nRF5340_audio not able to bond with android
I'm trying to get nrf5340_audio example running on nrf5340 audio dk.
I'm able to build the code and run it however i'm unable to bond with my mobile phone with android 15
I'm using nrf connect sdk version 2.9.1
Using below command to build the application
west build -b nrf5340_audio_dk/nrf5340/cpuapp --pristine -DCONFIG_AUDIO_DEV=1
Attaching logs below
** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
*** Using Zephyr OS v3.7.99-ca954a6216c9 ***
HL [00:00:00.268,737] <inf> board_version: Compatible board/HW version found: 10
HL [00:00:00.301,391] <inf> fw_info:
nRF5340 Audio nRF5340 Audio DK cpuapp
NCS base version: 2.9.1
Cmake run : Thu Mar 20 16:55:36 2025
HL [00:00:00.301,391] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.301,391] <inf> fw_info: HEADSET left device
HL [00:00:00.368,865] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 66
HL [00:00:00.369,079] <inf> bt_mgmt: Local identity addr: F8:BE:A1:CD:EE:E6 (ra)
HL [00:00:00.399,505] <inf> bt_mgmt_scan: Local addr: F8:BE:A1:CD:EE:E6 (randomd
HL [00:00:00.399,505] <inf> bt_mgmt_scan: Scanning successfully started
*** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
HL [00:00:00.376,617] <inf> board_version: Compatible board/HW version found: 10
HL [00:00:00.409,301] <inf> fw_info:
Cmake run : Thu Mar 20 18:27:28 2025
HL [00:00:00.409,301] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.409,301] <inf> fw_info: HEADSET left device
HL [00:00:00.482,971] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 66
HL [00:00:00.483,184] <inf> bt_mgmt: Local identity addr: CB:BB:A6:23:7B:20 (ra)
HL [00:00:00.512,084] <wrn> unicast_server: CSIP using the default SIRK, must bn
HL [00:00:00.515,838] <inf> bt_mgmt_adv: Local addr: 5F:85:78:D3:E0:D9 (random)
HL [00:00:00.516,357] <inf> bt_mgmt_adv: Advertising successfully started
HL [00:00:38.042,419] <inf> bt_mgmt: Connected: 46:E7:86:BF:E5:1D (random)
HL [00:00:38.042,449] <inf> main: Connection event. Num connections: 1
HL [00:01:21.386,779] <inf> bt_mgmt: Disconnected: 46:E7:86:BF:E5:1D (random),
HL [00:01:21.386,810] <inf> main: Disconnection event. Num connections: 0
HL [00:01:21.386,810] <wrn> bt_content_ctrl_media: Unable to look up conn point3
HL [00:01:21.387,695] <inf> bt_mgmt_adv: Local addr: 5F:85:78:D3:E0:D9 (random)
HL [00:01:21.388,214] <inf> bt_mgmt_adv: Advertising successfully started
HL [00:01:28.542,236] <inf> bt_mgmt: Connected: 46:E7:86:BF:E5:1D (random)
HL [00:01:28.542,266] <inf> main: Connection event. Num connections: 1
HL [00:01:30.927,185] <inf> main: Security changed
HL [00:01:33.207,153] <inf> bt_content_ctrl_media: Discovery of MCS finished
HL [00:02:12.233,978] <err> bt_content_ctrl_media: Invalid state: 0
HL [00:02:12.234,008] <wrn> bt_content_ctrl: Failed to change the streaming stae
HL [00:02:12.234,008] <wrn> main: Could not start: -140
HL [00:02:14.056,488] <err> bt_content_ctrl_media: Invalid state: 0
HL [00:02:14.056,488] <wrn> bt_content_ctrl: Failed to change the streaming stae
HL [00:02:14.056,488] <wrn> main: Could not start: -140
HL [00:00:01.838,623] <inf> bt_mgmt: Directed adv timed out with no connection,v
HL [00:00:01.841,979] <inf> bt_mgmt_adv: Local addr: 50:1E:3D:72:F7:D6 (random)
HL [00:00:01.842,498] <inf> bt_mgmt_adv: Advertising successfully started
    Is your previously provided log file from audio-dk taken when connecting audio-dk to the mobile phone?
