I can't get BLE_GAP_EVT_DISCONNECTED event
Hi!
S132, SDK17.1, nRF52832
Very strange behavior, I connected my central to the bonded peripherial success and got an BLE_GAP_EVT_CONNECTED event, but when I disconnected peripherial, I didn't get BLE_GAP_EVT_DISCONNECTED  event.
On this project I got recently this event, but I just added some code and now I have this behavior.
What possible reason? What should I check?
Thanks.
  • Hi Tomas,
    Do you know what kind of code you added ? Did you modify the SDK's code or only your application code ?
    Does it has anything with pulling out the event from the softdevice interrupt handler ?
    There is some similar tickets , for example: missing BLE_GAP_EVT_DISCONNECTED event
    Please try testing with some simple example in the SDK to see if you have the same issue ?
  • Hi!
    Similar tickets- it is good. I used SDK7.2.0 In this ticket pointed that this known bug and fixed it it SDK 7.3.0
    I have tested with simple SDK and it works. I made project on central example. And It worked. But I added some code, in the config.h I have changed cmt of UUID services, changed memory size in Keil project and after that I can't receive this event.
    But event BLE_GAP_EVT_CONNECTED I got successfully. But WO BLE_GAP_EVT_DISCONNECTED  evnt.
  • Hi Tomas,
    Changing UUID shouldn't be a problem, but changing memory size could be an issue. Could you show what you changed ?
    Can you try changing step by step to see at which step you see the problem ?
  • Hi Hung,
    I found out that when I got BLE_GAP_EVT_CONNECTED event, but in this event I didn't do
    all works properly. I gon an event BLE_GAP_EVT_DISCONNECTED like expected.
    But with this string
    I didn't get any messages in the RTT like:
    And I din't get BLE_GAP_EVT_DISCONNECTED .
    But before Keil's memories changed, it worked properly (also discovery nus_c worked).
    Now I have Keil's settings here:
    Seems, all services in the config.h are enabled. I don't know the reason of this behavior.
  • Hi ,
    If you comment out ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);, then there will be no BLE_NUS_C_EVT_DISCOVERY_COMPLETE event. So it's as expected.
    So you observed that you only see the issue after you change the memory configuration. What did you change and why you changed ?
    Could yo
1 2
