Regarding the Issue of Frequency Modification for nRF54L15
Hi!
    I'm currently attempting to develop software using the nRF54L15 and NCS v2.9.0 (previously, I used the nRF52840 and NCS v2.9.0). Both development processes are carried out in the VS Code environment.
    However, I've noticed abnormal issues during BLE Mesh debugging. The specific manifestations are as follows:
  1. In the nRF Connect plugin, the nRF54L15 - DK development board often cannot be erased. When I click the "erase board" button, an error occurs. At this time, the chip seems to be in a locked state, and I have to use the "Erase all" function in the "Programmer" software to fix it.
  2. Every time I click the "Debug" button in the nRF Connect plugin, it takes a long time (more than 10 seconds) to enter the debugging interface. Moreover, debugging fails and cannot proceed, which is manifested as follows:
    (1) In VS Code, except for the "Stop" and "Pause" buttons, other debugging buttons are grayed out and ineffective (I think the debugging is already running at this time). After clicking the "Pause" button and then clicking the "Restart" button, subsequent debugging will most likely fail.
    (2) In OZone, when clicking the "Download & Reset Program" button, it will most likely prompt "UsageFault", and only in a few cases can it jump to the debugging interface.
    However, the nRF52840 and nRF52833 development boards work normally. My supplier told me that the reason is "since Bluetooth is used, debugging will disrupt the timing, which in turn leads to hardware failures." But this cannot explain the fact that the same project can be debugged on the nRF52840.
    So I suspect that the debugging failure is caused by the nRF54L15's CPU running too fast (because its default frequency is 128MHz). I want to reduce its frequency to 64MHz, the same as that of the nRF52840. However, I can't find the macro definition (similar to the CONFIG_xxx macro definition) to modify the frequency. But the datasheet shows that the nRF54L15 can be selected between 128MHz and 64MHz. So how can I switch to the 64MHz frequency?
  • I find it strange that this is something it happens to care about now, just for the nRF54L, though does using a different path help for you?
    Elfving
    I'm very sorry, but I don't quite understand what you mean. However, the issue I'm currently concerned about is still "How to debug nRF54L15 using Ozone?" Moreover, the error warnings in my Ozone logs are the same as what you've encountered. They all show the message "Invalid escaped character '\n' found in parameter 1 at position 24".
    Are you saying that fixing this error can solve the problem? But it seems that I can't find a way to fix it for now.
    Listen
  • Hi again, and thanks for waiting during the Easter holidays,
    Is there any update on this issue from your side?
    So there seems to be two issues here, Ozone blaming the path, and VSC debugging being slow. I can reproduce the former, not the latter. The relevant R&D team have also not seen anything about the latter problem before. It could be that it stems from you getting the source code from a vendor-packaged source, like you mentioned. The relevant R&D team suggests that experimenting with "west debug" from CLI might be a way forward.
    Though if you are mainly interested in Ozone, I guess we can just focus on that part, since I can also reproduce that on my side.
    It did seem that way, though I find that when I try on my side it blames something else in my path.
    Elfving
  • Hi
    Yes! Do you have a way to solve the problem of "Invalid escaped character '\n' found in parameter 1 at position 24"?
    Listen
  • Sorry about the wait.
    I do not think it is related to the path anymore, that is just a symptom of the problem. This is reproducible on my side, and with some of my coworkers, but not all for some reason.
    And I am not certain yet why, though I think it could be related to the version of the Dk being used. What version are you using? It should say on the sticker on the top. Eg. v0.8.2.
    Elfving
