[nRF7002 + nRF5340] aws connection failure, error -11
SDK version: nRF Connect SDK v2.8.0
Toolchain version: nRF Connect SDK Toolchain v2.8.0
Development environment: Ubuntu 24.04
Development tool: Visual Studio Code
Development board: we are using our custom overlay board files.
Example refference path:
~/ncs/v2.8.0/nrf/samples/wifi/sta
~/ncs/v2.8.0/nrf/samples/cellular/modem_shell
~/ncs/v2.8.0/nrf/samples/net/aws_iot
We are using our custom .overlay files and .conf files for our project.
Note, We haven't migrated from HMv1 to HMv2 as our overlay files are out of SDK and we are not using sysbuild for building the project.
We just migrated our project from SDK v2.7.0 to v2.8.0 successfully. Main functionality is to make a connection with aws server and publish data.
We can either use WiFi or LTE for internet connection and then make a connection with the AWS. nRF7002 wifi module is used over QSPI interface.
We took all needed configurations from prj.conf files of above mentioned samples into our project and did all migtation related changes, as suggested in the migration guide here.
When we use WiFi as active interface for internet connection, the device gets connected to AP, and also makes a connection with aws server and are able to publish the data to server only once. each time after one publish to aws device hangs, the log stops.
When we use LTE as active interface for internet connection, we get the internet connection, but when we try to make the connection to the AWS, the connection request fails with following error.
mqtt_helper: mqtt_connect, error: -11
Note, all these functionality was working without issue on sdk v2.7.0.
Providing the detailed logs for WiFi under v2.8.0_wifi_logs and for LTE under v2.8.0_lte_logs below.
Please find a project related configs mentioned below and also the memory usage.
# MQTT config v2.8.0
CONFIG_HEAP_MEM_POOL_IGNORE_MIN=y
CONFIG_ZVFS_OPEN_MAX=25
CONFIG_MAIN_STACK_SIZE=6144
# Optimize Wi-Fi stack to save some memory
CONFIG_NRF70_RX_NUM_BUFS=16
CONFIG_WIFI_NRF70_LOG_LEVEL_DBG=y
CONFIG_NRF70_MAX_TX_AGGREGATION=4
CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
CONFIG_NET_BUF_RX_COUNT=8
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_HEAP_MEM_POOL_SIZE=120000
CONFIG_MODEM_CELLULAR_CMUX_MAX_FRAME_SIZE=4096
CONFIG_NET_IPV4=y
CONFIG_NET_IPV6=y
Memory usage :
Memory region         Used Size  Region Size  %age Used
           FLASH:      852544 B       912 KB     91.29%
             RAM:      408760 B         476 KB     83.86%
        IDT_LIST:          0 GB           32 KB      0.00%
v2.8.0_wifi_logs :
uart:~$ --- 93 messages dropped ---
[00:00:00.014,984] <dbg> net_pkt: net_pkt_init: (main): Allocating 16 RX (1088 bytes), 24 TX (1632 bytes), 0 RX data (0 bytes) and 0 TX data (0 bytes) buffers
uart:~$ [00:00:00.015,228] <dbg> net_tcp: net_tcp_init: (main): Workq started. Thread ID: 0x20013950
uart:~$ [00:00:00.015,380] <dbg> net_mgmt: net_mgmt_event_init: (main): Net MGMT initialized: queue of 10 entries, stack size of 5120
uart:~$ [00:00:00.015,411] <dbg> net_if: net_if_init: (main):
uart:~$ [00:00:00.015,563] <dbg> net_if: init_iface: (main): On iface 0x2000f160
uart:~$ [00:00:00.015,747] <dbg> net_if: update_operational_state: (main): iface 1 (0x2000f160), oper state DOWN admin DOWN carrier ON dormant ON
uart:~$ [00:00:00.015,838] <dbg> net_if: init_iface: (main): On iface 0x2000f1f0
uart:~$ [00:00:00.015,869] <dbg> net_mgmt: net_mgmt_add_event_callback: (main): Adding event callback 0x2000f714
uart:~$ [00:00:00.016,082] <dbg> net_if: update_operational_state: (main): iface 2 (0x2000f1f0), oper state DOWN admin DOWN carrier OFF dormant OFF
uart:~$ [00:00:00.016,143] <wrn> net_if: You have 1 IPv6 net_if addresses but 2 network interfaces
uart:~$ [00:00:00.237,243] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.239,776] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.239,959] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.240,203] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.240,295] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.240,386] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.240,478] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.244,171] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.244,354] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.244,598] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.244,689] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.244,781] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.244,842] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.247,039] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.247,192] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.247,467] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.247,558] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.247,619] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.247,711] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.249,908] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.250,061] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.250,305] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.250,396] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.250,488] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.250,579] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.252,899] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.253,051] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.253,479] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.253,601] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.253,692] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.253,784] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.256,774] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.257,324] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.257,629] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.257,720] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.257,781] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.257,873] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.260,681] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 21 sent to RPU
uart:~$ [00:00:00.260,925] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.261,016] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.261,108] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 21 -> status -2
uart:~$ [00:00:00.261,199] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.278,411] <inf> sample_main:
uart:~$ [00:00:24.656,372] <err> sample_pwr_mgnmt: ERROR: Runtime PWR value 0x3f does not match Runtime default 0x1f
uart:~$ [00:00:24.656,372] <dbg> network: iNetworkInit: Initializing AWS work funcs...
uart:~$ [00:00:24.656,494] <dbg> apt_aws: iAwsInit: AWS Work Queue initialized
uart:~$ [00:00:24.656,524] <dbg> apt_aws: iAwsInit: All AWS work funcs initialized
uart:~$ [00:00:24.656,524] <dbg> network: iNetworkInit: Initializing wireless...
uart:~$ [00:00:24.656,646] <inf> apt_net_if_mgr: Registering network management callbacks.
uart:~$ [00:00:24.656,677] <dbg> net_mgmt: net_mgmt_add_event_callback: (main): Adding event callback 0x20019c80
uart:~$ [00:00:24.656,738] <dbg> net_mgmt: net_mgmt_add_event_callback: (main): Adding event callback 0x20019c6c
uart:~$ [00:00:24.656,768] <dbg> net_mgmt: net_mgmt_add_event_callback: (main): Adding event callback 0x20019c58
uart:~$ [00:00:24.657,104] <inf> network: DATE_TIME_NOT_OBTAINED
uart:~$ uart:~$ [00:00:24.714,904] <inf> apt_net_if_mgr: WIFI_INTERFACE is selected as active interface
uart:~$ [00:00:24.714,935] <inf> apt_net_if_mgr: WIFI_IF is present, at index : 1
uart:~$ [00:00:24.714,935] <inf> apt_net_if_mgr: LTE_IF is present, at index : 2
uart:~$ [00:00:24.714,965] <inf> apt_net_if_mgr: ## WiFi interface is available
uart:~$ [00:00:24.714,965] <wrn> apt_net_if_mgr: Active Interface is selected, init and connection will be performed now ...
uart:~$ [00:00:24.714,996] <inf> apt_net_if_mgr: iface init interface event sent !!
uart:~$ [00:00:24.714,996] <dbg> apt_net_if_mgr: net_if_submit_ctrl_event_work: net_if_ctrl_event_work is pending
uart:~$ [00:00:24.715,026] <inf> apt_net_if_mgr: iface connect event sent !!
uart:~$ [00:00:24.715,026] <dbg> network: iNetworkInit: Starting AWS...
uart:~$ [00:00:24.715,240] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
uart:~$ [00:00:24.715,362] <inf> apt_net_if_mgr: net_if_ctrl_event_work_routine started...
uart:~$ [00:00:24.715,393] <wrn> apt_net_if_mgr: Unknown Event : 12
uart:~$ [00:00:24.715,515] <wrn> apt_net_if_mgr: Unknown Event : 12
uart:~$ [00:00:24.715,515] <inf> apt_net_if_mgr: NET_IF_INIT_IFACE_EVENT Received
uart:~$ [00:00:24.715,637] <inf> apt_net_if_mgr: WIFI_IF is present, at index : 1
uart:~$ [00:00:24.715,667] <inf> apt_net_if_mgr: LTE_IF is present, at index : 2
uart:~$ [00:00:24.715,667] <inf> apt_net_if_mgr: ## WiFi nterface is present and selected as active interface ##
uart:~$ [00:00:24.715,667] <inf> apt_net_if_mgr: WiFi interface control assigned
uart:~$ [00:00:24.715,698] <inf> apt_net_if_mgr: NET_IF_CONNECT_EVENT Received
uart:~$ [00:00:24.715,698] <inf> apt_net_if_mgr: Bringing up WiFi Network Interface..
uart:~$ [00:00:24.715,698] <inf> apt_net_if_mgr: WiFi command fired...
uart:~$ [00:00:24.715,728] <inf> apt_net_if_mgr: WiFi Connection Requested
uart:~$ [00:00:26.260,345] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:26.265,258] <dbg> network: iNetworkInit: Data file opened
uart:~$ [00:00:26.270,324] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 0 sent to RPU
uart:~$ [00:00:26.272,399] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:26.272,491] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 257 received from UMAC
uart:~$ [00:00:26.272,674] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 257 processed
uart:~$ [00:00:26.272,766] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:26.272,827] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:26.272,918] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 0 -> status 0
uart:~$ [00:00:26.272,979] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:26.273,315] <dbg> apt_net_if_mgr: wifi_cmd_exec: WiFi iface : 0x2000f160
uart:~$ uart:~$ uart:~$ [00:00:26.632,171] <wrn> sample_main: >> Power management successfully initialized!
uart:~$ [00:00:26.682,250] <inf> sample_main: >> Waiting for AWS to be connected...
uart:~$ [00:00:26.739,807] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:26.739,868] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 289 received from UMAC
uart:~$ [00:00:26.739,898] <dbg> wifi_nrf: reg_change_callbk_fn: reg_change_callbk_fn: Regulatory change event received
uart:~$ [00:00:26.739,929] <dbg> wifi_nrf: reg_change_callbk_fn: reg_change_callbk_fn: Unsolicited regulatory change event
uart:~$ [00:00:26.739,990] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 289 processed
uart:~$ uart:~$ [00:00:30.165,313] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:30.165,405] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 259 received from UMAC
uart:~$ [00:00:30.165,649] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 259 processed
uart:~$ [00:00:30.165,863] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:30.167,022] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 1 sent to RPU
uart:~$ [00:00:30.168,701] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:30.168,762] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 260 received from UMAC
uart:~$ [00:00:30.168,945] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 260 processed
uart:~$ [00:00:30.169,036] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:30.169,097] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 260 received from UMAC
uart:~$ [00:00:30.169,311] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 260 processed
uart:~$ [00:00:30.171,630] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:30.176,849] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 2 sent to RPU
uart:~$ [00:00:30.176,879] <dbg> wifi_nrf: nrf_wifi_wpa_supp_authenticate: nrf_wifi_wpa_supp_authenticate:Authentication request sent successfully
uart:~$ uart:~$ uart:~$ [00:00:30.541,595] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:30.541,656] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:30.541,748] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 2 -> status 0
uart:~$ [00:00:30.541,809] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:30.541,900] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:30.541,961] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 261 received from UMAC
uart:~$ [00:00:30.542,175] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 261 processed
uart:~$ [00:00:30.542,510] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:30.545,532] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 21 sent to RPU
uart:~$ [00:00:30.545,776] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:30.546,142] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:30.546,203] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:30.546,295] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 21 -> status -2
uart:~$ [00:00:30.546,356] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:30.550,262] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 3 sent to RPU
uart:~$ [00:00:30.550,292] <dbg> wifi_nrf: nrf_wifi_wpa_supp_associate: nrf_wifi_wpa_supp_associate: Association request sent successfully
uart:~$ [00:00:30.552,215] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:30.552,276] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:30.552,337] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 3 -> status 0
uart:~$ [00:00:30.552,429] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ uart:~$ uart:~$ --- 130 messages dropped ---
[00:00:31.601,440] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x20056408 length 4
uart:~$ [00:00:31.601,470] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 4
uart:~$ [00:00:31.601,715] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068dec data 0x20049624 length 90
uart:~$ --- 256 messages dropped ---
[00:00:31.601,806] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x200694e8 ref 0 (ethernet_remove_l2_header():615)
uart:~$ [00:00:31.601,898] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [21] pkt 0x20068dec ref 0 frags 0x20069520 (ethernet_send():762)
uart:~$ [00:00:31.601,989] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069520 ref 0 frags (nil) (ethernet_send():762)
uart:~$ --- 158 messages dropped ---
[00:00:31.602,050] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:31.602,142] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068da8, prio 1) network packet iface 1 (0x2000f160)
uart:~$ --- 34 messages dropped ---
[00:00:31.663,269] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x20068898 data 0x2005c14b length 1
uart:~$ --- 4 messages dropped ---
[00:00:31.663,299] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x20068898 data 0x2005c14a length 1
uart:~$ [00:00:31.663,360] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 4
uart:~$ --- 12 messages dropped ---
[00:00:31.663,391] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x20068898 data 0x2005c14b length 1
uart:~$ --- 24 messages dropped ---
[00:00:31.690,673] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20018b54 : 0x5d099
