Sleep does not work with BLE advertise
nRF52832, SDK 17.1.0 with Softdevice S132.
Softdevice sleep does not work when advertising. Application flow is to advertise one packet, then go to sleep for X seconds. Sleep part waits for a flag from "BLE_GAP_EVT_ADV_SET_TERMINATED" event.
If "sd_app_evt_wait" is replaced with "__WFI" when sleep works but BLE does not advertise anymore(even BLE_GAP_EVT_ADV_SET_TERMINATED is received).
Any idea how to put device to sleep?
This code works
	//BLE::advertise(&data, sizeof(data));
	while (1)
		/*if (System::isWoken() == Return_t::OK)
		//if (BLE::isAdvertiseDone() == Return_t::OK)
		if (1)
			System::startWakeupTimer();
			System::sleep();
		// Feed the dog
		System::feedWatchdog();
This code does not work(consumption around ~3.5mA)
	while (1)
		//if (1)
			System::sleep();
		// Feed the dog
sleep function:
	void sleep(void)
		__set_FPSCR(__get_FPSCR()  & ~(0x0000009F));
		(void) __get_FPSCR();
		sd_nvic_ClearPendingIRQ(FPU_IRQn);
		sd_power_dcdc_mode_set(NRF_POWER_DCDC_DISABLE);
		_PRINT("Sleep\n");
		sd_app_evt_wait();
		sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
Only RTC2 IRQ is enabled. FPU is disabled(soft FPU is used).
System init
	Return_t init(void)
		// Test crystals only in debug build
		#ifdef DEBUG
		_PRINT("Wait for HFXO\n");
		while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
		_PRINT("HFXO started\n");
		_PRINT("Wait for LFXO\n");
		NRF_CLOCK->TASKS_LFCLKSTART = 1;
		while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
		_PRINT("LFXO started\n");
		#endif // DEBUG
		// Configure power
		NRF_POWER->POFCON = 0;
		NRF_POWER->DCDCEN = 1;
		// Init watchdog
		NRF_WDT->CRV = (AppConfig::wdtTimeout * 32768) - 1;
		#ifdef DEBUG
		NRF_WDT->CONFIG = 1;
		#else
		NRF_WDT->CONFIG = 9;
		#endif // DEBUG
		NRF_WDT->TASKS_START = 1;
		// Enable RTC interrupt
		ret_code_t ret = sd_nvic_SetPriority(RTC2_IRQn, 2);
		if (ret != NRF_SUCCESS)
			APP_ERROR_CHECK(ret);
			return Return_t::NOK;
		ret = sd_nvic_EnableIRQ(RTC2_IRQn);
		// Enable compare0 interrupt
		NRF_RTC2->INTENSET = (1 << 16);
		// Set counter resolution of 125ms
		NRF_RTC2->PRESCALER = 4095;
		startWakeupTimer();
		return Return_t::OK;
	void startWakeupTimer(void)
		NRF_RTC2->TASKS_CLEAR = 1;
		NRF_RTC2->CC[0] = (AppConfig::measurePeriod * 1000) / 125;
		NRF_RTC2->TASKS_START = 1;
		_PRINT_INFO("Wakeup timer started\n");
EDIT: BLE init functions
	Return_t init(void)
		ret_code_t ret;
		ret = nrf_sdh_enable_request();
		uint32_t ramStart = 0;
		ret = nrf_sdh_ble_default_cfg_set(AppConfig::bleTag, &ramStart);
		// Enable BLE stack.
		ret = nrf_sdh_ble_enable(&ramStart);
		NRF_SDH_BLE_OBSERVER(m_ble_observer, 3, onBLEEvent, NULL);
		// Init GAP profile
		if (gapInit() != Return_t::OK)
		// Get MAC address
		ble_gap_addr_t addr;
		ret = sd_ble_gap_addr_get(&addr);
		_PRINTF_INFO("MAC: %02X%02X%02X%02X%02X%02X\n", addr.addr[5], addr.addr[4], addr.addr[3], addr.addr[2], addr.addr[1], addr.addr[0]);
		// Request HFXO
		ret = sd_clock_hfclk_request();
		// Init advertise
		return advInit();
	 * @brief Advertise data.
	 * @return \c Return_t::NOK on fail.
	 * @return \c Return_t::OK on success.
	Return_t advertise(const void* data, const uint8_t len)
		// Set custom data
		ble_advdata_manuf_data_t mnfData;
		mnfData.company_identifier = AppConfig::bleMnfID;
		mnfData.data.p_data = (uint8_t*)data;
		mnfData.data.size = len;
		// Set advertise data
		ble_advdata_t advData;
		memset(&advData, 0, sizeof(advData));
		advData.name_type = BLE_ADVDATA_FULL_NAME;
		advData.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
		advData.p_manuf_specific_data = &mnfData;
		advData.p_tx_power_level = &txPower;
		// Encode advertise data
		ret_code_t ret = ble_advdata_encode(&advData, gapAdvData.adv_data.p_data, &gapAdvData.adv_data.len);
		// Advertise data
		advDone = 0;
		ret = sd_ble_gap_adv_start(advHandle, AppConfig::bleTag);
 * @brief Init BLE GAP profile.
static Return_t gapInit(void)
	ble_gap_conn_sec_mode_t securtiyMode;
	BLE_GAP_CONN_SEC_MODE_SET_OPEN(&securtiyMode);
	ret_code_t ret = sd_ble_gap_device_name_set(&securtiyMode, (const uint8_t*)AppConfig::deviceName, __CONST_STR_LEN(AppConfig::deviceName));
 * @brief Init BLE advertise.
static Return_t advInit(void)
	// Set advertise config
	advConfig.primary_phy = BLE_GAP_PHY_AUTO;
	advConfig.duration = 0;
	advConfig.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
	advConfig.max_adv_evts	= AppConfig::advCount;
	advConfig.p_peer_addr = nullptr;
	advConfig.filter_policy = BLE_GAP_ADV_FP_ANY;
	advConfig.interval = 32; // Does not matter since max advertise event is set to 1
	ret_code_t ret = sd_ble_gap_adv_set_configure(&advHandle, &gapAdvData, &advConfig);
	// Set TX power
	ret = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, advHandle, txPower);
