Problems build hci_lpuart for thingy91 sdk2.9.0
I am trying to compile hci_lpuart for thingy91_nrf52840, but I have these issue.
hci_lpuart:
/opt/nordic/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c
In file included from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_macro.h:34,
from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/irq_multilevel.h:16,
from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/devicetree.h:20,
from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/device.h:12,
from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/drivers/uart.h:28,
from /opt/nordic/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c:18:
/opt/nordic/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c: In function 'boot_uart_fifo_init':
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util.h:97:55: error: size of unnamed array is negative
97 | #define ZERO_OR_COMPILE_ERROR(cond) ((int) sizeof(char[1 - 2 * !(cond)]) - 1)
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:72:26: note: in definition of macro '__DEBRACKET'
72 | #define __DEBRACKET(...) __VA_ARGS__
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1'
180 | Z_COND_CODE_1(_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/device.h:297:9: note: in expansion of macro 'COND_CODE_1'
297 | COND_CODE_1(DT_HAS_COMPAT_STATUS_OKAY(compat), \
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/device.h:299:22: note: in expansion of macro 'ZERO_OR_COMPILE_ERROR'
299 | (ZERO_OR_COMPILE_ERROR(0)))
/opt/nordic/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c:217:20: note: in expansion of macro 'DEVICE_DT_GET_ONE'
217 | uart_dev = DEVICE_DT_GET_ONE(zephyr_cdc_acm_uart);
[260/325] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.9.0/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
[10/20] No configure step for 'hci_lpuart'
FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build /opt/nordic/ncs/v2.9.0/nrf/samples/bluetooth/hci_lpuart/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
cd /opt/nordic/ncs/v2.9.0/nrf/samples/bluetooth/hci_lpuart/build/mcuboot && /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/cmake --build /opt/nordic/ncs/v2.9.0/nrf/samples/bluetooth/hci_lpuart/build
Any ideas on how to solve this? I'd really appreciate it.
And if you have any examples for sending data from an nRF7002, that would help.
  • Did you do any modifications to any of the builds? Can you describe what you did exactly so it can be reproduced?
  • I am getting a similar error for a project that was seemingly working a few days back, with no changes made to any configuration, using SDK / Toolchain 2.8.0.
    Below is the output from attempting to build this.
    C:/ncs/v2.8.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c: In function 'boot_uart_fifo_init':
    C:/ncs/v2.8.0/zephyr/include/zephyr/sys/util.h:97:55: error: size of unnamed array is negative
    C:/ncs/v2.8.0/zephyr/include/zephyr/sys/util_internal.h:72:26: note: in definition of macro '__DEBRACKET'
    C:/ncs/v2.8.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
    C:/ncs/v2.8.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
    C:/ncs/v2.8.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1'
    C:/ncs/v2.8.0/zephyr/include/zephyr/device.h:297:9: note: in expansion of macro 'COND_CODE_1'
    C:/ncs/v2.8.0/zephyr/include/zephyr/device.h:299:22: note: in expansion of macro 'ZERO_OR_COMPILE_ERROR'
    C:/ncs/v2.8.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c:217:20: note: in expansion of macro 'DEVICE_DT_GET_ONE'
    Any pointers?
  • Sounds like you have messed up somewhere in the NCS installation. Perhaps you can try reinstalling the entire thing.
  • I appreciate the tip, however this happened without me changing anything to do with the installation.
    To further this I followed your advice and received the same result over again.
    I am looking further into this and will update with anything I find, however it is seemingly occurring to a code-base which was previously working with the same build configuration.
  • It seems my problem revolved around me building my project for the thingy91, where the project, required to have the configuration of the 52840dk, in reference to MCU boot and some obscure configs related to that. If the OP is still having issues, I'd recommend having a hack at the dk variant of the chip set you are using, as these tend to include the MCU boot configs necessary.
