:12.971,069] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:39:13.071,136] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:39:13.071,777] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:39:13.071,807] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:39:13.171,875] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:39:13.527,679] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:39:13.640,075] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:39:13.744,384] <inf> BLE: exchange_func: MTU exchange done
    00> [01:39:14.443,908] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:39:14.443,939] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:39:14.443,969] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:39:14.444,000] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:39:14.444,061] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:39:14.444,183] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:39:14.453,216] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:39:14.553,314] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:39:15.401,885] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:39:15.401,947] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:39:15.401,977] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:39:15.560,882] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:15.703,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:15.853,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:16.003,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:16.153,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:16.303,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:16.453,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:16.633,941] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:16.753,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:16.903,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:17.053,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:17.203,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:17.353,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:17.503,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:17.653,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:17.807,434] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:18.003,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:18.153,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:18.303,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:18.453,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:18.603,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:18.753,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:18.903,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:19.053,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:39:19.303,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 1
    00> [01:39:19.453,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:19.603,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:19.757,415] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:19.903,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:20.053,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:20.203,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:20.403,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:20.553,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:20.743,560] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:20.853,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:21.003,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:21.153,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:21.303,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:21.453,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:21.603,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:21.753,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:21.903,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:22.053,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:22.203,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:39:22.353,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:22.503,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:22.653,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:22.803,985] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:22.953,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:23.103,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:23.207,427] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:23.353,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:23.503,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:23.653,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:23.833,953] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:23.953,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:24.103,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:24.253,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:24.403,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:24.577,026] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:24.703,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:24.853,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:25.003,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:25.153,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:25.303,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:25.453,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:25.603,942] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:25.753,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:25.903,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:26.150,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:26.297,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:26.403,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:26.583,953] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:26.703,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:26.853,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:27.003,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:27.153,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:27.303,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:27.480,499] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:27.603,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:27.771,301] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:27.903,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:28.053,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:28.203,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:28.353,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:28.503,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:28.653,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:28.853,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:29.047,027] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:29.153,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:29.303,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:29.453,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:29.603,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:29.753,967] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:29.903,961] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:30.053,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:30.203,948] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:30.353,973] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:30.473,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:39:30.498,870] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:39:30.499,145] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:39:30.792,541] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:39:30.792,633] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:39:30.799,530] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:39:30.899,597] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:39:30.900,238] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:39:30.900,268] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:39:31.000,335] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:39:40.832,550] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:39:41.043,945] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:39:41.148,254] <inf> BLE: exchange_func: MTU exchange done
    00> [01:39:41.897,796] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:39:41.897,827] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:39:41.897,857] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:39:41.897,888] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:39:41.897,949] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:39:41.898,071] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:39:41.907,104] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:39:42.007,202] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:39:42.905,761] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:39:42.905,822] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:39:42.905,853] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:39:43.064,758] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:43.207,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:43.357,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:39:43.534,362] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:43.657,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:43.807,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:43.957,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:44.107,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:44.257,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:44.457,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:44.607,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:44.757,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:44.907,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:45.057,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:45.207,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:45.357,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:45.507,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:45.711,303] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:45.868,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:46.007,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:46.207,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:46.371,704] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:46.507,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:39:46.757,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:46.907,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:47.057,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:47.207,855] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:47.391,387] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:47.507,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:47.657,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:47.857,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:48.007,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:48.157,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:48.350,891] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:48.491,394] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:48.607,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:48.757,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:48.907,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:49.057,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:49.207,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:49.357,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:49.461,303] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:49.607,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:49.757,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:49.907,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:50.057,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:50.207,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:50.404,357] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:50.550,903] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:39:50.697,418] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CEREG: 1,"C3C7","0DBD1516",7,
    00> [01:39:50.807,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:50.961,303] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:51.107,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:51.287,841] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:51.421,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:51.557,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:51.707,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:51.857,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:52.057,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:52.207,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:52.357,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:52.528,656] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:52.657,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:52.807,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:52.961,303] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:53.107,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:53.257,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:53.407,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:53.557,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:53.707,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:39:53.857,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:54.007,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:54.157,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:54.307,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:54.457,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:54.650,909] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:54.757,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:54.975,158] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:55.107,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:55.257,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:55.407,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:55.561,309] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:55.707,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:55.857,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:56.007,843] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:56.157,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:56.307,830] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:56.504,364] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:56.607,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:56.800,903] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:56.907,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:57.014,770] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:57.157,836] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:57.318,237] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:57.457,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:57.671,691] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:57.850,891] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:57.971,710] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:39:58.077,606] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:39:58.102,844] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:39:58.116,333] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:39:58.396,423] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:39:58.396,514] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:39:58.416,717] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:39:58.516,784] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:39:58.517,425] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:39:58.517,456] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:39:58.617,523] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> Received:
    00> +CEREG: 1,"C3C7","0DC27C15",7,
    00> [01:40:28.306,671] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:40:28.415,863] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:40:28.520,172] <inf> BLE: exchange_func: MTU exchange done
    00> [01:40:29.269,714] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:40:29.269,744] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:40:29.269,744] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:40:29.269,805] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:40:29.269,866] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:40:29.269,989] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:40:29.279,022] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:40:29.379,119] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:40:30.227,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:40:30.227,752] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:40:30.227,752] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:40:30.386,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:30.529,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:30.679,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:30.829,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:30.979,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:31.150,573] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:31.279,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:31.476,287] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:31.579,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:31.729,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:31.879,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:32.076,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:32.179,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:32.329,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:32.519,348] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:32.676,269] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:32.793,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:32.929,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:33.129,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:33.329,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:33.479,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:33.629,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:33.779,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:40:34.029,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:34.179,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:34.329,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:34.479,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:34.629,791] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:40:34.779,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:34.929,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:35.079,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:35.252,807] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:35.379,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:35.529,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:35.693,634] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:35.829,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:35.979,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:36.129,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:36.279,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:36.429,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:36.579,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:36.729,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:36.879,730] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:37.029,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:37.179,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:37.329,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:37.479,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:37.629,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:37.826,293] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:37.929,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:38.119,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:38.229,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:38.379,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:38.529,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:38.679,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:38.852,813] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:38.979,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:39.143,615] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:39.279,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:39.479,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:39.629,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:39.829,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:40.026,275] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:40.129,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:40.279,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:40.429,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:40.579,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:40.729,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:40.902,801] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:41.029,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:41.179,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:41.329,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:41.479,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:41.629,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:41.829,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:42.029,785] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:42.179,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:42.369,354] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:42.479,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:42.659,759] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:42.779,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:42.929,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:43.079,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:43.229,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:43.402,801] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:43.529,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:43.729,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:43.972,808] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:44.079,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:44.229,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:44.379,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:44.529,754] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:44.683,227] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:44.829,742] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:44.979,736] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:40:45.129,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:45.293,609] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:45.429,748] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:45.549,530] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:40:45.574,768] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:40:45.575,012] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:40:45.868,316] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:40:45.868,438] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:40:45.875,396] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:40:45.975,463] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:40:45.976,104] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:40:45.976,135] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:40:46.051,757] <inf> BLE: scan_filter_match: Filters matched. Address: E7:EA:8B:10:13:35 (random) connectable: 1
    00> [01:40:46.076,232] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:40:46.166,351] <inf> BLE: connected: Connected: E7:EA:8B:10:13:35 (random)
    00> [01:40:46.270,690] <inf> BLE: exchange_func: MTU exchange done
    00> [01:40:46.970,214] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:40:46.970,245] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:40:46.970,275] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:40:46.970,306] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:40:46.970,367] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:40:46.970,489] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:40:46.979,553] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:40:47.079,620] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:40:47.928,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:40:47.928,253] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:40:47.928,283] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:40:48.087,188] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:48.230,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:48.433,746] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:48.626,800] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:48.730,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:48.880,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:49.030,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:49.180,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:49.330,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:49.519,866] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:49.630,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:49.780,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:49.930,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:50.080,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:50.230,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:50.380,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:50.663,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:50.780,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:50.973,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:51.080,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:51.256,805] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:51.380,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:40:51.630,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:51.780,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:51.973,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:52.080,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:52.230,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:52.380,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:52.530,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:52.753,326] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:52.930,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:53.080,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:53.230,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:53.380,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:53.530,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:53.680,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:53.830,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:53.990,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:54.130,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:54.280,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:54.473,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:54.697,601] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:54.847,595] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:54.980,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:55.169,860] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:55.369,873] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:55.483,734] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:55.630,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:55.780,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:55.930,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:56.080,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:56.230,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .Received:
