Hardware-based downgrade protection in nRF5340
Hello.
This ticket was derived from another ticket.
I have a few questions about hardware-based downgrade protection.
  • About the Downgrade Protection of the Network Core
    Even with Downgrade Protection enabled, the Network Core is still downgradeable.
    However, version mismatches between the App Core and the Network Core should be avoided.
    If you have any ideas on how to resolve this, please let me know.
  • About the monotonic counter
    Is there a way to retrieve the current value?
    I am assuming it will be displayed on a PC serial terminal or a smartphone app.
  • About Image Swap
    It seems that when the update count reaches the value of SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS, the Image Swap of the App Core is performed every time the software is rebooted.
    Is this the expected behavior?
The logs during the update and reboot are as follows:
monotonic counter < SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS
Update
[00:00:18.749,969] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
[00:00:19.052,307] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:00:41.610,382] <inf> mcuboot_util: Image index: 1, Swap type: none
*** Booting MCUboot v2.1.0-dev-12e5ee106034 ***
*** Using nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
I: Starting bootloader
I: Image index: 0, Swap type: perm
I: Image index: 1, Swap type: perm
I: Image 0 upgrade secondary slot -> primary slot
I: Erasing the primary slot
I: Image 0 copying the secondary slot to the primary slot: 0x44784 bytes
D: writing magic; fa_id=4 off=0xebff0 (0xf7ff0)
D: erasing secondary header
D: erasing secondary trailer
I: Image 1 upgrade secondary slot -> primary slot
I: Image 1 copying the secondary slot to the primary slot: 0x2a3c0 bytes
D: writing magic; fa_id=1 off=0x3fff0 (0x3fff0)
I: Bootloader chainload address offset: 0xc000
*** Booting Mesh Light Fixture v2.9.0-d54b9798c66e ***
Reboot
I: Image index: 0, Swap type: none
I: Image index: 1, Swap type: none
monotonic counter = SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_SLOTS
Update
[00:00:30.237,457] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
[00:00:30.538,299] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:00:53.067,932] <inf> mcuboot_util: Image index: 1, Swap type: none
E: Security counter update failed after image upgrade.
Reboot
Thanks for reading.
a.da
