NRF52820 dongle for gaming mouse
Hello, I am trying to develop a 1000 Hz wireless gaming mouse. The mouse has a NRF52832 onboard and the dongle has a NRF52820 on it. (Cannot switch to 52840)
I do know about Bluetooth LLPM, but I'm trying to avoid it since it is expensive in terms of power consumption + processing.
I've tried using Gazell- was able to get the report rate up to 822 Hz; but it won't go beyond that. Could you suggest a Gazell configuration that will be able to push it to 1000 Hz?
I was also thinking of using Enhanced Shock Burst instead, will ESB perform better?
Also, in terms of power consumption, is Gazell/ ESB better than BLE?
Currently- USB is not enabled on the NRF52820, when it is enabled- will it significantly degrade the performance of whichever radio protocol I use?
    Due to the protocol implementation in gazell, it will limit the overall throughput to 1 payload every 2*600 us, which is close to the measured report rate that you list.
    You can use 504 us timeslot, as shown in the docs:
    https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/protocols/gazell/gzll.html
    But please also be aware of the drawbacks.
    Yes, you will be able to get a better throughput with ESB as compared to Gazell. The problem is that ESB does not include any pairing, hopping and similar.
    If you compare apples to apples, and send one payload every 20 milliseconds, then they are pretty similar, but a proprietary protocol allows you to send data with a lower latency.
    This highly depends on the amount of code that runs.
    Håkon
  • Thanks!
    We'll build on ESB's implementation and develop our own protocol.
  • Hi there, developing a 1000 Hz wireless gaming mouse sounds like an exciting challenge! For your issue, I think you could try tweaking the Gazell configuration to optimize the report rate. Enhanced Shock Burst (ESB) is also worth considering, as it might offer better performance in some cases. In terms of power consumption, Gazell and ESB are generally more efficient than BLE, but you’ll need to thoroughly test to ensure overall performance.
    By the way, if you enjoy puzzle-solving challenges like this optimization task, you might want to check out chiikawa puzzle. It’s a fun and relaxing puzzle game that’s perfect for unwinding after a busy work session!
  • Your project sounds exciting! Achieving a 1000 Hz report rate for a wireless gaming mouse is quite a challenge. I’ve been working on a similar concept for a slope game where precise control is crucial for navigating the terrain. If you can get the Gazell configuration optimized, it might really enhance the responsiveness of the mouse, which would be great for fast-paced gameplay.
  • 822 Hz is already close to the 1 kHz goal, so I’d first look at packet timing, ACK settings, payload size, and interrupt handling. ESB could be worth testing, but the actual improvement will depend on your firmware and packet design. I’d also compare power consumption under identical conditions. USB shouldn’t automatically cause a major performance hit, although its interrupt load could affect radio timing. For those interested in mobile gaming alongside technical projects, shadow fight 2 mod is another option worth checking out.
