Segger Embedded Studio -`UNPLACED_SECTIONS' problem
I try to start developing my nrf51/nrf52 projects using Segger Embedded Studio but each time I receive the same linker error:
"(...) section fs_data' will not fit in regionUNPLACED_SECTIONS'"
In my case fds.c or fstorage.c is the problem but i saw at this forum that others have problems with diffrent libraries.
Looking forward to any help. Cheers!
EDIT: For better readability I will try to add more detail of the problem:
I import Keil 4 project into Segger E. Studio. I follow the import procedure located at this topic: devzone.nordicsemi.com/.../
the exact error message I receive is:
"section fs_data loaded at [00000000,0000000f] overlaps section .vectors loaded at [00000000,000000a7]"
"region `UNPLACED_SECTIONS' overflowed by 17 bytes"
Next thing is I know where sections are defined (flash_placement.xml) but I have no idea what and how to change to make fs_data fit into the sections. I also found the .c file section options view (properties of the file -> secition options) but again nothing helpful is there.
I still try to dig the problem - If i find sth I will edit this post
  • I almost got it:
    It was enough to add fs_data line in flash_placement.xml to get rid of UNPLACED_SECTIONS linker error:
    <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="$(FLASH_NAME:FLASH)">
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START:)" />
        <ProgramSection alignment="4" load="Yes" name="fs_data" />
        <ProgramSection alignment="4" los" name=".init" />
    That fallowed to lack of __stop_fs_data and __start_fs_data definitions. Then I found this:
    Linker scripts
    Keil does not require linker scripts. Named sections are generated automatically when registration macros are invoked.
    For GCC compilations, you must add a definition for a linker script used in the compilation.This addition should be at the root level of the linker script file:
    SECTIONS { .fs_data_out ALIGN(4):
    { PROVIDE( __start_fs_data = .); KEEP(*(fs_data)) PROVIDE( __stop_fs_data = .); } = 0 } This definition will add a named section fs_data that is aligned to a word and that has __start_fs_data and __stop_fs_data as symbols that are used from the code.
    For IAR compilations, you must make additions to an ilink file.
    in Nordic InfoCenter infocenter.nordicsemi.com/index.jsp
    It should be super easy from this point. BUT I try to attach this simple linker script to Segger E. Studio without success... Help will be appreciated. How to do it properly?
    EDIT + FINAL ANSWER:
    devzone.nordicsemi.com/.../ finally solved the problem (notice the dot "." in front of fs_data section definition in this solution!)
    topic to close
  • You don't have to attach a hard-coded linker script to Segger Embedded Studio, it can generate it for you including the section variables __start_fs_data and __stop_fs_data.
    Put the following in the flash_placement xml file, you nearly had it right, you were just missing two keywords
    <ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data"
    address_symbol="__start_fs_data"  end_symbol="__stop_fs_data" />
    that will define those two linker symbols you need and set them to the start and end of the fs_data section.
    It's better to do it this way and let Segger Embedded Studio make the .ld file each time with all the correct pieces in it than to give it one hard-coded one which is what it seems your current solution does.
    Having looked at the linker file Nordic now has and realised this stuff is supposed to go in RAM it's more complicated. You import the flash_placement.xml file to your project and then add one line in the FLASH memory segment piece and one in the RAM memory segment piece
        <ProgramSection alignment="4" keep="Yes" load="Yes" runin=".fs_data_run" name=".fs_data" />
    </MemorySegment>
    <MemorySegment name="$(RAM_NAME:RAM);SRAM">
        <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data"  end_symbol="__stop_fs_data" />
    </MemorySegment>
    Then you also need to import the standard thumb_crt0.s file and add, I suggest after the tdata copy the following code which copies the fs_data from FLASH into RAM.
    ldr r2, =__tdata_end__
    bl memory_copy
    # ADD HERE ...
    ldr r0, =__fs_data_load_start__
    ldr r1, =__fs_data_start__
    ldr r2, =__fs_data_end__
    bl memory_copy
    # TO HERE ...
    If you use my first version - the data ends up in flash, but it's not very useful there as fds needs to modify it, which I didn't realise.
  • cannot load section placement file,what is the solution for this?
  • RK, you saved my week end ! This shall be included in the Segger IDE porting tutorial.