    00> +CSCON: 0
    00> [01:40:56.383,728] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:56.530,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:56.723,327] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:56.830,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:56.980,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:57.130,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:57.306,793] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:57.433,715] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:57.580,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:57.763,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:57.880,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:58.030,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:58.180,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:58.330,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:58.490,661] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:58.683,746] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:58.830,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:59.026,794] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:59.130,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:59.280,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:59.430,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:59.580,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:59.730,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:40:59.880,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:00.030,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:00.180,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:00.344,146] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:00.519,866] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:00.669,860] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:00.830,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:00.980,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:01.130,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:01.280,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:01.469,848] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:01.603,332] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:01.730,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:01.880,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:02.047,607] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:02.180,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:02.330,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:02.480,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:02.630,249] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:02.780,273] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:02.930,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:03.080,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:03.230,255] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:03.350,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:41:03.375,183] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:41:03.425,323] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:41:03.718,841] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:41:03.718,933] <inf> BLE: disconnected: Disconnected: E7:EA:8B:10:13:35 (random) (reason 19)
    00> [01:41:03.725,708] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:41:03.825,775] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:41:03.826,416] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:41:03.826,446] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:41:03.926,513] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:41:04.208,435] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:41:04.314,636] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:41:04.418,945] <inf> BLE: exchange_func: MTU exchange done
    00> [01:41:05.168,487] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:41:05.168,518] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:41:05.168,548] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:41:05.168,579] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:41:05.168,640] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:41:05.168,762] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:41:05.177,795] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:41:05.277,893] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:41:06.126,434] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:41:06.126,525] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:41:06.126,525] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:41:06.318,115] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:06.428,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:06.578,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:06.728,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:06.881,988] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:07.028,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:07.178,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:07.328,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:07.478,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:07.628,540] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:07.778,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:41:07.885,467] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:08.028,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:08.178,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:08.328,552] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:08.478,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:08.645,874] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:08.778,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:08.932,006] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:09.078,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:09.228,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:09.428,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:09.578,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:09.728,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:41:09.978,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:10.171,600] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:10.278,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:10.428,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:10.578,552] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:10.728,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:10.878,540] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:11.028,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:11.178,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:11.328,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:11.478,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:11.628,540] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:11.778,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:11.968,109] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:12.078,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:12.212,097] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:12.328,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:12.478,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:12.628,540] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:12.821,594] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:12.928,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:13.078,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:13.228,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:13.428,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:13.628,540] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:13.778,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:13.928,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:14.078,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:14.228,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:14.408,538] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:14.528,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:14.678,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:14.828,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:14.978,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:15.128,540] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:15.278,533] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:15.428,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:15.578,521] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:15.728,515] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:15.878,540] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:16.071,594] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:16.178,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:16.375,061] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:16.549,346] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:16.678,527] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:41:17.217,681] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:41:17.217,803] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 8)
    00> .Received:
    00> +CSCON: 1
    00> ...Received:
    00> +CSCON: 0
    00> Received:
    00> .[01:42:05.456,024] <inf> MAIN: ble_connected_state: Connection state timeout
    00> [01:42:05.456,054] <inf> PROTO: log_protocol_infos: Num: 70 - Extra: 0 - Off: 33603
    00> [01:42:05.456,054] <inf> PROTO: log_protocol_infos: data: 00 00 00 00
    00> [01:42:05.456,085] <inf> BLE: bluetooth_disconnect_ble_nus: No active connection to disconnect
    00> [01:42:05.456,115] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:42:05.556,182] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:42:05.556,823] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:42:05.556,854] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:42:05.638,122] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:42:05.656,921] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:42:05.743,591] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:42:05.847,900] <inf> BLE: exchange_func: MTU exchange done
    00> [01:42:06.547,424] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:42:06.547,454] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:42:06.547,485] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:42:06.547,515] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:42:06.547,607] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:42:06.547,729] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:42:06.556,762] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:42:06.656,829] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:42:07.505,401] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:42:07.505,493] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:42:07.505,493] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:42:07.664,428] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:07.807,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:07.957,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:08.107,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:08.257,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:08.407,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:08.600,555] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:08.707,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:08.857,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:09.007,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:42:09.157,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:09.307,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:09.467,895] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:09.607,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:09.757,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:09.907,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:10.057,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:10.207,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:10.314,422] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:10.457,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:10.647,064] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:10.757,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:10.907,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:11.057,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:42:11.321,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:11.457,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:11.607,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:11.757,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:11.907,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:12.057,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:12.207,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:12.387,481] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:12.547,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:12.687,469] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:12.807,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:12.957,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:13.107,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:13.307,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:13.457,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:13.607,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:13.767,883] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:13.907,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:14.057,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:14.207,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:14.357,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:14.554,016] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:14.657,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:14.847,076] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:14.957,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:15.107,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:15.260,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:15.428,283] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:15.557,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:15.721,343] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:15.857,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:16.007,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:16.157,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:16.407,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:16.557,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:16.707,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:16.897,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:17.007,507] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:17.157,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:17.307,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:17.457,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:17.697,082] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:17.817,901] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:17.957,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:18.107,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:18.257,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:18.407,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:18.604,003] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:18.734,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:18.857,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:19.010,955] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:19.157,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:42:19.307,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:42:19.457,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:19.607,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:19.757,476] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:19.907,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:20.057,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:20.207,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:20.357,482] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:20.557,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:20.707,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:20.904,022] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:21.047,088] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:21.160,949] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:21.307,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:21.484,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:21.647,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:21.778,289] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:21.907,470] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:22.071,350] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:22.207,489] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:22.414,428] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:22.557,495] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:22.677,276] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:42:22.702,484] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:42:22.702,728] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:42:22.946,075] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:42:22.946,166] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:42:23.003,112] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:42:23.103,179] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:42:23.103,820] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:42:23.103,851] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:42:23.122,711] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:42:23.203,918] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:42:23.232,330] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:42:23.336,639] <inf> BLE: exchange_func: MTU exchange done
    00> [01:42:24.036,163] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:42:24.036,193] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:42:24.036,224] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:42:24.036,254] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:42:24.036,315] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:42:24.036,437] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:42:24.045,501] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:42:24.145,599] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:42:24.994,140] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:42:24.994,201] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:42:24.994,232] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:42:25.153,137] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:25.335,815] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:25.446,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:25.596,221] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:25.763,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:25.896,209] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:26.056,610] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:26.196,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:26.349,670] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:26.496,215] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:26.646,209] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:26.796,203] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:26.946,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:27.135,803] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:27.246,215] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:27.517,028] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:27.646,209] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:27.796,203] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:27.946,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:28.106,628] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:28.263,549] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:28.396,209] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:28.546,203] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:42:28.876,220] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:28.996,215] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:29.185,821] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:29.296,203] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:29.446,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:29.692,749] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:29.796,203] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:29.963,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:30.139,282] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:30.246,215] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:30.396,209] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:42:30.546,203] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:30.696,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:30.946,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:31.139,282] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:31.253,143] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:31.396,240] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:31.546,203] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:31.696,228] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:42:32.235,382] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:42:32.235,473] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 8)
    00> ..Received:
    00> +CSCON: 0
    00> Received:
    00> ..Received:
    00> +CSCON: 1
    00> .[01:43:24.376,312] <inf> MAIN: ble_connected_state: Connection state timeout
    00> [01:43:24.376,342] <inf> PROTO: log_protocol_infos: Num: 43 - Extra: 0 - Off: 20454
    00> [01:43:24.376,342] <inf> PROTO: log_protocol_infos: data: 00 00 00 00
    00> [01:43:24.376,373] <inf> BLE: bluetooth_disconnect_ble_nus: No active connection to disconnect
    00> [01:43:24.376,403] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:43:24.476,470] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:43:24.477,111] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:43:24.477,142] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:43:24.577,209] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:43:24.627,105] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:43:24.735,504] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:43:24.839,813] <inf> BLE: exchange_func: MTU exchange done
    00> [01:43:28.988,525] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:43:28.988,555] <err> nus_c: bt_nus_handles_assign: Missing NUS TX characteristic.
    00> [01:43:28.988,555] <err> nus_c: bt_nus_subscribe_receive: Subscribe failed (err -128)
    00> [01:43:28.988,708] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 8)
    00> [01:43:28.988,769] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:43:28.997,802] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:43:29.097,869] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:43:29.097,869] <err> BLE: bluetooth_central_send_data: Cannot send data, no BLE connection
    00> ..Received:
    00> +CSCON: 0
    00> ...Received:
    00> +CSCON: 1
    00> .[01:44:29.038,299] <inf> MAIN: ble_connected_state: Connection state timeout
    00> [01:44:29.038,330] <inf> PROTO: log_protocol_infos: Num: 0 - Extra: 0 - Off: 0
    00> [01:44:29.038,330] <inf> PROTO: log_protocol_infos: data: 00 00 00 00
    00> [01:44:29.038,360] <inf> BLE: bluetooth_disconnect_ble_nus: No active connection to disconnect
    00> [01:44:29.038,391] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:44:29.138,458] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:44:29.139,099] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:44:29.139,129] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:44:29.239,196] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:44:29.286,468] <inf> BLE: scan_filter_match: Filters matched. Address: E7:EA:8B:10:13:35 (random) connectable: 1
    00> [01:44:29.396,484] <inf> BLE: connected: Connected: E7:EA:8B:10:13:35 (random)
    00> [01:44:29.500,793] <inf> BLE: exchange_func: MTU exchange done
    00> [01:44:33.649,505] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:44:33.649,505] <err> nus_c: bt_nus_handles_assign: Missing NUS TX characteristic.
