pwm can not work with softdevice, when i use s110(v7.1) , sdk 6.1
Hi Nordics,
I copy pwm sample code into my proximity project, to drive a buzzer .
I init pwm before softdevice. but, once "SOFTDEVICE_HANDLER_INIT" is excuted, the buzzer pin no longer toggle.
My question is , softdevice use TIMER0, my pwm use TIMER2, it seems that they are independent two modules. why pwm not working ?
Many thanks !
Bob
  • If you are using the code in pwm_example it may be because the example access some registers that are restricted when using SoftDevice, more specific NRF_CLOCK and NRF_POWER, see here. You will need to use sd_clock_hfclk_request and sd_power_mode_set instead, although these are not necessary (pwm will work fine with RC clock and not constant latency mode).
    This PWM example has a high possibility of inverting when using it with a SoftDevice. I will recommend to update to our newest SDK to use the newest driver which does not have this bug. You will need to update the SoftDevice also.
  • Ole Bauck, thanks for your answer. however, when i go to newest SDK, all samples are using S130 etc., costing much more space of my NRF51822QFAB, so space not enough. i do not want to change to NRF51822QFAA. do you have any idea ?
  • SDK 10 should also work fine, it has S110 examples.
  • Hi, Ole Bauck, The proximity example from SDK10 can run on my board. My board is using NRF51822QFABC0 and External XTAL 16MHz, but no XTAL 32.76khz.
  • Then you need to change to SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_RC_250_PPM_4000MS_CALIBRATION, NULL) or similar.
1 2
