I am using the Zephyr SPI driver to control a WS2812 LED strip through the SPI interface. Since only the MOSI line is required for communication, I want to configure the SPI interface to use only MOSI while leaving MISO and SCK unassigned, since I want to use them for other purposes.
When I manually assign MISO and SCK to arbitrary pins, everything works as expected. However, when I try to explicitly disconnect them using the following configuration:
psels = <NRF_PSEL(SPIM_MOSI, 2, 8)>,
<NRF_PSEL_DISCONNECTED(SPIM_MISO)>,
<NRF_PSEL_DISCONNECTED(SPIM_SCK)>;
it results in the following error:
ASSERTION FAIL [nrf_gpio_pin_present_check(*p_pin)] @ WEST_TOPDIR/modules/hal/nordic/nrfx/hal/nrf_gpio.h:944
Questions:
Is it possible to use only the MOSI line for SPI communication in Zephyr?
If so, what is the correct way to configure SPI to disable MISO and SCK without causing an assertion failure?