    00> [01:44:33.649,536] <err> nus_c: bt_nus_subscribe_receive: Subscribe failed (err -128)
    00> [01:44:33.649,688] <inf> BLE: disconnected: Disconnected: E7:EA:8B:10:13:35 (random) (reason 8)
    00> [01:44:33.649,719] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:44:33.658,752] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:44:33.758,819] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:44:33.758,819] <err> BLE: bluetooth_central_send_data: Cannot send data, no BLE connection
    00> ..Received:
    00> +CSCON: 0
    00> ..Received:
    00> +CSCON: 1
    00> ..[01:45:33.699,218] <inf> MAIN: ble_connected_state: Connection state timeout
    00> [01:45:33.699,249] <inf> PROTO: log_protocol_infos: Num: 0 - Extra: 0 - Off: 0
    00> [01:45:33.699,249] <inf> PROTO: log_protocol_infos: data: 00 00 00 00
    00> [01:45:33.699,279] <inf> BLE: bluetooth_disconnect_ble_nus: No active connection to disconnect
    00> [01:45:33.699,310] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:45:33.799,377] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:45:33.800,018] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:45:33.800,048] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:45:33.868,194] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:45:33.900,115] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:45:33.973,327] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:45:34.077,636] <inf> BLE: exchange_func: MTU exchange done
    00> [01:45:34.927,185] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:45:34.927,215] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:45:34.927,215] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:45:34.927,276] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:45:34.927,337] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:45:34.927,459] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:45:34.936,492] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:45:35.036,560] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:45:35.885,131] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:45:35.885,223] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:45:35.885,223] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:45:36.063,751] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:36.208,038] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:36.337,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:36.487,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:36.637,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:36.787,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:36.987,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:37.183,746] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:37.287,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:37.437,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:37.587,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:37.737,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:37.913,757] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:38.037,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:38.187,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:38.337,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:38.487,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:38.640,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:38.787,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:38.937,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:39.108,032] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:39.240,692] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:39.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:45:39.663,757] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:39.787,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:39.937,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:40.087,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:40.276,824] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:40.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:40.537,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:45:40.737,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:40.937,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:41.087,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:41.237,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:41.433,746] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:41.537,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:41.726,806] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:41.837,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:41.987,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:42.180,267] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:42.287,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:42.437,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:42.587,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:42.737,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:42.937,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:43.044,158] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:43.237,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:43.426,818] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:43.537,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:43.687,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:43.876,800] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:43.987,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:44.090,698] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:44.258,026] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:44.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:44.537,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:44.687,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:44.837,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:44.987,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:45.137,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:45.287,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:45.444,152] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:45.587,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:45.737,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:45.887,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:46.037,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:46.187,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:46.337,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:46.487,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:46.637,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:46.787,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:46.987,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:47.140,686] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:47.380,279] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:47.487,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:47.637,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:47.787,261] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:47.937,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:48.087,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:48.237,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:48.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:48.537,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:48.687,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:48.837,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:48.987,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:49.137,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:49.333,740] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:49.437,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:49.587,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:49.737,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:49.937,225] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:50.087,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:50.237,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:50.387,207] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:50.537,231] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:50.694,152] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:45:50.837,219] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:45:50.987,213] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:51.106,994] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:45:51.132,141] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:45:51.184,051] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:45:51.726,348] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:45:51.726,470] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 8)
    00> [01:45:51.784,637] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:45:51.884,704] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:45:51.885,345] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:45:51.885,375] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:45:51.893,218] <inf> BLE: scan_filter_match: Filters matched. Address: E7:EA:8B:10:13:35 (random) connectable: 1
    00> [01:45:51.985,443] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:45:51.998,809] <inf> BLE: connected: Connected: E7:EA:8B:10:13:35 (random)
    00> [01:45:52.103,118] <inf> BLE: exchange_func: MTU exchange done
    00> [01:45:52.852,661] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:45:52.852,691] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:45:52.852,722] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:45:52.852,752] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:45:52.852,813] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:45:52.852,935] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:45:52.861,968] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:45:52.962,066] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:45:53.810,638] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:45:53.810,699] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:45:53.810,729] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:45:53.969,635] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:54.112,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:54.319,641] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:54.473,114] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:54.612,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:54.762,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:54.912,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:55.083,526] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:55.255,767] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:55.362,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:55.512,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:55.662,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:55.812,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:55.962,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:56.112,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:56.262,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:56.412,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:56.562,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:56.712,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:56.862,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:57.062,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:57.212,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:45:57.462,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:57.612,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:57.762,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:57.912,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:58.083,526] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:58.212,738] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:58.362,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:58.516,174] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:58.662,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:58.812,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:58.962,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:59.112,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:59.309,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:59.412,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:59.562,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:59.735,778] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:45:59.862,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:00.012,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:00.162,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:00.333,526] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:00.462,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:00.612,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:00.762,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:00.912,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:01.062,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:01.212,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:01.362,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:01.512,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:01.705,780] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:01.859,252] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:46:01.962,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:02.112,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:02.262,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:02.412,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:02.562,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:02.712,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:02.862,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:03.012,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:03.166,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:03.312,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:03.509,246] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:03.612,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:03.805,786] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:03.912,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:04.062,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:04.212,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:04.362,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:04.512,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:04.662,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:04.812,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:04.962,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:05.112,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:05.262,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:05.496,276] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:05.612,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:05.762,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:05.955,780] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:06.062,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:06.212,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:06.316,192] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:06.462,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:06.612,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:06.762,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:06.912,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:07.062,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:07.233,520] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:07.362,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:07.512,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:07.662,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:07.883,514] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:08.012,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:08.162,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:08.335,784] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:08.485,778] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:08.612,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:08.762,725] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:08.882,507] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:46:08.907,623] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:46:08.907,867] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:46:09.251,281] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:46:09.251,403] <inf> BLE: disconnected: Disconnected: E7:EA:8B:10:13:35 (random) (reason 19)
    00> [01:46:09.308,319] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:46:09.408,386] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:46:09.409,027] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:46:09.409,057] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:46:09.509,124] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> Received:
    00> +CSCON: 1
    00> [01:46:43.688,690] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:46:43.802,337] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:46:43.906,646] <inf> BLE: exchange_func: MTU exchange done
    00> [01:46:44.706,176] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:46:44.706,207] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:46:44.706,237] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:46:44.706,268] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:46:44.706,329] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:46:44.706,481] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:46:44.715,484] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:46:44.815,582] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:46:45.664,154] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:46:45.664,215] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:46:45.664,245] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:46:45.823,150] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:45.966,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:46.116,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:46.266,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:46.416,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:46.566,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:46.716,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:46.866,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:47.016,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:47.166,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:47.316,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:46:47.492,767] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:47.623,168] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:47.766,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:47.916,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:48.066,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:48.262,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:48.366,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:48.516,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:48.666,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:48.816,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:48.966,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:49.116,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:46:49.380,096] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:49.516,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:49.666,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:49.816,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:49.969,696] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:50.116,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:50.266,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:50.416,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:50.587,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:50.766,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 0
    00> [01:46:50.916,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:51.066,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:51.216,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:51.366,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:51.516,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:51.666,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:51.816,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:51.969,696] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:52.116,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:52.266,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:52.416,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:52.566,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:52.755,828] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:52.866,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:53.037,048] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:53.166,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:53.273,162] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:53.416,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:53.592,773] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:53.716,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:53.866,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:54.016,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:54.166,259] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:54.316,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:54.466,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:54.616,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:54.766,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:54.955,810] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:55.066,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:55.216,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:55.366,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:55.537,048] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:55.666,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:55.816,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:55.966,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:56.116,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:56.266,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:56.416,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:56.566,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:56.716,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:56.909,301] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:57.016,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:57.166,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:57.362,762] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:57.466,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:57.616,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:46:57.766,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:57.916,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:58.109,283] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:58.216,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:58.366,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:58.516,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:58.666,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:58.816,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:59.012,756] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:59.159,301] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:59.266,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:59.369,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:59.516,265] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:59.666,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:59.837,036] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:46:59.966,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:00.116,241] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:00.266,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:00.419,708] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:00.536,010] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 279
    00> [01:47:00.561,157] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:47:00.614,746] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:47:00.854,797] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:47:00.854,919] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:47:00.915,130] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:47:01.015,197] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:47:01.015,838] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:47:01.015,869] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:47:01.115,936] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:47:06.683,990] <inf> BLE: scan_filter_match: Filters matched. Address: C8:71:CB:20:81:0A (random) connectable: 1
    00> [01:47:06.790,222] <inf> BLE: connected: Connected: C8:71:CB:20:81:0A (random)
    00> [01:47:06.894,531] <inf> BLE: exchange_func: MTU exchange done