    Dejan
    Ye previously provided logs are collected when i tried to pair the device with the audio dk
    Regards
    Do you have any other phone (which supports LE Audio) that you could use for testing?
    Dejan
  • Hi Dejan,
    I tried with another mobile which support LE Audio, with that mobile also i got same issue,
    I was able to bond with the device and connect in nRF Connect app but unable to use as headset
    Here are logs form nRF Connect app
    nRF Connect, 2025-03-26
    NRF5340_AUDIO (CB:BB:A6:23:7B:20)
    V	14:40:35.584	Connecting to CB:BB:A6:23:7B:20...
    D	14:40:35.584	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	14:40:35.608	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	14:40:35.608	Connected to CB:BB:A6:23:7B:20
    D	14:40:35.608	wait(1600ms)
    D	14:40:35.615	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    V	14:40:37.210	Discovering services...
    D	14:40:37.210	gatt.discoverServices()
    D	14:40:37.225	[Callback] Services discovered with status: 0
    I	14:40:37.226	Services discovered
    V	14:40:37.238	Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    - Client Supported Features [R W] (0x2B29)
    - Database Hash [R] (0x2B2A)
    Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    Published Audio Capabilities Service (0x1850)
    - Sink PAC [R] (0x2BC9)
    - Sink Audio Locations [R] (0x2BCA)
    - Source PAC [R] (0x2BCB)
    - Source Audio Locations [R] (0x2BCC)
    - Available Audio Contexts [N R] (0x2BCD)
    - Supported Audio Contexts [R] (0x2BCE)
    Audio Stream Control Service (0x184E)
    - ASE Control Point [N W WNR] (0x2BC6)
    - Sink ASE [N R] (0x2BC4)
    Coordinated Set Identification Service (0x1846)
    - Set Identity Resolving Key Characteristic [R] (0x2B84)
    - Size Characteristic [N R] (0x2B85)
    - Lock Characteristic [N R W] (0x2B86)
    - Rank Characteristic [R] (0x2B87)
    Common Audio Service (0x1853)
    Volume Control (0x1844)
    - Volume State [N R] (0x2B7D)
    - Volume Control Point [W] (0x2B7E)
    - Volume Flags [R] (0x2B7F)
    D	14:40:37.239	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	14:40:37.243	gatt.setCharacteristicNotification(00002bcd-0000-1000-8000-00805f9b34fb, true)
    E	14:40:37.247	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10403 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	14:40:37.247	gatt.setCharacteristicNotification(00002bc6-0000-1000-8000-00805f9b34fb, true)
    E	14:40:37.249	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10403 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	14:40:37.249	gatt.setCharacteristicNotification(00002bc4-0000-1000-8000-00805f9b34fb, true)
    E	14:40:37.250	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10403 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	14:40:37.251	gatt.setCharacteristicNotification(00002b85-0000-1000-8000-00805f9b34fb, true)
    E	14:40:37.252	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10403 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	14:40:37.252	gatt.setCharacteristicNotification(00002b86-0000-1000-8000-00805f9b34fb, true)
    E	14:40:37.254	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10403 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	14:40:37.254	gatt.setCharacteristicNotification(00002b7d-0000-1000-8000-00805f9b34fb, true)
    E	14:40:37.256	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10403 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    V	14:40:59.833	Reading characteristic 00002b86-0000-1000-8000-00805f9b34fb
    D	14:40:59.833	gatt.readCharacteristic(00002b86-0000-1000-8000-00805f9b34fb)
    E	14:40:59.836	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10403 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    V	14:41:12.501	Writing request to characteristic 00002b7e-0000-1000-8000-00805f9b34fb
    D	14:41:12.501	gatt.writeCharacteristic(00002b7e-0000-1000-8000-00805f9b34fb, value=0x2B7F)
    E	14:41:12.501	Exception occurred (Writing characteristic failed)
    I	14:42:35.321	PHY updated (TX: LE 2M, RX: LE 1M)
    Which mobile phone did you use?
    Does this phone support LE Audio?
    Dejan
