Sysbuild and MCUboot porting build error
I am working on a project with an nrf9160 on a custom board that I first developed with NCS v2.6.1.
I am trying to upgrade to latest NCS v2.9.1 but I am facing an issue a link stage.
I moved my custom board definition to HW model v2 without any (visible) issue and I want to move the build system to sysbuild and use MCUboot as immutable first-stage bootloader.
If followed the different guides and looked at how it has been done in the existing samples in NCS repository but I am facing an issue at link time where it says that a section does not fit in FLASH region.
[544/549] Linking C executable zephyr/zephyr_pre0.elf
/home/alexandre/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
/home/alexandre/ncs/toolchains/b77d8c1312/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 154696 bytes
collect2: error: ld returned 1 exit status
Here is the result of the partition manager report.
  flash_primary (0x100000 - 1024kB):
+---0x0: b0_container (0x8000 - 32kB)--------------+
| 0x0: b0 (0x8000 - 32kB)                          |
+---0x8000: s0 (0xc000 - 48kB)---------------------+
| 0x8000: s0_pad (0x200 - 512B)                    |
+---0x8200: s0_image (0xbe00 - 47kB)---------------+
| 0x8200: mcuboot (0xbe00 - 47kB)                  |
| 0x14000: EMPTY_0 (0x4000 - 16kB)                 |
+---0x18000: s1 (0xc000 - 48kB)--------------------+
| 0x18000: s1_pad (0x200 - 512B)                   |
| 0x18200: s1_image (0xbe00 - 47kB)                |
| 0x24000: EMPTY_1 (0x4000 - 16kB)                 |
+---0x28000: mcuboot_primary (0x68000 - 416kB)-----+
+---0x28000: tfm_secure (0x8000 - 32kB)------------+
| 0x28000: mcuboot_pad (0x200 - 512B)              |
+---0x28200: app_image (0x67e00 - 415kB)-----------+
+---0x28200: mcuboot_primary_app (0x67e00 - 415kB)-+
| 0x28200: tfm (0x7e00 - 31kB)                     |
+---0x30000: tfm_nonsecure (0x60000 - 384kB)-------+
| 0x30000: app (0x60000 - 384kB)                   |
| 0x90000: mcuboot_secondary (0x68000 - 416kB)     |
| 0xf8000: EMPTY_2 (0x6000 - 24kB)                 |
+---0xfe000: nonsecure_storage (0x2000 - 8kB)------+
| 0xfe000: settings_storage (0x2000 - 8kB)         |
I don't know where to start to investigate this issue. Also I am not sure to fully understand what are the different image built in non-secure mode (b0, s0, s1, ...).
Regards
Alexandre
    Please check what the size of the main app was in your  project based on v2.6.1 and also create a partition manager report of that project for comparison. The NSIB bootloader (B0) and the s0 and s1 slots are included when you enable SB_CONFIG_SECURE_BOOT_APPCORE and it results in less available space for the application slots.
    Vidar
  • Hello and thanks for your answer !
    Unfortunately adding version 2.9.1 broke my 2.6.1 installation.
    I get a cmake error regarding python when trying to build:
    -- CMake version: 3.21.0
    -- Using NCS Toolchain 2.8.20241119.788085347090 for building. (/home/alexandre/ncs/toolchains/b77d8c1312/cmake)
    CMake Error at /home/alexandre/ncs/toolchains/2be090971e/usr/local/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
      Could NOT find Python3 (missing: Interpreter) (Required is at least version
      "3.8")
          Reason given by package:
              Interpreter: Cannot run the interpreter "/home/alexandre/ncs/toolchains/b77d8c1312/usr/local/bin/python3"
    Have you tried using an older version of the NCS toolchain? It looks like you are currently using v2.8.0.
  • Sorry for the delay,
    I tried to specify the toolchain to use because I have both NCS version 2.6.1 and 2.9.1 installed but it does not work. I end up removing toolchain for 2.9.1 but I still have the same issue with toolchain 2.6:
    -- Using NCS Toolchain 2.6.20240304.188451165982 for building. (/home/alexandre/ncs/toolchains/2be090971e/cmake)
      "3.8")
    It still tries to run interpreter in toolchain b77d8c1312 which correspond to toolchain for 2.9.1 (I think).
    I will try to clean my env and reinstall it.
  • I assume this path does not exist anymore since you have removed the toolcain: /home/alexandre/ncs/toolchains/b77d8c1312/usr/local/bin/python3? Either way, I think you should be able to build the previous project with the new toolchain.