    00> [01:47:07.594,055] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:47:07.594,085] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:47:07.594,116] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:47:07.594,146] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:47:07.594,207] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:47:07.594,329] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:47:07.603,363] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:47:07.703,460] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:47:08.552,032] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:47:08.552,093] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:47:08.552,124] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:47:08.711,029] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:08.854,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:09.050,628] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:09.154,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:09.304,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:09.454,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:09.650,634] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:09.780,639] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:09.904,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:10.074,920] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:10.204,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:10.364,501] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:10.504,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:10.661,041] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:10.804,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:10.954,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:11.104,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:11.254,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:11.404,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:11.561,035] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:11.704,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:11.854,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:12.004,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:12.154,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:12.404,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:12.593,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:12.754,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:12.861,053] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:13.054,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:13.250,640] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:13.354,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:13.504,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:13.654,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:13.804,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:13.954,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:14.104,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:14.254,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:47:14.404,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:14.554,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:14.704,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:14.854,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:15.004,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:15.154,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:15.304,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:15.454,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:15.693,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:15.804,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:15.954,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:16.130,645] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:16.254,089] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:16.404,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:16.554,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:16.704,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:16.950,653] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:17.054,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:17.204,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:17.354,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:17.504,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:17.654,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:17.804,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:17.907,562] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:18.080,627] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:18.293,701] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:18.404,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:18.554,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:18.704,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:18.854,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:19.057,586] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:19.204,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:19.354,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:19.504,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 1
    00> [01:47:19.654,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:19.804,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:20.000,640] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:20.134,094] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:20.254,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:20.454,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:20.604,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:20.777,160] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:20.904,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:21.054,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:21.204,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:21.354,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:21.504,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:21.693,695] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:21.804,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:21.993,713] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:22.104,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:22.254,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:22.404,113] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:22.554,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:22.704,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:22.854,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:23.004,119] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:23.184,112] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:23.304,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:23.454,101] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:23.604,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:23.723,876] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:47:23.749,023] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:47:23.750,305] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:47:24.042,694] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:47:24.042,785] <inf> BLE: disconnected: Disconnected: C8:71:CB:20:81:0A (random) (reason 19)
    00> [01:47:24.050,689] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:47:24.150,756] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:47:24.151,397] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:47:24.151,428] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:47:24.166,168] <inf> BLE: scan_filter_match: Filters matched. Address: E1:35:E1:4C:E8:10 (random) connectable: 1
    00> [01:47:24.251,525] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:47:24.277,313] <inf> BLE: connected: Connected: E1:35:E1:4C:E8:10 (random)
    00> [01:47:24.381,622] <inf> BLE: exchange_func: MTU exchange done
    00> [01:47:25.081,176] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:47:25.081,207] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:47:25.081,237] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:47:25.081,268] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:47:25.081,329] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:47:25.081,451] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:47:25.090,484] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:47:25.190,582] <inf> MAIN: ble_connected_state: START FLAG sent
    00> .[01:47:26.039,154] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 72
    00> [01:47:26.039,215] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:47:26.039,215] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:47:26.244,689] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:26.391,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:26.541,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:26.691,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:26.848,144] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:26.991,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:27.141,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:27.291,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:27.441,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:27.591,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:27.741,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:27.891,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:28.041,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:28.191,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:28.341,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:28.491,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:28.641,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:28.801,635] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:28.941,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:29.091,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:29.241,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:29.391,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:29.541,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:29.691,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:47:29.941,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:30.091,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:30.241,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:30.391,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:30.562,011] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:30.691,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:30.841,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:30.991,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:31.141,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:31.291,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:31.530,822] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:31.648,162] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:31.791,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:31.941,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:32.091,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:32.241,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:32.344,696] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:32.517,761] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:32.641,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:32.791,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:32.941,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:33.091,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:33.287,750] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:33.391,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:33.541,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:33.691,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:33.841,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:33.991,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:34.141,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:34.291,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:34.471,221] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:34.591,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:34.741,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:34.891,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:35.041,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:35.191,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:35.341,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:35.541,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:35.691,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:47:35.891,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:36.041,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:36.234,283] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:36.341,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:36.491,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:36.641,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:36.791,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:36.941,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:37.108,551] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:37.241,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:37.405,090] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:37.641,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:37.841,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:38.041,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:38.191,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:38.341,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:38.491,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:38.667,755] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:38.791,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:38.941,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:39.091,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:39.241,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:39.412,017] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:39.541,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:39.691,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:39.841,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:40.037,750] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:40.141,235] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:40.291,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:40.530,822] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:40.641,204] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:40.791,229] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:40.941,223] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:41.091,217] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:41.241,210] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:41.361,022] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 279
    00> [01:47:41.386,138] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:47:41.386,596] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:47:41.629,791] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:47:41.629,913] <inf> BLE: disconnected: Disconnected: E1:35:E1:4C:E8:10 (random) (reason 19)
    00> [01:47:41.686,981] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:47:41.787,048] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:47:41.787,689] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:47:41.787,719] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:47:41.871,307] <inf> BLE: scan_filter_match: Filters matched. Address: E7:EA:8B:10:13:35 (random) connectable: 1
    00> [01:47:41.887,786] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:47:41.985,809] <inf> BLE: connected: Connected: E7:EA:8B:10:13:35 (random)
    00> [01:47:42.090,118] <inf> BLE: exchange_func: MTU exchange done
    00> [01:47:42.789,642] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:47:42.789,672] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:47:42.789,703] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:47:42.789,733] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:47:42.789,794] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:47:42.789,916] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:47:42.798,950] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:47:42.899,047] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:47:43.747,619] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 72
    00> [01:47:43.747,680] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:47:43.747,711] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:47:43.906,646] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:44.049,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:44.199,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:44.349,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:44.499,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:44.649,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:44.846,221] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:44.989,288] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:45.099,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:45.249,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:45.353,149] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:45.499,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:45.649,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:45.799,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:45.949,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:46.099,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:46.296,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:46.399,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:46.549,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:46.703,155] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> .[01:47:46.896,209] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:46.999,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:47.149,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x200301f3 length 492
    00> [01:47:47.399,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:47.549,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:47.699,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:47.853,149] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:47.999,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:48.149,719] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:48.442,749] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:48.549,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:48.699,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:48.849,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:48.999,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:49.156,616] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:49.349,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:49.499,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:49.649,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:49.799,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:49.949,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:50.099,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:50.249,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:50.399,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:50.549,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:50.699,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> Received:
    00> +CSCON: 0
    00> [01:47:50.849,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:50.999,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:51.149,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:51.339,294] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:51.449,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:51.676,239] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:51.922,760] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:52.049,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:52.199,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:52.349,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:52.549,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:52.699,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:52.849,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:52.999,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:53.160,095] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:53.299,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:53.453,155] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:53.599,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:53.796,234] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:53.899,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:54.049,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:54.222,747] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:54.349,700] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:54.499,694] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:54.610,107] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:54.799,682] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:54.949,707] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:55.149,688] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:47:55.688,842] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:47:55.688,964] <inf> BLE: disconnected: Disconnected: E7:EA:8B:10:13:35 (random) (reason 8)
    00> ...Received:
    00> +CSCON: 1
    00> ..[01:48:43.126,800] <inf> MAIN: ble_connected_state: Connection state timeout
    00> [01:48:43.126,831] <inf> PROTO: log_protocol_infos: Num: 74 - Extra: 0 - Off: 35551
    00> [01:48:43.126,831] <inf> PROTO: log_protocol_infos: data: 00 00 00 00
    00> [01:48:43.126,861] <inf> BLE: bluetooth_disconnect_ble_nus: No active connection to disconnect
    00> [01:48:43.126,892] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:48:43.226,959] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:48:43.227,600] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:48:43.227,630] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:48:43.327,697] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:48:43.372,680] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:48:43.484,741] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:48:43.589,080] <inf> BLE: exchange_func: MTU exchange done
    00> [01:48:44.288,604] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:48:44.288,635] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:48:44.288,665] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:48:44.288,696] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:48:44.288,757] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:48:44.288,879] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:48:44.297,912] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:48:44.398,010] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:48:45.246,582] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:48:45.246,643] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:48:45.246,673] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:48:45.405,578] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:45.548,645] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:45.698,638] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:45.848,663] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:45.998,657] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:46.148,651] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:46.298,645] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:46.448,638] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:46.598,663] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:48:46.788,238] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .Received:
    00> +CSCON: 0
    00> [01:48:50.837,799] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:48:50.837,921] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 8)
    00> ...Received:
    00> +CSCON: 1
    00> ..[01:49:44.382,598] <inf> MAIN: ble_connected_state: Connection state timeout
    00> [01:49:44.382,629] <inf> PROTO: log_protocol_infos: Num: 11 - Extra: 0 - Off: 4870
    00> [01:49:44.382,629] <inf> PROTO: log_protocol_infos: data: 00 00 00 00
    00> [01:49:44.382,659] <inf> BLE: bluetooth_disconnect_ble_nus: No active connection to disconnect
    00> [01:49:44.382,690] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:49:44.482,757] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:49:44.483,398] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:49:44.483,428] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:49:44.502,655] <inf> BLE: scan_filter_match: Filters matched. Address: D3:D4:C0:F4:AC:94 (random) connectable: 1
    00> [01:49:44.583,496] <inf> MAIN: ble_discovery_state: BLE Discovery State
    00> [01:49:44.616,638] <inf> BLE: connected: Connected: D3:D4:C0:F4:AC:94 (random)
    00> [01:49:44.720,947] <inf> BLE: exchange_func: MTU exchange done
    00> [01:49:45.420,501] <dbg> nus_c: bt_nus_handles_assign: Getting handles from NUS service.
