nrf5340 custom board build issue IPC Radio
I want to get the software for nrf5340 audio dk running on a custom board hardware. For that I created a custom board with the VS code plugin. For the beginning
I did´nt changed anything in the code, cause I just want to compile the audio dk software with a custom board. I compared the whole board files of the nrf5340 audio dk board and my new created custom board. They seem to be identical besides of the custom name.
So now my problem:
I can compile the sample audio dk software from SDK toolchain v2.9.1 without error with the nrf5340 board files.
When I try to use custom board files i always get a compile error at IPC Radio. And I don´t know how to solve it.
I added the log as txt.
I can imagine that this is not a big problem for most of you.
Best regards
Contax
Executing task: nRF Connect: Generate config nrf5340_headset/nrf5340/cpuapp for c:\ncs\v2.9.1\nrf\applications\nrf5340_audio_headset
Building nrf5340_audio_headset
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build c:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset --pristine --board nrf5340_headset/nrf5340/cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/users/v/desktop/headset/software/coms;c:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.9.1/zephyr/.cache
-- Board: nrf5340_headset, qualifiers: nrf5340/cpuapp
Parsing c:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/Kconfig.sysbuild
Loaded configuration 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/_sysbuild/empty.conf'
Merged configuration 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/_sysbuild/empty.conf'
Configuration saved to 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/zephyr/.config'
Kconfig header saved to 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/_sysbuild/autoconf.h'
   * Running CMake for nrf5340_audio_headset *
-- Application: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset
-- CMake version: 3.21.0
-- Zephyr version: 3.7.99 (C:/ncs/v2.9.1/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/Users/V/Desktop/headset/software/COMS/boards/privat/nrf5340_headset/nrf5340_headset_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset/zephyr/dts.cmake
warning: Experimental symbol NRF5340_AUDIO is enabled.
Parsing C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/Kconfig
Loaded configuration 'C:/Users/V/Desktop/headset/software/COMS/boards/privat/nrf5340_headset/nrf5340_headset_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/prj.conf'
Merged configuration 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset/zephyr/.config.sysbuild'
Configuration saved to 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset/zephyr/.config'
Kconfig header saved to 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Build type:
-- libmetal version: 1.6.0 (C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset)
-- Host:    Windows/AMD64
-- Target:  Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.6.1 (C:/ncs/v2.9.1/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS :  -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Setting build type to 'MinSizeRel' as none was specified.
CMake Warning at C:/ncs/v2.9.1/zephyr/CMakeLists.txt:2133 (message):
CMake Warning at C:/ncs/v2.9.1/zephyr/CMakeLists.txt:2164 (message):
        The CMake build type was set to 'MinSizeRel', but the optimization flag was set to '-Og'.
        This may be intentional and the warning can be turned off by setting the CMake variable 'NO_BUILD_TYPE_WARNING'
-- Configuring done
CMake Warning in C:/Users/V/Desktop/headset/software/COMS/boards/privat/nrf5340_headset/CMakeLists.txt:
  The object file directory
    C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset/zephyr/boards/boards/arm/nrf5340_headset/CMakeFiles/..__..__..__Users__V__Desktop__headset__software__COMS__boards__privat__nrf5340_headset.dir/./
  has 227 characters.  The maximum full path to an object file is 250
  characters (see CMAKE_OBJECT_PATH_MAX).  Object file
    nrf5340_headset_config.c.obj
  cannot be safely placed under this directory.  The build may not work
  correctly.
-- Generating done
-- Build files have been written to: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset
   * Running CMake for ipc_radio *
-- Application: C:/ncs/v2.9.1/nrf/applications/ipc_radio
-- Board: nrf5340_headset, qualifiers: nrf5340/cpunet
-- Found BOARD.dts: C:/Users/V/Desktop/headset/software/COMS/boards/privat/nrf5340_headset/nrf5340_headset_nrf5340_cpunet.dts
-- Generated zephyr.dts: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/ipc_radio/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/ipc_radio/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/ipc_radio/zephyr/dts.cmake
Parsing C:/ncs/v2.9.1/nrf/applications/ipc_radio/Kconfig
Loaded configuration 'C:/Users/V/Desktop/headset/software/COMS/boards/privat/nrf5340_headset/nrf5340_headset_nrf5340_cpunet_defconfig'
Merged configuration 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/sysbuild/ipc_radio/prj.conf'
Merged configuration 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/ipc_radio/zephyr/.config.sysbuild'
Configuration saved to 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/ipc_radio/zephyr/.config'
Kconfig header saved to 'C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/ipc_radio/zephyr/include/generated/zephyr/autoconf.h'
-- Build type:
-- libmetal version: 1.6.0 (C:/ncs/v2.9.1/nrf/applications/ipc_radio)
-- Machine: arm
-- Machine: arm
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/ipc_radio
-- Configuring done
-- Generating done
[4/653] Generating include/generated/zephyr/version.h
[648/653] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/nrf5340_audio_headset/zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\b620d30767\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -Os -DNDEBUG -gdwarf-4 -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf -L"c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main+fp/hard" -lm -lc -lgcc -lc && cmd.exe /C "cd /D C:\ncs\v2.9.1\nrf\applications\nrf5340_audio_headset\build\nrf5340_audio_headset\zephyr && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe -E true""
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(main.c.obj): in function `zbus_link_producers_observers':
C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/unicast_server/main.c:416: undefined reference to `volume_evt_sub'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(main.c.obj): in function `main':
C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/unicast_server/main.c:525: undefined reference to `nrf5340_audio_dk_init'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(audio_system.c.obj): in function `audio_system_start':
C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/src/audio/audio_system.c:407: undefined reference to `hw_codec_default_conf_enable'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(audio_system.c.obj): in function `audio_system_stop':
C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/src/audio/audio_system.c:429: undefined reference to `hw_codec_soft_reset'
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(audio_system.c.obj): in function `audio_system_init':
C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/src/audio/audio_system.c:484: undefined reference to `hw_codec_init'
collect2.exe: error: ld returned 1 exit status
[10/20] No configure step for 'ipc_radio'
FAILED: _sysbuild/sysbuild/images/nrf5340_audio_headset-prefix/src/nrf5340_audio_headset-stamp/nrf5340_audio_headset-build C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build/_sysbuild/sysbuild/images/nrf5340_audio_headset-prefix/src/nrf5340_audio_headset-stamp/nrf5340_audio_headset-build
cmd.exe /C "cd /D C:\ncs\v2.9.1\nrf\applications\nrf5340_audio_headset\build\nrf5340_audio_headset && C:\ncs\toolchains\b620d30767\opt\bin\cmake.exe --build ."
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' --build C:/ncs/v2.9.1/nrf/applications/nrf5340_audio_headset/build
 *  The terminal process terminated with exit code: 1.
 *  Executing task: nRF Connect: Generate config nrf5340_headset/nrf5340/cpuapp for c:\ncs\v2.9.1\nrf\applications\nrf5340_audio_headset
-- Build type:
-- Machine: arm
-- Machine: arm
-- Configuring done
  correctly.
-- Generating done
-- Build type:
-- Machine: arm
-- Machine: arm
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
-- Zephyr version: 3.7.99 (C:/ncs/v2.9.1/zephyr), build: v3.7.99-ncs2-1
-- Build type:
-- Machine: arm
-- Machine: arm
-- Configuring done
  correctly.
-- Generating done
-- Build type:
-- Machine: arm
-- Machine: arm
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
