Hey dear nordic support team
hey all nordic users,
I would like to report an error that is happening with devices that have very low sleep time intervals ( 3 min or 5 min). After a while those devices are crashing with an error shown in screen shot below (UART Logs). I also attached the UART logs in a file, the devices were working fine an after a while they crash ( all cases are with devices with low sleep time)
- LTE-M
- Modem firmware version 1.3.5
- Connection was successful before, no other issues
- Data was transferred
- we always Reboot the device when waking up from sleep mode
I: Modem library successfully shut down I: new sleep time in seconds : 130 (-49 Elapsed Time in seconds) I: Alarm set for 130 seconds. I: Going to deep sleep uart:~$ *** Booting nRF Connect SDK v2.5.0 *** W: Reset cause: 163 W: RESET BY PIN I: Firmware VERSION 3.2.8 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ea0 I: data wra: 0, 418 I: No Bottle type is selected W: Please Select Bottle type for accurate Filling Level. I: Calibration data SLOP [0.000000] OFFSET [0] I: Display Language is ENGLISH I: Calibration data SLOP [0.000000] OFFSET [0] I: Measured Weight: 0 grams I: Filling Level: 0 I: Voltage: 3958 I: Battery Percentage: 78% I: HS4013_ID : -1475241472 | Temperature is : 21 | Humidity is : 36 I: Modem FW version: mfw_nrf9160_1.3.5 I: Using LTE LC neighbor search type GCI extended complete for 2 cells I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ] I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: C%XTIME: "40","52309210727240","00" onnected to Network I: Waiting for modem to acquire network time... I: Network time obtained %CCLK: "25/03/29,01:27:30+04",0 OK I: Current UNIX time: 1743211650013 I: Stored Time in NVS (UNIX) 1743178781995 I: Difference in days: 0.38 I: Not enough time has passed. No location sent. I: Current RSRP: -93 dBm I: Current RSRQ: -8 dB I: Current SNR (Signal to Noise ratio): 35 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS I: [mqtt_evt_handler:207] MQTT client connected! I: [mqtt_evt_handler:279] SUBACK packet id: 1234 I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:27:37.000Z","data":{"weightGrams":0,"voltageMillivolts":3958,"fillingLevelPercentage":0,"batteryPercentage ":78,"signalStrengthDbm":-93,"temperatureCelsius":21,"humidityPercentage":36,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm wareVersion":"3.2.8","hardwareVersion":"7.0"}}] I: Time Diff : 1743211657 I: Publishing data... I: getAllTwins Publish I: [mqtt_evt_handler:270] PUBACK packet id: 1 I: [mqtt_evt_handler:270] PUBACK packet id: 3 I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=112 I: Twin_Update_Data Publish I: Twin_Update_Data Publish I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=0 I: :: sdk is Disconnected From IoTConnect :: I: [mqtt_evt_handler:214] MQTT client disconnected 0 I: disconnection 0 I: Powering off LTE modem... +CGEV: ME PDN DEACT 0 +CEREG: 0 I: Network disconnected..! +CGEV: ME DETACH +CSCON: 0 I: RRC mode: idle I: LTE modem is powered off. I: Deinitializing LTE link controller... I: LTE link controller deinitialized I: Modem library successfully shut down I: new sleep time in seconds : 129 (-50 Elapsed Time in seconds) I: Alarm set for 129 seconds. I: Going to deep sleep uart:~$ *** Booting nRF Connect SDK v2.5.0 *** W: Reset cause: 163 W: RESET BY PIN I: Firmware VERSION 3.2.8 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ea0 I: data wra: 0, 418 I: No Bottle type is selected W: Please Select Bottle type for accurate Filling Level. I: Calibration data SLOP [0.000000] OFFSET [0] I: Display Language is ENGLISH I: Calibration data SLOP [0.000000] OFFSET [0] I: Measured Weight: 0 grams I: Filling Level: 0 I: Voltage: 3958 I: Battery Percentage: 78% I: HS4013_ID : -1475241472 | Temperature is : 21 | Humidity is : 36 I: Modem FW version: mfw_nrf9160_1.3.5 I: Using LTE LC neighbor search type GCI extended complete for 2 cells I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ] I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: C%XTIME: "40","52309210039240","00" onnected to