    00> [01:49:45.420,532] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS TX characteristic.
    00> [01:49:45.420,532] <dbg> nus_c: bt_nus_handles_assign: Found handle for CCC of NUS TX characteristic.
    00> [01:49:45.420,593] <dbg> nus_c: bt_nus_handles_assign: Found handle for NUS RX characteristic.
    00> [01:49:45.420,654] <dbg> nus_c: bt_nus_subscribe_receive: [SUBSCRIBED]
    00> [01:49:45.420,776] <inf> MAIN: ble_discovery_state: BLE Connected
    00> [01:49:45.429,809] <inf> MAIN: set_state: [STATE_BLE_DISCOVERY] -> [STATE_BLE_CONNECTED]
    00> [01:49:45.529,876] <inf> MAIN: ble_connected_state: START FLAG sent
    00> [01:49:46.378,448] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 72
    00> [01:49:46.378,540] <inf> PROTO: protocol_parse_packet: Header received
    00> [01:49:46.378,540] <inf> PROTO: protocol_parse_packet: Len: 72
    00> [01:49:46.537,475] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:46.680,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:46.830,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:47.027,069] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:47.130,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:47.280,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:47.430,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:47.580,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:47.730,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:47.901,336] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:48.030,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:48.180,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:48.330,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:48.484,008] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:48.630,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:48.780,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:48.980,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> .[01:49:49.130,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:49.280,517] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:49.430,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:49.580,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:49.730,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:49.880,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:50.030,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fdff length 492
    00> [01:49:50.280,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:50.430,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:50.580,566] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:50.730,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> Received:
    00> +CSCON: 0
    00> [01:49:50.880,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:51.030,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:51.180,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:51.330,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:51.514,099] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:51.630,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:51.780,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:51.930,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:52.080,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:52.230,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:52.380,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:52.530,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:52.680,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:52.830,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:53.030,517] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:53.180,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:53.357,055] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:53.480,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:53.630,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:53.780,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:53.930,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:54.080,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:54.230,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:54.380,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:54.530,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:54.680,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:54.830,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:54.980,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:55.130,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:55.280,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:55.430,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:55.580,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:55.730,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:55.880,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:56.030,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:56.180,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:56.330,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:56.480,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:56.630,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:56.780,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:56.930,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:57.080,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:57.230,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:57.380,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:57.570,129] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:57.680,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:57.830,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:57.980,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:58.130,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:58.280,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:58.444,396] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:58.580,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:58.730,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:58.880,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:59.080,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> .[01:49:59.230,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:59.430,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:59.580,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:59.730,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:49:59.880,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:00.030,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:00.180,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:00.330,535] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:00.433,990] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:00.610,534] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:00.730,529] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:00.880,523] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:01.030,548] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:01.180,541] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:01.330,566] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 492
    00> [01:50:01.450,317] <dbg> nus_c: on_received: [NOTIFICATION] data 0x2002fff9 length 279
    00> [01:50:01.475,463] <inf> PROTO: protocol_parse_packet: Last packet
    00> [01:50:01.475,677] <inf> MAIN: ble_connected_state: Sending ACK packet
    00> [01:50:01.719,116] <dbg> nus_c: on_received: [UNSUBSCRIBED]
    00> [01:50:01.719,207] <inf> BLE: disconnected: Disconnected: D3:D4:C0:F4:AC:94 (random) (reason 19)
    00> [01:50:01.776,062] <inf> MAIN: set_state: [STATE_BLE_CONNECTED] -> [STATE_BLE_DISCONNECTION]
    00> [01:50:01.876,129] <inf> MAIN: ble_disconnection_state: BLE Disconnection State
    00> [01:50:01.876,770] <inf> BLE: bluetooth_start_scan: Start bt_scan
    00> [01:50:01.876,800] <inf> MAIN: set_state: [STATE_BLE_DISCONNECTION] -> [STATE_BLE_DISCOVERY]
    00> [01:50:01.976,867] <inf> MAIN: ble_discovery_state: BLE Discovery State
    (Connection lost)
    Behavior Summary:
    • The central continues scanning and connecting even after failures, though there’s a slight delay due to a connection timeout.
    • Sensors advertise for 45 seconds, waiting for a connection. If none occurs, they enter deep sleep.
    • The system works well with 3 sensors but shows intermittent failures when a 4th sensor is added — even though the timing should, in theory, allow it.
    I’m currently working on capturing a sensor-side log during a failed connection attempt to provide further insight from both ends of the communication.
    Please let me know if there’s any additional configuration or timing consideration that could affect system stability when multiple peripherals are active. Any suggestions regarding the bt_nus_subscribe_receive error (-128) or best practices for handling service discovery during quick reconnects would also be greatly appreciated.
