Segger Embedded Studio -`UNPLACED_SECTIONS' problem
I try to start developing my nrf51/nrf52 projects using Segger Embedded Studio but each time I receive the same linker error:
"(...) section fs_data' will not fit in regionUNPLACED_SECTIONS'"
In my case fds.c or fstorage.c is the problem but i saw at this forum that others have problems with diffrent libraries.
Looking forward to any help. Cheers!
EDIT: For better readability I will try to add more detail of the problem:
I import Keil 4 project into Segger E. Studio. I follow the import procedure located at this topic: devzone.nordicsemi.com/.../
the exact error message I receive is:
"section fs_data loaded at [00000000,0000000f] overlaps section .vectors loaded at [00000000,000000a7]"
"region `UNPLACED_SECTIONS' overflowed by 17 bytes"
Next thing is I know where sections are defined (flash_placement.xml) but I have no idea what and how to change to make fs_data fit into the sections. I also found the .c file section options view (properties of the file -> secition options) but again nothing helpful is there.
I still try to dig the problem - If i find sth I will edit this post
  • Please open a new question as this thread is several years old. When you do, please provide more information about what you do and attach linker configuration etc.
  • This is my flash_placement.xml file.
    <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="$(FLASH_NAME:FLASH)">
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START:)" />
        <ProgramSection alignment="4" load="Yes" name=".init" />
        <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
        <ProgramSection alignment="4" load="Yes" name=".text" />
        <ProgramSection alignment="4" load="Yes" name=".dtors" />
        <ProgramSection alignment="4" load="Yes" name=".ctors" />
        <ProgramSection alignment="4" load="Yes" name=".rodata" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".dfu_trans" inputsections="*(SORT(.dfu_trans*))" address_symbol="__start_dfu_trans" end_symbol="__stop_dfu_trans" />
        <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
        <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
        <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
        <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" runin=".fs_data_run" name=".fs_data" />
      </MemorySegment>
      <MemorySegment name="$(RAM_NAME:RAM);SRAM">
        <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START:$(SRAM_START:))" />
        <ProgramSection alignment="4" load="No" name=".fast_run" />
        <ProgramSection alignment="4" load="No" name=".data_run" />
        <ProgramSection alignment="4" load="No" name=".tdata_run" />
        <ProgramSection alignment="4" load="No" keep="Yes" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
        <ProgramSection alignment="4" load="No" name=".bss" />
        <ProgramSection alignment="4" load="No" name=".tbss" />
        <ProgramSection alignment="4" load="No" name=".non_init" />
        <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" />
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
      <MemorySegment name="$(FLASH2_NAME:FLASH2)">
        <ProgramSection alignment="4" load="Yes" name=".text2" />
        <ProgramSection alignment="4" load="Yes" name=".rodata2" />
        <ProgramSection alignment="4" load="Yes" runin=".data2_run" name=".data2" />
      </MemorySegment>
      <MemorySegment name="$(RAM2_NAME:RAM2)">
        <ProgramSection alignment="4" load="No" name=".data2_run" />
        <ProgramSection alignment="4" load="No" name=".bss2" />
      </MemorySegment>
    </Root>
    I am getting this error `UNPLACED_SECTIONS' overflowed by 1024 bytes. Can you help me with this?
