Smartbadge epaper custom board using nrf5340/nrf7002, with an NFC loop to allow NFC card emulation/communication. Building using NCS2.9 with sysbuild.
I want to be able to dynamically change my NFC card emulation under user control, between
-off (no emulation response)
- type 2 card with NDEF
- type 4 card with NDEF
- type 4 ISODEP APDU cmd/response
Looking at the NFC samples I created code that looks like this:
bool nfcmgr_enable(nfc_ref_t inst, nfc_card_type_t ctype, nfc_cb_t cb_fn, void* cb_ctx) {
if (inst==NULL) {
return false;
struct _nfc_ctx* ctx = (struct _nfc_ctx*)inst;
ctx->cb_fn = cb_fn;
ctx->cb_ctx = cb_ctx;
ctx->ctype = ctype;
//uint8_t selres = 0x00; // TBD do we need to play with SEL_RES (aka SAK)?
//nfc_t4t_parameter_set(NFC_T4T_PARAM_SELRES, &selres, 1);
switch (ctype) {
case NFC_TYPE4_APDU: {
// register with nfc_t4t
if (ctx->setupdone==false) {
int ret = nfc_t4t_setup(_nfc_t4t_apdu_cb, &_ctx);
if (ret!=0) {
log_warn("nfcmgr : could not setup nfc_t4t library for APDU operation, error %d", ret);
return false;
nfc_t4t_emulation_start();
ctx->enabled = true;
case NFC_TYPE2_NDEF: {
// else type 2 also possible as a simple data storage tag only (no ISODEP)
#ifdef CONFIG_NFC_T2T_NRFXLIB
int ret = nfc_t2t_setup(_nfc_t2t_cb, &_ctx);
if (ret==0) {
log_warn("nfcmgr : could not setup nfc_t2t library for basic NDEF card, error %d", ret);
return false;
ctx->setupdone = true;
nfc_t2t_payload_raw_set(ctx->ndef_buff, MAXLEN_NDEF); //ctx->ndef_sz);
nfc_t2t_emulation_start();
#else /* CONFIG_NFC_T2T_NRFXLIB*/
log_warn("nfcmgr : nfc_t2t library not enabled");
#endif /* CONFIG_NFC_T2T_NRFXLIB*/
case NFC_TYPE4_NDEF: {
int ret = nfc_t4t_setup(_nfc_t4t_ndef_cb, &_ctx);
if (ret!=0) {
log_warn("nfcmgr : could not setup nfc_t4t library for basic NDEF card, error %d", ret);
return false;
nfc_t4t_ndef_rwpayload_set(ctx->ndef_buff, MAXLEN_NDEF); //ctx->ndef_sz);
default: {
log_warn("nfcmgr : could not setup unknown mode %d", ctx->ctype);
return false;
return true;
void nfcmgr_disable(nfc_ref_t inst) {
if (inst==NULL) {
return;
ctx->cb_fn = NULL;
ctx->cb_ctx = NULL;
log_warn("nfcmgr : nfc disable disabled as crashes...");
#ifdef CRASH
if (ctx->enabled) {
switch (ctx->ctype) {
nfc_t4t_emulation_stop();
nfc_t4t_done(); // release NFC periph
nfc_t2t_emulation_stop();
nfc_t2t_done(); // release NFC periph
default: {
log_warn("nfcmgr : could not disable unknown mode %d", ctx->ctype);
ctx->enabled = false;
It works to enable the NFC operation the first time eg for type 4 using the ndef library to do the HL exchanges.
I am experiencing a problem to disable the nfc emulation, as when I call nfc_t4t_emulation_stop() it fails the assert