    Thanks again for your support!
    Central Bluetooth.c
    /* main.c - Application main entry point */
    #include <errno.h>
    #include <zephyr/kernel.h>
    #include <zephyr/device.h>
    #include <zephyr/sys/byteorder.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/uuid.h>
    #include <zephyr/bluetooth/gatt.h>
    #include <bluetooth/services/nus.h>
    #include <bluetooth/services/nus_client.h>
    #include <bluetooth/gatt_dm.h>
    #include <bluetooth/scan.h>
    #include <zephyr/settings/settings.h>
    #include <zephyr/random/rand32.h>
    #include "bluetooth_central_app.h"
    #include "data_structures.h"
    #include "protocol.h"
    LOG_MODULE_REGISTER(BLE, CONFIG_LOG_DEFAULT_LEVEL);
    #ifdef CONFIG_USE_CODED_PHY
    #pragma message "Build with LongRange"
    #else
    #pragma message "Build WITHOUT LongRange"
    #endif //CONFIG_USE_CODED_PHY
    /* Connection handle */
    static struct bt_conn *default_conn;
    /* NUS client handle */
    static struct bt_nus_client nus_client;
    /* Buffer to receive data - 492 bytes */
    static uint8_t packet_buffer[BLUETOOTH_PACKET_SIZE] = {0};
    /* Buffer size */
    static uint16_t packet_buffer_len = 0;
    /* Services discovery flag*/
    static bool services_discovery_completed = false;
    K_SEM_DEFINE(ble_connection_discovery_sem, 0, 1);
    static void ble_data_sent(struct bt_nus_client *nus, uint8_t err,
    						  const uint8_t *const data, uint16_t len)
    	ARG_UNUSED(nus);
    	//LOG_INF("NUS sent data callback");
    void bluetooth_start_scan (void)
    	int ret = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
    	if (ret != SUCCESS) {
    		LOG_ERR("Scanning failed to start (ret %d)", ret);
    	LOG_INF("Start bt_scan");
    static uint8_t ble_data_received(struct bt_nus_client *nus, const uint8_t *data, uint16_t len)
    	ARG_UNUSED(nus);
    	// LOG_INF("Received data len: %d", len);
    	memset((void *)&packet_buffer, (int)0x00, (size_t)BLUETOOTH_PACKET_SIZE);
    	memcpy((void *)&packet_buffer, (const void *)data, (size_t)len);
    	packet_buffer_len = len;
    	if (protocol_parse_packet((const uint8_t *)&packet_buffer, packet_buffer_len) == SUCCESS) {
    		return BT_GATT_ITER_CONTINUE;
    	return BT_GATT_ITER_STOP;
    static void discovery_complete(struct bt_gatt_dm *dm,
    							   void *context)
    	struct bt_nus_client *nus = context;
    	//LOG_INF("Service discovery completed");
    	bt_gatt_dm_data_print(dm);
    	bt_nus_handles_assign(dm, nus);
    	bt_nus_subscribe_receive(nus);
    	bt_gatt_dm_data_release(dm);
    	k_sem_give(&ble_connection_discovery_sem);
    	services_discovery_completed = true;
    static void discovery_service_not_found(struct bt_conn *conn, void *context)
    	LOG_INF("Service not found");
    static void discovery_error(struct bt_conn *conn, int err, void *context)
    	LOG_ERR("Error while discovering GATT database: (%d)", err);
    struct bt_gatt_dm_cb discovery_cb = {
    	.completed = discovery_complete,
    	.service_not_found = discovery_service_not_found,
    	.error_found = discovery_error,
    static void gatt_discover(struct bt_conn *conn)
    	int ret = SUCCESS;
    	if (conn != default_conn) {
    		return;
    	ret = bt_gatt_dm_start(conn, BT_UUID_NUS_SERVICE, &discovery_cb, &nus_client);
    		LOG_ERR("could not start the discovery procedure, error code: %d", ret);
    static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
    	if (!err) {
    		LOG_INF("MTU exchange done");
    	} else {
    		LOG_ERR("MTU exchange failed (err %" PRIu8 ")", err);
    static void connected(struct bt_conn *conn, uint8_t conn_err)
    	char addr[BT_ADDR_LE_STR_LEN] = {0};
    	int ret = SUCCESS;
    	if (conn_err) {
    		LOG_ERR("Failed to connect to %s (%d)", addr, conn_err);
    		if (default_conn == conn) {
    			bt_conn_unref(default_conn);
    			default_conn = NULL;
    			bluetooth_start_scan();
    		return;
    	LOG_INF("Connected: %s", addr);
    	// Verificar MTU atual
    	uint16_t mtu = bt_gatt_get_mtu(conn);
    	//LOG_INF("Current MTU size: %u", mtu);
    	// Negociar MTU apenas se necessário
    	if (mtu == 23) { // Tamanho padrão significa que ainda não foi negociado
    		static struct bt_gatt_exchange_params exchange_params;
    		exchange_params.func = exchange_func;
    		ret = bt_gatt_exchange_mtu(conn, &exchange_params);
    		if (ret == 0) {
    			//LOG_INF("MTU exchange initiated");
    		} else if (ret == -EALREADY) {
    			LOG_WRN("MTU already exchanged");
    		} else {
    			LOG_ERR("MTU exchange failed (ret %d)", ret);
    	} else {
    		LOG_INF("MTU already negotiated, no need to exchange");
    	gatt_discover(conn);
    	// ret = bt_conn_set_security(conn, BT_SECURITY_L2);
    	// if (ret)
    	// 	LOG_WRN("Failed to set security: %d", ret);
    	// 	gatt_discover(conn);
    	ret = bt_scan_stop();
    	if ((!ret) && (ret != -EALREADY)) {
    		LOG_INF("Stop LE scan failed (ret %d)", ret);
    	LOG_INF("Disconnected: %s (reason %u)", addr, reason);
    	if (default_conn != conn) {
    		return;
    int bluetooth_is_connected(void)
    	if (default_conn == NULL){
    		return ERROR;
    	return SUCCESS;
    void bluetooth_disconnect_ble_nus(void)
    	if (default_conn) {
    		int ret = bt_conn_disconnect(default_conn, BT_HCI_ERR_LOCALHOST_TERM_CONN);
    		if (ret) {
    			LOG_ERR("Disconnection failed (err %d)", ret);
    		} else {
    			LOG_INF("Disconnection initiated");
    	} else {
    		LOG_INF("No active connection to disconnect");
    static void security_changed(struct bt_conn *conn, bt_security_t level,
    							 enum bt_security_err err)
    	if (!err) {
    		LOG_INF("Security changed: %s level %u", addr, level);
    	else {
    		LOG_ERR("Security failed: %s level %u err %d", addr, level, err);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected = connected,
    	.disconnected = disconnected,
    	.security_changed = security_changed
    static void scan_filter_match(struct bt_scan_device_info *device_info,
    							  struct bt_scan_filter_match *filter_match,
    							  bool connectable)
    	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
    	LOG_INF("Filters matched. Address: %s connectable: %d", addr, connectable);
    	// Se já houver uma conexão ativa, ignora novos anúncios
    	if (default_conn) {
    		LOG_INF("Já existe conexão ativa. Ignorando novo anúncio.");
    		return;
    	int ret;
    	struct bt_conn_le_create_param *conn_params;
    	if (ret) {
    		LOG_ERR("Stop LE scan failed (ret %d)", ret);
    	conn_params = BT_CONN_LE_CREATE_PARAM(
    		BT_CONN_LE_OPT_CODED | BT_CONN_LE_OPT_NO_1M,
    		BT_GAP_SCAN_FAST_INTERVAL,
    		BT_GAP_SCAN_FAST_INTERVAL);
    	ret = bt_conn_le_create(device_info->recv_info->addr, conn_params,
    							BT_LE_CONN_PARAM_DEFAULT,
    							&default_conn);
    	if (ret) {
    		LOG_ERR("Create conn failed (ret %d)", ret);
    	//LOG_INF("Connection pending");
    static void scan_connecting_error(struct bt_scan_device_info *device_info)
    	LOG_ERR("Connecting failed");
    static void scan_connecting(struct bt_scan_device_info *device_info,
    	default_conn = bt_conn_ref(conn);
    static int nus_client_init(void)
    	int ret = SUCCESS;
    	struct bt_nus_client_init_param init = {
    		.cb = {
    			.received = ble_data_received,
    			.sent = ble_data_sent,
    	ret = bt_nus_client_init(&nus_client, &init);
    		LOG_ERR("NUS Client initialization failed (ret %d)", ret);
    		return ret;
    	LOG_INF("NUS Client module initialized");
    	return ret;
    BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
    				scan_connecting_error, scan_connecting);
    static int scan_init(void)
    	int ret = SUCCESS;
    	/* Use active scanning and disable duplicate filtering to handle any
    	 * devices that might update their advertising data at runtime. */
    	struct bt_le_scan_param scan_param = {
    		.type     = BT_LE_SCAN_TYPE_ACTIVE,
    		.interval = BT_GAP_SCAN_FAST_INTERVAL,
    		.window   = BT_GAP_SCAN_FAST_WINDOW,
    		.options  = BT_LE_SCAN_OPT_CODED | BT_LE_SCAN_OPT_NO_1M
    	struct bt_scan_init_param scan_init = {
    		.connect_if_match = 0,
    		.scan_param = &scan_param,
    		.conn_param = NULL
    	#else
    		.connect_if_match = 1,
    	bt_scan_init(&scan_init);
    	bt_scan_cb_register(&scan_cb);
    	ret = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
    		LOG_ERR("Scanning filters cannot be set (ret %d)", ret);
    		return ret;
    	ret = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
    		LOG_ERR("Filters cannot be turned on (ret %d)", ret);
    		return ret;
    	LOG_INF("Scan module initialized");
    	return ret;
