toolchain installation directory relative to VSCode workspaceFolder?
HI!
We want to use different toolchains folder per VSCode projects, but it seems, that the nrf-connect setting "nrf-connect.toolchainManager.installDirectory" is not capable of working with ${workspaceFolder} Variable nor with a pur relative path like "..".
On the other hand, it seems, that it must point to a folder where a folder "toolchains" exists in, in which a toolchains.json file lives. ....
Is this correct? IMHO, it would be more nice to just point to a folder, where the toolchains.json is and not to a hardcoded toolchains folder.
Anyway, it would be nice if there is more docu to the installDirectory setting and how to setup custom folder installation with this setting.
Is it anyhow possible, to use not absolute paths with this setting?
Cheers
Thilo
  • Hi Vidar
    here you go.
    Cheers,
    Thilo
    // IMPORTANT: The following data can contain sensitive or confidential information about your environment.
    // If you do not want others to see this information, make sure to remove it before sharing the data.
    // For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "linux",
        "osVersion": "#57-Ubuntu SMP PREEMPT_DYNAMIC Wed Feb 12 23:42:21 UTC 2025",
        "osKernel": "6.8.0-55-generic",
        "vscode": "1.98.2",
        "electron": "34.2.0",
        "node": "v20.18.2",
        "name": "Ubuntu",
        "id": "ubuntu",
        "version": "24.04.2 LTS (Noble Numbat)",
        "versionId": "24.04"
      "system": {
        "date": "2025-03-20T15:34:04.991Z",
        "vscodeRoot": "/usr/share/code/resources/app",
        "nrfConnectForDesktopInstalled": "unknown",
        "vscodeUptime": "00:28:06",
        "osUptime": "335:23:56",
        "cpu": "AMD Ryzen 9 5950X 16-Core Processor"
      "workspace": {
        "name": "pan-isn (Workspace)",
        "workspaceFile": "/media/data/projects/pan-ng/PAN-ISN/pan-isn.code-workspace",
        "folders": [
          "/media/data/projects/pan-ng/PAN-ISN",
          "/media/data/projects/pan-ng/ZephyrSDK/zephyr",
          "/media/data/projects/pan-ng/ZephyrSDK/nrf",
          "/media/data/projects/pan-ng/ZephyrSDK/bootloader",
          "/media/data/projects/pan-ng/ZephyrSDK/nrfxlib"
      "sdks": [
          "version": "v2.6.1",
          "path": "/media/data/projects/pan-ng/ZephyrSDK"
          "path": "/opt/ncs/v2.6.1"
          "path": "/media/data/projects/ateam/ZephyrSDK"
      "activeBuild": "/media/data/projects/pan-ng/PAN-ISN/build",
      "apps": [
          "workspace": "/media/data/projects/pan-ng/PAN-ISN",
          "uri": "/media/data/projects/pan-ng/PAN-ISN",
          "buildConfigurations": [
              "id": "/media/data/projects/pan-ng/PAN-ISN/build",
              "name": "build",
              "boardId": "pan_ng_module_cpuapp",
              "type": "Zephyr",
              "isChild": false,
              "isStale": true,
              "taskBindings": {
                "build": [],
                "pristineBuild": [],
                "flash": [],
                "eraseAndFlash": []
              "sdk": "/media/data/projects/pan-ng/ZephyrSDK"
      "toolchains": [
          "version": "2.6.1",
          "path": "/media/data/projects/pan-ng/PAN-ISN/../toolchains/2be090971e"
          "version": "2.6.1",
          "path": "/opt/ncs/toolchains/2be090971e"
      "connectedDevices": [],
      "tools": {
        "/media/data/projects/pan-ng/Toolchain/2.6.1/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.5",
        "/opt/SEGGER/JLink/JLinkExe": "7.98e",
        "/usr/local/bin/nrfjprog": "10.21.0",
        "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/bin/cmake": "3.21.0",
        "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/bin/west": "1.2.0",
        "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/bin/python3": "3.9.18",
        "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/bin/ninja": "1.10.2",
        "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/bin/gperf": "3.1",
        "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/bin/dtc": "1.5.0",
        "/media/data/projects/pan-ng/Toolchain/2.6.1/opt/bin/gn": "2132",
        "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/bin/git": "2.37.3",
        "arm-gdbPath": "/media/data/projects/pan-ng/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb",
        "riscv-gdbPath": "/media/data/projects/pan-ng/Toolchain/2.6.1/opt/zephyr-sdk/riscv64-zephyr-elf/bin/riscv64-zephyr-elf-gdb"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.7.9",
          "binPath": "/home/cest/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-linux-x64/platform/nrfutil/bin/nrfutil-device",
          "jlinkInfo": {
            "description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
            "expectedVersion": {
              "version": "JLink_V7.94i",
              "versionFormat": "string"
            "name": "JlinkARM",
            "version": "JLink_V7.98e",
        "nrfutil-toolchain-manager": {
          "version": "0.14.4",
