nRF5340_audio not able to bond with android
I'm trying to get nrf5340_audio example running on nrf5340 audio dk.
I'm able to build the code and run it however i'm unable to bond with my mobile phone with android 15
I'm using nrf connect sdk version 2.9.1
Using below command to build the application
west build -b nrf5340_audio_dk/nrf5340/cpuapp --pristine -DCONFIG_AUDIO_DEV=1
Attaching logs below
** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
*** Using Zephyr OS v3.7.99-ca954a6216c9 ***
HL [00:00:00.268,737] <inf> board_version: Compatible board/HW version found: 10
HL [00:00:00.301,391] <inf> fw_info:
nRF5340 Audio nRF5340 Audio DK cpuapp
NCS base version: 2.9.1
Cmake run : Thu Mar 20 16:55:36 2025
HL [00:00:00.301,391] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.301,391] <inf> fw_info: HEADSET left device
HL [00:00:00.368,865] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 66
HL [00:00:00.369,079] <inf> bt_mgmt: Local identity addr: F8:BE:A1:CD:EE:E6 (ra)
HL [00:00:00.399,505] <inf> bt_mgmt_scan: Local addr: F8:BE:A1:CD:EE:E6 (randomd
HL [00:00:00.399,505] <inf> bt_mgmt_scan: Scanning successfully started
*** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
HL [00:00:00.376,617] <inf> board_version: Compatible board/HW version found: 10
HL [00:00:00.409,301] <inf> fw_info:
Cmake run : Thu Mar 20 18:27:28 2025
HL [00:00:00.409,301] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.409,301] <inf> fw_info: HEADSET left device
HL [00:00:00.482,971] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 66
HL [00:00:00.483,184] <inf> bt_mgmt: Local identity addr: CB:BB:A6:23:7B:20 (ra)
HL [00:00:00.512,084] <wrn> unicast_server: CSIP using the default SIRK, must bn
HL [00:00:00.515,838] <inf> bt_mgmt_adv: Local addr: 5F:85:78:D3:E0:D9 (random)
HL [00:00:00.516,357] <inf> bt_mgmt_adv: Advertising successfully started
HL [00:00:38.042,419] <inf> bt_mgmt: Connected: 46:E7:86:BF:E5:1D (random)
HL [00:00:38.042,449] <inf> main: Connection event. Num connections: 1
HL [00:01:21.386,779] <inf> bt_mgmt: Disconnected: 46:E7:86:BF:E5:1D (random),
HL [00:01:21.386,810] <inf> main: Disconnection event. Num connections: 0
HL [00:01:21.386,810] <wrn> bt_content_ctrl_media: Unable to look up conn point3
HL [00:01:21.387,695] <inf> bt_mgmt_adv: Local addr: 5F:85:78:D3:E0:D9 (random)
HL [00:01:21.388,214] <inf> bt_mgmt_adv: Advertising successfully started
HL [00:01:28.542,236] <inf> bt_mgmt: Connected: 46:E7:86:BF:E5:1D (random)
HL [00:01:28.542,266] <inf> main: Connection event. Num connections: 1
HL [00:01:30.927,185] <inf> main: Security changed
HL [00:01:33.207,153] <inf> bt_content_ctrl_media: Discovery of MCS finished
HL [00:02:12.233,978] <err> bt_content_ctrl_media: Invalid state: 0
HL [00:02:12.234,008] <wrn> bt_content_ctrl: Failed to change the streaming stae
HL [00:02:12.234,008] <wrn> main: Could not start: -140
HL [00:02:14.056,488] <err> bt_content_ctrl_media: Invalid state: 0
HL [00:02:14.056,488] <wrn> bt_content_ctrl: Failed to change the streaming stae
HL [00:02:14.056,488] <wrn> main: Could not start: -140
HL [00:00:01.838,623] <inf> bt_mgmt: Directed adv timed out with no connection,v
HL [00:00:01.841,979] <inf> bt_mgmt_adv: Local addr: 50:1E:3D:72:F7:D6 (random)
HL [00:00:01.842,498] <inf> bt_mgmt_adv: Advertising successfully started
  • Hi Dejan,
    The specifications say it has Bluetooth 5.4 and supports SBC/AAC/aptX
    HD/aptX/LDAC/LHDC
    Does your phone have the latest updates?
    You can try to clear bonds on the audio-dk (by holding button 5 while resetting), forget the device on the phone and toggle Bluetooth.
    It is unexpected that there is early problem when headset connects, disconnects and connects again. It could be that the phone is not fully ready which causes connect/disconnect loop. You could try to add following config to your project configuration file
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DBG=y
    CONFIG_UNICAST_SERVER_LOG_LEVEL_DBG=y
    and provide new log. Furthermore, if you have sniffer, you could try to capture sniffer log which could provide additional information.
    Dejan
    I built the application by adding the flags you mentioned, also cleared the bonds.
