nrf_dm on the nrf54l15
Is there a trick to getting nrf_dm to compile on the nrf54l15?
I've installed v2.9.1
Command I normally use (nrf52840):
west build -b nrf52840dk_nrf52840 -d build_nrf52840dk_nrf52840 -- -DSHIELD=waveshare_epaper_gdey0213b74
Command I tried (not sure if it's correct?):
west build -b nrf54l15bsim/nrf54l15/cpuapp -d build_nrf54L15 -- -DSHIELD=waveshare_epaper_gdey0213b74
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.9.1/zephyr/.cache
-- Board: nrf54l15bsim, qualifiers: nrf54l15/cpuapp
-- Shield(s): waveshare_epaper_gdey0213b74
Parsing C:/ncs/v2.9.1/nrf/samples/bluetooth/nrf_dm/Kconfig.sysbuild
Loaded configuration 'C:/ncs/v2.9.1/nrf/samples/bluetooth/nrf_dm/build_nrf54L15/_sysbuild/empty.conf'
Merged configuration 'C:/ncs/v2.9.1/nrf/samples/bluetooth/nrf_dm/build_nrf54L15/_sysbuild/empty.conf'
Configuration saved to 'C:/ncs/v2.9.1/nrf/samples/bluetooth/nrf_dm/build_nrf54L15/zephyr/.config'
Kconfig header saved to 'C:/ncs/v2.9.1/nrf/samples/bluetooth/nrf_dm/build_nrf54L15/_sysbuild/autoconf.h'
* Running CMake for nrf_dm *
-- Application: C:/ncs/v2.9.1/nrf/samples/bluetooth/nrf_dm
-- CMake version: 3.21.0
-- Using NCS Toolchain 2.8.20241119.782234748775 for building. (C:/ncs/toolchains/b620d30767/cmake)
-- Zephyr version: 3.7.99 (C:/ncs/v2.9.1/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found toolchain: host (gcc/ld)
CMake Error at C:/ncs/v2.9.1/zephyr/cmake/compiler/host-gcc/generic.cmake:5 (find_program):
Could not find CMAKE_C_COMPILER using the following names: gcc
C:/ncs/v2.9.1/zephyr/cmake/modules/FindHostTools.cmake:108 (include)
C:/ncs/v2.9.1/zephyr/cmake/modules/dts.cmake:9 (find_package)
C:/ncs/v2.9.1/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:8 (find_package)
CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
CMake configure failed for Zephyr project: nrf_dm
cmake/modules/sysbuild_images.cmake:20 (ExternalZephyrProject_Cmake)
cmake/modules/sysbuild_default.cmake:20 (include)
C:/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
C:/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
template/CMakeLists.txt:10 (find_package)
See also "C:/ncs/v2.9.1/nrf/samples/bluetooth/nrf_dm/build_nrf54L15/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b620d30767/opt/bin/python.exe '-BC:\ncs\v2.9.1\nrf\samples\bluetooth\nrf_dm\build_nrf54L15' -GNinja -DBOARD=nrf54l15bsim/nrf54l15/cpuapp -DSHIELD=waveshare_epaper_gdey0213b74 '-SC:\ncs\v2.9.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\ncs\v2.9.1\nrf\samples\bluetooth\nrf_dm'
  • Hey Michael,
    It appears you're building for the Babblesim board target and not the nRF54L15-DK target. Try changing from:
    nrf54l15bsim/nrf54l15/cpuapp to nrf54l15dk/nrf54l15/cpuapp
    Helmut Lord
  • Thanks. I tried this... I don't fully understand all the output from the compile. nrf_dm specifies processors in the nrf_dm yaml file... nrf54 is not part of the processor list, but I don't know if that is a problem or not?
    PS C:\ncs\v2.9.1\nrf\samples\bluetooth\nrf_dm> west build -b nrf54l15dk/nrf54l15/cpuapp -d build_nrf54L15 -- -DSHIELD=waveshare_epaper_gdey0213b74
    -- Board: nrf54l15dk, qualifiers: nrf54l15/cpuapp
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.9.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts
    -- Found devicetree overlay: C:/ncs/v2.9.1/zephyr/boards/shields/waveshare_epaper/waveshare_epaper_gdey0213b74.overlay
    -- Found devicetree overlay: C:/ncs/v2.9.1/nrf/samples/bluetooth/nrf_dm/app.overlay
    devicetree error: C:/ncs/v2.9.1/zephyr/boards/shields/waveshare_epaper/dts/waveshare_epaper_common.dtsi:7 (column 1): parse error: undefined node label 'arduino_spi'
    CMake Error at C:/ncs/v2.9.1/zephyr/cmake/modules/dts.cmake:295 (execute_process):
    execute_process failed command indexes:
    1: "Child return code: 1"
    ←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b620d30767/opt/bin/python.exe '-BC:\ncs\v2.9.1\nrf\samples\bluetooth\nrf_dm\build_nrf54L15' -GNinja -DBOARD=nrf54l15dk/nrf54l15/cpuapp -DSHIELD=waveshare_epaper_gdey0213b74 '-SC:\ncs\v2.9.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\ncs\v2.9.1\nrf\samples\bluetooth\nrf_dm'
    ←[0m
  • nrf_dm is not supported for the nRF54 series, these devices use Channel Sounding for ranging.
  • Thanks!
    Is "Channel Sounding" a similar function to "nrf_dm"? Is there a "Channel Sounding" sample that I can use to revise my current "nrf_dm" code/job to so that I can get the same type of result using the nrf54l15?
    And, most importanly, would it be superior to the results I am currently getting with nrf_dm on the nrf52840?
  • Hi Michael,
    You can find the samples in the NCS 2.9, the documentation is here and here.
    Yes it is similar, and uses a lot of the same technology. Though there are a few differences, like for instance ndt being propriatery and CS being an official part of BLE, which means that you can use it with other products as well.
    Another thing that might make more of a difference to you, is that we unfortunately do not really provide a product-quality angle algorithm for it - you will have to create that yourself. Like it says in the documentation of the samples:
    It also provides a basic distance estimation algorithm to demonstrate the IQ data handling. The accuracy is not representative for Channel Sounding and should be replaced if accuracy is important.
    Yes, with a decent angle algorithm it is expected to be a bit better, but somewhat comparable to the results you got with NDT.
    Elfving
