To preface:
- nRF Connect SDK 2.9.0
- nRF9151 DK
- Windows 11 PC
I just stumbled upon a potential issue after trying to figure out why I couldn't use 'softreset' in my settings.json file per this guide:
The above guide states to add the following to your settings.json to enable 'softreset' functionality:
"nrf-connect.applicationOptions": {
"/path/to/your/application": {
"flash": {
"softreset": true
However, this didn't work for me. I tried adding it to my local workspace settings.json, then my user settings.json in AppData\Roaming\...
Nothing worked. Every time I programmed the devkit I could see the reset line pulse low (I am monitoring pin 10 on header P18 of the nRF9151DK).
Just when I was about to give up, I stumbled on this:
Upon checking the item highlighted in red, the following was added to my workspace settings.json file:
"nrf-connect.flash.softreset": true
[00:00:07.360,382] <wrn> nrf_modem_lib_netif: The modem has detected a reset loop. LTE network attach is now restricted for the next 30 minutes.