    After this I'm able to pair with the device and as well connect to it using nRF Connect app
    However i don't see it being connected as headphone on my mobile
    Logs from device:
    HL [00:00:00.268,890] <inf> board_version: Compatible board/HW version found: 10
    HL [00:00:00.301,544] <inf> fw_info:
             Cmake run : Mon Mar 24 15:18:35 2025
    HL [00:00:00.301,544] <inf> fw_info: ------- DEBUG BUILD -------
    HL [00:00:00.301,574] <inf> fw_info: HEADSET left device
    HL [00:00:00.375,427] <inf> bt_mgmt: Clearing all bonds
    HL [00:00:00.378,601] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 66
    HL [00:00:00.378,814] <inf> bt_mgmt: Local identity addr: CB:BB:A6:23:7B:20 (ra)
    HL [00:00:00.407,653] <wrn> unicast_server: CSIP using the default SIRK, must bn
    HL [00:00:00.411,376] <inf> bt_mgmt_adv: Local addr: 7E:13:03:A1:A0:D7 (random)
    HL [00:00:00.411,865] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:00:05.200,042] <inf> bt_vol_rend: Volume = 195, mute state = 1
    HL [00:00:24.455,413] <inf> bt_mgmt: Connected: 40:6B:55:BA:2A:C0 (random)
    HL [00:00:24.455,444] <inf> main: Connection event. Num connections: 1
    HL [00:00:55.737,365] <inf> bt_mgmt: Disconnected: 40:6B:55:BA:2A:C0 (random),
    HL [00:00:55.737,396] <inf> main: Disconnection event. Num connections: 0
    HL [00:00:55.737,426] <wrn> bt_content_ctrl_media: Unable to look up conn point3
    HL [00:00:55.738,311] <inf> bt_mgmt_adv: Local addr: 7E:13:03:A1:A0:D7 (random)
    HL [00:00:55.738,830] <inf> bt_mgmt_adv: Advertising successfully started
    HL [00:01:07.733,032] <inf> bt_mgmt: Connected: 40:6B:55:BA:2A:C0 (random)
    HL [00:01:07.733,062] <inf> main: Connection event. Num connections: 1
    HL [00:01:11.248,046] <inf> main: Security changed
    HL [00:01:13.617,889] <inf> bt_content_ctrl_media: Discovery of MCS finished
    Logs from nRF Connect:
    nRF Connect, 2025-03-24
    NRF5340_AUDIO (7E:13:03:A1:A0:D7)
    V	15:37:13.412	Connecting to 7E:13:03:A1:A0:D7...
    D	15:37:13.412	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	15:37:13.435	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	15:37:13.435	Connected to 7E:13:03:A1:A0:D7
    D	15:37:13.435	wait(1600ms)
    V	15:37:15.037	Discovering services...
    D	15:37:15.037	gatt.discoverServices()
    D	15:37:15.050	[Callback] Services discovered with status: 0
    I	15:37:15.050	Services discovered
    V	15:37:15.065	Generic Attribute (0x1801)
    Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    Client Supported Features [R W] (0x2B29)
    Database Hash [R] (0x2B2A)
    Generic Access (0x1800)
    Device Name [R W] (0x2A00)
    Appearance [R] (0x2A01)
    Published Audio Capabilities Service (0x1850)
    Sink PAC [R] (0x2BC9)
    Sink Audio Locations [R] (0x2BCA)
    Source PAC [R] (0x2BCB)
    Source Audio Locations [R] (0x2BCC)
    Available Audio Contexts [N R] (0x2BCD)
    Supported Audio Contexts [R] (0x2BCE)
    Audio Stream Control Service (0x184E)
    ASE Control Point [N W WNR] (0x2BC6)
    Sink ASE [N R] (0x2BC4)
    Coordinated Set Identification Service (0x1846)
    Set Identity Resolving Key Characteristic [R] (0x2B84)
    Size Characteristic [N R] (0x2B85)
    Lock Characteristic [N R W] (0x2B86)
    Rank Characteristic [R] (0x2B87)
    Common Audio Service (0x1853)
    Volume Control (0x1844)
    Volume State [N R] (0x2B7D)
    Volume Control Point [W] (0x2B7E)
    Volume Flags [R] (0x2B7F)
    D	15:37:15.065	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	15:37:15.069	gatt.setCharacteristicNotification(00002bcd-0000-1000-8000-00805f9b34fb, true)
    E	15:37:15.072	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10132 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	15:37:15.073	gatt.setCharacteristicNotification(00002bc6-0000-1000-8000-00805f9b34fb, true)
    E	15:37:15.076	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10132 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	15:37:15.077	gatt.setCharacteristicNotification(00002bc4-0000-1000-8000-00805f9b34fb, true)
    E	15:37:15.080	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10132 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	15:37:15.080	gatt.setCharacteristicNotification(00002b85-0000-1000-8000-00805f9b34fb, true)
    E	15:37:15.082	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10132 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	15:37:15.082	gatt.setCharacteristicNotification(00002b86-0000-1000-8000-00805f9b34fb, true)
    E	15:37:15.084	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10132 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    D	15:37:15.084	gatt.setCharacteristicNotification(00002b7d-0000-1000-8000-00805f9b34fb, true)
    E	15:37:15.086	Exception occurred (Need BLUETOOTH PRIVILEGED permission: Neither user 10132 nor current process has android.permission.BLUETOOTH_PRIVILEGED.)
    I	15:37:22.393	PHY updated (TX: LE 2M, RX: LE 1M)
    In the nRF Connect application, you could try to press on "Device Information". You should then be able to see (under Bluetooth Audio) if the phone supports LE Audio. Can you check this?
    Dejan
    It shows it support LE audio, attaching screenshot
    Regards