uart:~$ --- 9 messages dropped ---
[00:00:31.701,232] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20019c58 : 0x23a41
uart:~$ [00:00:31.701,293] <dbg> net_mgmt: mgmt_event_work_handler: (net_mgmt): Handling events, forwarding it relevantly
uart:~$ [00:00:31.715,148] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:31.715,606] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x20068898 data 0x200380b8 length 42
uart:~$ [00:00:31.718,719] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:31.736,206] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068e30 data 0x2005630c length 8
uart:~$ [00:00:31.736,816] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068e30 data 0x200491e4 length 70
uart:~$ [00:00:31.737,060] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_buf_map_tx: bounce_buf_addr: 0xc8c64, rpu_addr: 0xb0008c64, buf_le
uart:~$ --- 2 messages dropped ---
[00:00:31.739,196] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 (ethernet_remove_l2_header():615)
uart:~$ [00:00:31.739,288] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068e30 ref 0 frags 0x2006953c (ethernet_send():762)
uart:~$ [00:00:31.739,349] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 frags (nil) (ethernet_send():762)
uart:~$ [00:00:31.739,440] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:31.742,187] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 2 received from UMAC
uart:~$ [00:00:31.747,589] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:31.747,680] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 3 received from UMAC
uart:~$ [00:00:31.747,863] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 126
uart:~$ [00:00:31.747,924] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 126 (requested 126)
uart:~$ [00:00:31.748,016] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:31.748,046] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x20068898 data 0x200379e8 length 126
uart:~$ [00:00:31.748,229] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:00:31.748,291] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068898 data 0x2005531a length 8
uart:~$ [00:00:31.748,321] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 8
uart:~$ [00:00:31.748,443] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 24 RX 15 RDATA 0 TDATA 0
uart:~$ [00:00:31.757,446] <dbg> net_pkt: net_pkt_skip: (net_socket_service): pkt 0x20068898 skip 20
uart:~$ [00:00:31.757,476] <dbg> net_pkt: net_pkt_skip: (net_socket_service): pkt 0x20068898 skip 0
uart:~$ [00:00:31.757,507] <dbg> net_pkt: net_pkt_read: (net_socket_service): pkt 0x20068898 data 0x2006a828 length 84
uart:~$ [00:00:31.757,598] <dbg> net_pkt: net_pkt_unref_debug: (net_socket_service): RX [15] pkt 0x20068898 ref 0 frags 0x20069408 (zsock_recv_dgram():1217)
uart:~$ [00:00:31.757,659] <dbg> net_pkt: net_pkt_unref_debug: (net_socket_service): RDATA (?) [0] frag 0x20069408 ref 0 frags (nil) (zsock_recv_dgram():1217)
uart:~$ [00:00:31.757,751] <dbg> net_pkt: net_pkt_frag_unref_debug: (net_socket_service): RDATA (?) [0] frag 0x20069408 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:31.763,183] <dbg> net_pkt: pkt_alloc_with_buffer: (date_time_work_q): On iface 0x2000f160 size 48
uart:~$ [00:00:31.763,244] <dbg> net_pkt: pkt_estimate_headers_length: (date_time_work_q): HDRs length estimation 28
uart:~$ [00:00:31.763,275] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (date_time_work_q): Data allocation maximum size 76 (requested 48)
uart:~$ [00:00:31.763,366] <dbg> net_pkt: pkt_alloc_buffer: (date_time_work_q): TDATA (?) [0] frag 0x2006953c ref 1 (context_alloc_pkt():1914)
uart:~$ [00:00:31.763,427] <dbg> net_pkt: pkt_estimate_headers_length: (date_time_work_q): HDRs length estimation 28
uart:~$ [00:00:31.763,488] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:00:31.763,519] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068e30 skip 20
uart:~$ [00:00:31.763,580] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068e30 data 0x2005630c length 8
uart:~$ [00:00:31.763,641] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068e30 skip 8
uart:~$ [00:00:31.763,671] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068e30 data 0x2005f584 length 48
uart:~$ [00:00:31.763,732] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:00:31.763,763] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068e30 skip 20
uart:~$ [00:00:31.763,824] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068e30 data 0x2005630c length 8
uart:~$ [00:00:31.763,854] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068e30 skip 8
uart:~$ [00:00:31.763,946] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 0) network packet iface 1 (0x2000f160)
uart:~$ [00:00:31.764,068] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 1 (ethernet_fill_header():532)
uart:~$ [00:00:31.764,129] <dbg> net_pkt: net_pkt_frag_insert_debug: (tx_q[0]): pkt 0x20068e30 frag 0x20069504 (ethernet_fill_header:583)
uart:~$ [00:00:31.764,221] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068e30 data 0x200491e4 length 90
uart:~$ [00:00:31.764,465] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_buf_map_tx: bounce_buf_addr: 0xc8c64, rpu_addr: 0xb0008c64, buf_le
uart:~$ [00:00:31.766,571] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 (ethernet_remove_l2_header():615)
uart:~$ [00:00:31.766,662] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068e30 ref 0 frags 0x2006953c (ethernet_send():762)
uart:~$ [00:00:31.766,754] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 frags (nil) (ethernet_send():762)
uart:~$ [00:00:31.766,815] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:31.766,906] <dbg> net_if: net_if_tx: (tx_q[0]): Calling context send cb 0x2000f9f8 status 90
uart:~$ [00:00:31.768,890] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:31.768,951] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 2 received from UMAC
uart:~$ [00:00:31.814,392] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:31.814,483] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 3 received from UMAC
uart:~$ [00:00:31.814,636] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 64
uart:~$ [00:00:31.814,697] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 64 (requested 64)
uart:~$ [00:00:31.814,788] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:31.814,819] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x20068898 data 0x20036cc8 length 64
uart:~$ [00:00:31.814,941] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [15] pkt 0x20068898 ref 0 frags 0x20069408 (net_arp_input():887)
uart:~$ [00:00:31.815,032] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 frags (nil) (net_arp_input():887)
uart:~$ [00:00:31.815,124] <dbg> net_pkt: net_pkt_frag_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:31.815,185] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 24 RX 16 RDATA 0 TDATA 0
uart:~$ [00:00:32.018,371] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:32.018,432] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 3 received from UMAC
uart:~$ [00:00:32.018,615] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 90
uart:~$ [00:00:32.018,646] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 90 (requested 90)
uart:~$ [00:00:32.018,737] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:32.018,768] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x20068898 data 0x200379a8 length 90
uart:~$ [00:00:32.018,951] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:00:32.018,981] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068898 data 0x2005531a length 8
uart:~$ [00:00:32.019,012] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 8
uart:~$ [00:00:32.019,134] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 24 RX 15 RDATA 0 TDATA 0
uart:~$ [00:00:32.024,353] <dbg> net_pkt: net_pkt_read: (date_time_work_q): pkt 0x20068898 data 0x2005f5b4 length 48
uart:~$ [00:00:32.024,414] <dbg> net_pkt: net_pkt_unref_debug: (date_time_work_q): RX [15] pkt 0x20068898 ref 0 frags 0x20069408 (zsock_recv_dgram():1217)
uart:~$ [00:00:32.024,475] <dbg> net_pkt: net_pkt_unref_debug: (date_time_work_q): RDATA (?) [0] frag 0x20069408 ref 0 frags (nil) (zsock_recv_dgram():1217)
uart:~$ [00:00:32.024,536] <dbg> net_pkt: net_pkt_frag_unref_debug: (date_time_work_q): RDATA (?) [0] frag 0x20069408 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:32.024,688] <inf> network: DATE_TIME_OBTAINED_NTP
uart:~$ [00:00:32.024,719] <inf> network: Obtained time:1742363887000
uart:~$ uart:~$ uart:~$ [00:00:32.601,623] <dbg> net_if: rs_timeout: (sysworkq): RS no respond iface 0x2000f160 count 1
uart:~$ [00:00:32.601,684] <dbg> net_if: net_if_start_rs: (sysworkq): Starting ND/RS for iface 0x2000f160
uart:~$ [00:00:32.601,715] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f160 size 12
uart:~$ [00:00:32.601,745] <dbg> net_pkt: pkt_estimate_headers_length: (sysworkq): HDRs length estimation 44
uart:~$ [00:00:32.601,776] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 56 (requested 12)
uart:~$ [00:00:32.601,898] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x2006953c ref 1 (net_ipv6_send_rs():2093)
uart:~$ [00:00:32.601,928] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200562f8 length 40
uart:~$ [00:00:32.601,959] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 40
uart:~$ [00:00:32.601,989] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x20056320 length 4
uart:~$ [00:00:32.602,020] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 4
uart:~$ [00:00:32.602,081] <dbg> net_pkt: net_pkt_memset: (sysworkq): pkt 0x20068e30 byte 0 amount 4
uart:~$ [00:00:32.602,111] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611dc length 2
uart:~$ [00:00:32.602,142] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200136f0 length 6
uart:~$ [00:00:32.602,203] <dbg> net_pkt: net_pkt_memset: (sysworkq): pkt 0x20068e30 byte 0 amount 0
uart:~$ [00:00:32.602,233] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200562f8 length 40
uart:~$ [00:00:32.602,264] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 40
uart:~$ [00:00:32.602,294] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x20056320 length 4
uart:~$ [00:00:32.602,325] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 4
uart:~$ [00:00:32.602,447] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 1) network packet iface 1 (0x2000f160)
uart:~$ [00:00:32.602,539] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 1 (ethernet_fill_header():532)
uart:~$ [00:00:32.602,569] <dbg> net_pkt: net_pkt_frag_insert_debug: (tx_q[0]): pkt 0x20068e30 frag 0x20069504 (ethernet_fill_header:583)
uart:~$ [00:00:32.602,630] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068e30 data 0x200491e4 length 70
uart:~$ [00:00:32.602,874] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_buf_map_tx: bounce_buf_addr: 0xc8c64, rpu_addr: 0xb0008c64, buf_le
uart:~$ [00:00:32.604,888] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 (ethernet_remove_l2_header():615)
uart:~$ [00:00:32.604,980] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068e30 ref 0 frags 0x2006953c (ethernet_send():762)
uart:~$ [00:00:32.605,041] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 frags (nil) (ethernet_send():762)
uart:~$ [00:00:32.605,102] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:32.608,428] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:32.608,489] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 2 received from UMAC
uart:~$ [00:00:32.608,642] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:32.608,703] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 3 received from UMAC
uart:~$ [00:00:32.608,886] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 92
uart:~$ [00:00:32.608,947] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 92 (requested 92)
uart:~$ [00:00:32.609,039] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:32.609,069] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x20068898 data 0x20036cc8 length 92
uart:~$ [00:00:32.609,222] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:00:32.609,252] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068898 data 0x2005531a length 8
uart:~$ [00:00:32.609,283] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 8
uart:~$ [00:00:32.609,375] <dbg> net_pkt: pkt_alloc_with_buffer: (rx_q[0]): On iface 0x2000f160 size 32
uart:~$ [00:00:32.609,405] <dbg> net_pkt: pkt_estimate_headers_length: (rx_q[0]): HDRs length estimation 24
uart:~$ [00:00:32.609,436] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (rx_q[0]): Data allocation maximum size 56 (requested 32)
uart:~$ [00:00:32.609,527] <dbg> net_pkt: pkt_alloc_buffer: (rx_q[0]): TDATA (?) [0] frag 0x2006953c ref 1 (net_icmpv4_send_error():562)
uart:~$ [00:00:32.609,588] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:00:32.609,619] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 20
uart:~$ [00:00:32.609,649] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068e30 data 0x2005630c length 4
uart:~$ [00:00:32.609,680] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 4
uart:~$ [00:00:32.609,741] <dbg> net_pkt: net_pkt_memset: (rx_q[0]): pkt 0x20068e30 byte 0 amount 4
uart:~$ [00:00:32.609,771] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:00:32.609,802] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 20
uart:~$ [00:00:32.609,863] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068e30 data 0x2005630c length 4
uart:~$ [00:00:32.609,893] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 4
uart:~$ [00:00:32.609,985] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [15] pkt 0x20068898 ref 0 frags 0x20069408 (processing_data():176)
uart:~$ [00:00:32.610,046] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 frags (nil) (processing_data():176)
uart:~$ [00:00:32.610,137] <dbg> net_pkt: net_pkt_frag_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:32.610,198] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 23 RX 16 RDATA 0 TDATA 0
uart:~$ [00:00:32.610,229] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 1) network packet iface 1 (0x2000f160)
uart:~$ [00:00:32.610,351] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 1 (ethernet_fill_header():532)
uart:~$ [00:00:32.610,382] <dbg> net_pkt: net_pkt_frag_insert_debug: (tx_q[0]): pkt 0x20068e30 frag 0x20069504 (ethernet_fill_header:583)
uart:~$ [00:00:32.610,473] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068e30 data 0x200491e4 length 70
uart:~$ [00:00:32.610,687] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_buf_map_tx: bounce_buf_addr: 0xc8c64, rpu_addr: 0xb0008c64, buf_le
uart:~$ [00:00:32.611,206] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 (ethernet_remove_l2_header():615)
uart:~$ [00:00:32.611,297] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068e30 ref 0 frags 0x2006953c (ethernet_send():762)
uart:~$ [00:00:32.611,358] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 frags (nil) (ethernet_send():762)
uart:~$ [00:00:32.611,419] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:32.612,823] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:32.612,884] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 2 received from UMAC
uart:~$ uart:~$ uart:~$ [00:00:33.602,478] <dbg> net_if: rs_timeout: (sysworkq): RS no respond iface 0x2000f160 count 2