Network I: Waiting for modem to acquire network time... I: Network time obtained %CCLK: "25/03/29,01:30:32+04",0 OK I: Current UNIX time: 1743211832013 I: Stored Time in NVS (UNIX) 1743178781995 I: Difference in days: 0.38 I: Not enough time has passed. No location sent. I: Current RSRP: -93 dBm I: Current RSRQ: -8 dB I: Current SNR (Signal to Noise ratio): 34 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS I: [mqtt_evt_handler:207] MQTT client connected! I: [mqtt_evt_handler:279] SUBACK packet id: 1234 I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:30:40.000Z","data":{"weightGrams":0,"voltageMillivolts":3958,"fillingLevelPercentage":0,"batteryPercentage ":78,"signalStrengthDbm":-93,"temperatureCelsius":21,"humidityPercentage":36,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm wareVersion":"3.2.8","hardwareVersion":"7.0"}}] I: Time Diff : 1743211840 I: Publishing data... I: [mqtt_evt_handler:214] MQTT client disconnected -128 E: Cmmand send failed E: getAllTwins Publish Failed +CSCON: 0 I: RRC mode: idle E: ERROR: mqtt_live -128 E: ERROR: mqtt_live -128 E: ERROR: mqtt_live -128 E: ERROR: mqtt_live -128 I: :: sdk is Disconnected From IoTConnect :: I: disconnection -128 +CGEV: ME PDN DEACT 0 +CSCON: 1 I: RRC mode: connected +CEREG: 0 I: Network disconnected..! +CGEV: ME DETACH +CSCON: 0 I: RRC mode: idle I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: C%XTIME: "40","52309210133240","00" onnected to Network I: Current RSRP: -93 dBm I: Current RSRQ: -7 dB I: Current SNR (Signal to Noise ratio): 34 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS I: [mqtt_evt_handler:207] MQTT client connected! I: [mqtt_evt_handler:279] SUBACK packet id: 1234 I: Sensor data is uart:~$ *** Booting nRF Connect SDK v2.5.0 *** W: Reset cause: 163 W: RESET BY PIN I: Firmware VERSION 3.2.8 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ea0 I: data wra: 0, 418 I: No Bottle type is selected W: Please Select Bottle type for accurate Filling Level. I: Calibration data SLOP [0.000000] OFFSET [0] I: Display Language is ENGLISH I: Calibration data SLOP [0.000000] OFFSET [0] I: Measured Weight: 0 grams I: Filling Level: 0 I: Voltage: 3957 I: Battery Percentage: 77% I: HS4013_ID : -1475241472 | Temperature is : 22 | Humidity is : 35 I: Modem FW version: mfw_nrf9160_1.3.5 I: Using LTE LC neighbor search type GCI extended complete for 2 cells I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ] I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: C%XTIME: "40","52309210130540","00" onnected to Network I: Waiting for modem to acquire network time... I: Network time obtained %CCLK: "25/03/29,01:31:53+04",0 OK I: Current UNIX time: 1743211913013 I: Stored Time in NVS (UNIX) 1743178781995 I: Difference in days: 0.38 I: Not enough time has passed. No location sent. I: Current RSRP: -91 dBm I: Current RSRQ: -7 dB I: Current SNR (Signal to Noise ratio): 37 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS E: MQTT connect failed 5 I: [mqtt_evt_handler:214] MQTT client disconnected -111 E: ERROR: mqtt_input -111 E: Error : IoTConnect_Connect Fail +CSCON: 0 I: RRC mode: idle E: ERROR: mqtt_live -128 E: MQTT Connection Failed I: Trying to reinit IotConnect MQTT Connection I: :: sdk is Disconnected From IoTConnect :: I: disconnection -128 +CGEV: ME PDN DEACT 0 +CSCON: 1 I: RRC mode: connected +CEREG: 0 I: Network disconnected..! +CGEV: ME DETACH +CSCON: 0 I: RRC mode: idle I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: Co%XTIME: "40","52309210233440","00" nnected to Network I: Current RSRP: -90 dBm I: Current RSRQ: -8 dB I: Current SNR (Signal to Noise ratio): 37 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS I: [mqtt_evt_handler:207] MQTT client connected! I: [mqtt_evt_handler:279] SUBACK packet id: 1234 I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:32:51.000Z","data":{"weightGrams":0,"voltageMillivolts":3957,"fillingLevelPercentage":0,"batteryPercentage ":77,"signalStrengthDbm":-90,"temperatureCelsius":22,"humidityPercentage":35,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm wareVersion":"3.2.8","hardwareVersion":"7.0"}}] I: