Sleep does not work with BLE advertise
nRF52832, SDK 17.1.0 with Softdevice S132.
Softdevice sleep does not work when advertising. Application flow is to advertise one packet, then go to sleep for X seconds. Sleep part waits for a flag from "BLE_GAP_EVT_ADV_SET_TERMINATED" event.
If "sd_app_evt_wait" is replaced with "__WFI" when sleep works but BLE does not advertise anymore(even BLE_GAP_EVT_ADV_SET_TERMINATED is received).
Any idea how to put device to sleep?
This code works
	//BLE::advertise(&data, sizeof(data));
	while (1)
		/*if (System::isWoken() == Return_t::OK)
		//if (BLE::isAdvertiseDone() == Return_t::OK)
		if (1)
			System::startWakeupTimer();
			System::sleep();
		// Feed the dog
		System::feedWatchdog();
This code does not work(consumption around ~3.5mA)
	while (1)
		//if (1)
			System::sleep();
		// Feed the dog
sleep function:
	void sleep(void)
		__set_FPSCR(__get_FPSCR()  & ~(0x0000009F));
		(void) __get_FPSCR();
		sd_nvic_ClearPendingIRQ(FPU_IRQn);
		sd_power_dcdc_mode_set(NRF_POWER_DCDC_DISABLE);
		_PRINT("Sleep\n");
		sd_app_evt_wait();
		sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
Only RTC2 IRQ is enabled. FPU is disabled(soft FPU is used).
System init
	Return_t init(void)
		// Test crystals only in debug build
		#ifdef DEBUG
		_PRINT("Wait for HFXO\n");
		while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
		_PRINT("HFXO started\n");
		_PRINT("Wait for LFXO\n");
		NRF_CLOCK->TASKS_LFCLKSTART = 1;
		while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
		_PRINT("LFXO started\n");
		#endif // DEBUG
		// Configure power
		NRF_POWER->POFCON = 0;
		NRF_POWER->DCDCEN = 1;
		// Init watchdog
		NRF_WDT->CRV = (AppConfig::wdtTimeout * 32768) - 1;
		#ifdef DEBUG
		NRF_WDT->CONFIG = 1;
		#else
		NRF_WDT->CONFIG = 9;
		#endif // DEBUG
		NRF_WDT->TASKS_START = 1;
		// Enable RTC interrupt
		ret_code_t ret = sd_nvic_SetPriority(RTC2_IRQn, 2);
		if (ret != NRF_SUCCESS)
			APP_ERROR_CHECK(ret);
			return Return_t::NOK;
		ret = sd_nvic_EnableIRQ(RTC2_IRQn);
		// Enable compare0 interrupt
		NRF_RTC2->INTENSET = (1 << 16);
		// Set counter resolution of 125ms
		NRF_RTC2->PRESCALER = 4095;
		startWakeupTimer();
		return Return_t::OK;
	void startWakeupTimer(void)
		NRF_RTC2->TASKS_CLEAR = 1;
		NRF_RTC2->CC[0] = (AppConfig::measurePeriod * 1000) / 125;
		NRF_RTC2->TASKS_START = 1;
		_PRINT_INFO("Wakeup timer started\n");
EDIT: BLE init functions
	Return_t init(void)
		ret_code_t ret;
		ret = nrf_sdh_enable_request();
		uint32_t ramStart = 0;
		ret = nrf_sdh_ble_default_cfg_set(AppConfig::bleTag, &ramStart);
		// Enable BLE stack.
		ret = nrf_sdh_ble_enable(&ramStart);
		NRF_SDH_BLE_OBSERVER(m_ble_observer, 3, onBLEEvent, NULL);
		// Init GAP profile
		if (gapInit() != Return_t::OK)
		// Get MAC address
		ble_gap_addr_t addr;
		ret = sd_ble_gap_addr_get(&addr);
		_PRINTF_INFO("MAC: %02X%02X%02X%02X%02X%02X\n", addr.addr[5], addr.addr[4], addr.addr[3], addr.addr[2], addr.addr[1], addr.addr[0]);
		// Request HFXO
		ret = sd_clock_hfclk_request();
		// Init advertise
		return advInit();
	 * @brief Advertise data.