uart:~$ [00:00:33.602,539] <dbg> net_if: net_if_start_rs: (sysworkq): Starting ND/RS for iface 0x2000f160
uart:~$ [00:00:33.602,569] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f160 size 12
uart:~$ [00:00:33.602,630] <dbg> net_pkt: pkt_estimate_headers_length: (sysworkq): HDRs length estimation 44
uart:~$ [00:00:33.602,661] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 56 (requested 12)
uart:~$ [00:00:33.602,752] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x2006953c ref 1 (net_ipv6_send_rs():2093)
uart:~$ [00:00:33.602,783] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200562f8 length 40
uart:~$ [00:00:33.602,813] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 40
uart:~$ [00:00:33.602,844] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x20056320 length 4
uart:~$ [00:00:33.602,874] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 4
uart:~$ [00:00:33.602,935] <dbg> net_pkt: net_pkt_memset: (sysworkq): pkt 0x20068e30 byte 0 amount 4
uart:~$ [00:00:33.602,966] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611dc length 2
uart:~$ [00:00:33.602,996] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200136f0 length 6
uart:~$ [00:00:33.603,057] <dbg> net_pkt: net_pkt_memset: (sysworkq): pkt 0x20068e30 byte 0 amount 0
uart:~$ [00:00:33.603,088] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200562f8 length 40
uart:~$ [00:00:33.603,118] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 40
uart:~$ [00:00:33.603,149] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x20056320 length 4
uart:~$ [00:00:33.603,179] <dbg> net_pkt: net_pkt_skip: (sysworkq): pkt 0x20068e30 skip 4
uart:~$ [00:00:33.603,302] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 1) network packet iface 1 (0x2000f160)
uart:~$ [00:00:33.603,393] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 1 (ethernet_fill_header():532)
uart:~$ [00:00:33.603,424] <dbg> net_pkt: net_pkt_frag_insert_debug: (tx_q[0]): pkt 0x20068e30 frag 0x20069504 (ethernet_fill_header:583)
uart:~$ [00:00:33.603,485] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068e30 data 0x200491e4 length 70
uart:~$ [00:00:33.603,729] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_buf_map_tx: bounce_buf_addr: 0xc8c64, rpu_addr: 0xb0008c64, buf_le
uart:~$ [00:00:33.605,834] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 (ethernet_remove_l2_header():615)
[00:00:33.605,895] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068e30 ref 0 frags 0x2006953c (ethernet_send():762)
uart:~$ [00:00:33.605,987] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 frags (nil) (ethernet_send():762)
uart:~$ [00:00:33.606,048] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 (net_pkt_unref_debug():608)
[00:00:33.607,666] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:33.692,413] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 8
uart:~$ --- 46 messages dropped ---
[00:00:33.692,443] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 8
uart:~$ [00:00:33.692,504] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x20067b78 length 64
uart:~$ [00:00:33.692,535] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:00:33.695,373] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068e30 ref 0 frags 0x2006953c (ethernet_send():762)
uart:~$ [00:00:33.695,434] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 frags (nil) (ethernet_send():762)
uart:~$ [00:00:33.695,495] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x2006953c ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:33.742,340] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 3 received from UMAC
uart:~$ --- 100 messages dropped ---
[00:00:33.742,553] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 330
uart:~$ [00:00:33.742,614] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 330 (requested 330)
uart:~$ [00:00:33.742,706] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:33.742,767] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x20068898 data 0x20036cc8 length 330
uart:~$ --- 151 messages dropped ---
[00:00:33.799,407] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068da8 skip 20
uart:~$ [00:00:33.799,499] <dbg> net_tcp: tcp_send_process_no_lock: (rx_q[0]): ACK Seq=57618419 Ack=1864105825 Len=0
uart:~$ [00:00:33.799,530] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068da8 skip 20
uart:~$ [00:00:33.799,652] <dbg> net_pkt: net_pkt_ref_debug: (rx_q[0]): TX [22] pkt 0x20068da8 ref 2 (tcp_send():370)
uart:~$ [00:00:33.799,743] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): TX [22] pkt 0x20068da8 ref 1 frags 0x2006953c (tcp_send():418)
uart:~$ [00:00:33.799,835] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [14] pkt 0x200688dc ref 0 frags 0x20069408 (tcp_in():3570)
uart:~$ --- 127 messages dropped ---
[00:00:34.029,846] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (): Data allocation maximum size 68 (requested 20)
uart:~$ [00:00:34.029,968] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x2006953c ref 1 (tcp_out_ext():1558)
uart:~$ [00:00:34.030,029] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x200562f8 length 20
uart:~$ [00:00:34.030,059] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068dec skip 20
uart:~$ [00:00:34.030,120] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x2005630c length 20
uart:~$ [00:00:34.030,151] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068dec skip 20
uart:~$ [00:00:34.030,212] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x200562f8 length 20
[00:00:34.077,667] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x2006953c ref 1 (tcp_out_ext():1558)
uart:~$ [00:00:34.077,728] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x200562f8 length 20
uart:~$ [00:00:34.077,758] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068dec skip 20
uart:~$ [00:00:34.077,819] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x2005630c length 20
uart:~$ [00:00:34.077,850] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068dec skip 20
uart:~$ [00:00:34.077,911] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x200562f8 length 20
uart:~$ [00:00:34.125,457] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x20069520 ref 1 (tcp_out_ext():1558)
[00:00:34.125,549] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068da8 data 0x200562f8 length 20
uart:~$ [00:00:34.125,610] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ [00:00:34.125,640] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068da8 data 0x2005630c length 20
uart:~$ [00:00:34.125,701] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ --- 301 messages dropped ---
[00:00:34.125,732] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068da8 data 0x200562f8 length 20
uart:~$ [00:00:34.125,793] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ [00:00:34.172,912] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x200562f8 length 20
uart:~$ [00:00:34.172,973] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068dec skip 20
uart:~$ [00:00:34.173,004] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x2005630c length 20
uart:~$ [00:00:34.173,065] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068dec skip 20
uart:~$ [00:00:34.173,095] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068dec data 0x200562f8 length 20
uart:~$ [00:00:34.517,639] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ --- 61 messages dropped ---
[00:00:34.517,700] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x200688dc data 0x2005531a length 20
uart:~$ [00:00:34.517,730] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:34.517,822] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:34.517,883] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:34.517,913] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:34.517,974] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:36.210,327] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 84
uart:~$ --- 155 messages dropped ---
[00:00:36.210,388] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 84 (requested 84)
uart:~$ --- 1 messages dropped ---
[00:00:36.210,479] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:36.210,540] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x200688dc data 0x20037318 length 84
uart:~$ [00:00:36.210,693] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:36.210,754] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x200688dc data 0x2005531a length 20
uart:~$ [00:00:36.210,784] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:36.262,481] <dbg> net_pkt: net_pkt_unref_debug: (): TX [22] pkt 0x20068dec ref 1 frags 0x20069558 (tcp_send():418)
uart:~$ [00:00:36.262,969] <dbg> net_mqtt_enc: connect_request_encode: Encoding Protocol Description.
                                       4d 51 54 54                                      |MQTT
uart:~$ [00:00:36.263,000] <dbg> net_mqtt_enc: pack_utf8_str: (): >> str_size:00000006 cur:0x2001a566, end:0x2001b561
uart:~$ [00:00:36.263,031] <dbg> net_mqtt_enc: pack_uint16: (): >> val:0004 cur:0x2001a566, end:0x2001b561
uart:~$ --- 39 messages dropped ---
[00:00:36.263,092] <dbg> net_mqtt_enc: connect_request_encode: (): Encoding Protocol Version 04.
uart:~$ [00:00:36.263,122] <dbg> net_mqtt_enc: pack_uint8: (): >> val:04 cur:0x2001a56c, end:0x2001b561
uart:~$ --- 25 messages dropped ---
[00:00:36.263,153] <dbg> net_mqtt_enc: pack_uint8: (): >> val:00 cur:0x2001a56d, end:0x2001b561
uart:~$ [00:00:36.263,183] <dbg> net_mqtt_enc: connect_request_encode: (): Encoding Keep Alive Time 0640.
uart:~$ [00:00:36.263,244] <dbg> net_mqtt_enc: pack_uint16: (): >> val:0640 cur:0x2001a56e, end:0x2001b561
uart:~$ --- 182 messages dropped ---
[00:00:36.263,244] <dbg> net_mqtt_enc: connect_request_encode: Encoding Client Id.
                                       34 36 41 31 30 36 37 42  39 38 46 36 41 31 31 39 |46A1067B 98F6A119
uart:~$ [00:00:36.263,305] <dbg> net_mqtt_enc: pack_utf8_str: (): >> str_size:00000012 cur:0x2001a570, end:0x2001b561
uart:~$ [00:00:36.263,336] <dbg> net_mqtt_enc: pack_uint16: (): >> val:0010 cur:0x2001a570, end:0x2001b561
uart:~$ [00:00:36.263,366] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (): << msg type:0x10 length:0x0000001c
uart:~$ --- 58 messages dropped ---
[00:00:36.268,585] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 (ethernet_remove_l2_header():615)
uart:~$ [00:00:36.268,676] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [21] pkt 0x20068da8 ref 0 frags 0x2006953c (ethernet_send():762)
uart:~$ [00:00:36.333,007] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:36.373,596] <dbg> net_pkt: net_pkt_skip: (mqtt_helper_thread): pkt 0x20068da8 skip 20
uart:~$ --- 110 messages dropped ---
[00:00:36.373,718] <dbg> net_tcp: tcp_send_process_no_lock: (mqtt_helper_thread): ACK,PSH Seq=57620298 Ack=1864111403 Len=81
uart:~$ [00:00:36.410,949] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 84
uart:~$ [00:00:36.411,010] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 84 (requested 84)
uart:~$ [00:00:36.411,102] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
[00:00:36.411,163] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x200688dc data 0x20036cc8 length 84
uart:~$ --- 67 messages dropped ---
[00:00:36.451,568] <dbg> net_pkt: pkt_estimate_headers_length: (mqtt_helper_thread): HDRs length estimation 48
uart:~$ --- 112 messages dropped ---
[00:00:36.451,599] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (mqtt_helper_thread): Data allocation maximum size 68 (requested 20)
[00:00:36.451,690] <dbg> net_pkt: pkt_alloc_buffer: (mqtt_helper_thread): TDATA (?) [0] frag 0x20069520 ref 1 (tcp_out_ext():1558)
uart:~$ [00:00:36.451,751] <dbg> net_pkt: net_pkt_write: (mqtt_helper_thread): pkt 0x20068dec data 0x200562f8 length 20
uart:~$ [00:00:36.451,782] <dbg> net_pkt: net_pkt_skip: (mqtt_helper_thread): pkt 0x20068dec skip 20
uart:~$ [00:00:36.492,309] <dbg> net_tcp: tcp_in: (rx_q[0]): Lowering send window from 32412 to 1365
uart:~$ [00:00:36.503,448] <dbg> net_mqtt_rx: mqtt_handle_packet: (mqtt_helper_thread): [CID 0x20016644]: Received MQTT_PKT_TYPE_SUBACK!
uart:~$ [00:00:36.532,409] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): TX [22] pkt 0x20068dec ref 1 frags 0x20069504 (tcp_send():418)
[00:00:36.532,653] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069520 ref 1 (ethernet_fill_header():532)
uart:~$ [00:00:36.532,714] <dbg> net_pkt: net_pkt_frag_insert_debug: (tx_q[0]): pkt 0x20068dec frag 0x20069520 (ethernet_fill_header:583)
uart:~$ [00:00:36.532,806] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 54 sent to RPU
uart:~$ [00:00:36.532,928] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068dec data 0x200491e4 length 54
uart:~$ [00:00:36.533,172] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_buf_map_tx: bounce_buf_addr: 0xc8c64, rpu_addr: 0xb0008c64, buf_le
uart:~$ [00:00:36.535,583] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
[00:00:36.535,675] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:36.535,736] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:36.535,797] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:36.535,827] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:00:36.536,041] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ --- 62 messages dropped ---
[00:00:36.536,315] <dbg> net_tcp: tcp_in: (rx_q[0]): ACK,PSH Seq=1864111538 Ack=57620670 Len=126 [ESTABLISHED Seq=57620670 Ack=1864111538]
uart:~$ [00:00:36.536,468] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 40
uart:~$ [00:00:36.536,529] <dbg> net_pkt: pkt_alloc_with_buffer: (rx_q[0]): On iface 0x2000f160 size 20
uart:~$ [00:00:36.536,590] <dbg> net_pkt: pkt_estimate_headers_length: (rx_q[0]): HDRs length estimation 48
uart:~$ [00:00:36.536,621] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (rx_q[0]): Data allocation maximum size 68 (requested 20)
uart:~$ [00:00:36.536,743] <dbg> net_pkt: pkt_alloc_buffer: (rx_q[0]): TDATA (?) [0] frag 0x20069504 ref 1 (tcp_out_ext():1558)
uart:~$ [00:00:36.652,618] <dbg> net_pkt: net_pkt_read: (mqtt_helper_thread): pkt 0x20068920 data 0x200202d4 length 5
uart:~$ [00:00:36.652,709] <dbg> net_pkt: net_pkt_read: (mqtt_helper_thread): pkt 0x20068920 data 0x200202d9 length 28
uart:~$ [00:00:36.652,801] <dbg> net_pkt: net_pkt_unref_debug: (mqtt_helper_thread): RX [13] pkt 0x20068920 ref 0 frags 0x20069424 (zsock_recv_stream_immediate():1289)
uart:~$ [00:00:36.652,862] <dbg> net_pkt: net_pkt_unref_debug: (mqtt_helper_thread): RDATA (?) [0] frag 0x20069424 ref 0 frags (nil) (zsock_recv_stream_immediate():1289)
uart:~$ [00:00:36.652,923] <dbg> net_pkt: net_pkt_frag_unref_debug: (mqtt_helper_thread): RDATA (?) [0] frag 0x20069424 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:36.653,289] <dbg> net_mqtt: mqtt_input: (mqtt_helper_thread): state:0x00000006
uart:~$ [00:00:36.653,381] <dbg> net_mqtt_dec: unpack_uint8: (mqtt_helper_thread): >> cur:0x2001b561, end:0x2001b563
uart:~$ [00:00:36.653,411] <dbg> net_mqtt_dec: unpack_uint8: (mqtt_helper_thread): << val:40
uart:~$ [00:00:36.653,442] <dbg> net_mqtt_dec: packet_length_decode: (mqtt_helper_thread): length:0x00000002
uart:~$ [00:00:36.653,533] <dbg> net_mqtt_rx: mqtt_handle_packet: (mqtt_helper_thread): [CID 0x20016644]: Received MQTT_PKT_TYPE_PUBACK!