Time Diff : 1743211971 I: Publishing data... uart:~$ *** Booting nRF Connect SDK v2.5.0 *** W: Reset cause: 163 W: RESET BY PIN I: Firmware VERSION 3.2.8 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ea0 I: data wra: 0, 418 I: No Bottle type is selected W: Please Select Bottle type for accurate Filling Level. I: Calibration data SLOP [0.000000] OFFSET [0] I: Display Language is ENGLISH I: Calibration data SLOP [0.000000] OFFSET [0] I: Measured Weight: 0 grams I: Filling Level: 0 I: Voltage: 3957 I: Battery Percentage: 77% I: HS4013_ID : -1475241472 | Temperature is : 22 | Humidity is : 35 I: Modem FW version: mfw_nrf9160_1.3.5 I: Using LTE LC neighbor search type GCI extended complete for 2 cells I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ] I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: Co%XTIME: "40","52309210337040","00" nnected to Network I: Waiting for modem to acquire network time... I: Network time obtained %CCLK: "25/03/29,01:33:10+04",0 OK I: Current UNIX time: 1743211990012 I: Stored Time in NVS (UNIX) 1743178781995 I: Difference in days: 0.38 I: Not enough time has passed. No location sent. I: Current RSRP: -93 dBm I: Current RSRQ: -7 dB I: Current SNR (Signal to Noise ratio): 34 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS I: [mqtt_evt_handler:207] MQTT client connected! I: [mqtt_evt_handler:279] SUBACK packet id: 1234 I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:33:17.000Z","data":{"weightGrams":0,"voltageMillivolts":3957,"fillingLevelPercentage":0,"batteryPercentage ":77,"signalStrengthDbm":-93,"temperatureCelsius":22,"humidityPercentage":35,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm wareVersion":"3.2.8","hardwareVersion":"7.0"}}] I: Time Diff : 1743211997 I: Publishing data... I: getAllTwins Publish I: [mqtt_evt_handler:270] PUBACK packet id: 1 I: [mqtt_evt_handler:270] PUBACK packet id: 3 I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=112 I: Twin_Update_Data Publish I: Twin_Update_Data Publish I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=0 I: :: sdk is Disconnected From IoTConnect :: I: [mqtt_evt_handler:214] MQTT client disconnected 0 I: disconnection 0 I: Powering off LTE modem... +CGEV: ME PDN DEACT 0 +CEREG: 0 I: Network disconnected..! +CGEV: ME DETACH +CSCON: 0 I: RRC mode: idle I: LTE modem is powered off. I: Deinitializing LTE link controller... I: LTE link controller deinitialized I: Modem library successfully shut down I: new sleep time in seconds : 133 (-46 Elapsed Time in seconds) I: Alarm set for 133 seconds. I: Going to deep sleep uart:~$ *** Booting nRF Connect SDK v2.5.0 *** W: Reset cause: 163 W: RESET BY PIN I: Firmware VERSION 3.2.8 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ea0 I: data wra: 0, 418 I: No Bottle type is selected W: Please Select Bottle type for accurate Filling Level. I: Calibration data SLOP [0.000000] OFFSET [0] I: Display Language is ENGLISH I: Calibration data SLOP [0.000000] OFFSET [0] I: Measured Weight: 0 grams I: Filling Level: 0 I: Voltage: 3957 I: Battery Percentage: 77% I: HS4013_ID : -1475241472 | Temperature is : 21 | Humidity is : 36 I: Modem FW version: mfw_nrf9160_1.3.5 I: Using LTE LC neighbor search type GCI extended complete for 2 cells I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ] I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: C%XTIME: "40","52309210631140","00" onnected to Network I: Waiting for modem to acquire network time... I: Network time obtained %CCLK: "25/03/29,01:36:14+04",0 OK I: Current UNIX time: 1743212174013 I: Stored Time in NVS (UNIX) 1743178781995 I: Difference in days: 0.39 I: Not enough time has passed. No location sent. I: Current RSRP: -93 dBm I: Current RSRQ: -8 dB I: Current SNR (Signal to Noise ratio): 34 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 E: connect() failed, err: 116 | -1 FD 0 E: Base_url is NULL E: Failed to Init IoTConnect sdk I: :: sdk is Disconnected From IoTConnect :: I: disconnection -128 +CGEV: ME PDN DEACT 0 +CEREG: 0 I: Network disconnected..! +CGEV: ME DETACH +CSCON: 0 I: RRC mode: idle I: Retrying ---------- I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: Con%XTIME: "40","52309210636340","00" nected to Network I: Current RSRP: -93 dBm I: Current RSRQ: -8 dB I: Current SNR (Signal to Noise ratio): 35 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS I: [mqtt_evt_handler:207] MQTT client connected! I: [mqtt_evt_handler:279] SUBACK packet id: 1234 I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:36:43.000Z","data":{"weightGrams":0,"voltageMillivolts":3957,"fillingLevelPercentage":0,"batteryPercentage ":77,"signalStrengthDbm":-93,"temperatureCelsius":21,"humidityPercentage":36,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm wareVersion":"3.2.8","hardwareVersion":"7.0"}}] I: Time Diff : 1743212203 I: Publishing data... I: getAllTwins Publish I: [mqtt_evt_handler:270] PUBACK packet id: 1 I: [mqtt_evt_handler:270] PUBACK packet id: 3 I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=112 I: Twin_Update_Data Publish I: Twin_Update_Data Publish I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=0 I: :: sdk is Disconnected From IoTConnect :: I: [mqtt_evt_handler:214] MQTT client disconnected 0 I: disconnection 0 I: Powering off LTE modem... +CGEV: ME PDN DEACT 0 +CEREG: 0 I: Network disconnected..! +CGEV: ME DETACH +CSCON: 0 I: RRC mode: idle I: LTE modem is powered off. I: Deinitializing LTE link controller... I: LTE link controller deinitialized I: Modem library successfully shut down I: new sleep time in seconds : 107 (-72 Elapsed Time in seconds) I: Alarm set for 107 seconds. I: Going to deep sleep uart:~$ *** Booting nRF Connect SDK v2.5.0 *** W: Reset cause: 163 W: RESET BY PIN I: Firmware VERSION 3.2.8 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ea0 I: data wra: 0, 418 I: No Bottle type is selected W: Please Select Bottle type for accurate Filling Level. I: Calibration data SLOP [0.000000] OFFSET [0] I: Display Language is ENGLISH I: Calibration data SLOP [0.000000] OFFSET [0] I: Measured Weight: 0 grams I: Filling Level: 0 I: Voltage: 3958 I: Battery Percentage: 78% I: HS4013_ID : -1475241472 | Temperature is : 21 | Humidity is : 36 I: Modem FW version: mfw_nrf9160_1.3.5 I: Using LTE LC neighbor search type GCI extended complete for 2 cells I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ] I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: Co%XTIME: "40","52309210931140","00" nnected to Network I: Waiting for modem to acquire network time... I: Network time obtained %CCLK: "25/03/29,01:39:14+04",0 OK I: Current UNIX time: 1743212354013 I: Stored Time in NVS (UNIX) 1743178781995 I: Difference in days: 0.39 I: Not enough time has passed. No location sent. I: Current RSRP: -91 dBm I: Current RSRQ: -8 dB I: Current SNR (Signal to Noise ratio): 36 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS I: [mqtt_evt_handler:207] MQTT client connected! I: [mqtt_evt_handler:279] SUBACK packet id: 1234 I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:39:21.000Z","data":{"weightGrams":0,"voltageMillivolts":3958,"fillingLevelPercentage":0,"batteryPercentage ":78,"signalStrengthDbm":-91,"temperatureCelsius":21,"humidityPercentage":36,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm wareVersion":"3.2.8","hardwareVersion":"7.0"}}] I: Time Diff : 1743212361 I: Publishing data... I: getAllTwins Publish I: [mqtt_evt_handler:270] PUBACK packet id: 1 I: [mqtt_evt_handler:270] PUBACK packet id: 3 I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=112 I: Twin_Update_Data Publish I: Twin_Update_Data Publish I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=0 I: :: sdk is Disconnected From IoTConnect :: I: [mqtt_evt_handler:214] MQTT client disconnected 0 I: disconnection 0 I: Powering off LTE modem... +CGEV: ME PDN DEACT 0 +CEREG: 0 I: Network disconnected..! +CGEV: ME DETACH +CSCON: 0 I: RRC mode: idle I: LTE modem is powered off. I: Deinitializing LTE link controller... I: LTE link controller deinitialized I: Modem library successfully shut down I: new sleep time in seconds : 130 (-49 Elapsed Time in seconds) I: Alarm set for 130 seconds. I: Going to deep sleep uart:~$ *** Booting