          "binPath": "/home/cest/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-linux-x64/platform/nrfutil/bin/nrfutil-toolchain-manager"
      "environment": {
        "westEnv": {
          "GIT_EXEC_PATH": "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/libexec/git-core",
          "HOME": "/home/cest",
          "PATH": "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/bin:/media/data/projects/pan-ng/Toolchain/2.6.1/usr/bin:/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/bin:/media/data/projects/pan-ng/Toolchain/2.6.1/opt/bin:/media/data/projects/pan-ng/Toolchain/2.6.1/opt/nanopb/generator-bin:/media/data/projects/pan-ng/Toolchain/2.6.1/opt/zephyr-sdk/aarch64-zephyr-elf/bin:/media/data/projects/pan-ng/Toolchain/2.6.1/opt/zephyr-sdk/x86_64-zephyr-elf/bin:/media/data/projects/pan-ng/Toolchain/2.6.1/opt/zephyr-sdk/arm-zephyr-eabi/bin:/media/data/projects/pan-ng/Toolchain/2.6.1/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/home/cest/bin:/home/cest/.local/bin:/home/cest/.nvm/versions/node/v20.17.0/bin:/home/cest/bin:/home/cest/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/usr/local/bin:/usr/local/cuda/bin:/home/cest/.cargo/bin:/media/data/projects/fzf/bin:/home/cest/bin:/home/cest/.local/bin:/home/cest/.nvm/versions/node/v20.17.0/bin:/home/cest/bin:/home/cest/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/usr/local/bin:/usr/local/cuda/bin:/home/cest/.cargo/bin:/media/data/projects/fzf/bin",
          "ZEPHYR_BASE": "/media/data/projects/pan-ng/ZephyrSDK/zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "/media/data/projects/pan-ng/Toolchain/2.6.1/opt/zephyr-sdk",
          "PYTHONPATH": "/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/lib/python3.9:/media/data/projects/pan-ng/Toolchain/2.6.1/usr/local/lib/python3.9/site-packages",
          "USER": "cest"
        "inherited": {
          "ELECTRON_RUN_AS_NODE": "1",
          "PATH": "/home/cest/bin:/home/cest/.local/bin:/home/cest/.nvm/versions/node/v20.17.0/bin:/home/cest/bin:/home/cest/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/usr/local/bin:/usr/local/cuda/bin:/home/cest/.cargo/bin:/media/data/projects/fzf/bin",
          "USER": "cest"
      "terminal": {
        "defaultProfile": null
      "config": {
          "topdir": "",
          "toolchain": {
            "path": ""
          "ozonePath": "",
          "applications": [
            "${workspaceFolder}"
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
            "${workspaceFolder}/ruag-zephyr-sdk"
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": false
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": null,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": "${workspaceFolder}/.."
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask",
          "terminalProfile": {
            "shell": null
          "terminalMode": "character"
        "marus25.cortex-debug": {
          "variableUseNaturalFormat": true,
          "liveWatchRefreshRate": "300",
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "dbgServerLogfile": null
      "extensions": {
        "internal": {
            "version": "2025.1.127",
            "path": "/home/cest/.vscode/extensions/nordic-semiconductor.nrf-connect-2025.1.127-linux-x64",
            "isActive": true
            "version": "2024.9.14",
            "path": "/home/cest/.vscode/extensions/nordic-semiconductor.nrf-terminal-2024.9.14",
            "isActive": true
            "version": "2024.12.15",
            "path": "/home/cest/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2024.12.15",
            "isActive": true
            "version": "2024.12.13",
            "path": "/home/cest/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2024.12.13",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.12.1",
          "ms-vscode.cpptools": "1.23.6",
          "ms-vscode.js-debug": "1.97.1",
          "augustocdias.tasks-shell-input": "1.17.0",
          "bierner.markdown-mermaid": "1.27.0",
          "cschlosser.doxdocgen": "1.4.0",
          "foxundermoon.shell-format": "7.2.5",
          "gsppvo.vscode-commandbar": "0.3.1",
          "HarryHopkinson.vs-code-runner": "2.2.5",
          "keroc.hex-fmt": "1.0.0",
          "mcu-debug.debug-tracker-vscode": "0.0.15",
          "mcu-debug.memory-view": "0.0.25",
          "mcu-debug.peripheral-viewer": "1.4.6",
          "mcu-debug.rtos-views": "0.0.7",
          "mhutchie.git-graph": "1.30.0",
          "ms-azuretools.vscode-docker": "1.29.4",
          "ms-python.debugpy": "2025.4.1",
          "ms-python.isort": "2023.10.1",
          "ms-python.python": "2025.2.0",
          "ms-python.vscode-pylance": "2025.3.2",
          "ms-vscode-remote.remote-ssh": "0.118.0",
          "ms-vscode-remote.remote-ssh-edit": "0.87.0",
          "ms-vscode.cpptools-extension-pack": "1.3.1",
          "ms-vscode.remote-explorer": "0.4.3",
          "vscodevim.vim": "1.29.0"
  • Hi Thilo,
    Thanks for sharing the support information. Unfortunately, we haven't been able to reproduce the issue on our end. Do you have a minimal project that we could use to replicate the problem?
