Problems build hci_lpuart for thingy91 sdk2.9.0
I am trying to compile hci_lpuart for thingy91_nrf52840, but I have these issue.
hci_lpuart:
/opt/nordic/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c
In file included from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_macro.h:34,
from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/irq_multilevel.h:16,
from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/devicetree.h:20,
from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/device.h:12,
from /opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/drivers/uart.h:28,
from /opt/nordic/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c:18:
/opt/nordic/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c: In function 'boot_uart_fifo_init':
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util.h:97:55: error: size of unnamed array is negative
97 | #define ZERO_OR_COMPILE_ERROR(cond) ((int) sizeof(char[1 - 2 * !(cond)]) - 1)
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:72:26: note: in definition of macro '__DEBRACKET'
72 | #define __DEBRACKET(...) __VA_ARGS__
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
64 | __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
59 | __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1'
180 | Z_COND_CODE_1(_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/device.h:297:9: note: in expansion of macro 'COND_CODE_1'
297 | COND_CODE_1(DT_HAS_COMPAT_STATUS_OKAY(compat), \
/opt/nordic/ncs/v2.9.0/zephyr/include/zephyr/device.h:299:22: note: in expansion of macro 'ZERO_OR_COMPILE_ERROR'
299 | (ZERO_OR_COMPILE_ERROR(0)))
/opt/nordic/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/serial_adapter.c:217:20: note: in expansion of macro 'DEVICE_DT_GET_ONE'
217 | uart_dev = DEVICE_DT_GET_ONE(zephyr_cdc_acm_uart);
[260/325] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.9.0/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj
[10/20] No configure step for 'hci_lpuart'
FAILED: _sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build /opt/nordic/ncs/v2.9.0/nrf/samples/bluetooth/hci_lpuart/build/_sysbuild/sysbuild/images/bootloader/mcuboot-prefix/src/mcuboot-stamp/mcuboot-build
cd /opt/nordic/ncs/v2.9.0/nrf/samples/bluetooth/hci_lpuart/build/mcuboot && /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/cmake --build /opt/nordic/ncs/v2.9.0/nrf/samples/bluetooth/hci_lpuart/build
Any ideas on how to solve this? I'd really appreciate it.
And if you have any examples for sending data from an nRF7002, that would help.
    did it work before upgrading to 2.9.0? Have you tried other samples?
  • did it work before upgrading to 2.9.0?
    yes and the same issue.
    Others samples build without problems.
  • I can build,
    I add the " --no-sysbuild"  flag as an extra build argument.
    But , I have new problem with lte_ble_gateway
    *** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
    *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    [00:00:00.230,041] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.230,224] <inf> lte_ble_gw: Initializing Bluetooth..
    [00:00:00.230,224] <err> bt_hci_core: No HCI driver registered
    [00:00:00.230,224] <err> lte_ble_gw: Bluetooth init failed (err -19)
  • Did you flash the HCI to the nrf52840? Can you show the zephyr.dts of both builds?
  • Yes, I flashed HCI to the nrf52840. You can then compile lte_ble_gateway with SDK 3.0.0.
    I am using examples lte_ble_gateway and hci_lpuart SDK 3.0.0
    But now I have this error.
    [00:00:00.227,783] <wrn> lpuart: req pin low when expected high
    [00:00:00.227,935] <err> lpuart: Empty receiver state:4
    *** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
    *** Using Zephyr OS v4.0.99-a0e545cb437a ***
    [00:00:00.230,804] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.230,926] <inf> lte_ble_gw: Initializing Bluetooth..
    [00:00:00.476,013] <inf> lte_ble_gw: Establishing LTE link (this may take some time) ...
    [00:00:02.258,636] <wrn> lpuart: req pin low when expected high
    [00:00:02.258,758] <err> lpuart: Empty receiver state:4
    [00:00:04.339,965] <wrn> lpuart: req pin low when expected high
    [00:00:04.340,118] <err> lpuart: Empty receiver state:4
    [00:00:06.381,744] <wrn> lpuart: req pin low when expected high
    [00:00:06.381,896] <err> lpuart: Empty receiver state:4
    [00:00:08.398,681] <wrn> lpuart: req pin low when expected high
    [00:00:08.398,803] <err> lpuart: Empty receiver state:4
    ASSERTION FAIL [success] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:432
    command opcode 0x0c03 timeout
    [00:00:10.241,455] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000000 r2/a3: 0x00000002
    [00:00:10.241,485] <err> os: r3/a4: 0x00000003 r12/ip: 0x20018b28 r14/lr: 0x0002039f
    [00:00:10.241,485] <err> os: xpsr: 0x01000000
    [00:00:10.241,516] <err> os: Faulting instruction address (r15/pc): 0x000203ac
    [00:00:10.241,546] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    [00:00:10.241,577] <err> os: Current thread: 0x2000f6e8 (unknown)
    [00:00:10.456,787] <err> os: Halting system