uart:~$ [00:00:36.653,564] <dbg> net_mqtt_dec: unpack_uint16: (mqtt_helper_thread): >> cur:0x2001b563, end:0x2001b565
uart:~$ --- 11 messages dropped ---
[00:00:36.653,594] <dbg> net_mqtt_dec: unpack_uint16: (mqtt_helper_thread): << val:3a25
uart:~$ [00:00:36.653,625] <dbg> mqtt_helper: mqtt_evt_handler: MQTT_EVT_PUBACK: id = 14885 result = 0
uart:~$ [00:00:36.653,625] <dbg> apt_aws: aws_iot_event_handler: AWS EVT handler
uart:~$ [00:00:36.653,656] <inf> apt_aws: AWS_IOT_EVT_PUBACK, message ID: 14885
uart:~$ [00:00:36.653,686] <dbg> mqtt_helper: mqtt_helper_poll_loop: Polling on socket fd: 14
uart:~$ [00:00:36.653,778] <dbg> net_pkt: net_pkt_read: (mqtt_helper_thread): pkt 0x200688dc data 0x200202d4 length 5
uart:~$ [00:00:36.653,869] <dbg> net_pkt: net_pkt_read: (mqtt_helper_thread): pkt 0x200688dc data 0x200202d9 length 121
uart:~$ [00:00:36.653,961] <dbg> net_pkt: net_pkt_unref_debug: (mqtt_helper_thread): RX [14] pkt 0x200688dc ref 0 frags 0x20069408 (zsock_recv_stream_immediate():1289)
uart:~$ [00:00:36.654,663] <dbg> net_pkt: net_pkt_skip: (mqtt_helper_thread): pkt 0x20068dec skip 20
uart:~$ [00:00:36.654,693] <dbg> net_pkt: net_pkt_write: (mqtt_helper_thread): pkt 0x20068dec data 0x2005630c length 20
uart:~$ [00:00:36.654,754] <dbg> net_pkt: net_pkt_skip: (mqtt_helper_thread): pkt 0x20068dec skip 20
uart:~$ [00:00:36.654,815] <dbg> net_pkt: net_pkt_skip: (mqtt_helper_thread): pkt 0x20068dec skip 20
uart:~$ [00:00:36.655,029] <dbg> net_pkt: net_pkt_skip: (mqtt_helper_thread): pkt 0x20068dec skip 20
uart:~$ [00:00:36.655,120] <dbg> net_tcp: tcp_send_process_no_lock: (mqtt_helper_thread): ACK Seq=57620670 Ack=1864111664 Len=0
uart:~$ [00:00:36.655,151] <dbg> net_pkt: net_pkt_skip: (mqtt_helper_thread): pkt 0x20068dec skip 20
uart:~$ [00:00:36.655,242] <dbg> net_pkt: net_pkt_ref_debug: (mqtt_helper_thread): TX [22] pkt 0x20068dec ref 2 (tcp_send():370)
uart:~$ [00:00:36.655,334] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 0) network packet iface 1 (0x2000f160)
uart:~$ [00:00:36.655,456] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069520 ref 1 (ethernet_fill_header():532)
uart:~$ [00:00:36.655,517] <dbg> net_pkt: net_pkt_frag_insert_debug: (tx_q[0]): pkt 0x20068dec frag 0x20069520 (ethernet_fill_header:583)
uart:~$ [00:00:36.655,609] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068dec data 0x200435a4 length 54
uart:~$ [00:00:36.655,853] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_buf_map_tx: bounce_buf_addr: 0xc8c64, rpu_addr: 0xb0008c64, buf_le
uart:~$ [00:00:36.656,188] <dbg> net_pkt: net_pkt_unref_debug: (mqtt_helper_thread): TX [22] pkt 0x20068dec ref 1 frags 0x20069520 (tcp_send():418)
uart:~$ [00:00:36.657,043] <dbg> net_mqtt: mqtt_input: (mqtt_helper_thread): state:0x00000006
uart:~$ [00:00:36.657,104] <dbg> net_mqtt_dec: unpack_uint8: (mqtt_helper_thread): >> cur:0x2001b561, end:0x2001b563
uart:~$ [00:00:36.657,775] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069520 ref 0 (ethernet_remove_l2_header():615)
uart:~$ [00:00:36.657,836] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068dec ref 0 frags 0x20069504 (ethernet_send():762)
uart:~$ [00:00:36.657,928] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 frags (nil) (ethernet_send():762)
uart:~$ [00:00:36.657,989] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:36.658,081] <dbg> net_mqtt_dec: unpack_uint8: (mqtt_helper_thread): << val:30
uart:~$ [00:00:36.658,111] <dbg> net_mqtt_dec: packet_length_decode: (mqtt_helper_thread): length:0x0000005f
uart:~$ [00:00:36.658,203] <dbg> net_mqtt_rx: mqtt_handle_packet: (mqtt_helper_thread): [CID 0x20016644]: Received MQTT_PKT_TYPE_PUBLISH
uart:~$ [00:00:36.658,233] <dbg> net_mqtt_dec: unpack_utf8_str: (mqtt_helper_thread): >> cur:0x2001b563, end:0x2001b599
uart:~$ [00:00:36.658,264] <dbg> net_mqtt_dec: unpack_uint16: (mqtt_helper_thread): >> cur:0x2001b563, end:0x2001b599
uart:~$ [00:00:36.658,325] <dbg> net_mqtt_dec: unpack_uint16: (mqtt_helper_thread): << val:0034
uart:~$ [00:00:36.658,355] <dbg> net_mqtt_dec: unpack_utf8_str: (mqtt_helper_thread): << str_size:00000036
uart:~$ [00:00:36.658,416] <dbg> net_mqtt_rx: mqtt_handle_packet: (mqtt_helper_thread): PUB QoS:00, message len 00000029, topic len 00000034
uart:~$ [00:00:36.659,454] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:36.659,545] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 2 received from UMAC
uart:~$ [00:00:36.659,881] <dbg> mqtt_helper: mqtt_helper_poll_loop: Polling on socket fd: 14
uart:~$ [00:00:36.741,088] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:36.741,180] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 3 received from UMAC
uart:~$ [00:00:36.741,333] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 42
uart:~$ [00:00:36.741,394] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 42 (requested 42)
uart:~$ [00:00:36.741,485] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:36.741,516] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x200688dc data 0x20037318 length 42
uart:~$ [00:00:36.741,638] <dbg> net_pkt: pkt_alloc_with_buffer: (rx_q[0]): On iface 0x2000f160 size 28
uart:~$ [00:00:36.741,668] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (rx_q[0]): Data allocation maximum size 28 (requested 28)
uart:~$ [00:00:36.741,760] <dbg> net_pkt: pkt_alloc_buffer: (rx_q[0]): TDATA (?) [0] frag 0x20069504 ref 1 (arp_prepare_reply():716)
uart:~$ [00:00:36.741,821] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [14] pkt 0x200688dc ref 0 frags 0x20069408 (net_arp_input():887)
uart:~$ [00:00:36.741,882] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 frags (nil) (net_arp_input():887)
uart:~$ [00:00:36.741,973] <dbg> net_pkt: net_pkt_frag_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:36.742,034] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 22 RX 15 RDATA 0 TDATA 0
uart:~$ [00:00:36.742,065] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 1) network packet iface 1 (0x2000f160)
uart:~$ [00:00:36.742,156] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069520 ref 1 (ethernet_fill_header():532)
uart:~$ [00:00:36.742,218] <dbg> net_pkt: net_pkt_frag_insert_debug: (tx_q[0]): pkt 0x20068dec frag 0x20069520 (ethernet_fill_header:583)
uart:~$ [00:00:36.742,309] <dbg> net_pkt: net_pkt_read: (tx_q[0]): pkt 0x20068dec data 0x200435a4 length 42
uart:~$ [00:00:36.742,553] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_buf_map_tx: bounce_buf_addr: 0xc8c64, rpu_addr: 0xb0008c64, buf_le
uart:~$ [00:00:36.743,072] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069520 ref 0 (ethernet_remove_l2_header():615)
uart:~$ [00:00:36.743,164] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068dec ref 0 frags 0x20069504 (ethernet_send():762)
uart:~$ [00:00:36.743,225] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 frags (nil) (ethernet_send():762)
uart:~$ [00:00:36.743,316] <dbg> net_pkt: net_pkt_frag_unref_debug: (tx_q[0]): TDATA (?) [0] frag 0x20069504 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:36.744,781] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:36.744,842] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 2 received from UMAC
uart:~$ uart:~$ uart:~$ [00:00:37.136,718] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:37.136,779] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 3 received from UMAC
uart:~$ [00:00:37.136,962] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 64
uart:~$ [00:00:37.137,023] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 64 (requested 64)
uart:~$ [00:00:37.137,115] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:37.137,145] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x200688dc data 0x20036cc6 length 64
uart:~$ [00:00:37.137,268] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [14] pkt 0x200688dc ref 0 frags 0x20069408 (net_arp_input():887)
uart:~$ [00:00:37.137,329] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 frags (nil) (net_arp_input():887)
uart:~$ [00:00:37.137,390] <dbg> net_pkt: net_pkt_frag_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:37.137,481] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 23 RX 15 RDATA 0 TDATA 0
uart:~$ uart:~$ uart:~$ [00:00:38.365,661] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 2 recd
uart:~$ [00:00:38.365,753] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_data_event_process: Event 3 received from UMAC
uart:~$ [00:00:38.365,936] <dbg> net_pkt: pkt_alloc_with_buffer: (nrf70_bh_wq): On iface 0x2000f160 size 64
uart:~$ [00:00:38.365,966] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (nrf70_bh_wq): Data allocation maximum size 64 (requested 64)
uart:~$ [00:00:38.366,058] <dbg> net_pkt: pkt_alloc_buffer: (nrf70_bh_wq): RDATA (?) [0] frag 0x20069408 ref 1 (net_pkt_from_nbuf():370)
uart:~$ [00:00:38.366,088] <dbg> net_pkt: net_pkt_write: (nrf70_bh_wq): pkt 0x200688dc data 0x20037316 length 64
uart:~$ [00:00:38.366,210] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [14] pkt 0x200688dc ref 0 frags 0x20069408 (processing_data():176)
uart:~$ [00:00:38.366,302] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 frags (nil) (processing_data():176)
uart:~$ [00:00:38.366,363] <dbg> net_pkt: net_pkt_frag_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069408 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:00:38.366,424] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 23 RX 15 RDATA 0 TDATA 0
uart:~$
v2.8.0_lte_logs :
uart:~$ --- 93 messages dropped ---
[00:00:00.015,014] <dbg> net_pkt: net_pkt_init: (main): Allocating 16 RX (1088 bytes), 24 TX (1632 bytes), 0 RX data (0 bytes) and 0 TX data (0 bytes) buffers
uart:~$ [00:00:00.015,258] <dbg> net_tcp: net_tcp_init: (main): Workq started. Thread ID: 0x20013950
uart:~$ [00:00:00.015,380] <dbg> net_mgmt: net_mgmt_event_init: (main): Net MGMT initialized: queue of 10 entries, stack size of 5120
uart:~$ [00:00:00.015,411] <dbg> net_if: net_if_init: (main):
uart:~$ [00:00:00.015,594] <dbg> net_if: init_iface: (main): On iface 0x2000f160
uart:~$ [00:00:00.015,747] <dbg> net_if: update_operational_state: (main): iface 1 (0x2000f160), oper state DOWN admin DOWN carrier ON dormant ON
uart:~$ [00:00:00.015,838] <dbg> net_if: init_iface: (main): On iface 0x2000f1f0
uart:~$ [00:00:00.015,869] <dbg> net_mgmt: net_mgmt_add_event_callback: (main): Adding event callback 0x2000f714
uart:~$ [00:00:00.016,113] <dbg> net_if: update_operational_state: (main): iface 2 (0x2000f1f0), oper state DOWN admin DOWN carrier OFF dormant OFF
uart:~$ [00:00:00.016,174] <wrn> net_if: You have 1 IPv6 net_if addresses but 2 network interfaces
uart:~$ [00:00:00.241,119] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.243,408] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.243,591] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.243,835] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.243,927] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.244,018] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.244,110] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.247,833] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.247,985] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.248,260] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.248,321] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.248,413] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.248,504] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.250,671] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.250,823] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.251,098] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.251,190] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.251,281] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.251,342] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.253,540] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.253,692] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.253,967] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.254,058] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.254,150] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.254,211] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.256,530] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.256,713] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.257,141] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.257,232] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.257,354] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.257,415] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.260,406] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 7 sent to RPU
uart:~$ [00:00:00.260,955] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_hal_ctrl_cmd_send: caller 0x62337
uart:~$ [00:00:00.261,260] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.261,352] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.261,413] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 7 -> status -67
uart:~$ [00:00:00.261,505] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.264,312] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_cmd_cfg: Command 21 sent to RPU
uart:~$ [00:00:00.264,556] <dbg> wifi_nrf: zep_shim_pr_dbg: nrf_wifi_fmac_event_callback: Event type 3 recd
uart:~$ [00:00:00.264,648] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 received from UMAC
uart:~$ [00:00:00.264,739] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Command 21 -> status -2
uart:~$ [00:00:00.264,831] <dbg> wifi_nrf: zep_shim_pr_dbg: umac_event_ctrl_process: Event 292 processed
uart:~$ [00:00:00.282,104] <inf> sample_main:
uart:~$ [00:00:24.665,527] <err> sample_pwr_mgnmt: ERROR: Runtime PWR value 0x3f does not match Runtime default 0x1f
uart:~$ [00:00:24.665,527] <dbg> network: iNetworkInit: Initializing AWS work funcs...
