Hello.
We are updating firmware to use nrf sdk 2.9.1 (from 2.5.2).
Below is my proj.conf, should I expect any breaking changes?
# Stacks and Heaps
CONFIG_MAIN_STACK_SIZE=16384
CONFIG_HEAP_MEM_POOL_SIZE=131072
# I2C Configuration
CONFIG_I2C=y
CONFIG_NRFX_TWIM1=y
# SPI Configuration
CONFIG_SPI=y
CONFIG_SPI_BITBANG=n # (Final value taken as 'y')
CONFIG_SPI_ASYNC=y
CONFIG_NRFX_SPIM4=y
# Shell and Console / Serial
CONFIG_SHELL=y
CONFIG_SHELL_LOG_LEVEL_ERR=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_UART_LINE_CTRL=y
CONFIG_PRINTK=y
# GPIO Configuration
CONFIG_GPIO=y
CONFIG_NFCT_PINS_AS_GPIOS=y
CONFIG_GPIO_INIT_PRIORITY=60
# ADC Configuration
CONFIG_ADC=y
# USB Configuration
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="Zephyr USB console sample"
CONFIG_USB_DEVICE_PID=0x0004
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
CONFIG_USB_MASS_STORAGE=n
CONFIG_DISK_DRIVER_FLASH=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
# Clock and Power Settings
CONFIG_SOC_ENABLE_LFXO=n
CONFIG_SOC_LFXO_CAP_EXTERNAL=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM=y
# Debug and Logging
CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=n
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_DEBUG_THREAD_INFO=n
CONFIG_SEGGER_DEBUGMON=n
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_RING_BUFFER=y
CONFIG_SPSC_PBUF=y
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=n
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=n
# (CONFIG_PRINTK is defined above in Shell/Console)
CONFIG_ASSERT=n
# Bluetooth and NUS
CONFIG_UART_ASYNC_API=n
CONFIG_NRFX_UARTE0=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="ABC"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_NUS=y
CONFIG_BT_SETTINGS=y
# Flash and Storage
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# DK Library and System Workqueue
CONFIG_DK_LIBRARY=y
# Sensors
CONFIG_SENSOR=y
CONFIG_ADXL372=n
CONFIG_BME280_FILTER_16=y
CONFIG_BME280_TEMP_OVER_16X=y
CONFIG_BME280_HUMIDITY_OVER_16X=y
CONFIG_BME280_PRESS_OVER_16X=y
CONFIG_BME280_STANDBY_1000MS=y
# NRFX and Peripherals
CONFIG_NRFX_DPPI=y
CONFIG_NRFX_TIMER0=y
CONFIG_NRFX_GPIOTE=y
We are using nRF5340.
Thank you for help.
Przemek
