I'm getting a verification failed message each time I try to do a quickstart with the NRF91X.
I was able to do the default QR code demo earlier, so it seems to work on some level. Can you please advise? Thanks - Jeremy
2025-03-17T19:54:48.545Z INFO Initialising the bundled nrfutil device 2025-03-17T19:54:48.549Z DEBUG Started watching devices 2025-03-17T19:54:49.842Z INFO Using the bundled core version for nrfutil device: 7.13.0 2025-03-17T19:54:50.032Z INFO Using nrfutil-device version: 2.7.5 2025-03-17T19:54:50.032Z INFO Using nrf-device-lib version: 0.17.41 2025-03-17T19:54:50.033Z INFO Using nrfjprog DLL version: 10.24.2 2025-03-17T19:54:50.033Z INFO Using JLink version: JLink_V8.20 2025-03-17T19:54:50.033Z INFO Your version of SEGGER J-Link (8.20) is newer than the one this app was tested with (7.94i). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version. 2025-03-17T19:54:51.546Z DEBUG Selected device: Nordic Thingy:91 X 2025-03-17T19:54:51.568Z DEBUG Changed step: Info 2025-03-17T19:54:55.793Z DEBUG Changed step: Rename 2025-03-17T19:54:57.040Z DEBUG Changed step: Program 2025-03-17T19:55:03.149Z ERROR [mcuboot] delete package returns error 607 2025-03-17T19:56:12.018Z DEBUG Changed step: Verify 2025-03-17T19:56:15.028Z INFO Opened port with options: {"path":"/dev/tty.usbmodem14231202","baudRate":115200} 2025-03-17T19:56:16.034Z ERROR Error: Received ERROR as return value from AT command 2025-03-17T19:56:16.038Z INFO Closed port: /dev/tty.usbmodem14231202 2025-03-17T20:06:35.380Z INFO Opened port with options: {"path":"/dev/tty.usbmodem14231202","baudRate":115200} 2025-03-17T20:06:36.383Z ERROR Error: Received ERROR as return value from AT command 2025-03-17T20:06:36.387Z INFO Closed port: /dev/tty.usbmodem14231202 2025-03-17T20:07:11.309Z INFO Opened port with options: {"path":"/dev/tty.usbmodem14231202","baudRate":115200} 2025-03-17T20:07:11.402Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.402Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.403Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.403Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.403Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.403Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.404Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.404Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.405Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.406Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.407Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.408Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.409Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.410Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.410Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.410Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.410Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.410Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.410Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: loadToBuffer: Shell prompt has not been set 2025-03-17T20:07:11.411Z DEBUG Shell Parser: found shell prompt: "uart:~$ " 2025-03-17T20:07:12.314Z ERROR Error: Received ERROR as return value from AT command 2025-03-17T20:07:12.317Z INFO Closed port: /dev/tty.usbmodem14231202