uart:~$ [00:00:24.665,649] <dbg> apt_aws: iAwsInit: AWS Work Queue initialized
uart:~$ [00:00:24.665,679] <dbg> apt_aws: iAwsInit: All AWS work funcs initialized
uart:~$ [00:00:24.665,679] <dbg> network: iNetworkInit: Initializing wireless...
uart:~$ [00:00:24.665,802] <inf> apt_net_if_mgr: Registering network management callbacks.
uart:~$ [00:00:24.665,832] <dbg> net_mgmt: net_mgmt_add_event_callback: (main): Adding event callback 0x20019c80
uart:~$ [00:00:24.665,893] <dbg> net_mgmt: net_mgmt_add_event_callback: (main): Adding event callback 0x20019c6c
uart:~$ [00:00:24.665,924] <dbg> net_mgmt: net_mgmt_add_event_callback: (main): Adding event callback 0x20019c58
uart:~$ [00:00:24.666,259] <inf> network: DATE_TIME_NOT_OBTAINED
uart:~$ uart:~$ [00:00:24.727,569] <inf> apt_net_if_mgr: LTE_INTERFACE is selected as active interface
uart:~$ [00:00:24.727,600] <inf> apt_net_if_mgr: WIFI_IF is present, at index : 1
uart:~$ [00:00:24.727,630] <inf> apt_net_if_mgr: LTE_IF is present, at index : 2
uart:~$ [00:00:24.727,630] <inf> apt_net_if_mgr: ## LTE interface is available ##
uart:~$ [00:00:24.727,630] <wrn> apt_net_if_mgr: Active Interface is selected, init and connection will be performed now ...
uart:~$ [00:00:24.727,661] <inf> apt_net_if_mgr: iface init interface event sent !!
uart:~$ [00:00:24.727,691] <dbg> apt_net_if_mgr: net_if_submit_ctrl_event_work: net_if_ctrl_event_work is pending
uart:~$ [00:00:24.727,691] <inf> apt_net_if_mgr: iface connect event sent !!
uart:~$ [00:00:24.727,722] <dbg> network: iNetworkInit: Starting AWS...
uart:~$ [00:00:24.727,935] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
uart:~$ [00:00:24.728,057] <inf> apt_net_if_mgr: net_if_ctrl_event_work_routine started...
uart:~$ [00:00:24.728,057] <wrn> apt_net_if_mgr: Unknown Event : 12
uart:~$ [00:00:24.728,179] <wrn> apt_net_if_mgr: Unknown Event : 12
uart:~$ [00:00:24.728,179] <inf> apt_net_if_mgr: NET_IF_INIT_IFACE_EVENT Received
uart:~$ [00:00:24.728,332] <inf> apt_net_if_mgr: WIFI_IF is present, at index : 1
uart:~$ [00:00:24.728,332] <inf> apt_net_if_mgr: LTE_IF is present, at index : 2
uart:~$ [00:00:24.728,363] <inf> apt_net_if_mgr: ## LTE nterface is present and selected as active interface ##
uart:~$ [00:00:24.728,363] <inf> apt_net_if_mgr: LTE interface control assigned
uart:~$ [00:00:24.728,363] <inf> apt_net_if_mgr: NET_IF_CONNECT_EVENT Received
uart:~$ [00:00:24.728,363] <inf> apt_net_if_mgr: Bringing up LTE network interface...
uart:~$ [00:00:24.728,393] <inf> apt_net_if_mgr: Power sequencing lte modem...
uart:~$ [00:00:24.774,566] <dbg> network: iNetworkInit: Data file opened
uart:~$ uart:~$ uart:~$ [00:00:25.141,754] <wrn> sample_main: >> Power management successfully initialized!
uart:~$ [00:00:25.191,833] <inf> sample_main: >> Waiting for AWS to be connected...
uart:~$ [00:00:25.728,698] <dbg> apt_net_if_mgr: lte_init: LTE iface address : 0x2000f1f0
uart:~$ [00:00:25.728,729] <dbg> net_if: net_if_up: (): iface 2 (0x2000f1f0)
uart:~$ [00:00:25.728,790] <dbg> net_mgmt: net_mgmt_event_notify_with_info: (): Notifying Event layer 2 code 1 type 4
uart:~$ [00:00:25.728,851] <dbg> net_mgmt: mgmt_event_work_handler: (net_mgmt): Handling events, forwarding it relevantly
uart:~$ [00:00:25.728,881] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Event layer 2 code 1 cmd 4
uart:~$ [00:00:25.728,912] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20010ce4 : 0x4236d
uart:~$ [00:00:25.728,942] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20018b40 : 0x5d141
uart:~$ [00:00:25.729,095] <dbg> net_if: update_operational_state: (): iface 2 (0x2000f1f0), oper state DOWN admin UP carrier OFF dormant OFF
uart:~$ uart:~$ [00:01:00.191,589] <dbg> net_if: update_operational_state: (sysworkq): iface 2 (0x2000f1f0), oper state UP admin UP carrier ON dormant OFF
uart:~$ [00:01:00.191,650] <dbg> net_mgmt: net_mgmt_event_notify_with_info: (sysworkq): Notifying Event layer 2 code 1 type 2
uart:~$ [00:01:00.191,711] <dbg> net_mgmt: mgmt_event_work_handler: (net_mgmt): Handling events, forwarding it relevantly
uart:~$ [00:01:00.191,772] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Event layer 2 code 1 cmd 2
uart:~$ [00:01:00.191,802] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20019c80 : 0x23d15
uart:~$ [00:01:00.191,802] <inf> apt_net_if_mgr: NET_EVENT_IF_UP event detected!
uart:~$ --- 81 messages dropped ---
[00:01:00.191,802] <inf> apt_net_if_mgr: LTE Interface Up!!!
uart:~$ [00:01:00.191,802] <inf> apt_net_if_mgr: g_net_info.wifi_info.wifi_if_state : 0
uart:~$ [00:01:00.191,833] <inf> apt_net_if_mgr: g_net_info.lte_info.lte_if_state : 1
uart:~$ [00:01:00.191,864] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20010ce4 : 0x4236d
uart:~$ [00:01:00.191,894] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20017138 : 0x5c495
uart:~$ [00:01:00.191,925] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20018b7c : 0x5d02d
uart:~$ [00:01:00.191,986] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x2000f714 : 0x4b9d1
uart:~$ --- 57 messages dropped ---
[00:01:00.192,016] <dbg> net_pkt: pkt_alloc_with_buffer: (net_mgmt): On iface 0x2000f1f0 size 4
uart:~$ [00:01:00.192,077] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (net_mgmt): Data allocation maximum size 4 (requested 4)
uart:~$ [00:01:00.221,984] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 0
uart:~$ [00:01:00.222,015] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x20068898 data 0x2005c146 length 1
uart:~$ [00:01:00.222,076] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x20068898 data 0x2005c147 length 1
uart:~$ --- 83 messages dropped ---
[00:01:00.225,585] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:00.225,646] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:00.225,738] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068da8 ref 0 frags 0x20069504 (modem_ppp_send_handler():381)
uart:~$ --- 117 messages dropped ---
[00:01:00.225,799] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069504 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:00.225,891] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:00.281,219] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 2
uart:~$ [00:01:00.281,250] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x20068898 data 0x2005c146 length 1
uart:~$ [00:01:00.281,311] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x20068898 data 0x2005c147 length 1
uart:~$ [00:01:00.315,002] <dbg> net_pkt: pkt_alloc_buffer: (rx_q[0]): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:00.315,063] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068da8 data 0x2005c167 length 1
uart:~$ [00:01:00.315,093] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068da8 data 0x2005c157 length 1
uart:~$ [00:01:00.315,155] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068da8 data 0x2000f648 length 8
uart:~$ [00:01:00.315,246] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (rx_q[0]): TDATA (?) [0] frag 0x20069504 ref 1 (ppp_send_pkt():467)
[00:01:00.315,307] <dbg> net_pkt: net_pkt_frag_insert_debug: (rx_q[0]): pkt 0x20068da8 frag 0x20069504 (ppp_send_pkt:474)
uart:~$ [00:01:00.315,338] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068da8 data 0x2005c14e length 2
uart:~$ [00:01:00.315,399] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068da8 data 0x2005c16c length 4
uart:~$ [00:01:00.315,490] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [15] pkt 0x200688dc ref 0 frags 0x20069424 (ppp_recv():154)
uart:~$ [00:01:00.315,551] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069424 ref 0 frags (nil) (ppp_recv():154)
uart:~$ --- 43 messages dropped ---
[00:01:00.315,643] <dbg> net_pkt: net_pkt_frag_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069424 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:00.370,758] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x200688dc data 0x2000f578 length 4
uart:~$ --- 76 messages dropped ---
[00:01:00.370,819] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 4
uart:~$ [00:01:00.371,398] <dbg> net_mgmt: net_mgmt_event_notify_with_info: (rx_q[0]): Notifying Event layer 4 code 276 type 7
uart:~$ [00:01:00.371,490] <dbg> net_pkt: pkt_alloc_with_buffer: (rx_q[0]): On iface 0x2000f1f0 size 18
uart:~$ [00:01:00.374,328] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.374,359] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.374,420] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ --- 3 messages dropped ---
[00:01:00.374,450] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.418,426] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068dec skip 20
uart:~$ [00:01:00.418,487] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068dec skip 12
uart:~$ [00:01:00.418,518] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068dec skip 8
uart:~$ [00:01:00.418,579] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068dec data 0x2005630c length 8
uart:~$ [00:01:00.418,609] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068dec skip 8
uart:~$ [00:01:00.418,701] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:00.418,975] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,006] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,067] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,128] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,158] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,219] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,281] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,342] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,372] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,433] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,494] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,555] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,586] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,647] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,677] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,738] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,799] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,830] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,891] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.419,952] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,013] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,043] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,104] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,166] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,196] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,257] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,318] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,349] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,410] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,471] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,501] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,562] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,623] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,684] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,715] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,776] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.420,837] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,020] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,081] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,112] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,173] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,234] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,295] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,325] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,386] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,447] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,478] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,539] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,600] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,630] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,691] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,752] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,783] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,844] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,905] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.421,966] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.422,058] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:00.422,119] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:00.422,180] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:00.431,060] <inf> apt_net_if_mgr: RSRP -72 dB
uart:~$ [00:01:00.456,420] <inf> apt_net_if_mgr: RSRQ -8 dB
uart:~$ [00:01:00.456,451] <inf> apt_net_if_mgr: IMEI: 863427063352620
uart:~$ [00:01:00.456,481] <inf> apt_net_if_mgr: MODEL_ID: BG96
uart:~$ [00:01:00.456,512] <inf> apt_net_if_mgr: MANUFACTURER: Quectel
uart:~$ [00:01:00.456,573] <inf> apt_net_if_mgr: SIM_IMSI: 234500093583367
uart:~$ [00:01:00.456,604] <inf> apt_net_if_mgr: SIM_ICCID: 8944501207215833670F
uart:~$ [00:01:00.456,634] <inf> apt_net_if_mgr: FW_VERSION: BG96MAR02A07M1G
uart:~$ [00:01:00.456,634] <inf> apt_net_if_mgr: LTE REGISTRATION_STATUS : 5
uart:~$ [00:01:00.456,756] <dbg> net_mgmt: mgmt_event_work_handler: (net_mgmt): Handling events, forwarding it relevantly
uart:~$ [00:01:00.456,787] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Event layer 4 code 276 cmd 3
uart:~$ [00:01:00.456,848] <dbg> net_mgmt: mgmt_run_slist_callbacks: (net_mgmt): Running callback 0x20019c58 : 0x23a41
uart:~$ uart:~$ uart:~$ --- 30 messages dropped ---
[00:01:00.848,022] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:00.848,052] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ --- 79 messages dropped ---
[00:01:00.848,083] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:00.848,144] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:00.848,175] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:00.848,205] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:00.848,236] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:00.848,297] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:00.848,327] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:00.862,274] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068dec data 0x200562f8 length 20
uart:~$ [00:01:00.862,304] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068dec skip 20
uart:~$ [00:01:00.862,365] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068dec skip 12
uart:~$ [00:01:00.862,426] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068dec skip 8
uart:~$ [00:01:00.862,457] <dbg> net_pkt: net_pkt_write: (date_time_work_q): pkt 0x20068dec data 0x2005630c length 8
uart:~$ [00:01:00.862,518] <dbg> net_pkt: net_pkt_skip: (date_time_work_q): pkt 0x20068dec skip 8
uart:~$ [00:01:00.862,609] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:00.862,670] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:00.862,762] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 1 frags 0x200694e8 (ppp_send():187)
uart:~$ [00:01:00.862,792] <dbg> net_if: net_if_tx: (tx_q[0]): Calling context send cb 0x2000f938 status 56
uart:~$ [00:01:00.862,884] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.862,945] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.862,976] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,037] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,098] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,128] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,189] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,250] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,311] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,342] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,403] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,464] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,494] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,555] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,616] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,647] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,708] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,769] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,800] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,861] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,922] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.863,952] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,013] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,074] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,105] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,166] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,227] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,257] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,318] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,379] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,410] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,471] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,532] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,562] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,624] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,685] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,746] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,929] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.864,990] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,051] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,081] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,142] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,203] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,234] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,295] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,356] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,386] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,447] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,478] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,539] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,570] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,631] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,692] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,722] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,783] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,844] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:00.865,936] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:00.865,997] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:00.866,088] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ --- 54 messages dropped ---
[00:01:01.274,810] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.274,841] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ --- 97 messages dropped ---
[00:01:01.274,871] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.274,932] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.274,963] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.274,993] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.275,024] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.275,085] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.275,115] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.275,146] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.291,717] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.291,748] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.291,809] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.291,870] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.291,900] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.291,961] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.291,992] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,053] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,114] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,144] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,205] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,266] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,297] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,358] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,419] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,449] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,510] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,572] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,602] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,663] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,755] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,816] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,846] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,907] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.292,968] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,029] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,060] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,121] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,182] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,365] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,426] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,487] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,548] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,579] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,640] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,701] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,731] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,792] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,853] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,884] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.293,945] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,006] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,036] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,097] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,158] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,219] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,250] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,311] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,342] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,403] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,464] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,525] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,555] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,616] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,677] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,738] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,769] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,830] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,891] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,921] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.294,982] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.295,166] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.295,227] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.295,288] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.295,318] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.295,379] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.295,410] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:01.295,532] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:01.295,593] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:01.295,684] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ --- 18 messages dropped ---
[00:01:01.669,158] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,189] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,250] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,281] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,311] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,372] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,403] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,433] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,464] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,525] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,555] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,586] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,647] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,677] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,708] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,769] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,799] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,830] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,891] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,921] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,952] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.669,982] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,043] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,074] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,104] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,166] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,257] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,288] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,318] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,379] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,410] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,440] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,501] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,532] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,562] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,593] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,654] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,684] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,715] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,776] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,806] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,837] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,898] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,928] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,959] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.670,989] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,051] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,081] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,112] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,173] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,203] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,234] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,264] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,325] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,356] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,417] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,478] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,508] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,569] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,600] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,661] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,722] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,752] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,813] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,844] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:01.671,936] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x200688dc data 0x2005c1f4 length 2
