Is the VSS Pin (pin 103) connected internally to GND_Shield?
Dear Nordic Support Team,
 In the datasheet of the nrf9160 (nRF9160_PS_v2.2.pdf) the VSS pin appears in the section 6.4.5.1 GPIO Electrical Specification, but I cannot find the information if it is internally connected to GND_Shield.
Best regards
Stefan
  • Hello Stefan,
    No sure what you are referring to. The GND_Shield pins of the nRF9160 are connected to Ground, similarly the VSS is connected to Ground. This is described in chapter 10 Hardware and layout.
    Øyvind
  • Hi ,
    thanks for your reply. I know that they have to be connected them to ground, my question is: Are they connected in the nrf9160?
    I tried to read VCC_GPIO on a custom board and was wondering why the readings are so far away from the 1.778 V I was measuring with an external Multimeter. The readings are outside the 4% DC error, and always lower than 1.779 V. I increased the aquisition time to 40 µs, but this did not solve the issue.
    When the modem was active the VCC_GPIO read with the ADC was even lower, so I thought that ground bouncing might be the issue and that it would be better to have the VSS pin routed to the star ground point separately from the GND_Shield pins (which I suspected to be the ground pins for the modem).
    But now I have set up this sample zephyr/samples/drivers/adc on a nRF9160-dk and this is what I read for the 1.8 V VCC_GPIO:
    - adc@e000, channel 1: 7621 = 1674 mV
    I use this devicetree setup for this channel:
        channel@1 {
            reg = <1>;
            zephyr,gain = "ADC_GAIN_1_6";
            zephyr,reference = "ADC_REF_INTERNAL";
            zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;
            zephyr,input-positive = <NRF_SAADC_VDD>;
            zephyr,resolution = <14>;
            zephyr,oversampling = <8>;
    Do you have an idea why the reading is so wrong?
  • What version of nRF Connect SDK are you using? Could you share your project?
    I would like to test and see if I get the same result.
  • 7433.adc.zip
    Hi ,
     please find attached the zipped adc folder from zephyr/samples/drivers. I am using nRF Connect SDK v2.6.1, and simply zipped the adc folder after deleting the build directory.
    I have build it with 'west build -b nrf9160dk_nrf9160_ns', in the prj.conf you can see that I am using Segger RTT for logging.
  • Hello, and thanks for providing your project. I see the same result and inquired internally. This does look like a known issue, which there is currently no solution to.
    Øyvind