nRF Connect SDK v2.5.0 *** W: Reset cause: 163 W: RESET BY PIN I: Firmware VERSION 3.2.8 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ea0 I: data wra: 0, 418 I: No Bottle type is selected W: Please Select Bottle type for accurate Filling Level. I: Calibration data SLOP [0.000000] OFFSET [0] I: Display Language is ENGLISH I: Calibration data SLOP [0.000000] OFFSET [0] I: Measured Weight: 0 grams I: Filling Level: 0 I: Voltage: 3958 I: Battery Percentage: 78% I: HS4013_ID : -1475241472 | Temperature is : 21 | Humidity is : 36 I: Modem FW version: mfw_nrf9160_1.3.5 I: Using LTE LC neighbor search type GCI extended complete for 2 cells I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ] I: Waiting for network.. +CEREG: 2,"C936","018D3017",7 W: LTE Searching +CSCON: 1 I: RRC mode: connected +CGEV: ME PDN ACT 0,0 +CNEC_ESM: 50,0 +CEREG: 5,"C936","018D3017",7,,,"00000000","11100000" I: Network registration status: Connected - roaming I: Connec%XTIME: "40","52309210241140","00" ted to Network I: Waiting for modem to acquire network time... I: Network time obtained %CCLK: "25/03/29,01:42:14+04",0 OK I: Current UNIX time: 1743212534012 I: Stored Time in NVS (UNIX) 1743178781995 I: Difference in days: 0.39 I: Not enough time has passed. No location sent. I: Current RSRP: -93 dBm I: Current RSRQ: -8 dB I: Current SNR (Signal to Noise ratio): 33 dB I: Current Network Band: 20 I: Signal Strength: Fair I: Signal Quality: Excellent I: Initializing Iot Connect Init I: Start IoTConnect_Init I: Get URL address ... I: Resolved 52.179.195.5 (AF_INET) I: Connecting to discovery.iotconnect.io:443 I: .. OK I: This is json format I: Connecting to euagent.iotconnect.io I: .. OK I: Device : 359746167113302 Status : I: .. OK I: Sync_Response_Data Saved I: Init IoTConnect sdk SUCCESS I: IPv4 Address found 20.50.65.137 I: MQTT_Init SUCCESS I: [mqtt_evt_handler:207] MQTT client connected! I: [mqtt_evt_handler:279] SUBACK packet id: 1234 I: Sensor data is [{"uniqueId":"359746167113302","time":"2025-03-29T01:42:21.000Z","data":{"weightGrams":0,"voltageMillivolts":3958,"fillingLevelPercentage":0,"batteryPercentage ":78,"signalStrengthDbm":-93,"temperatureCelsius":21,"humidityPercentage":36,"cylinderCapacity":0,"cylinderChangedEvent":0,"latitude":0,"longitude":0,"uncertaintyMeters":0,"firm wareVersion":"3.2.8","hardwareVersion":"7.0"}}] I: Time Diff : 1743212541 I: Publishing data... I: getAllTwins Publish I: [mqtt_evt_handler:270] PUBACK packet id: 1 I: [mqtt_evt_handler:270] PUBACK packet id: 3 I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=112 I: Twin_Update_Data Publish I: Twin_Update_Data Publish I: [mqtt_evt_handler:230] MQTT PUBLISH result=0 len=0 I: :: sdk is Disconnected From IoTConnect :: I: [mqtt_evt_handler:214] MQTT client disconnected 0 I: disconnection 0 I: Powering off LTE modem... +CGEV: ME PDN DEACT 0 +CEREG: 0 I: Network disconnected..! +CGEV: ME DETACH +CSCON: 0 I: RRC mode: idle I: LTE modem is powered off. I: Deinitializing LTE link controller... I: LTE link controller deinitialized I: Modem library successfully shut down I: new sleep time in seconds : 130 (-49 Elapsed Time in seconds) I: Alarm set for 130 seconds. I: Going to deep sleep uart:~$ *** Booting nRF Connect SDK v2.5.0 *** W: Reset cause: 163 W: RESET BY PIN I: Firmware VERSION 3.2.8 I: 2 Sectors of 4096 bytes I: alloc wra: 0, ea0 I: data wra: 0, 418 I: No Bottle type is selected W: Please Select Bottle type for accurate Filling Level. I: Calibration data SLOP [0.000000] OFFSET [0] I: Display Language is ENGLISH I: Calibration data SLOP [0.000000] OFFSET [0] I: Measured Weight: 0 grams I: Filling Level: 0 I: Voltage: 3958 I: Battery Percentage: 78% I: HS4013_ID : -1475241472 | Temperature is : 21 | Humidity is : 36 I: Modem FW version: mfw_nrf9160_1.3.5 I: Using LTE LC neighbor search type GCI extended complete for 2 cells I: Extracted IMEI: [ 359746167113302 ] Device ID : [ gasvisor-ID359746167113302 ] I: Waiting for network.. E: Modem has crashed, reason 0x10, PC: 0x9a776 I: Modem has crashed, re-initializing E: Failed to set functional mode. Please check XSYSTEMMODE.