uart:~$ [00:01:01.672,058] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 20
uart:~$ [00:01:01.672,119] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x200688dc data 0x2005530e length 8
uart:~$ [00:01:01.672,149] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 8
uart:~$ [00:01:01.672,210] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 12
uart:~$ [00:01:01.672,241] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x200688dc skip 8
uart:~$ [00:01:01.672,363] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 24 RX 15 RDATA 0 TDATA 0
uart:~$ [00:01:01.672,637] <dbg> net_pkt: net_pkt_read: (date_time_work_q): pkt 0x200688dc data 0x2005f5b4 length 48
uart:~$ [00:01:01.672,729] <dbg> net_pkt: net_pkt_unref_debug: (date_time_work_q): RX [15] pkt 0x200688dc ref 0 frags 0x20069424 (zsock_recv_dgram():1217)
uart:~$ [00:01:01.672,790] <dbg> net_pkt: net_pkt_unref_debug: (date_time_work_q): RDATA (?) [0] frag 0x20069424 ref 0 frags (nil) (zsock_recv_dgram():1217)
uart:~$ [00:01:01.672,851] <dbg> net_pkt: net_pkt_frag_unref_debug: (date_time_work_q): RDATA (?) [0] frag 0x20069424 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:01.673,004] <inf> network: DATE_TIME_OBTAINED_NTP
uart:~$ [00:01:01.673,034] <inf> network: Obtained time:1742364219000
uart:~$ uart:~$ uart:~$ --- 48 messages dropped ---
[00:01:02.408,477] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,538] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,569] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,599] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,630] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,691] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,721] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,782] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,813] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,874] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,905] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.408,966] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,149] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,179] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,240] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,271] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,332] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,362] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,393] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,454] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,484] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,515] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,576] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,606] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,637] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,698] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,729] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,790] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,820] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,881] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.409,942] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,003] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,034] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,095] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,156] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,186] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,247] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,308] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,339] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,400] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,461] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,491] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,552] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,614] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,644] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,705] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,766] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,797] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,858] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,919] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.410,949] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,010] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,071] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,102] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,163] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,193] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,254] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,315] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,346] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,407] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,468] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,499] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,560] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,621] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,651] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,834] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,926] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.411,956] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.412,048] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:02.412,139] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:02.412,231] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ --- 96 messages dropped ---
[00:01:02.795,471] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.795,532] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.795,593] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ --- 58 messages dropped ---
[00:01:02.795,654] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.795,715] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ --- 122 messages dropped ---
[00:01:02.795,776] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.795,837] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.795,898] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.795,928] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.795,989] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.796,051] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.799,560] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:02.820,770] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.820,831] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.820,861] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.820,922] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.820,983] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,014] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,075] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,136] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,197] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,228] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,289] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,472] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,533] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,594] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,655] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,685] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,746] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,807] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,838] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,899] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,960] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.821,990] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,052] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,113] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,143] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,174] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,235] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,265] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,326] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,387] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,448] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,479] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,540] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,601] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,631] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,692] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,753] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,784] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,845] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,906] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,967] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.822,998] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,059] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,120] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,150] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,211] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,242] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,303] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,333] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,394] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,455] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,486] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,547] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,608] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,638] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,699] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,760] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,791] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,852] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,913] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.823,944] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.824,005] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.824,035] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.824,096] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.824,310] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.824,371] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.824,401] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:02.824,523] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:02.824,584] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
[00:01:02.824,645] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ --- 160 messages dropped ---
[00:01:03.201,568] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
[00:01:03.201,629] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:03.201,690] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:03.201,751] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:03.201,782] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:03.201,843] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:03.201,904] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:03.222,198] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x200688dc data 0x20061217 length 1
uart:~$ [00:01:03.230,926] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068da8 data 0x20056320 length 4
uart:~$ [00:01:03.230,957] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 4
uart:~$ [00:01:03.231,018] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068da8 data 0x200562f8 length 20
uart:~$ [00:01:03.231,048] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ [00:01:03.231,109] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 12
uart:~$ [00:01:03.231,140] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 8
uart:~$ [00:01:03.231,201] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068da8 data 0x2005630c length 20
uart:~$ [00:01:03.231,231] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ [00:01:03.231,353] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ --- 21 messages dropped ---
[00:01:03.231,506] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ [00:01:03.231,597] <dbg> net_tcp: tcp_send_process_no_lock: (): SYN Seq=48444825 Len=0
uart:~$ [00:01:03.231,628] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ [00:01:03.231,689] <dbg> net_pkt: pkt_alloc_with_buffer: (): On iface 0x2000f1f0 size 44
uart:~$ [00:01:03.231,750] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (): Data allocation maximum size 44 (requested 44)
uart:~$ [00:01:03.231,842] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x20069520 ref 1 (net_pkt_clone_internal():1950)
uart:~$ [00:01:03.231,903] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:03.231,933] <dbg> net_pkt: net_pkt_clone_internal: (): Cloned 0x20068da8 to 0x20068e30
uart:~$ [00:01:03.233,215] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,276] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,306] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,367] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,428] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,459] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,520] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,581] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,612] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,673] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,734] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,764] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,825] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,856] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,917] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.233,978] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,008] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,069] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,130] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,161] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,222] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,283] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,313] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,375] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,588] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,619] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,680] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.234,771] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [21] pkt 0x20068e30 ref 1 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:03.234,954] <dbg> net_pkt: net_pkt_unref_debug: (): TX [21] pkt 0x20068e30 ref 0 frags 0x20069520 (tcp_send():418)
uart:~$ [00:01:03.235,046] <dbg> net_pkt: net_pkt_unref_debug: (): TDATA (?) [0] frag 0x20069520 ref 0 frags (nil) (tcp_send():418)
uart:~$ [00:01:03.235,137] <dbg> net_pkt: net_pkt_frag_unref_debug: (): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:03.235,229] <dbg> net_tcp: tcp_conn_ref: (): conn: 0x200696a8, ref_count: 2
uart:~$ [00:01:03.235,260] <dbg> net_tcp: tcp_in: (): LISTEN->SYN_SENT
uart:~$ [00:01:03.315,521] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:03.315,551] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:03.315,643] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:03.315,673] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611f7 length 1
uart:~$ [00:01:03.315,734] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611e7 length 1
uart:~$ [00:01:03.315,765] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x2000f648 length 8
uart:~$ [00:01:03.315,856] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069504 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:03.315,917] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068e30 frag 0x20069504 (ppp_send_pkt:474)
uart:~$ [00:01:03.315,948] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611de length 2
uart:~$ [00:01:03.315,979] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611fc length 4
uart:~$ [00:01:03.316,070] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:03.316,131] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [21] pkt 0x20068e30 ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:03.316,223] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [21] pkt 0x20068e30 ref 1 frags 0x20069504 (ppp_send():187)
uart:~$ [00:01:03.316,284] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,345] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,406] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,436] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,497] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,558] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,619] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,650] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,711] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,772] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,802] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,864] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,925] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.316,955] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.317,016] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.317,047] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.317,169] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [21] pkt 0x20068e30 ref 0 frags 0x20069504 (modem_ppp_send_handler():381)
uart:~$ [00:01:03.317,230] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069504 ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:03.317,321] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:03.317,382] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069504 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ --- 617 messages dropped ---
[00:01:03.930,786] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.930,847] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.930,877] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.930,938] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.930,999] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,030] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,091] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,121] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ --- 73 messages dropped ---
[00:01:03.931,304] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,365] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,427] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,457] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,518] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,579] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,610] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.931,671] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,214] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,275] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,336] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,367] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,428] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,489] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,520] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,581] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,642] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,672] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,733] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,794] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,825] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,886] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,916] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.970,977] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,038] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,069] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,130] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,191] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,221] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,282] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,343] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,374] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,435] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,466] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,527] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,588] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,618] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,679] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,740] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,771] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,832] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,893] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,923] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.971,984] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,015] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,076] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,137] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,320] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,381] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,412] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,473] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,534] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,564] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,625] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,686] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,717] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,778] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,839] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,869] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,930] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.972,991] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,022] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,083] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,144] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,175] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,236] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,297] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,327] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,388] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,419] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,480] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,541] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,602] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:03.973,693] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [22] pkt 0x20068e30 ref 0 frags 0x20069504 (modem_ppp_send_handler():381)
uart:~$ [00:01:03.973,754] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069504 ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:03.973,846] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:03.973,937] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069504 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ --- 300 messages dropped ---
[00:01:04.604,095] <dbg> net_pkt: net_pkt_read: (): pkt 0x20068898 data 0x200202d4 length 5
uart:~$ [00:01:04.604,187] <dbg> net_pkt: net_pkt_read: (): pkt 0x20068898 data 0x200202d9 length 95
uart:~$ [00:01:04.604,248] <dbg> net_pkt: net_pkt_unref_debug: (): RX [14] pkt 0x20068898 ref 0 frags 0x20069440 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:04.604,339] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069440 ref 0 frags 0x20069424 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:04.604,431] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069424 ref 0 frags (nil) (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:04.604,492] <dbg> net_pkt: net_pkt_frag_unref_debug: (): RDATA (?) [0] frag 0x20069440 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:04.604,614] <dbg> net_pkt: pkt_alloc_with_buffer: (): On iface 0x2000f1f0 size 20
uart:~$ [00:01:04.604,675] <dbg> net_pkt: pkt_estimate_headers_length: (): HDRs length estimation 48
uart:~$ [00:01:04.604,705] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (): Data allocation maximum size 68 (requested 20)
uart:~$ [00:01:04.604,797] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x200694e8 ref 1 (tcp_out_ext():1558)
uart:~$ --- 573 messages dropped ---
[00:01:04.604,858] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:04.604,919] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ --- 241 messages dropped ---
[00:01:04.604,949] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:04.604,980] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.605,041] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:04.605,102] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.605,133] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 12
uart:~$ [00:01:04.694,610] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): RDATA (?) [0] frag 0x20069478 ref 1 (modem_ppp_process_received_byte():272)
uart:~$ [00:01:04.694,671] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:04.717,315] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x2006945c ref 0 frags 0x20069478 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:04.717,407] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069478 ref 0 frags 0x20069494 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:04.717,468] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069494 ref 0 frags (nil) (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:04.717,559] <dbg> net_pkt: net_pkt_frag_unref_debug: (): RDATA (?) [0] frag 0x20069424 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:04.717,742] <dbg> net_pkt: pkt_alloc_with_buffer: (): On iface 0x2000f1f0 size 20
uart:~$ [00:01:04.717,773] <dbg> net_pkt: pkt_estimate_headers_length: (): HDRs length estimation 48
uart:~$ [00:01:04.717,803] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (): Data allocation maximum size 68 (requested 20)
uart:~$ [00:01:04.717,926] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x200694e8 ref 1 (tcp_out_ext():1558)
uart:~$ [00:01:04.717,987] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:04.718,017] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.718,078] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:04.718,109] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.718,170] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:04.718,200] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.718,261] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 12
uart:~$ [00:01:04.718,292] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 8
