Hardware-based downgrade protection in nRF5340
Hello.
This ticket was derived from another ticket.
I have a few questions about hardware-based downgrade protection.
  • About the Downgrade Protection of the Network Core
    Even with Downgrade Protection enabled, the Network Core is still downgradeable.
    However, version mismatches between the App Core and the Network Core should be avoided.
    If you have any ideas on how to resolve this, please let me know.
  • About the monotonic counter
    Is there a way to retrieve the current value?
    I am assuming it will be displayed on a PC serial terminal or a smartphone app.
  • About Image Swap
    It seems that when the update count reaches the value of SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS, the Image Swap of the App Core is performed every time the software is rebooted.
    Is this the expected behavior?
The logs during the update and reboot are as follows:
monotonic counter < SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS
Update
[00:00:18.749,969] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
[00:00:19.052,307] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:00:41.610,382] <inf> mcuboot_util: Image index: 1, Swap type: none
*** Booting MCUboot v2.1.0-dev-12e5ee106034 ***
*** Using nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
I: Starting bootloader
I: Image index: 0, Swap type: perm
I: Image index: 1, Swap type: perm
I: Image 0 upgrade secondary slot -> primary slot
I: Erasing the primary slot
I: Image 0 copying the secondary slot to the primary slot: 0x44784 bytes
D: writing magic; fa_id=4 off=0xebff0 (0xf7ff0)
D: erasing secondary header
D: erasing secondary trailer
I: Image 1 upgrade secondary slot -> primary slot
I: Image 1 copying the secondary slot to the primary slot: 0x2a3c0 bytes
D: writing magic; fa_id=1 off=0x3fff0 (0x3fff0)
I: Bootloader chainload address offset: 0xc000
*** Booting Mesh Light Fixture v2.9.0-d54b9798c66e ***
Reboot
I: Image index: 0, Swap type: none
I: Image index: 1, Swap type: none
monotonic counter = SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS
Update
[00:00:30.237,457] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
[00:00:30.538,299] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:00:53.067,932] <inf> mcuboot_util: Image index: 1, Swap type: none
E: Security counter update failed after image upgrade.
Reboot
Thanks for reading.
a.da
    As a sanity check, could you go through the 19 lines in the device log and tell me if I see the same thing as you
    6: you enter the bootloader and load the image to secondary. It has index 0 and swap type perm. You get an error that states "the new image is not valid", i.e something is detected and it should abort the update here. Nonetheless, it keeps on running and you update the image in the secondary slot to the primary slot in L 12. This is what you mean when you say the protection has failed for the netcore?
    If my understanding matches your observation I'll escalate it as a bug.
    Andreas
  • Another question, what file are you using for the update? A multi-image update implies that you update both app and netcore simultaneous. Is the logs from your update with or without simultaneous update?
    Andreas
  • Hi Andreas,
    Yes, that's correct.
    I understand that lines 7 to 8 indicate an error in the update of the App Core.
    On the other hand, lines 9 to 12 seem to indicate the successful update of the Net Core.
    Therefore, it seems that the protection for the App Core is enabled, while the protection for the Net Core is not.
    However, I do not know the correct log that would be output if both protections are enabled.
    I haven't been able to find an example to reference.
    dfu_application.zip
    It includes "app.signed.bin", "ipc_radio.bin", and "manifest.json".
    a.da
  • Hi a.da,
    While looking around for what could be wrong I found some PRs and suggestiosn
    Use
    PR
    https://github.com/nrfconnect/sdk-nrf/pull/20787
    https://github.com/nrfconnect/sdk-mcuboot/pull/402,
    Together with https://github.com/nrfconnect/sdk-zephyr/pull/2269/files and the configuration (which you already use) added to sysbuild.conf
    # Enable Hardware-based downgrade protection
    SB_CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION=y
    SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS=24
    SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_VALUE=1
    and build with this command:
    west build -p -b nrf5340dk/nrf5340/cpuapp -- -DFILE_SUFFIX=nrf5340_bt -Dhci_ipc_CONFIG_FW_INFO_FIRMWARE_VERSION=2
    -Db0n_CONFIG_PCD_READ_NETCORE_APP_VERSION=y
    Do you use the b0n_CONIIG_PCD_READ_NETCORE_APP_VERSION configuration?
    Can you check if the two PRs are applied?
    Andreas
  • Hi Andreas,
    I have enabled downgrade protection on the SMP Server Sample with PR2269 applied.
    There were no changes in the logs. Net Core was not enabled.
    E: Image in the secondary slot is not valid!
    I: Image 1 copying the secondary slot to the primary slot: 0x25f3c bytes
    I: Bootloader chainload address offset: 0x10000
    I: Jumping to the first image slot
    *** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
    As written here.
    ./sysbuild/b0n.conf
    PR20787 and PR402 were already applied when working on the originating ticket.
    Have you tried the sample?
    What do you want me to confirm?
    a.da
