What are the prerequisites to get the ICCID
I would like to know what are the prerequisites to get the ICCID of the sim card:
    int err = 0;
    LOG_INF("Initializing modem library");
    /* initialize the modem library */
    err = nrf_modem_lib_init(NORMAL_MODE);
    if (err)
        LOG_ERR("nrf_modem_lib_init error: %i", err);
    /* register callbacks */
    lte_lc_register_handler(on_modem_lte_lc_event);
    err = nrf_modem_at_printf("AT%%CESQ=1");
    if (err)
        LOG_ERR("nrf_modem_at_printf(CESQ): %i", err);
        return;
    /* initialize info structures, this will contain the SIM card numbers as well */
    err = modem_info_init();
    if (err)
        LOG_ERR("Failed to initialize modem info!");
        return;
    LOG_INF("Changing functional mode");
    modem_get_info(INFO_IMEI); <=== in this internal function I can get the IMEI at this stage
    char temp_char[24] = {0};
    err = nrf_modem_at_cmd(temp_char, sizeof(temp_char), "AT%%XICCID");
    if(err == 0)
        LOG_INF("AT cmd ICCID:    %s", temp_char);
        LOG_ERR("AT cmd ICCID failed %d", err); <=== I always get here with error 65536
This is the code I use, nothing special. I can get the IMEI of the modem but not the ICCID, I always get error 65536 which does not really make sense to me (= 0x10000, which is also not a negative nr).
Question is what do I need more to get the ICCID?
At this moment I do a lte_lc_init_and_connect, but that feels like overkill, just to get the ICCID...
Kind regards
  • I noticed here  Incorrect ICCID value from modem_infothat they are talking about CFUN 41 (Sim card only)
    So I did this change:
        // Set the modem to activate only the UICC (SIM card)
        err = lte_lc_func_mode_set(LTE_LC_FUNC_MODE_ACTIVATE_UICC);
        if (err) {
            LOG_ERR("Failed to activate UICC, error: %d", err);
            return;
        if (err)
            return;
        // Retrieve the ICCID
        char iccid[24] = {0};
        err = modem_info_string_get(MODEM_INFO_ICCID, iccid, sizeof(iccid));
        if (err < 0) {
            LOG_ERR("Failed to get ICCID, error: %d", err);
        } else {
            LOG_INF("ICCID: %s", iccid);
    before modem_info_init i set lte_lc_func_mode_set(LTE_LC_FUNC_MODE_ACTIVATE_UICC) and after modem_info_init I readout the ICCID:​modem_info_string_get(MODEM_INFO_ICCID, iccid, sizeof(iccid))
    And this seems to work.
    I'm not sure if this is the proper way of doing it, but it seems to work... Not sure if I should set function mode back to off before starting connection.
    SIM card needs to be activated to be able to read UICCID. You can look at CFUN set command and lte_lc_func_mode API.
    "Full functionality" corresponds to LTE_LC_FUNC_MODE_NORMAL, "Activates LTE without changing GNSS" (CFUN=21) corresponds to LTE_LC_FUNC_MODE_ACTIVATE_LTE and "Activates UICC" corresponds to LTE_LC_FUNC_MODE_ACTIVATE_UICC. All these 3 modes can accomplish UICC initialization.
    This is good news. Your method seems to be OK.
    When you use nrf_modem_lib_init(), it initializes the Modem library in normal operating mode.
    Dejan