uart:~$ [00:01:04.718,353] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:04.718,383] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.718,444] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.718,627] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.718,750] <dbg> net_tcp: tcp_send_process_no_lock: (): ACK Seq=48445375 Ack=3417817273 Len=0
uart:~$ [00:01:04.718,780] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:04.718,872] <dbg> net_pkt: net_pkt_ref_debug: (): TX [22] pkt 0x20068e30 ref 2 (tcp_send():370)
uart:~$ [00:01:04.718,963] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:04.719,024] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 3 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:04.719,116] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 2 frags 0x200694e8 (ppp_send():187)
uart:~$ [00:01:04.719,207] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,268] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,329] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,360] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,421] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,482] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,543] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,573] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,635] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,696] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,726] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,787] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,848] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,879] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,940] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.719,970] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,031] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,092] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,123] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,184] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,245] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,275] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,336] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,367] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,428] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,489] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,520] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,581] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,642] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,672] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,733] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,764] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,825] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,855] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,916] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.720,977] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.721,038] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.721,069] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.721,130] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.721,191] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:04.721,282] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [22] pkt 0x20068e30 ref 1 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:04.721,496] <dbg> net_pkt: net_pkt_unref_debug: (): TX [22] pkt 0x20068e30 ref 0 frags 0x200694e8 (tcp_send():418)
uart:~$ [00:01:04.721,588] <dbg> net_pkt: net_pkt_unref_debug: (): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (tcp_send():418)
uart:~$ [00:01:04.721,649] <dbg> net_pkt: net_pkt_frag_unref_debug: (): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ --- 123 messages dropped ---
[00:01:05.212,829] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:05.212,890] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ --- 184 messages dropped ---
[00:01:05.212,951] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ --- 199 messages dropped ---
[00:01:05.212,982] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ --- 417 messages dropped ---
[00:01:05.213,043] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:05.213,104] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:05.213,165] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ --- 378 messages dropped ---
[00:01:05.213,226] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 127 (requested 128)
uart:~$ [00:01:05.213,348] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): RDATA (?) [0] frag 0x20069478 ref 1 (modem_ppp_process_received_byte():272)
uart:~$ --- 340 messages dropped ---
[00:01:05.233,764] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:05.254,577] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:05.289,733] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069408 ref 0 frags 0x20069440 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:05.289,825] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069440 ref 0 frags 0x20069424 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:05.327,972] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.328,002] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.365,570] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069408 ref 0 frags 0x2006945c (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:05.365,661] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x2006945c ref 0 frags 0x20069478 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:05.365,753] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069478 ref 0 frags (nil) (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:05.365,814] <dbg> net_pkt: net_pkt_frag_unref_debug: (): RDATA (?) [0] frag 0x200694b0 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:05.365,997] <dbg> net_pkt: pkt_alloc_with_buffer: (): On iface 0x2000f1f0 size 20
uart:~$ [00:01:05.366,058] <dbg> net_pkt: pkt_estimate_headers_length: (): HDRs length estimation 48
uart:~$ [00:01:05.366,088] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (): Data allocation maximum size 68 (requested 20)
uart:~$ [00:01:05.366,180] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x200694e8 ref 1 (tcp_out_ext():1558)
uart:~$ [00:01:05.366,241] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:05.366,302] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:05.366,363] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:05.366,394] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:05.366,455] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:05.366,485] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:05.366,516] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 12
uart:~$ [00:01:05.366,577] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 8
uart:~$ [00:01:05.366,638] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:05.366,668] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:05.366,729] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:05.366,912] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:05.367,004] <dbg> net_tcp: tcp_send_process_no_lock: (): ACK Seq=48445375 Ack=3417818637 Len=0
uart:~$ [00:01:05.367,065] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:05.367,156] <dbg> net_pkt: net_pkt_ref_debug: (): TX [22] pkt 0x20068e30 ref 2 (tcp_send():370)
uart:~$ [00:01:05.367,248] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:05.367,309] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 3 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:05.367,401] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 2 frags 0x200694e8 (ppp_send():187)
uart:~$ [00:01:05.367,492] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,523] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,584] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,645] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,706] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,736] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,797] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,858] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,919] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.367,950] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,011] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,072] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,103] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,164] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,194] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,255] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,316] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,347] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,408] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,469] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,499] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,560] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,621] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,652] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,713] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,774] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,804] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,865] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,896] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,957] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.368,988] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,049] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,110] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,140] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,201] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,262] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,293] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,354] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,415] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,445] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:05.369,537] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [22] pkt 0x20068e30 ref 1 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:05.369,781] <dbg> net_pkt: net_pkt_unref_debug: (): TX [22] pkt 0x20068e30 ref 0 frags 0x200694e8 (tcp_send():418)
uart:~$ [00:01:05.369,873] <dbg> net_pkt: net_pkt_unref_debug: (): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (tcp_send():418)
uart:~$ [00:01:05.369,934] <dbg> net_pkt: net_pkt_frag_unref_debug: (): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ --- 94 messages dropped ---
[00:01:05.851,135] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.851,196] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.851,257] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.851,318] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ --- 283 messages dropped ---
[00:01:05.851,379] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.851,440] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.851,501] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.851,562] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ --- 827 messages dropped ---
[00:01:05.851,593] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ --- 436 messages dropped ---
[00:01:05.887,664] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.887,695] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:05.887,756] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 127 (requested 128)
uart:~$ [00:01:05.887,878] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): RDATA (?) [0] frag 0x20069440 ref 1 (modem_ppp_process_received_byte():272)
uart:~$ [00:01:05.960,327] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:05.960,388] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:05.960,449] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:06.002,044] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069424 ref 0 frags 0x20069440 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:06.002,105] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069440 ref 0 frags 0x20069408 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:06.002,197] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069408 ref 0 frags (nil) (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:06.002,258] <dbg> net_pkt: net_pkt_frag_unref_debug: (): RDATA (?) [0] frag 0x20069494 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:06.002,471] <dbg> net_pkt: pkt_alloc_with_buffer: (): On iface 0x2000f1f0 size 20
uart:~$ [00:01:06.002,502] <dbg> net_pkt: pkt_estimate_headers_length: (): HDRs length estimation 48
uart:~$ [00:01:06.002,532] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (): Data allocation maximum size 68 (requested 20)
uart:~$ [00:01:06.002,655] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x200694e8 ref 1 (tcp_out_ext():1558)
uart:~$ [00:01:06.002,716] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:06.002,746] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.002,807] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:06.002,838] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.002,899] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:06.002,929] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.002,990] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 12
uart:~$ [00:01:06.003,021] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 8
uart:~$ [00:01:06.003,082] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:06.003,112] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.003,173] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.003,356] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.003,479] <dbg> net_tcp: tcp_send_process_no_lock: (): ACK Seq=48445375 Ack=3417820001 Len=0
uart:~$ [00:01:06.003,509] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.003,601] <dbg> net_pkt: net_pkt_ref_debug: (): TX [22] pkt 0x20068e30 ref 2 (tcp_send():370)
uart:~$ [00:01:06.003,692] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:06.003,753] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 3 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:06.003,845] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 2 frags 0x200694e8 (ppp_send():187)
uart:~$ [00:01:06.003,936] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.003,997] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,028] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,089] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,150] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,211] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,241] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,302] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,364] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,394] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,455] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,516] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,547] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,608] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,669] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,699] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,760] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,791] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,852] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,913] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.004,943] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,004] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,065] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,096] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,157] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,218] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,249] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,310] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,340] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,401] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,462] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,493] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,554] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,584] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,645] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,706] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,737] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,798] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,828] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,889] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.005,981] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [22] pkt 0x20068e30 ref 1 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:06.006,225] <dbg> net_pkt: net_pkt_unref_debug: (): TX [22] pkt 0x20068e30 ref 0 frags 0x200694e8 (tcp_send():418)
uart:~$ [00:01:06.006,286] <dbg> net_pkt: net_pkt_unref_debug: (): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (tcp_send():418)
uart:~$ [00:01:06.006,378] <dbg> net_pkt: net_pkt_frag_unref_debug: (): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:06.316,101] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:06.316,162] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:06.316,253] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:06.316,284] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611f7 length 1
uart:~$ [00:01:06.316,314] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611e7 length 1
uart:~$ [00:01:06.316,345] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x2000f648 length 8
uart:~$ [00:01:06.316,467] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:06.316,497] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068e30 frag 0x20069520 (ppp_send_pkt:474)
uart:~$ [00:01:06.316,528] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611de length 2
uart:~$ [00:01:06.316,589] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068e30 data 0x200611fc length 4
uart:~$ [00:01:06.316,680] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:06.316,741] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:06.316,802] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 1 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:06.316,864] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.316,925] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.316,955] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.316,986] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.317,047] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.317,077] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.317,138] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ --- 360 messages dropped ---
[00:01:06.317,169] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.317,230] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.317,260] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ --- 96 messages dropped ---
[00:01:06.317,291] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.317,352] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.504,577] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:06.504,638] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:06.504,699] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:06.504,730] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ --- 1202 messages dropped ---
[00:01:06.504,791] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:06.518,310] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:06.518,371] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:06.636,566] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x200694b0 ref 0 frags 0x20069424 (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:06.636,688] <dbg> net_pkt: net_pkt_unref_debug: (): RDATA (?) [0] frag 0x20069424 ref 0 frags (nil) (zsock_recv_stream_immediate():1289)
uart:~$ [00:01:06.636,749] <dbg> net_pkt: net_pkt_frag_unref_debug: (): RDATA (?) [0] frag 0x2006945c ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:06.636,932] <dbg> net_pkt: pkt_alloc_with_buffer: (): On iface 0x2000f1f0 size 20
uart:~$ [00:01:06.636,993] <dbg> net_pkt: pkt_estimate_headers_length: (): HDRs length estimation 48
uart:~$ [00:01:06.637,023] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (): Data allocation maximum size 68 (requested 20)
uart:~$ [00:01:06.637,115] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x200694e8 ref 1 (tcp_out_ext():1558)
uart:~$ [00:01:06.637,176] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:06.637,237] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.637,268] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:06.637,329] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.637,390] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:06.637,420] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.637,451] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 12
uart:~$ [00:01:06.637,512] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 8
uart:~$ [00:01:06.637,542] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:06.637,603] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.637,664] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.637,847] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.637,939] <dbg> net_tcp: tcp_send_process_no_lock: (): ACK Seq=48445375 Ack=3417821365 Len=0
uart:~$ [00:01:06.638,000] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.638,092] <dbg> net_pkt: net_pkt_ref_debug: (): TX [22] pkt 0x20068e30 ref 2 (tcp_send():370)
uart:~$ [00:01:06.638,183] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ --- 48 messages dropped ---
[00:01:06.638,244] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 3 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:06.638,336] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 2 frags 0x200694e8 (ppp_send():187)
uart:~$ [00:01:06.638,427] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.638,458] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.638,519] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.638,580] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.638,610] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:06.762,390] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.762,451] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:06.762,481] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.762,512] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x200562f8 length 20
uart:~$ [00:01:06.762,542] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.762,573] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 12
uart:~$ [00:01:06.762,634] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 8
uart:~$ [00:01:06.762,664] <dbg> net_pkt: net_pkt_write: (): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:06.762,695] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.762,756] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.762,939] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.763,061] <dbg> net_tcp: tcp_send_process_no_lock: (): FIN,ACK Seq=48445375 Ack=3417821365 Len=0
uart:~$ [00:01:06.763,092] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068e30 skip 20
uart:~$ [00:01:06.763,122] <dbg> net_pkt: pkt_alloc_with_buffer: (): On iface 0x2000f1f0 size 40
uart:~$ [00:01:06.763,183] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (): Data allocation maximum size 40 (requested 40)
uart:~$ [00:01:06.763,275] <dbg> net_pkt: pkt_alloc_buffer: (): TDATA (?) [0] frag 0x20069520 ref 1 (net_pkt_clone_internal():1950)
uart:~$ [00:01:06.763,305] <dbg> net_pkt: net_pkt_skip: (): pkt 0x20068da8 skip 20
uart:~$ [00:01:06.763,366] <dbg> net_pkt: net_pkt_clone_internal: (): Cloned 0x20068e30 to 0x20068da8
uart:~$ [00:01:06.763,427] <dbg> net_pkt: net_pkt_ref_debug: (): TX [21] pkt 0x20068da8 ref 2 (tcp_send():370)
uart:~$ [00:01:06.763,519] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068da8, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:06.763,580] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [21] pkt 0x20068da8 ref 3 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:06.763,641] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [21] pkt 0x20068da8 ref 2 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:06.763,732] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.763,763] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.763,824] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.763,885] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.763,916] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.763,977] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,038] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,099] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,160] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,190] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,251] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,312] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,343] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,404] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,434] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,495] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,556] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,587] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,648] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,709] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,739] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,801] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,831] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,892] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,953] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.764,984] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,045] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,106] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,136] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,197] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,228] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,289] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,350] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,380] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,441] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,502] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,533] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,594] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,655] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,686] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068da8 data 0x2006123a length 1
uart:~$ [00:01:06.765,808] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [21] pkt 0x20068da8 ref 1 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:06.766,021] <dbg> net_pkt: net_pkt_unref_debug: (): TX [21] pkt 0x20068da8 ref 0 frags 0x20069520 (tcp_send():418)
uart:~$ [00:01:06.766,113] <dbg> net_pkt: net_pkt_unref_debug: (): TDATA (?) [0] frag 0x20069520 ref 0 frags (nil) (tcp_send():418)
uart:~$ [00:01:06.766,174] <dbg> net_pkt: net_pkt_frag_unref_debug: (): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ --- 353 messages dropped ---