    static void auth_cancel(struct bt_conn *conn)
    	LOG_INF("Pairing cancelled: %s", addr);
    static void pairing_complete(struct bt_conn *conn, bool bonded)
    	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
    static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
    	LOG_WRN("Pairing failed conn: %s, reason %d", addr, reason);
    static struct bt_conn_auth_cb conn_auth_callbacks = {
    	.cancel = auth_cancel,
    static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
    	.pairing_complete = pairing_complete,
    	.pairing_failed = pairing_failed
    int bluetooth_central_init(void)
    	int ret = SUCCESS;
    	// Enable pins of SKY66112-11
    	const struct device* gpio0_dev = device_get_binding("gpio@50000000"); // gpio 0
    	//	Table 6. SKY66112-11 Mode Control Logic1
    	//	Mode	Description 		CPS	CHL
    	//	1 	Receive LNA 		0 	X
    	//	2 	Transmit high-power 	0 	1
    	gpio_pin_configure(gpio0_dev, 6, GPIO_OUTPUT); // gpio 0.06 - CPS
    	gpio_pin_set(gpio0_dev, 6, 0);
    	gpio_pin_configure(gpio0_dev, 8, GPIO_OUTPUT); // gpio 0.08 - CHL
    	gpio_pin_set(gpio0_dev, 8, 1);
    	ret = bt_conn_auth_cb_register(&conn_auth_callbacks);
    		LOG_ERR("Failed to register authorization callbacks.");
    		return ERROR;
    	ret = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
    		LOG_ERR("Failed to register authorization info callbacks.");
    		return ERROR;
    	ret = bt_enable(NULL);
    		LOG_ERR("Bluetooth init failed (ret %d)", ret);
    		return ERROR;
    	LOG_INF("Bluetooth initialized");
    	if (IS_ENABLED(CONFIG_SETTINGS)) {
    		settings_load();
    	ret = scan_init();
    		LOG_ERR("scan_init failed (ret %d)", ret);
    		return ERROR;
    	ret = nus_client_init();
    		LOG_ERR("nus_client_init failed (ret %d)", ret);
    		return ERROR;
    		return ERROR;
    	LOG_INF("Scanning successfully started");
    	return SUCCESS;
    int bluetooth_central_send_data(const uint8_t *data, uint16_t len)
    	int ret = SUCCESS;
    	if (!default_conn) {
    		LOG_ERR("Cannot send data, no BLE connection");
    		return -ENOTCONN;
    	ret = bt_nus_client_send(&nus_client, data, len);
    		LOG_ERR("BT NUS send ERROR: %d", ret);
    		return ERROR;
    	return ret;
    bool bluetooth_service_discovery_completed(void)
    	return services_discovery_completed;
    Central main.c
    #include <zephyr/sys/reboot.h>
    #include "imachine_central.h"
    #include "flash.h"
    #include "comm_uart.h"
    #include "watchdog.h"
    LOG_MODULE_REGISTER(MAIN, CONFIG_LOG_DEFAULT_LEVEL);
    static bool ack_sent = false;
    static bool start_sent = false;
    static protocol_ack_st ack_packet = {0};
    static int timeout_count;
    typedef enum {
    	STATE_INITIAL,
    	STATE_WATCHDOG_CONFIG,
    	STATE_WATCHDOG_ERROR,
    	STATE_FLASH_CONFIG,
    	STATE_FLASH_ERROR,
    	STATE_BLE_CONFIG,
    	STATE_BLE_DISCOVERY,
    	STATE_BLE_CONNECTED,
    	STATE_BLE_WAIT_DISCONNECTION,
    	STATE_BLE_DISCONNECTION,
    	STATE_BLE_DISCOVERY_TIMEOUT,
    	STATE_BLE_ERROR,
    	STATE_FATAL_ERROR,
    	STATE_COUNT,
    } machine_state_t;
    static machine_state_t current_state;
    const char* state_names[STATE_COUNT] = {
    	"STATE_INITIAL",
    	"STATE_WATCHDOG_CONFIG",
    	"STATE_WATCHDOG_ERROR",
    	"STATE_FLASH_CONFIG",
    	"STATE_FLASH_ERROR",
    	"STATE_BLE_CONFIG",
    	"STATE_BLE_DISCOVERY",
    	"STATE_BLE_CONNECTED",
    	"STATE_BLE_WAIT_DISCONNECTION",
    	"STATE_BLE_DISCONNECTION",
    	"STATE_BLE_DISCOVERY_TIMEOUT",
    	"STATE_BLE_ERROR",
    	"STATE_FATAL_ERROR",
    #include <hal/nrf_gpio.h>
    static const struct gpio_dt_spec led1_g = GPIO_DT_SPEC_GET(DT_ALIAS(led1_g), gpios);
    static const struct gpio_dt_spec led2_b = GPIO_DT_SPEC_GET(DT_ALIAS(led2_b), gpios);
    static struct k_work_delayable led_toggle_worker;
    static void led_toggle_work_handler(struct k_work *work)
    	gpio_pin_toggle_dt(&led1_g);
    	/* Re-agenda para rodar novamente após 1 minuto */
    	k_work_schedule(&led_toggle_worker, K_SECONDS(1));
    void main_worker_init()
    	gpio_pin_configure_dt(&led1_g, GPIO_OUTPUT_INACTIVE);
    	gpio_pin_configure_dt(&led2_b, GPIO_OUTPUT_INACTIVE);
    	k_work_init_delayable(&led_toggle_worker, led_toggle_work_handler);
    void set_state(machine_state_t new_state)
    	LOG_INF("[%s] -> [%s]", state_names[current_state], state_names[new_state]);
    	current_state = new_state;
    void initial_state()
    	LOG_INF("Initial State");
    	init_uart();
    	main_worker_init();
    	set_state(STATE_WATCHDOG_CONFIG);
    void watchdog_config_state() {
    	LOG_INF("Watchdog Config State");
    	if( watchdog_init() == SUCCESS ) {
    		set_state(STATE_FLASH_CONFIG);
    	else {
    		set_state(STATE_WATCHDOG_ERROR);
    void watchdog_error_state() {
    	LOG_ERR("Watchdog Error State");
    	LOG_ERR("Handle Watchdog Error");
    	set_state(STATE_FATAL_ERROR);
    void flash_config_state()
    	LOG_INF("Flash Config State");
    	if( storage_config() == SUCCESS ) {
    		set_state(STATE_BLE_CONFIG);
    	} else {
    		set_state(STATE_FLASH_ERROR);
    void flash_error_state()
    	LOG_ERR("Flash Error State");
    	LOG_ERR("Handle Flash Error");
    void ble_config_state()
    	LOG_INF("BLE Configuration State");
    	if( bluetooth_central_init() == SUCCESS ) {
    		LOG_INF("BLE Successfully Configured");
    		set_state(STATE_BLE_DISCOVERY);
    	} else {
    		LOG_WRN("BLE init FAILED");
    		//k_sleep(K_MSEC(3000));
    		set_state(STATE_BLE_ERROR);
    void ble_discovery_state()
    	LOG_INF("BLE Discovery State");
    	k_sem_reset(&ble_connection_discovery_sem);
    	int ret = k_sem_take(&ble_connection_discovery_sem, K_MINUTES(30));
    	if (ret == 0) {
    		LOG_INF("BLE Connected");
    		ack_sent = false;
    		start_sent = false;
    		memset(&ack_packet, 0, sizeof(protocol_ack_st));
    		clear_state_flags();
    		// create a timeout of connected state
    		timeout_count = 60000/SM_DELTA_TIME;
    		set_state(STATE_BLE_CONNECTED);
    	} else {
    		LOG_WRN("BLE Connection timeout");
    		set_state(STATE_BLE_DISCOVERY_TIMEOUT);
    void ble_connected_state()
    	gpio_pin_set_dt(&led2_b, 1);
    	timeout_count--;
    	if (timeout_count <= 0) {
    		LOG_INF("Connection state timeout");
    		log_protocol_infos();
    		bluetooth_disconnect_ble_nus();
    		timeout_count = 10000/SM_DELTA_TIME;
    		set_state(STATE_BLE_WAIT_DISCONNECTION);
    		return;
    	if (start_sent == false) {
    		uint8_t data = START_FLAG;
    		LOG_INF("START FLAG sent");
    		bluetooth_central_send_data((const uint8_t *)&data, sizeof(data));
    		start_sent = true;
    	/* Wait for receiving all packets */
    	if (protocol_received_all_packets() != true) {
    		return;
    	if (ack_sent == false) {
    		LOG_INF("Sending ACK packet");
    		protocol_build_ack(&ack_packet);
    		int ret = bluetooth_central_send_data((const uint8_t *)&ack_packet, sizeof(protocol_ack_st));
    			LOG_ERR("Failed to send data over BLE connection (err %d)", ret);
    		ack_sent = true;
    	/* If ACK was succesfully sent... save data into flash memory */
    	if (ack_sent != true) {
    		return;
    	if (bluetooth_is_connected() == SUCCESS) {
    		return;
    void ble_wait_disconnection_state()
    	gpio_pin_set_dt(&led2_b, 0);
    	timeout_count--;
    	// Wait for timeout finish
    		set_state(STATE_BLE_DISCONNECTION);
    void ble_disconnection_state()
    	LOG_INF("BLE Disconnection State");
    void ble_discovery_timeout_state()
    	LOG_WRN("BLE Discovery Timeout State");
    void ble_error_state()
    	LOG_ERR("BLE Error State");
    void fatal_error_state()
    	LOG_ERR("Fatal Error State");
    	LOG_ERR("Rebooting");
    	sys_reboot(SYS_REBOOT_COLD);
    int state_machine_run(void)
    	switch (current_state) {
    		case STATE_INITIAL:
    			initial_state();
    		case STATE_WATCHDOG_CONFIG:
    			watchdog_config_state();
    		case STATE_FLASH_CONFIG:
    			flash_config_state();
    		case STATE_FLASH_ERROR:
    			flash_error_state();
    		case STATE_BLE_CONFIG:
    			ble_config_state();
    		case STATE_BLE_DISCOVERY:
    			ble_discovery_state();
    		case STATE_BLE_CONNECTED:
    			ble_connected_state();
    		case STATE_BLE_WAIT_DISCONNECTION:
    			ble_wait_disconnection_state();
    		case STATE_BLE_DISCONNECTION:
    			ble_disconnection_state();
    		case STATE_BLE_DISCOVERY_TIMEOUT:
    			ble_discovery_timeout_state();
    		case STATE_BLE_ERROR:
    			ble_error_state();
    		case STATE_FATAL_ERROR:
    			fatal_error_state();
    		case STATE_COUNT:
    			// Only here to clear the warning:
    			// warning: enumeration value 'STATE_COUNT' not handled in switch [-Wswitch]
    			// 'STATE_COUNT' is used to keep track of the enum size.
