nPM1300 Configuration
I would like your support in reviewing and helping define the correct configuration for the NPM1300 charger in our application.
Here is the current configuration we are using:
npm1300_charger: charger {
    compatible = "nordic,npm1300-charger";
    status = "okay";
    term-microvolt = <4100000>;
    term-warm-microvolt = <4000000>;
    current-microamp = <130000>;
    dischg-limit-microamp = <1340000>;
    vbus-limit-microamp = <500000>;
    thermistor-ohms = <10000>;
    thermistor-beta = <3435>;
    charging-enable;
We are using the following battery: renata ICP621333PA-01 3.7V / 230mAh
Could you please confirm whether this configuration is appropriate for the battery in use? I noticed that the PMIC offers additional protection and safety configurations. If possible, I would appreciate your guidance on defining a recommended and more complete set of parameters.
We are also encountering a couple of issues:
  1. Occasionally, the PMIC does not detect the USB-C charger connection during boot.
  2. When the USB connection is not recognized, the fuel gauge reports 0% state of charge (SOC).
Any advice or suggestions to address these issues would be greatly appreciated.
    From the first glance, the disttcharge limit (1.34 A) seems too high for such a small battery. The battery datasheet recommends to stay within 1C (240mA) or 2C bursts/non-continuous (480mA).
    As for the USB detection issue, it is difficult to say without more information. First, what NCS version are you using? For a while we had some issues properly exposing the VBUS status register via the charger API, and the USB detection relied on interrupts.
    Do you have any code snippets and logs to share, so that we can look into this? Particularly related to the start of the application, where the 0% value comes from.
    Edvin
  • we are using NCS version 2.7.0.
    this function is called in boot and returns the usb connection status on init:
    int battery_init(void)
        if (hal_fg_init() != 0) {
            LOG_ERR("failed to initialize fuel gauge HAL");
            return -1;
        } else {
            hal_fg_register_events_cb(charger_event_cb);
        battery_info.flags.is_charger_connected = 0;
        battery_info.flags.is_full = 0;
        battery_info.flags.is_critical_level = 0;
        battery_info.flags.is_low_level = 0;
        battery_info.flags.unused = 0;
        if(battery_update_info() < 0) {
            return -1;
        if(hal_fg_charger_connected()) {
            battery_info.flags.is_charger_connected = 1;
        return 0;
    bool hal_fg_charger_connected(void)
        struct sensor_value val;
        bool connected;
        int ret;
        ret = sensor_attr_get(fuelgauge_device, SENSOR_CHAN_CURRENT, SENSOR_ATTR_UPPER_THRESH, &val);
        if (ret < 0) {
            LOG_ERR("failed to read npm1300 current");
            return false;
        connected = (val.val1 != 0) || (val.val2 != 0);
        if (!connected) {
            /* the SENSOR_CHAN_CURRENT attr is not working properly so this code is needed.
             remove when npm1300 charger driver fix this issue. */
            float avg_current_mA;
            ret = hal_fg_get_data(NULL, &avg_current_mA, NULL, NULL);
            if (ret < 0) {
                return false;
            connected = (avg_current_mA < 0);
        return connected;
    Sorry for the late reply!
    There were some issues detecting the VBUS status register in some NCS versions, and I believe this was present on v2.7.0.
    I suggest that on startup, you check the register directly, and then use the events to be notified on changes on the USB connection.
    You can read the register using this snippet:
    https://github.com/nrfconnect/sdk-zephyr/blob/v3.6.99-ncs2/drivers/sensor/nordic/npm1300_charger/npm1300_charger.c#L301
    ret = mfd_npm1300_reg_read(config->mfd, VBUS_BASE, VBUS_OFFSET_STATUS, &data->vbus_stat);
    Alternatively, you can read it more directly like it is done here:
    https://github.com/nrfconnect/sdk-nrf/blob/v2.7.0/samples/pmic/native/npm1300_one_button/src/main.c#L64-L72
    	if (pins & BIT(NPM1300_EVENT_VBUS_DETECTED)) {
    		printk("Vbus connected\n");
    		vbus_connected = true;
    	if (pins & BIT(NPM1300_EVENT_VBUS_REMOVED)) {
    		printk("Vbus removed\n");
    		vbus_connected = false;
    Edvin
  • thanks I will try it and see if this works.
    regarding the first question I asked, about the correct battery configuration settings, I used chatGPT to help me with that.
    can you review it here and let me know if its OK? It would be helpful to have a professional set of eyes to approve it:
    chatgpt.com/.../67f21a09-60ec-8001-95c5-2149c9cc0a10
  • Our PMIC team commented on the discharge limit was a bit high. Try setting it to 240mA.
    Edvin