	 * @return \c Return_t::NOK on fail.
	 * @return \c Return_t::OK on success.
	Return_t advertise(const void* data, const uint8_t len)
		// Set custom data
		ble_advdata_manuf_data_t mnfData;
		mnfData.company_identifier = AppConfig::bleMnfID;
		mnfData.data.p_data = (uint8_t*)data;
		mnfData.data.size = len;
		// Set advertise data
		ble_advdata_t advData;
		memset(&advData, 0, sizeof(advData));
		advData.name_type = BLE_ADVDATA_FULL_NAME;
		advData.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
		advData.p_manuf_specific_data = &mnfData;
		advData.p_tx_power_level = &txPower;
		// Encode advertise data
		ret_code_t ret = ble_advdata_encode(&advData, gapAdvData.adv_data.p_data, &gapAdvData.adv_data.len);
		// Advertise data
		advDone = 0;
		ret = sd_ble_gap_adv_start(advHandle, AppConfig::bleTag);
 * @brief Init BLE GAP profile.
static Return_t gapInit(void)
	ble_gap_conn_sec_mode_t securtiyMode;
	BLE_GAP_CONN_SEC_MODE_SET_OPEN(&securtiyMode);
	ret_code_t ret = sd_ble_gap_device_name_set(&securtiyMode, (const uint8_t*)AppConfig::deviceName, __CONST_STR_LEN(AppConfig::deviceName));
 * @brief Init BLE advertise.
static Return_t advInit(void)
	// Set advertise config
	advConfig.primary_phy = BLE_GAP_PHY_AUTO;
	advConfig.duration = 0;
	advConfig.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
	advConfig.max_adv_evts	= AppConfig::advCount;
	advConfig.p_peer_addr = nullptr;
	advConfig.filter_policy = BLE_GAP_ADV_FP_ANY;
	advConfig.interval = 32; // Does not matter since max advertise event is set to 1
	ret_code_t ret = sd_ble_gap_adv_set_configure(&advHandle, &gapAdvData, &advConfig);
	// Set TX power
	ret = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, advHandle, txPower);
    When using a SoftDevice you should wait by calling sd_app_evt_wait(), and not WFI (or WFE for that matter) directly. Advertising in itself should not cause any probem, should not contribute to current consumption in between advertising events. Can you show the implementation of your BLE::advertise(), as it is including that that increases the current consumption?
    BLE functions are added to main post.
    Seems like device does not go to sleep since I can connect to it via SWD(J-Link). I guess some BLE event prevents sleep.
    I tried __WFI just for test otherwise SD sleep function is used.
    I do not see anyting problematic with the advertising related code. However, I did not understand the explanation about how the device does not seem to be sleeping as you can connect to it via SWD. Can you explain what you mean by the device not sleeping? And how you have tested and verified? Have you checked the current consumptoin or do you test in some other way?
    (If testing current consumption, note that an active debug session will cause a high current consumption due to clocks and reculators being kept on, so you sould check without debugging).
  • I do tests like this:
    - Make some changes in code.
    - Flash new code to the device via J-Link
    - Unplug the device from J-Link
    - Connect the device to PPK2 (set to 3V)
    - Turn on PPK2 power supply
    - Measure power consumption with 100kHz
    When advertise function is called, sleep does not work and device uses ~3.5mA. If advertise function is not called(but BLE::init is called before while(1)) then sleep works and power consumption is around 170uA(ignore that high number, pressure sensor and I2C bus is not implemented yet).
    I did not try to disable Softdevice before going to sleep. I'll try that since it seems like it's the only option for sleep
    I see. There is no need to disable the SoftDevice in order to sleep, but you must call sd_app_evt_wait() in you rmain loop. However, I see that you only call your sleep() function when BLE::isAdvertiseDone(). This looks like a mistake. You should always call sd_app_evt_wait() from you rmain loop.