[00:01:06.766,296] <dbg> net_tcp: net_tcp_put: (): ESTABLISHED->FIN_WAIT_1
uart:~$ --- 204 messages dropped ---
[00:01:06.766,326] <dbg> net_tcp: tcp_conn_unref: (): conn: 0x200696a8, ref_count=2
uart:~$ [00:01:06.766,357] <err> mqtt_helper: mqtt_connect, error: -11
uart:~$ --- 147 messages dropped ---
[00:01:07.134,368] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:07.134,399] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:07.134,460] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:07.134,521] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:07.134,582] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:07.134,643] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:07.154,754] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068920 data 0x20061217 length 1
uart:~$ [00:01:07.171,478] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 8
uart:~$ [00:01:07.171,508] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068e30 data 0x2005630c length 20
uart:~$ [00:01:07.171,569] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 20
uart:~$ [00:01:07.171,630] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 20
uart:~$ [00:01:07.171,752] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 20
uart:~$ [00:01:07.171,844] <dbg> net_tcp: tcp_send_process_no_lock: (rx_q[0]): RST Seq=48445376 Len=0
uart:~$ [00:01:07.171,905] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068e30 skip 20
uart:~$ [00:01:07.171,997] <dbg> net_pkt: net_pkt_ref_debug: (rx_q[0]): TX [22] pkt 0x20068e30 ref 2 (tcp_send():370)
uart:~$ [00:01:07.172,088] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): TX [22] pkt 0x20068e30 ref 1 frags 0x200694e8 (tcp_send():418)
uart:~$ [00:01:07.172,149] <dbg> net_tcp: tcp_in: (rx_q[0]): FIN_WAIT_1->TIME_WAIT
uart:~$ [00:01:07.172,241] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [14] pkt 0x20068920 ref 0 frags 0x20069424 (processing_data():176)
uart:~$ [00:01:07.172,302] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069424 ref 0 frags 0x200694b0 (processing_data():176)
uart:~$ [00:01:07.172,393] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x200694b0 ref 0 frags 0x200694cc (processing_data():176)
uart:~$ [00:01:07.172,485] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x200694cc ref 0 frags 0x20069494 (processing_data():176)
uart:~$ [00:01:07.172,546] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069494 ref 0 frags 0x20069478 (processing_data():176)
uart:~$ [00:01:07.172,637] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069478 ref 0 frags 0x2006945c (processing_data():176)
uart:~$ [00:01:07.172,698] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x2006945c ref 0 frags (nil) (processing_data():176)
uart:~$ [00:01:07.172,790] <dbg> net_pkt: net_pkt_frag_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069424 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:07.172,943] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 22 RX 15 RDATA 0 TDATA 0
uart:~$ [00:01:07.173,034] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:07.173,095] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:07.173,187] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 1 frags 0x200694e8 (ppp_send():187)
uart:~$ --- 174 messages dropped ---
[00:01:07.173,248] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.173,309] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.173,370] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.173,431] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.173,461] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.173,522] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.323,974] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 22 RX 14 RDATA 0 TDATA 0
uart:~$ [00:01:07.324,035] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068e30, prio 0) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:07.324,127] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:07.324,188] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [22] pkt 0x20068e30 ref 1 frags 0x200694e8 (ppp_send():187)
uart:~$ [00:01:07.324,279] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:07.324,310] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068898 data 0x20061217 length 1
uart:~$ [00:01:07.324,401] <dbg> net_pkt: net_pkt_read: (rx_q[0]): pkt 0x20068898 data 0x2005c1f4 length 2
uart:~$ [00:01:07.324,523] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:01:07.324,584] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 12
uart:~$ [00:01:07.324,615] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 8
uart:~$ [00:01:07.324,676] <dbg> net_pkt: net_pkt_write: (rx_q[0]): pkt 0x20068898 data 0x20055396 length 20
uart:~$ [00:01:07.324,707] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:01:07.324,798] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:01:07.324,859] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:01:07.324,920] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:01:07.324,981] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:01:07.325,164] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:01:07.325,439] <dbg> net_tcp: tcp_in: (rx_q[0]): FIN,ACK Seq=3417821992 Ack=48445376 Len=0 [TIME_WAIT Seq=48445376 Ack=3417821365]
uart:~$ [00:01:07.325,469] <dbg> net_tcp: tcp_in: (rx_q[0]): Lowering send window from 27450 to 1365
uart:~$ [00:01:07.325,531] <dbg> net_pkt: net_pkt_skip: (rx_q[0]): pkt 0x20068898 skip 20
uart:~$ [00:01:07.325,622] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RX [14] pkt 0x20068898 ref 0 frags 0x20069478 (processing_data():176)
uart:~$ [00:01:07.325,683] <dbg> net_pkt: net_pkt_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069478 ref 0 frags (nil) (processing_data():176)
uart:~$ [00:01:07.325,775] <dbg> net_pkt: net_pkt_frag_unref_debug: (rx_q[0]): RDATA (?) [0] frag 0x20069478 ref 0 (net_pkt_unref_debug():608)
uart:~$ [00:01:07.325,866] <dbg> net_pkt: net_pkt_print: (rx_q[0]): TX 22 RX 15 RDATA 0 TDATA 0
uart:~$ [00:01:07.325,927] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.325,988] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,049] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,080] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,141] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,202] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,232] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,293] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,354] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,416] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,477] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,507] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,568] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,599] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,660] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,690] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,751] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,812] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,873] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,904] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,965] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.326,995] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,056] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,087] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,148] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,209] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,239] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,301] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,362] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,392] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,453] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,514] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,575] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,606] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,667] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,728] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,758] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,819] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,880] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.327,911] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068e30 data 0x2006123a length 1
uart:~$ [00:01:07.328,155] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [22] pkt 0x20068e30 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:07.328,247] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:07.328,308] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ [00:01:08.671,051] <dbg> net_tcp: tcp_timewait_timeout: (tcp_work): conn: 0x200696a8  [TIME_WAIT Seq=48445376 Ack=3417821365]
uart:~$ [00:01:08.671,112] <dbg> net_tcp: tcp_conn_close_debug: (tcp_work): conn: 0x200696a8 closed by TCP stack (tcp_timewait_timeout():1954)
uart:~$ [00:01:08.671,142] <dbg> net_tcp: tcp_conn_close_debug: (tcp_work): TIME_WAIT->CLOSED
uart:~$ [00:01:08.671,203] <dbg> net_tcp: tcp_conn_unref: (tcp_work): conn: 0x200696a8, ref_count=1
uart:~$ [00:01:08.671,325] <dbg> net_if: net_if_addr_unref_debug: (tcp_work): [2] ifaddr 100.75.251.108 state 1 ref 1 (tcp_conn_release():783)
uart:~$ [00:01:08.671,386] <dbg> net_pkt: net_pkt_unref_debug: (tcp_work): TX [23] pkt 0x20068dec ref 0 frags (nil) (tcp_conn_release():795)
uart:~$ [00:01:08.671,447] <dbg> net_pkt: net_pkt_unref_debug: (tcp_work): RX [15] pkt 0x200688dc ref 0 frags (nil) (tcp_conn_release():798)
uart:~$ [00:01:09.316,680] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:09.316,741] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:09.316,833] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:09.316,864] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611f7 length 1
uart:~$ [00:01:09.316,925] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611e7 length 1
uart:~$ [00:01:09.316,955] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x2000f648 length 8
uart:~$ [00:01:09.317,047] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:09.317,108] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068dec frag 0x20069520 (ppp_send_pkt:474)
uart:~$ [00:01:09.317,138] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611de length 2
uart:~$ [00:01:09.317,169] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611fc length 4
uart:~$ [00:01:09.317,260] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:09.317,321] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:09.317,382] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 1 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:09.317,443] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,504] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,535] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,596] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,626] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,657] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,718] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,749] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,810] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,840] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,871] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,932] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.317,962] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.318,023] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.318,054] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.318,084] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:09.318,176] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:09.318,237] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:09.318,298] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:09.318,359] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ [00:01:12.317,321] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:12.317,382] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:12.317,474] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:12.317,504] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611f7 length 1
uart:~$ [00:01:12.317,535] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611e7 length 1
uart:~$ [00:01:12.317,596] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x2000f648 length 8
uart:~$ [00:01:12.317,687] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:12.317,718] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068dec frag 0x20069520 (ppp_send_pkt:474)
uart:~$ [00:01:12.317,749] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611de length 2
uart:~$ [00:01:12.317,810] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611fc length 4
uart:~$ [00:01:12.317,901] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:12.317,962] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:12.318,023] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 1 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:12.318,115] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,145] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,176] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,237] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,267] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,328] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,359] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,420] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,450] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,481] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,542] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,572] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,603] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,664] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,695] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,725] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:12.318,817] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:12.318,878] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:12.318,939] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:12.319,000] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ [00:01:15.317,932] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:15.317,993] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:15.318,084] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:15.318,115] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611f7 length 1
uart:~$ [00:01:15.318,145] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611e7 length 1
uart:~$ [00:01:15.318,206] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x2000f648 length 8
uart:~$ [00:01:15.318,298] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:15.318,328] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068dec frag 0x20069520 (ppp_send_pkt:474)
uart:~$ [00:01:15.318,359] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611de length 2
uart:~$ [00:01:15.318,420] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611fc length 4
uart:~$ [00:01:15.318,511] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:15.318,572] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:15.318,634] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 1 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:15.318,695] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.318,756] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.318,786] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.318,847] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.318,878] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.318,939] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.318,969] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,030] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,061] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,091] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,152] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,183] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,213] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,274] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,305] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,335] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:15.319,427] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:15.319,488] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:15.319,549] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:15.319,610] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ [00:01:18.318,542] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:18.318,603] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:18.318,695] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:18.318,725] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611f7 length 1
uart:~$ [00:01:18.318,756] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611e7 length 1
uart:~$ [00:01:18.318,817] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x2000f648 length 8
uart:~$ [00:01:18.318,908] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:18.318,939] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068dec frag 0x20069520 (ppp_send_pkt:474)
uart:~$ [00:01:18.318,969] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611de length 2
uart:~$ [00:01:18.319,030] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611fc length 4
uart:~$ [00:01:18.319,122] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:18.319,183] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:18.319,244] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 1 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:18.319,335] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,366] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,396] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,458] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,488] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,549] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,580] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,641] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,671] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,702] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,763] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,793] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,824] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,885] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,915] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.319,946] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:18.320,037] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:18.320,098] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:18.320,159] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:18.320,220] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ [00:01:21.319,152] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:21.319,213] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:21.319,305] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:21.319,335] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611f7 length 1
uart:~$ [00:01:21.319,366] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611e7 length 1
uart:~$ [00:01:21.319,427] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x2000f648 length 8
uart:~$ [00:01:21.319,519] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:21.319,549] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068dec frag 0x20069520 (ppp_send_pkt:474)
uart:~$ [00:01:21.319,580] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611de length 2
uart:~$ [00:01:21.319,641] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611fc length 4
uart:~$ [00:01:21.319,732] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:21.319,793] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:21.319,854] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 1 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:21.319,946] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.319,976] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,007] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,068] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,098] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,159] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,190] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,251] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,281] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,312] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,373] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,404] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,434] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,495] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,526] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,556] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:21.320,648] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:21.320,709] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:21.320,770] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:21.320,831] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ [00:01:24.319,763] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:24.319,824] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:24.319,915] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:24.319,946] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611f7 length 1
uart:~$ [00:01:24.319,976] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611e7 length 1
uart:~$ [00:01:24.320,037] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x2000f648 length 8
uart:~$ [00:01:24.320,129] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:24.320,159] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068dec frag 0x20069520 (ppp_send_pkt:474)
uart:~$ [00:01:24.320,190] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611de length 2
uart:~$ [00:01:24.320,251] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611fc length 4
uart:~$ [00:01:24.320,343] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:24.320,404] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:24.320,465] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 1 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:24.320,556] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,587] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,617] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,678] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,709] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,770] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,800] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,861] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,892] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,922] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.320,983] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.321,014] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.321,044] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.321,105] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.321,136] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.321,166] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:24.321,258] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:24.321,319] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:24.321,380] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:24.321,441] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$ uart:~$ uart:~$ [00:01:24.727,752] <inf> apt_net_if_mgr: net_if_auto_ctrl_work_routine started...
uart:~$ [00:01:24.727,783] <inf> apt_net_if_mgr: Checking network connectivity...
uart:~$ [00:01:24.727,783] <inf> apt_net_if_mgr: Network connectivity present
uart:~$ [00:01:24.727,783] <inf> apt_net_if_mgr: Next connection check retry in 1 minutes
uart:~$ uart:~$ [00:01:27.320,404] <dbg> net_pkt: pkt_alloc_with_buffer: (sysworkq): On iface 0x2000f1f0 size 10
uart:~$ [00:01:27.320,465] <dbg> net_pkt: net_pkt_alloc_buffer_debug: (sysworkq): Data allocation maximum size 10 (requested 10)
uart:~$ [00:01:27.320,556] <dbg> net_pkt: pkt_alloc_buffer: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 1 (ppp_my_options_add():224)
uart:~$ [00:01:27.320,587] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611f7 length 1
uart:~$ [00:01:27.320,617] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611e7 length 1
uart:~$ [00:01:27.320,678] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x2000f648 length 8
uart:~$ [00:01:27.320,770] <dbg> net_pkt: net_pkt_get_reserve_data_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 1 (ppp_send_pkt():467)
uart:~$ [00:01:27.320,800] <dbg> net_pkt: net_pkt_frag_insert_debug: (sysworkq): pkt 0x20068dec frag 0x20069520 (ppp_send_pkt:474)
uart:~$ [00:01:27.320,831] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611de length 2
uart:~$ [00:01:27.320,892] <dbg> net_pkt: net_pkt_write: (sysworkq): pkt 0x20068dec data 0x200611fc length 4
uart:~$ [00:01:27.320,983] <dbg> net_if: net_if_tx: (tx_q[0]): Processing (pkt 0x20068dec, prio 1) network packet iface 2 (0x2000f1f0)
uart:~$ [00:01:27.321,044] <dbg> net_pkt: net_pkt_ref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 2 (modem_ppp_ppp_api_send():476)
uart:~$ [00:01:27.321,105] <dbg> net_pkt: net_pkt_unref_debug: (tx_q[0]): TX [23] pkt 0x20068dec ref 1 frags 0x20069520 (ppp_send():187)
uart:~$ [00:01:27.321,197] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,228] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,258] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,319] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,350] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,411] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,441] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,502] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,533] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,563] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,624] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,655] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,685] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,746] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,777] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,807] <dbg> net_pkt: net_pkt_read: (sysworkq): pkt 0x20068dec data 0x2006123a length 1
uart:~$ [00:01:27.321,899] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TX [23] pkt 0x20068dec ref 0 frags 0x20069520 (modem_ppp_send_handler():381)
uart:~$ [00:01:27.321,960] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 frags 0x200694e8 (modem_ppp_send_handler():381)
uart:~$ [00:01:27.322,021] <dbg> net_pkt: net_pkt_unref_debug: (sysworkq): TDATA (?) [0] frag 0x200694e8 ref 0 frags (nil) (modem_ppp_send_handler():381)
uart:~$ [00:01:27.322,082] <dbg> net_pkt: net_pkt_frag_unref_debug: (sysworkq): TDATA (?) [0] frag 0x20069520 ref 0 (net_pkt_unref_debug():608)
uart:~$
uart:~$