    			LOG_ERR("Unknown state");
    	watchdog_feed();
    	return 0;
    	LOG_INF("-----------------------------");
    	LOG_INF("-- iMachine Central BLE V3 --");
    	current_state = STATE_INITIAL;
    	int k = 0;
    	while (true) {
    		state_machine_run();
    		k_sleep(K_MSEC(SM_DELTA_TIME));
    		if(k % 100 == 0 ) {
    			printk(".");
    		k++;
    	return 0;
    Peripheral Bluetooth.c
    #include "bluetooth.h"
    #include <zephyr/types.h>
    #include "flash.h"
    #include "imachine.h"
    #include "configuration.h"
    #include <stddef.h>
    #include <zephyr/sys/util.h>
    #include <zephyr/bluetooth/hci_vs.h>
    #define DEVICE_NAME CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
    /* Set when is connected to a Gateway */
    static bool is_connected = false;
    /* Set when Bluetooth hardware is running */
    static bool is_running = false;
    /* Buffer to receive data */
    static uint8_t buffer[BLUETOOTH_PACKET_SIZE] = {0};
    static uint16_t buffer_len = 0;
    static bool receive_data = false;
    static bool bluetooth_services_discovered = false;
    K_SEM_DEFINE(ble_connection_sem, 0, 1);
    K_SEM_DEFINE(ble_disconnection_sem, 0, 1);
    static struct bt_conn *current_conn = NULL;
    static struct bt_le_ext_adv *adv;
    static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN)
    #else
    static const struct bt_data adverstising[] = {
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    static const struct bt_data service_data[] = {
    static void print_conn_addr(struct bt_conn *conn)
    	char addr_str[BT_ADDR_LE_STR_LEN];
    	struct bt_conn_info info;
    	if (bt_conn_get_info(conn, &info) == 0) {
    		bt_addr_le_to_str(info.le.dst, addr_str, sizeof(addr_str));
    		LOG_INF("Connected to device: %s", addr_str);
    	} else {
    		LOG_ERR("Unable to get connection info");
    static void connected(struct bt_conn *conn, uint8_t ret)
    	if (ret) {
    		LOG_INF("Connection failed (ret 0x%02x)", ret);
    	} else {
    		LOG_INF("Connected");
    		is_connected = true;
    		current_conn = bt_conn_ref(conn);
    		print_conn_addr(conn);
    		k_sem_give(&ble_connection_sem);
    	LOG_INF("Disconnected (reason 0x%02x)", reason);
    	is_connected = false;  // Update connection state
    	k_sem_give(&ble_disconnection_sem);
    	//set_is_it_ok_to_deep_sleep(true);
    	if (current_conn) {
    		bt_conn_unref(current_conn);
    void parse_command(const uint8_t *const data, uint16_t len)
    	if (len == 1) {
    		uint8_t msg[30];
    		int ret;
    		switch (data[0]) {
    			case START_FLAG:
    				LOG_INF("START FLAG received");
    				bluetooth_services_discovered = true;
    				imachine_bluetooth_send_data();
    				return;
    			case SANITY_CHECK:
    				LOG_INF("SANITY_CHECK received");
    				snprintf((char *)msg, sizeof(msg), "#SANITY_CHECK received");
    			case CONFIG_RTC_PERIOD:
    				LOG_INF("CONFIG_RTC_PERIOD received");
    				snprintf((char *)msg, sizeof(msg), "#CONFIG_RTC_PERIOD received");
    			case SLEEP_CMD:
    				LOG_INF("SLEEP_CMD received");
    				snprintf((char *)msg, sizeof(msg), "#SLEEP_CMD received");
    				LOG_WRN("Unknown command received: 0x%.2x", data[0]);
    				return;
    		ret = bluetooth_send_data((uint8_t *)msg, strlen((char *)msg));
    	} else if (len == sizeof(protocol_ack_st)) {
    		// TODO: define better ACK packet size
    		LOG_INF("ACK received");
    		memcpy((void *)buffer, (const void *)data, (size_t)len);
    		buffer_len = len;
    		set_received_data_flag(true);
    	} else {
    		LOG_ERR("Packet len invalid");
    		LOG_ERR("Expected: %d, received: %d", sizeof(protocol_ack_st), len);
    static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data, uint16_t len)
    	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
    	LOG_INF("Received data from: %s", addr);
    	for(int i = 0; i < len; i++) {
    		printk("%x", data[i]);
    	printk("\n");
    	printk("\n");
    	parse_command(data, len);
    static struct bt_nus_cb nus_cb = {
    	.received = bt_receive_cb,
    static int bt_ready(void)
    	int ret = SUCCESS;
    		settings_load();
    		struct bt_le_adv_param param =
    		BT_LE_ADV_PARAM_INIT(BT_LE_ADV_OPT_CONNECTABLE |
    				BT_LE_ADV_OPT_EXT_ADV |
    				BT_LE_ADV_OPT_CODED,
    				BT_GAP_ADV_FAST_INT_MIN_2,
    				BT_GAP_ADV_FAST_INT_MAX_2,
    				NULL);
    		ret = bt_le_ext_adv_create(&param, NULL, &adv);
    		if (ret) {
    			LOG_INF("Failed to create advertiser set (ret %d)", ret);
    			return ret;
    		LOG_INF("Created adv:");
    		ret = bt_le_ext_adv_set_data(adv, ad, ARRAY_SIZE(ad), NULL, 0);
    		if (ret) {
    			LOG_INF("Failed to set advertising data (ret %d)", ret);
    			return ret;
    		ret = bt_le_ext_adv_start(adv, NULL);
    		if (ret) {
    			LOG_INF("Failed to start advertising set (ret %d)", ret);
    			return ret;
    		LOG_INF("Advertiser set started");
    	#else
    		ret = bt_le_adv_start(BT_LE_ADV_CONN, adverstising, ARRAY_SIZE(adverstising),
    				service_data, ARRAY_SIZE(service_data));
    			LOG_ERR("Advertising failed to start (ret %d)", ret);
    			return ERROR;
    		LOG_INF("Advertising successfully started");
    	return ret;
    int bluetooth_send_data(uint8_t *data, uint16_t len)
    	int ret = SUCCESS;
    	if (data == NULL) {
    		LOG_ERR("Packet data cannot be NULL");
    		return ERROR;
    	if (len > BLUETOOTH_PACKET_SIZE) {
    		LOG_ERR("Packet size must be less or equal to %d", BLUETOOTH_PACKET_SIZE);
    		return ERROR;
    	ret = bt_nus_send(NULL, data, len);
    		return ERROR;
    	return ret;
    int bluetooth_init(void)
    	int ret = SUCCESS;
    	/* Enable Bluetooth hardware */
    		return ERROR;
    	/* Enable NUS */
    	ret = bt_nus_init(&nus_cb);
    		LOG_ERR("Failed to initialize UART service (ret: %d)", ret);
    		return ERROR;
    	ret = bt_ready();
    		return ERROR;
    	/* Set Bluetooth running flag */
    	is_running = true;
    	/* Wait for service discovery */
    	// Check if necessary
    	//k_sleep(K_MSEC(2000));
    	return ret;
    bool is_bluetooth_connected(void)
    	return is_connected;
    bool is_bluetooth_running(void)
    	return is_running;
    void bluetooth_get_received_buffer(uint8_t *data, uint16_t *len)
    	memcpy((void *)data, (const void *)buffer, (size_t)buffer_len);
    	*len = buffer_len;
    bool get_received_data_flag(void)
    	return receive_data;
    void set_received_data_flag(bool flag)
    	receive_data = flag;
    bool get_bluetooth_services_discovered(void)
    	return bluetooth_services_discovered;
    void disconnect_ble_nus(void)
    	if (current_conn) {
    		int ret = bt_conn_disconnect(current_conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
    		if (ret) {
    		} else {
    	} else {
    void stop_advertising(void)
    		bt_le_ext_adv_stop(adv);
    	#else
    		bt_le_adv_stop();
    void bluetooth_disable(void)
    	stop_advertising();
    	bt_disable();
    Peripheral main.c
    #include "flash.h"
    typedef enum {
    	STATE_INITIAL,
    	STATE_FLASH_CONFIG,
    	STATE_FLASH_ERROR,
    	STATE_BLE_CONFIG,
    	STATE_BLE_ERROR,
    	STATE_FATAL_ERROR,
    	STATE_COUNT,
    } machine_state_t;
    	"STATE_INITIAL",
    	"STATE_BLE_CONFIG",
    	"STATE_BLE_ERROR",
    	init_uart();
    	main_worker_init();
    	else {
    	} else {
    	} else {
    	if (ret == 0) {
    		ack_sent = false;
    		start_sent = false;
    	} else {
    	timeout_count--;
    		return;
    		start_sent = true;
    		return;
    		ack_sent = true;
    		return;
    		return;
    	timeout_count--;
    		case STATE_INITIAL:
    			initial_state();
    			ble_config_state();
    			ble_error_state();
    		case STATE_COUNT:
    	watchdog_feed();
    	return 0;
    	int k = 0;
    	while (true) {
    		if(k % 100 == 0 ) {
    			printk(".");
    		k++;
    	return 0;
  • Hi Arthur,
    I think there was something wrong with your state machine.
    This transition should never happen:
    When the peripheral is already disconnected there is no point (and not possible) to do service discovery.
    So you should check that and stop the state machine to continue if the link is disconnected.
    The next step is to check why the link is terminated. I would suggest to use the sniffer to track that. Have you found a reliable way to reproduce the disconnection ?
